Welcome to the North American Subaru Impreza Owners Club Monday December 29, 2014
Old 01-06-2011, 09:50 AM   #1501
d3v0
Member#: 225692
2015 WRX
brake boosting with a 16g?
d3v0 is offline   Reply With Quote
Old 01-07-2011, 12:37 AM   #1502
SlowImport
Member#: 123720
2003 WRX Wagon
Platinum Silver Metallic
Originally Posted by Evilchargerfan View Post
How much did they say that they will charge you for this service?
you have me interested,
Josh
SlowImport is offline   Reply With Quote
Old 02-02-2011, 11:20 AM   #1503
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
figured one of u might want my td04
http://forums.nasioc.com/forums/show....php?t=2122441
Old 02-02-2011, 01:32 PM   #1504
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
I don't normally do this, but $800??!?
wrx wagone is offline   Reply With Quote
Old 02-02-2011, 01:51 PM   #1505
Phatron
Member#: 36033
CEO PhatBottiTuning
whoops
Old 02-24-2011, 01:50 PM   #1506
Spec R
Member#: 187752
99 RS/X5/Volt
just had the service done this past week.
heres the breakdown:
$70 used TD04 bad oil seals
$22 shipping to Blouch via FedEx from Los Angeles
$545 heavy/full rebuild with 19T upgrade compressor wheel, no porting, no coating.
$25 shipping back to LA.
$662 total
subtract I can re-sell the TD04 that's still in the car ~ $60-70 bucks
$600 or so
so compare $600 with a brand new 16G plus shipping at $720
yeah its a bit much, but whatever. we'll see how it performs in a bit. I'm more about spool up and low-end anyway since I'm not your typical boy-racer.
Spec R is offline   Reply With Quote
Old 02-25-2011, 09:07 AM   #1507
Scooby921
Merci Buckets
Member#: 88606
2011 GMC Sierra
'13 JCW
$662 total
$600 or so
I think you're still cheaper than mine.
$130 used Deadbolt Monster TD04
$450 rebuild
$50 ceramic coating of the turbine housing
---**** itself
$100 new donor
$250 rebuild
But having driven my car and a local friend's 2.0L with a 16G-XT I'll take the 19T. The way the cars were tuned they were very close in peak power/air flow. The 19T provided better throttle response. Of course my results are a little skewed as the turbine housing was ported and polished and coated.
Scooby921 is offline   Reply With Quote
Old 02-25-2011, 01:28 PM   #1508
SlowImport
Member#: 123720
2003 WRX Wagon
I can't wait to see what kind of power Spec R makes!
Keep us posted,
Josh
Old 02-25-2011, 02:08 PM   #1509
AllAWD
Member#: 17079
$450 rebuild
---**** itself
$100 new donor
$250 rebuild
Just what did your 19T and the 16g-XT make? Also, a baseline stock number for the dyno would help.
Talking to my tuner the 19Ts he tuned couldn't beat a vf39, any of the 16gs outran them. On his dyno: stock 2.0L 175whp, tuned TD04 240whp, best TD04/19T ~270whp, VF39 290whp, 16gEVOIII 310whp+
AllAWD is online now   Reply With Quote
Old 02-25-2011, 02:45 PM   #1510
Spec R
Member#: 187752
99 RS/X5/Volt
Keep us posted,
Josh
I'll be running the stock downpipe with cats in place so dont expect anything large.
however, i had my car my baselined on yimisports dynojet after I got my car BAR inspected (100%bone stock) and it put down 200whp/202wtq, so thats unusually high for a 2002 EJ205.
i'm also going to be running close to stock boost levels as I'm also using stock injectors.
Old 02-27-2011, 02:57 PM   #1511
Sierramitch
Member#: 267538
I'm very interested in Spec R's results! Please post your sheet when it's done!
Sierramitch is offline   Reply With Quote
Old 02-27-2011, 06:32 PM   #1512
xsnapshot
Member#: 170973
2004 WRX 4EAT
Whoa.200/200 stock? Thats about 15-20% higher than most. When this is done are you going to be getting dynoed on the same dyno again?
Since most people see between a 25-35% increase in power with a tuned stage 2 vs stock, then your stage 2 #'s should be around 250-270 on that same dyno. I hope you see at least that with the 19t.
At stock boost levels I found that the performance techniques 19t upgrade really did not move much more air than the stock turbo. Imo I'd be happy with 270 on that dyno with your injectors.
xsnapshot is offline   Reply With Quote
Old 02-28-2011, 12:56 PM   #1513
Spec R
Member#: 187752
99 RS/X5/Volt
I had the car tuned for stage2 (no cats) on the same dyno and put down 222whp/245wtq. Paul said he had issues with the turbo and wastegate being "tired" and couldnt boost past 14.5 psi.
however, i'm not getting it tuned on the same dyno for the 19T. i'll post the results either way.
Old 02-28-2011, 04:55 PM   #1514
Sierramitch
Member#: 267538
Great I'm looking forward to it! Are still planning on tuning with cats in place or w/o them?
Old 02-28-2011, 05:07 PM   #1515
Spec R
Member#: 187752
99 RS/X5/Volt
downpipe cats only, aftermarket catless uppipe
Old 02-28-2011, 05:51 PM   #1516
Sierramitch
Member#: 267538
Sweet! :0 like I said earlier I can't wait to see your results! Now it's time to be patient... GLW the tune!
Old 03-10-2011, 12:28 AM   #1517
Sierramitch
Member#: 267538
Any updates on the tune?
Old 03-11-2011, 05:38 PM   #1518
Spec R
Member#: 187752
99 RS/X5/Volt
they're having nagging issues with the grimmspeed bcs...but the results look promising.
Old 03-11-2011, 10:45 PM   #1519
Sierramitch
Member#: 267538
Bummer dude I hope they work it out... Well keep us/me posted haha.
Old 03-14-2011, 02:02 PM   #1520
Scooby921
Merci Buckets
Member#: 88606
2011 GMC Sierra
'13 JCW
Its hard to make great comparisons between the two cars as they weren't quite the same build and the same guy didn't tune them. Neither of them was done on a dyno, so there are no dyno numbers to compare. I think at peak the 16g-xt was pushing 10g/s more than my 19t when comparing logs. The 19T spooled up around 3000rpm while the 16g-xt was 3600rpm. Power across the mid-range was about the same. 16g-xt wins the peak power battle as it could push 18psi at redline where my 19t dropped off to 12psi.
My 19T was making around 265hp/tq on the airboy dyno compared to the 230hp/tq it made with the stage 2 tune. The 16g-xt was around 275hp on an airboy dyno. But it wasn't my spreadsheet so I have no idea what was used for delta weight and other variables. Having driven both cars I was happier with my 19t than the 16g-xt. IMO the 16g-xt isn't worth the cost over a normal big 16g or evo3 16g.
Both cars had more potential. 16g-xt was pushing 18psi, but had a bigger TMIC. My car was peaking at 20psi, but using a stock TMIC and accordion y-pipe. In the grand scheme the 16g did and will make more power. I had better response and I think overall area under the curve was similar in this instance.
Old 03-14-2011, 03:25 PM   #1521
barryj
Member#: 146723
2005 WRX
This is a great thread!
I'm planning on going with the 19t upgrade for my 2.0.
It seems to me that the TD04 19t creates the best low end power increase with the least stress on the drivetrain of all the possible turbo upgrades....which equals a better DD and longevity.
A couple of questions....On youtube I saw the Blouch "3000GT td04 19t upgrade" video...in that Blouch upgraded/replaced the Compressor and Turbine wheel.
It is my understanding that for our Suby TD04 upgrade only the turbine wheel is upgraded..is that right? and why not both replaced?? The turbo in the video looked like a OEM TD04 to me....so why the difference???
Is their a youtube video of the $375 19t upgrade????
barryj is offline   Reply With Quote
Old 03-14-2011, 03:33 PM   #1522
AllAWD
Member#: 17079
The Subaru upgrade is compressor (19t) only for $375. Blouch will both on request, but the reasoning I read was that they didn't think the exhaust housing was large enough to see gains with an upgraded turbine wheel to justify cost so they offered the clip which gives you better flow and less rotating mass. The bigger turbine wheel is going to also increase spool-up time.
Upgrading both wheels reach the cost of a new 16g. The 3000GT doesn't have that option due to space and geometry so doing everything possible to the TD04 was more cost effective.
Old 03-14-2011, 04:21 PM   #1523
barryj
Member#: 146723
2005 WRX
Hey AllWD,
Thanks for the info....is clipping part of the $375 or extra?
Any other options that Blouch offers with this upgrade?
BJ
Old 03-14-2011, 04:29 PM   #1524
AllAWD
Member#: 17079
Hey AllWD,
BJ
Not sure, but I am guessing they could do anything you want. Commonly, porting is available and rebuild if needed.
It's best to call Blouch. There have been a couple complaints about them not replying to email, but they seem very helpful by phone.
Old 03-14-2011, 06:11 PM   #1525
barryj
Member#: 146723
2005 WRX
Yep, If you call in the morning they always pick up the phone. I've talked to Mike a couple of times. From my experience you have to be very specific with your questions for him. He is a engineer, not a sales person.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 09:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 09:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 11:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 02:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 08:19 PM
