Old 03-17-2011, 11:27 AM   #226
vicious_fishes
Member#: 158864
dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno dyno
looks very nice what size is the collector, appears to be 2.25?
Old 03-17-2011, 12:02 PM   #227
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
looks great!
So I guess we'll have to use some sort of aftermarket cat for this right?
Zac86 is offline   Reply With Quote
Old 03-17-2011, 01:10 PM   #228
Back Road Runner
Member#: 60082
2004 Forester STI
Very clean.
Will there be options for different diameters? For example, a person running a stock or lightly modified may prefer a 1.5" to 1.625" pipe, but a person with head work and aggressive cams will end up more towards 1.75" instead. Heck, even a serious race build would step things up to 2" for the primaries. It all depends on where you want the scavenging efficiency to be.
Old 03-17-2011, 03:43 PM   #229
GEE-OTTO
Member#: 201277
2008 Legacy
Man that is nice finished piece for the pre 06 guys I will be interested to see the numbers vs stock vs Borla rep with that near 90 degree bend eliminated from the mix. These should flow well with the matching catback you guys are making
GEE-OTTO is offline   Reply With Quote
Old 03-17-2011, 03:47 PM   #230
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, which fitment and style is that supposed to be?
Old 03-17-2011, 03:49 PM   #231
awdorgtfo
Member#: 252252
2007 WRX Wagon
vf39 ewg
God...these are BEAUTIFUL!
awdorgtfo is offline   Reply With Quote
Old 03-17-2011, 04:20 PM   #232
Back Road Runner
Member#: 60082
2004 Forester STI
Probably walk to your local exhaust shop along with a cat and muffler, and go "fab up everything in between."
...not a bad way to go really, but you don't get mandrel bends from a generic muffler shop which is boo.
Really I think you'd just need a midpipe fabbed up in between the header and whatever cat back exhaust you decide to run. That isn't too hard nor expensive either.
Old 03-17-2011, 05:21 PM   #233
MickeyD488
Member#: 276627
2005 Impreza 2.5RS
San Remo Red
Beautiful job guys! So are you going to be making a cat pipe to match this as well, and if so, would that be included in the price? Please dyno it soon and be sure to make a vid and post the chart. The length looks to be pretty equal, I can't wait to hear that beast purr...
MickeyD488 is offline   Reply With Quote
Old 03-17-2011, 05:46 PM   #234
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
It does? Besides there is no "pretty equal" when it comes to headers. Its either exactly EL or its not and none of the benefits come along with it. Some of the best looking pieces I have seen for a car, though.
RaceFaceXC is offline   Reply With Quote
Old 03-17-2011, 06:36 PM   #235
Back Road Runner
Member#: 60082
2004 Forester STI
Small suggestions on the dyno thing:
  • I would test a couple collector designs to gauge potential gains from an added secondary pipe + resonator. I'm not really sure how crucial this is for a 4-2-1 design though versus a 4-1 design.
  • Test with and without a tune for both stock and with the header. One gain the header offers is the ability to run a little more timing. The stock ECU will not adjust enough to show these gains.
Old 03-17-2011, 06:38 PM   #236
MickeyD488
Member#: 276627
2005 Impreza 2.5RS
San Remo Red
Ok, after looking closer I now see that the one side is longer, my bad...Still looks awesome though
Old 03-17-2011, 07:12 PM   #237
Zac86
Member#: 136919
ABP
what are the springs for?
Old 03-17-2011, 07:21 PM   #238
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
To keep the joint as tight as possible while still allowing for thermal expansion/contraction and relative movement, usually to avoid cracking.
Old 03-18-2011, 09:47 AM   #239
GEE-OTTO
Member#: 201277
2008 Legacy
Well the V-band isnt there for nothing they probably have a CBE in the works to form a full system OR they are going to adapt their current CBE's to mate up it only makes sense since you have to go full custom this this header
Old 03-18-2011, 01:37 PM   #240
kero
Member#: 94299
2007 2.5i wagon mutt
Would there be any longevity issues with the springs, especially with the harsh winters up in the northeast???
kero is offline   Reply With Quote
Old 03-18-2011, 08:22 PM   #241
garagedefeat
Member#: 101399
2005 Forester XTi
MoorePerformanceParts.com
End of next week is the plan. Tentative of course. Final diameter out is 2.5." it has a mini reverse megaphone on it that's a bit tough to see. Collector dia. is under wraps right now.
Originally Posted by Zac86 View Post
looks great!
Thanks! And right on the cat part. It's a 304 piece that is modular. it can be set up to accept either a 200 cel street cat, 100 cel race cat or a test pipe. 2 02 sensor bungs, with one bung utilizing E.G. Flow Modification™ technology . Cat pipe will bolt up to any cat-back exhaust that fits like the stock one does, but it will be designed around the Moore Performance cat-back.
Originally Posted by Back Road Runner View Post
Very clean.
Thanks for the compliment. This can be custom built to spec. of course we won't be able to run group buys with different sizes unless we can get a number of commitments, but We're pretty flexible for those that want to go custom. For example, we have a customer that's going to try out turbo header with smaller dia. primaries. The only limitation is physical space. A big 2" or so setup with a supercharger =
Question about cat pipe answered above. As someone had mentioned, the straight nature of the cat pipe would make it an easy fab if someone wanted to do it, but yes, they will be offered at a discount with the header. Sound clips before and after, and hopefully some video will accompany the dyno charts.
Definitely not equal length, as someone brought up. The customer wanted it unequal - sacrificing some HP for what will hopefully be a decent growl. Equal length will be an option, however.
The first test will be back-to-back without tuning since many people have no tuning abilities with these setups. The following test will be with full fuel and timing control on a MAP-based setup.
Correct! See above.
In terms of them wearing out or corroding? Springs are high-grade stainless, from the motorcycle industry; they should be good to go in harsh environments. Slip fits are slip fits - the expansion and creativity they afford (shallow merges mainly....hard to weld piping to a merge correctly if two pipes are in close proximity to one another) have a few trade-offs, but nothing too serious. N/a headers are being designed at this time with single slip fits. All of our turbo headers get double slip fits.
garagedefeat is offline   Reply With Quote
Old 03-18-2011, 08:49 PM   #242
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Do you have any equal length header design/mock up pictures you could post? I'm curious... ;-)
rhino6303 is offline   Reply With Quote
Old 03-18-2011, 09:16 PM   #243
FXTSPORTS08
Member#: 232340
2008 F XT Sports
Dark Gray
Such a sweet looking header!!!
Originally Posted by garagedefeat View Post
FXTSPORTS08 is offline   Reply With Quote
Old 03-18-2011, 09:55 PM   #244
vicious_fishes
Member#: 158864
now all we need is dyno/cost. a 2.5 inch collector is exactly what i wanted to hear.
how does weight compare with the stock piece?
Old 03-19-2011, 11:07 AM   #245
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
looking forward to seeing this!
Matt515 is offline   Reply With Quote
Old 03-19-2011, 01:45 PM   #246
royalnewjersey
Member#: 250954
2013 WRX Hatch
WRB - On Order
Really nice work! I'm keeping a close eye on these!
Just to clarify, are these a bolt on for the 2006+ guys, or for 2005 and below? Also, what is the price range we're looking at for these?
I'm really interested to hear sound clips before (stock) and after (moore). If there's a throaty UEL growl, I'll be buying a set.
royalnewjersey is offline   Reply With Quote
Old 03-19-2011, 02:40 PM   #247
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Read the thread
Old 03-19-2011, 05:29 PM   #248
royalnewjersey
Member#: 250954
2013 WRX Hatch
WRB - On Order
^^^ There's a lot of off-topic chatter, unrelated info, and misinformation from people OTHER than Moore Performance. You could have just answered the question instead of being a douche.
Moore didn't post information with the pictures so I'm merely clarifying.
.... Is this really what NASIOC has become?
Old 03-19-2011, 05:43 PM   #249
awdorgtfo
Member#: 252252
2007 WRX Wagon
vf39 ewg
garagedefeat IS Moore Performance.
Old 03-19-2011, 06:18 PM   #250
GEE-OTTO
Member#: 201277
2008 Legacy
Yes. This site is prevalent with the "smartass"
Moore Performance Axleback for 93-05 impreza.....feedback wanted! Moore Performance Normally Aspirated Powertrain 181 03-21-2011 10:11 AM
Moore Performance 08+ wrx/sti divorced wastegate DP ready for production! Moore Performance Factory 2.5L Turbo Powertrain 3 02-25-2010 09:57 PM
Moore Performance 08+ sti downpipe/catback.....what do you want?? Moore Performance Factory 2.5L Turbo Powertrain 2 12-26-2009 06:30 PM
Moore Performance Divorced Wastegate Downpipe and Catback Exhaust Group Buy!! Spun Autosports Vendor 'Group Buy' Classifieds 27 12-03-2009 07:48 PM
Message Board Statistics All times are GMT -4. The time now is 01:41 PM.
