Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 07-02-2010, 11:47 PM   #501
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Ambient Temp: 65
Elevation: 250?
Weather: Clear
Tires: Toyo Proxes 4 205/55/16
Car: 1990 Legacy Wagon
Tuner: Doug Vincent and Bobby W @ PRE
Dyno Info: Dynojet PRE Racing
Peak HP at RPM: 392 at 6500 rpm 17 psi 423 @6000 rpm 23 psi
Peak Torque at RPM: 375 at 5000 rpm 17psi 429 @ 5250 rpm 23 psi
Target Boost: 17 and 23
Fuel: e85
Engine/Power Modifications: 2.5 2002 RS block, 99.5 mm CP pistons, STI rods, 1997 EJ20 twin turbo heads, 800 CC injectors, 5th injector 800 cc (barely needed), Vortech FMU 3-1, Ebay T3/T4 turbo. Borla NA header, custom up and downpipe, 3" exhaust
Drivetrain Mods - dual diaphram pressure plate, 6 puck, 1997 STI gearset in NA case.
Tuned for daily driving 17psi and "race" 23 psi. GRAPH RPM IS OFF BY ABOUT 400rpm (low)!
The 17psi map has been tweaked a little more so probably close to 400 torque, but not on the graph. Dip in the boost probably due to fluke, wasnt doing that other runs.
Then I turned up the boost to 23 but it obviously would not hold and tapered to 20. Had been on dyno for about two hours so I called it good for now.
reddevil is offline   Reply With Quote
Old 07-11-2010, 02:48 PM   #502
bufaton
Member#: 143617
2004 Impreza STI
Cobb Stage 2
Thumbs up
Facility: IPS Motorsports, Columbus Ohio
Type of Dyno: DynoJet
Boost: Target 20psi tapering to 14psi
Fuel: Mobil 93
Conditions: 96 degrees F, 27% humidity
Peak HP at RPM: 298.75
Peak Torque at RPM: 345.51
Mods: Cobb Stage 2 (catted exhaust, downpipe, accessport), K&N Typhoon filter, One step colder plugs.
bufaton is offline   Reply With Quote
Old 07-12-2010, 11:09 AM   #503
VT_Hatch
Member#: 237095
2009 WRX
This thread needs more 09+ WRXs
VT_Hatch is offline   Reply With Quote
Old 08-17-2010, 08:04 PM   #504
STi_chet
Member#: 187528
91 Supra Turbo
Ambient Temp: 90
Elevation: ??
Weather: Hot
Tires: Falken RT 615 225/45/17
Car: 2005 STi
Tuner: EFI Logics
Dyno Info: Mustang
Peak HP: 308
Peak Torque: 339
Target Boost: 21
Fuel: 93
Engine/Power Modifications: Intake, Helix catless downpipe, Surewin catback, walbro fuel pump, 1 step colder plugs, Grimspeeed PnP manifold and crosspipe, Grimspeed EWG kit, & V2 AP.
Drivetrain Mods - Stock
STi_chet is offline   Reply With Quote
Old 08-25-2010, 03:26 PM   #505
acwrx
Member#: 245394
Agreed
acwrx is offline   Reply With Quote
Old 09-11-2010, 11:31 PM   #506
mr_durdan
Member#: 77690
2007 STI
Car: 05 WRX 5-spd
Facility: P&L Motorsports
Type of Dyno: Dynojet
Baseline # for a stocker at the dyno: 155-180
Boost: don't know yet
Fuel: blue line = 93 oct, green line = e85
Target AFR: .75 lambda
SAE Corrections: none
Peak HP at RPM: 93 [email protected], [email protected]
Peak Torque at RPM: 93 [email protected], [email protected]
Mods: BPM catless up-pipe & 3" tbe, BPM turbo inlet, Cobb AP ver2, Walbro 255, 800cc mod stock injectors, Process West TMIC, Grimmspeed EBCS, tuned by Jorge
http:[email protected]/4980981449/
mr_durdan is offline   Reply With Quote
Old 09-14-2010, 02:18 PM   #507
balls2dawalls
Member#: 248432
06 VF39 WRX TR
San Remo Red
Car: 2006 WRX TR
Facility: Back roads
Type of Dyno: Airboy Dyno
Baseline # for a stocker at the dyno: 200
Boost: 17.5 psi
Fuel: 93 octane
Target AFR: 11.1
Peak HP at RPM: 300 WHP @ 6140 RPM
Peak Torque at RPM: 305 ft-lb @ 3680
Mods:
-VF39,
-STi TMIC,
-Walbro 255 lph fuel pump
-Samco Hoses
-Cobb SRI w/ SPT intake heat shield
-TXS 4" Bellmouth catless DP
-3" custom welded eBay catback
-OS tuned at 17.5 PSI
balls2dawalls is offline   Reply With Quote
Old 09-26-2010, 09:44 PM   #508
kevin 5150
Member#: 21774
Quoting VT Hatch --- "This thread needs more 09+ WRXs"
Facility: Carb Connection
Baseline # for a stocker at the dyno: don't know. just have factory numbers at the crank.
Boost: 18.10
Fuel: ?
Target AFR: ?
SAE Corrections:
Peak HP at RPM: 270.45
Peak Torque at RPM: 303.61
Mods: CNT Downpipe, K&N drop in filter
***Tuned by Josh @ NW Tuning Technologies.***
kevin 5150 is offline   Reply With Quote
Old 09-26-2010, 10:27 PM   #509
wrath1517
Member#: 193723
2002 RS STI HYBRID
VEHICLE: 2002 RS with 2.5 STI Hybrid swap
SHOP: TopSpeed
TUNER: Doug
DYNO: Dynojet
FUEL: 93 octane
MAX WHP: 314
MAX TQ: 304
Mods:
5 spd conversion
STI CLUTCH AND FLYWHEEL
vf43
Big TMIC
TGV deletes
Custom CAI
Tanabe TBE
STI cams
DW750cc
IXIZ Custom Fuel Rails
NGK one step colder plugs
Walbro 255 pump
Cobb v2 accessport
wrath1517 is offline   Reply With Quote
Old 10-09-2010, 11:52 PM   #510
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
Installed Grimmspeed EBCS!
Also did a custom Tranny Fluid Cocktail because my town lacks redline.. lol
Lucas 80w-90, Valvoline 80w-90, Pennzoil Syncromesh!! Great so far!
thanks to Andy Tatman @ FTW Tuning I got a tune done today.
Max WHP: 303.4 @ 5,420
Max WTQ: 332 @ 3,539
Gpmoto Large MAF Housing Short ram, Self ported Headers/Wrapped, grimmspeed Cross-over Pipe/coated/wrapped, Greddy UP Wrapped, Stock ej257, Stock vf39, TopSpeed 4"DP, HKS Mid-Pipe, Gymkhana AB.
Flyin_Hayn is offline   Reply With Quote
Old 10-17-2010, 02:28 PM   #511
BlueSTiboy04
Member#: 201700
2004 WRX STi
2004 STi
Shop: IAG
Tuner: Jorge
Dyno: Dynojet
FUEL: 93 octane
Max WHP: 306
Max TQ: 355
Power Mods
Cobb AP V2
Cobb TBE
IAG Big MAF intake
Deatschwerks 850cc Injectors
Walbro fuel pump
Grimspeed Up-pipe
Tial 38mm EWG
Grimspeed EBCS
Stock VF39
Stock Top Mount
BlueSTiboy04 is offline   Reply With Quote
Old 11-15-2010, 04:28 PM   #512
Turbo ROb
Member#: 202290
2015 WRX
Car: 2005 WRX
Tuned by: Ed at EQ Tuning in Fairfield, CA
Type of Dyno: Road Tune
Boost: 17 psi
Fuel: 91 octane
Peak HP at RPM: 220 WHP @ 6350 RPM
Peak Torque at RPM: 222 ft-lb @ 3810
Mods:
-MBC
-Invidia Catless Downpipe
-MADDAD Whisper catback Exhaust
-OpenSource tuned at 17 PSI
Turbo ROb is offline   Reply With Quote
Old 11-22-2010, 11:14 PM   #513
Q2SubZero
Member#: 191717
2000 2.5RS Sedan
SRP
Car: 2000 2.5RS Sedan
Tuned by: GarageTuning in Orange, CA
Type of Dyno: DynoPak
Boost: 26 peak tapering to ~23 at redline
Fuel: 91 + Meth (stock sti injectors/pump)
Peak HP at RPM: 377 WHP @ 5224 RPM
Peak Torque at RPM: 435 WTQ @ 3857 RPM
Mods:
'04 STI w/built bottom end
'07 Legacy SpecB 6spd Manual trans
TD06-20G (8cm hot side)
HKS 3" TBE exhaust
Q2SubZero is offline   Reply With Quote
Old 12-13-2010, 12:56 AM   #514
j4s0ni2ice
Member#: 255191
2008 STi
Car: 06 STi with 49K miles.
Facility: PRE in Gresham, OR
Type of Dyno: Dyno Dynamics
Baseline # for a stocker at the dyno: 240
Boost: 19 psi (a little creep to 20 at 5000 RPM)
Fuel: 92 octane
Target AFR: ?
SAE Corrections: ?
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Mods: Perrin CAI and inlet tube, 3" Invidia catted V4 downpipe and Invidia 3" N1 Race Cat back. DW 740 injectors + Walbro
j4s0ni2ice is offline   Reply With Quote
Old 12-15-2010, 12:01 AM   #515
kodie arnett
Member#: 267158
2006 wrx
black
Car:2006 wrx with sti drivetrain swap
Tuner: Harvy at the boost creep
Type of Dyno: dyno dynamics
Boost: 21lbs
Altitude: 5100ft!
Fuel: gods drink! e85
Target AFR:14.2
Peak HP at RPM: 407awhp at 6100RPM
Peak Torque at RPM: 383awt at 4900RPM
Mods: fp green, ID 1000cc, walbro 255, fmic, invidia f1 turbo back, grimspeed 44mm uppipe, tial 44mm external wastegate, tial Q bov, all on a stock block.... lol
i dont know how to put pictures up but there on my facebook at kodie Arnett
kodie arnett is offline   Reply With Quote
Old 12-21-2010, 11:50 PM   #516
subiewrx05
Member#: 261092
2005 subaru
2005 Subaru Wrx
Facility: Performance Engineering Racing/Gresham,OR
Dynoyno Dynamics
Baseline:170 awhp and 170 wtq
Fuel:92 octane
Boost:20.2
Peak AWHP: 334.5 @ 6500 rpms
Peak WTQ: 307 @ 6500 rpms
Mods: HTA68 FP Turbo, Toyo Sports FMIC, Turbo XS BOV, AEM short ram cold air intake, Cusco Oil Catch Can, 3" Bellmouth Downpipe, Invidia Full Turbo Back Exhaust, Turbo Inlet, DeatschWerks 780 cc injectors, 255 Lph Walboro fuel pump, uppipe and header pipes, EStreet Boost controller, Defi boost Gauge, TGV Deletes, HardRace motor and tranny mounts
[IMG][/IMG]
subiewrx05 is offline   Reply With Quote
Old 01-05-2011, 09:27 PM   #517
Base9se
Member#: 216903
1991 Miata
Car: 2007 WRX TR
Facility: Cobb - Plano, TX
Boost: 16 & 19 psi
Fuel: 93 Oct
NOTE: Temperature was ~55F.
Modifications
VF39 Turbo
2006 STI TMIC
ERZ Catted Downpipe
Invidia Catback Exhaust
Grimmspeed 3-Port EBCS
K&N Drop-In Filter
Walbro 255LPH Fuel Pump
With an 8 hour drive from Louisiana, I am very pleased with the gains. Cobb Plano facility is top notch! It was definitely worth the drive.
Here's the link from my previous dyno chart using Cobb AP OTS STG 2 map. Note that this is not the same dyno, but I plan on getting back on the dyno dynamics to actually see the difference. No matter, the protune gains are very significant compared to the OTS map.
16psi Dyno
19psi Dyno
Base9se is offline   Reply With Quote
Old 01-26-2011, 04:22 PM   #518
just smurfy
Member#: 135893
2012 Smart Car
murdered out w/ stickers
Originally Posted by Frankenboost View Post
547whp on Surgeline's mustang dyno and 471lb/ft tq.
pfft...I think my Stg 2 WRX could take ya.
:smurfy torches WRX, buys an STI and calls Tim post haste:
just smurfy is offline   Reply With Quote
Old 02-02-2011, 10:41 AM   #519
dabeatjunkie
Member#: 272627
2005 Impreza WRX
blue
Default WRX 2005 with TD05 S16G
WRX 2005
TD05 S16G turbo
STI intercooler
STI Hoodscoop
Walbro fuelpump
STI 550 cc injectors
98 octane fuel
Tuner: EMS
dabeatjunkie is offline   Reply With Quote
Old 02-04-2011, 12:30 AM   #520
imprezive-wgn
Member#: 272845
03 wrx wagon
wrb
Facilityynotech Tuning
Type of Dyno:Mustang
Baseline # for a stocker at the dyno:220
Boost:22psi
Fuel:93oct
Target AFR:11.2
SAE Corrections:0
Peak HP at RPM:[email protected]
Peak Torque at RPM:[email protected]
Mods:je pistons, eagle rods, acl bearings, arp main, rod and head studs, cometic head gaskets, perrin equal header, ewg up-pipe, fp green hta, tial 38mm with 14.5psi spring, invidia 3in downpipe to full 3in exhaust, 3in exhaust dump, perrin intake, big maf, godspeed fmic kit, deatscwerks 850cc injectors, walboro 255, 2step colder ngk iridium plugs, 05 wrx tranny and stage 5 comp clutch with act street light flywheel and custom tune from a friend using opensource.
imprezive-wgn is offline   Reply With Quote
Old 02-05-2011, 03:22 AM   #521
Vpduong
Member#: 272971
2009 WRX
2009 Wrx hatch
mods are turboxs catless turboback
perrin equal length header
cobb ap
avo short ram
perrin recirc valve
process west topmount
329WHP 379 torque
http://www.facebook.com/photo.php?fb...6182.549179584
Vpduong is offline   Reply With Quote
Old 02-10-2011, 06:53 PM   #522
lando
Member#: 149637
2010 STI SE
Car: 2010 STI SE
Facility: All Aspects Motorsports, Chesapeake VA.
Baseline #: I dunno
Boost: 20psi
Fuel: 93oct
Target AFR: meh
SAE Corrections: 5
Peak HP at RPM: 277.38 at 5500rpm
Peak Torque at RPM: 316.55 at 3500RPM
Mods: CNT 3inch TBE, AEM CAI, Cobb AP STG 2 w/AEM OTS map
landodyno by Lando123, on Flickr
lando is offline   Reply With Quote
Old 03-13-2011, 07:20 PM   #523
Gabriel~
Member#: 180998
2010 WRX STI
Default 2010 STI 354/346 wtq/hp
Facility:Cobb Tuning Plano
Type of Dyno: Mustang
Boost: 19.9
Fuel: 93 octane
Peak HP at RPM: 346 @ 5850
Peak Torque at RPM: 354 @ 4250
Mods: COBB Tuning AccessPORT, MXP TBE, AEM CAI, Grimmspeed up-pipe with Tial 38mm EWG, Perrin EBCS, Perrin FMIC, Perrin Turbo Inlet, walboro 255, 850 cc deatschwerks injectors, Blouch 20g-xt 10cm
Dyno sheet up in a few minutes. Very happy with this turbo, headers in the future and TGV deletes will be done soon.
Gabriel~ is offline   Reply With Quote
Old 04-18-2011, 09:55 AM   #524
hieu1004
Member#: 240385
E92 BMW M3
Edited
hieu1004 is offline   Reply With Quote
Old 04-27-2011, 01:35 AM   #525
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Hey guys finally got a pro tune today and here's my #'s: 296HP 318TQ
Open Source tuned JDM ECU on 91 octane crappy Cali gas
EJ207 Ver8
Stock VF37
Stock Boost Control [email protected]
AEM CAI
Unorthodox Racing under drive crank pulley
Perrin Turbo Inlet
TurboXS 4" Downpipe
Greddy EVO2 Catback
ACT HD clutch
Stock 04 WRX 5spd
[IMG] Uploaded with ImageShack.us[/IMG]
murrdogg24 is offline   Reply With Quote
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
