Old 03-17-2011, 12:14 PM   #26
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I have an idea....... put an auto tranny so you can drive it
Old 03-17-2011, 12:24 PM   #27
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i have always played off my driving becuz of my 5 speed wrx back in the day...running 12.7+ @ 115 with 2.0+ 60's
In the STi 12.0 @ 115 mph with 1.7 60's....not really horrible driving. In the STi my times have always been pretty good for my traps. I just couldnt drive the 5 speed to save my life.
12.0 @ 115 is better than 12.0 at 121 right
Old 03-17-2011, 01:07 PM   #28
Phatron
Member#: 36033
CEO PhatBottiTuning
im kinda digging the big gaudy undertray
Old 03-17-2011, 01:19 PM   #29
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice Ron going all out! Are you going to finally put some E85 in the tank? Since your going all out don't forget the moonshine! You can drive Ron don't lie...
I wanna see some progress get back to the shop! Def put that drag wing on! What tranny you running a 6mt? Get some drag radials for sure too!
How much did those brakes cost you for all 4
corners? Do they mount right up or fabrication needed?
TDagen is online now   Reply With Quote
Old 03-17-2011, 01:39 PM   #30
Phatron
Member#: 36033
CEO PhatBottiTuning
Cars got a 06 STi 6 speed in it....r160 rear...stock wrx axles
No e85....the car will be on race gas 100% of the time.
The brakes were $8xx....for the rotors, pads, and calipers....kenny drew, cut and mocked up the top hats and the caliper mounts and sent them off to get cnc'd....so im not sure on the total yet. So yes fabrication was needed for both the top hats and caliper mounts.
Old 03-17-2011, 03:11 PM   #31
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Those brake prices are cheap as chit. I spent $5xx on Hawk HPS pads, brembo blanks, SS lines and ATE fluid.
Subian is offline   Reply With Quote
Old 03-17-2011, 03:13 PM   #32
Badler
Member#: 133597
Kenny is the man! I'll have to stop by and check it out. Been meaning to stop in anyways. Good luck!!
Does that mean you'll be down here occasionally? Need/want to get road tuned when I sort out my misfire problem.
LMK if you need me to drive it to 13s.
Old 03-17-2011, 04:12 PM   #33
Phatron
Member#: 36033
CEO PhatBottiTuning
Yeah, i've been going down 1-2 times a month. i have every other friday off so i usually go down those weekends. i am probably heading down there tonight or tomorrow.
kenny's skills are amazing. i cant get over his quality of work and work ethic. one in a million. kelly is great too. i feel right at home when im there.
Old 03-17-2011, 07:21 PM   #34
Badler
Member#: 133597
Yeah, he's been killing it for a long time. I was stoked when I found out he was doing Subaru stuff. When I met him he was building pre-runners. His welds are second to none IMO. You planning on road racing it too I hope? Kinda assuming it's going to be drag only by the brakes, wing, etc... though.
Old 03-17-2011, 08:46 PM   #35
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
Originally Posted by maxpowr View Post
Omg! i want your builder to make me a SS bong.
HAHAHAHAHAHHAHAHAHAHA
SikSilvrSuby is offline   Reply With Quote
Old 03-18-2011, 09:27 AM   #36
69subaru360
Member#: 159682
1995 WRX
2015 F150
Tubular front end?
With what you cut off, I would do a tubular front end, front mount the turbo in the grille area on one side, civic radiator on the other. Then an air to water intercooler behind the dash on the pass side with an ice tank in the trunk.
With all the free space up front it's kind of stupid to have a long run of pipe and the turbo behind the engine. Low mounted twins right off the heads would be cool too.
Old 03-18-2011, 09:57 AM   #37
juanmedina
Member#: 133146
I agree .
I think he is doing something like this:
Old 03-18-2011, 10:07 AM   #38
69subaru360
Member#: 159682
1995 WRX
2015 F150
^ I like that, but if you are going this far and it's a drag car, might was well front mount the turbo(s) and do an air to water intercooler. It's not really any more work at that this point.
Old 03-18-2011, 12:02 PM   #39
Phatron
Member#: 36033
CEO PhatBottiTuning
We talked about the front mount turbo a little last time. It's hard to tell which direction we will end up going. I mean we talked about 20 different motor setups several different times until he just made a decision for me
Part of the reason for duplicating the above kit is to get the jigs 100% set so he can produce the kit for customers.
Old 03-18-2011, 03:04 PM   #40
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
If it's a drag only car, he may as well cement the block and run methanol and run no radiator.
Then park the turbo and AWIC where the radiator area.
Old 03-18-2011, 03:13 PM   #41
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Smart...i like planning ahead. planning on reproducing the piping kit as well? I can def market that kind of professional work.
Old 03-18-2011, 06:39 PM   #42
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by Homemade WRX View Post
If it's a drag only car, he may as well cement the block and run methanol and run on radiator.
True. But then you can't drive it on the street at all.
I'd like to see it as a fast street/strip car. You know the kind you trailer to the track, but could still take out for a drive once and a while. Maybe something that runs in the 9.5-10.5 range. You'd still need some sort of cooling system for that.
Old 03-19-2011, 07:47 PM   #43
juanmedina
Member#: 133146
I agree I hope Ron built something that people can replicate, F filled blocks.
Here is another idea Ron, go with a carbon fiber roof while your are at it
Old 03-19-2011, 07:53 PM   #44
69subaru360
Member#: 159682
1995 WRX
2015 F150
The roof skin isn't really that heavy. But if you have the money go for it. It's not nearly as hard to get the roof skin off as people would have you believe.
Old 03-19-2011, 07:57 PM   #45
Phatron
Member#: 36033
CEO PhatBottiTuning
the roof is thin and light already.....i dont think it would save much weight.....unless i chopped about 6" of the pillars off......then i would save a little weight and reduce the drag. we've discussed chopping it down a bit, but its probably not gonna happen....it just adds lots of little projects with all the windows and fabbing a new roof
Old 03-20-2011, 09:57 PM   #46
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
Ron I'm building a rear diffuser for my GC now. I'm using alumilite. It's pretty easy to work with a pretty light. I picked up a 4'x 8' sheet at a local sign shop for around $100. If I have enought left over I'm gonna go a front lip spoiler.
RFoy91TSi is offline   Reply With Quote
Old 03-20-2011, 11:48 PM   #47
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Looking good Ron, my car should be up and running again soon so i wont feel so jealous lol!
Loving that turbo intake!!
binjoau is offline   Reply With Quote
Old 03-24-2011, 08:26 PM   #48
juanmedina
Member#: 133146
i still keep hopping between the GTX30 and GTX35 for my drag car build....EFR's are just off the table because of the wait.
I really dont wanna rev the car out to 8k....so i think the GTX35 is going to be "too laggy" at a 7500rpm redline to make sufficient use of its powerband.....so the gtx30 looks like a better choice.
also....i like v-band turbine housings vice t3 for ease of install and removal.....and the EFR doesnt have a v-band option...despite what aboothman might think, there are more things that people look at when picking a turbo besides whats hilighted in the EFR brochure....and wait time and ease of installation are 2 of my main decision factors.
stock sleeves so im gonna keep it around 30 psi
I didn't wanted to hijack the other thread so I copy your posts.
Ron so what trap speed or ET are you shooting for?
Russel is up and running finally he said thanks, he will reinstall 1200cc as soon as he get them back.
Old 03-24-2011, 08:51 PM   #49
Phatron
Member#: 36033
CEO PhatBottiTuning
not really any goals....
Old 03-24-2011, 09:31 PM   #50
karlknaupp
Member#: 60871
2004 WRB WRX
just fast as possible
karlknaupp is offline   Reply With Quote
COBB Tuning Surgeline: 2004 WRX Wagon 2.5L GT35R E85 Employee Car Build Cobb Tuning Proven Power Bragging 34 11-30-2011 06:04 AM
FS/FT : IL: 2002 WRX Wagon 2.5L hybrid/4EAT smeagol Private Vehicle 'For Sale' Classifieds 4 07-30-2010 05:28 PM
FS/FT : 2002 WRX Wagon 2.5L hybrid/4EAT smeagol MWSOC Private Classifieds 0 07-04-2010 11:15 PM
2002 WRX FXT 2.5L, 18G, boost/rev issues 2000wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-13-2010 06:36 PM
2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo triguy Proven Power Bragging 12 10-18-2008 03:09 PM
