Old 06-13-2010, 09:39 PM   #26
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Originally Posted by txl146 View Post
One thing to add to 300whp (stretching): bigger TMIC or FMIC
This is correct. I forgot it. I'll add it above.
Originally Posted by gonzo1 View Post
Thanx guys for the advice. I want 300whp, sorry. That sounds great ckxx. Looking at the stretching. Do you recommend more air like sti intercooler or differEnt? Or is stock ok with cold air intake? How would I get STI injectors to plug?
They will physically plug in, but because they flow more fuel the car will run rich. Getting it tuned will correct this.
CKxx is offline   Reply With Quote
Old 06-13-2010, 09:41 PM   #27
Irish2ner
Member#: 249324
04 WRX
Originally Posted by Subr-man View Post
injectors, larger top mount, vf39 turbo, upgraded fuel pump, a tune, and get rid of the BOV you will actually improve on perfromance if you do
You will actually lose performance with a BOV? is it strictly for sound? sorry for the noob questions....i know nothing about turbo'd cars and i am just starting to educate myself
Irish2ner is offline   Reply With Quote
Old 06-13-2010, 09:42 PM   #28
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Old 06-13-2010, 09:47 PM   #29
04wrxGreg
Member#: 211570
2004 Impreza WRX
JBP
Originally Posted by MrBlue View Post
Stickers... lots and lots of stickers.
hahahaha +1
04wrxGreg is offline   Reply With Quote
Old 06-13-2010, 09:51 PM   #30
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
to get 300whp on any given dyno, including a mustang, you need a minimum of an 18g with 93 octane. If you have e85, you can hit 300whp on a vf series turbo.
scoobystas is offline   Reply With Quote
Old 06-13-2010, 10:08 PM   #31
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Byzatium! That's why people come here right?! To get advice from enthusist that have been thru this process "experience". Im grateful for you advice but I'm sure there has been others that have been thru this and have done it. Thanx crash I know what u meant. Well I'm going to look into it more. Cobb Stage 2 upgrade looks good. Anyone think it's not the right way? Should I just vf39, sti inj, fuel pump, sti intercooler, sound better? Will a different stage clutch make a difference? Thanx
Like I said, it was just a warning because you are coming off very wallet happy and eager to spend money (might as well just hold it open for people to take out of it ) and you're waaaaaaaaaaaay in over your head. Never mod a car past your level of understanding. If you do, you will mess up, do something wrong, break something, lose a lot of money, and in general suffer a ton of headaches. This a great place to learn, and a terrible place to be spoonfed answers. Also in being spoonfed without learning on your own you're not soaking up what you need to be learning in the 1st place.
Byzantium is offline   Reply With Quote
Old 06-13-2010, 11:19 PM   #32
spinnaker226
Member#: 214359
loose the weight you dont need as well, and beef up the motor and transmission mounts. you'll free up some HP/TQ
spinnaker226 is offline   Reply With Quote
Old 06-13-2010, 11:20 PM   #33
prometheum
Member#: 92003
04 bicycle!
http://forums.nasioc.com/forums/show....php?t=1393580
read that but replace 400 with 300
start with going stage 2
up/down pipes + tune
get used to that. there's no way in hell that's gonna net you 300 at the wheels
then upgrade to an 18g or comparably sized turbo 16g is not going to get you there and most vf series turbos aren't gonna get you there either.
injectors, fuel pump and intercooler
prometheum is offline   Reply With Quote
Old 06-13-2010, 11:21 PM   #34
sedagive
Member#: 186334
I just purchased a 05 wrx 2.0. Has a cold air intake, hks bov
Thats as far as I got.
sedagive is offline   Reply With Quote
Old 06-13-2010, 11:24 PM   #35
JF824
Member#: 71460
2007 WRX/STi
HTA Green 11.89 @ 119
IMO you should for now put your stock air box and diverter valve back on and go with something like a stage 2 cobb ap setup. Then once you learn more you can start considering turbo and fuel system setups. I guarantee you your car will perform better with youR exhaust and an OTS map then it does now with. T BE, intake, and bov.
JF824 is offline   Reply With Quote
Old 06-14-2010, 03:40 AM   #36
TheBlackRex
Member#: 101090
2002 WRX w/ VF39
Midnight Black
I'm making about 290 whp on a dyno dynameter (XS Engineering).
I would say go with an evoIII 16g turbo, walbro fuel pump and modified stock injectors (if you have a tuner near you familiar with Subaru's they should know how to properly do this). Also suggest a bigger intercooler, catless up pipe & downpipe.
Then your tuner can tune your ECU with one software or another to make sure it runs at optimum.
The readings you get will depend on your car and the dyno, but that should put you there.
TheBlackRex is offline   Reply With Quote
Old 06-14-2010, 03:47 AM   #37
mr.phil.roxass
Member#: 223470
2005 PSM wrx impreza
eckk.
i have this exact setup and more..i actually have PE800cc injectors, vf39,sti tmic, walbro fuel pump, and opensource tune,ewg setup,full 3inch catback,dp....my car is still running strong..
mr.phil.roxass is offline   Reply With Quote
Old 03-26-2011, 07:39 AM   #38
gonzo1
Member#: 243589
2005 Impreza WRX
Ok. After running Stage 2 for a few months, I upgraded. Setup is Walbro pump, 07 STI injectors, VF43 turbo, Large TMIC, Cobb catless DP, Invidia 3" exhaust and Cobb access-port for tuning. Next will be the header/up pipe....
gonzo1 is offline   Reply With Quote
Old 03-26-2011, 08:09 AM   #39
SnowgodCCR
Member#: 256968
2008 STi
Red
Well then you're an ass. I bought my '02 off a lot with an AEM CAI and a Blitz BOV. I wasn't thrilled about it, but you know what? They're FINE and I didn't pay anything for them.
To the OP: You're looking at spending about $8000 (for NEW parts, much less if used) to get to 300whp out of the 2.0.
At a minimum you need:
Larger intercooler, either front mount or top mount
16g or 18g turbo or equivalent size. 18g would be easier to make the power, but laggier.
275lph+ fuel pump
STi or larger injectors
Colder plugs
Up pipe
Downpipe
Catback
To help things along a little, you can also (optionally) get your stock headers polished/ported with a crosspipe or get aftermarket headers. Your turbo inlet can also be swapped for something that would increase velocity to the turbo.
The route that I'm taking on my upgrade path is to start with the smallish bolt-on stuff that acts as supporting mods for big stuff. Then I can do the big stuff later at minimal momentary cash outlay. Lets face it, a better turbo is $1500-$1900, but all the stuff you need to run it safely will run you two times that.
SnowgodCCR is offline   Reply With Quote
Old 03-26-2011, 01:50 PM   #40
alan.g.01
Member#: 277672
alan.g.01 is offline   Reply With Quote
Old 03-26-2011, 02:18 PM   #41
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by Byzantium View Post
Well, my advice is: Stop trying to spend money and start researching. Do so for several months without spending a dime. To be honest at your stage you are asking for a train wreck.
Listen to this man.
Old 03-26-2011, 04:37 PM   #42
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
^I agree. I will say get a tune on the car to make it a little happier (yes more power) and find a stock recirc valve. Then maybe focus a little on suspension and just driving the car. Once you feel you're ready for more jam then 300whp is certainly easily obtainable. I personally recommend going with a 18G or maybe a 20G either with an 8cm^2 exhaust housing. My 02 WRX made 310whp and 285wtq (3700rpm) on a dynojet, 93oct and about 20psi boost with a Blouch 18g 8cm^2.
I miss that car. Sold it to a friend and he blew the tranny in 3 months. It lasted me 130k miles (10k @310whp, the rest at 230ish) So that brings me to my next point. The 5 speed will last as long as you shift well and dont launch the crap out of it. But once you get to these power levels you really are just on borrowed time. Save for a 6speed swap.
Old 03-26-2011, 10:19 PM   #43
Exarch
Member#: 208321
2015 WRX
^This^
I hate to come across as a jerk, but you sound like you have a ton of reading to do. Assembling an arbitrary group of parts that will make X horsepower without knowing the what, when, where and why behind those selections is a bad way to go about it.
You're better off spending the next six months learning and saving your money then going off and buying a bunch of stuff because, "some dude on some forum on some part of the internet told me this would be awesome".
Exarch is offline   Reply With Quote
Old 03-26-2011, 10:27 PM   #44
jimbosv650
Member#: 261307
04 wrx wagon
Well it sounds like you're closer to your goal, but the up pipe was probably the first thing you should have upgraded if you're running a bigger turbo and increasing boost levels.
jimbosv650 is offline   Reply With Quote
Old 03-26-2011, 10:45 PM   #45
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
[quote=CKxx;31020256]You still haven't said if you want 300 CRANK hp, or 300 WHEEL hp.
No, STi pinks are not "plug and play."
FOR 300 WHEEL HP (easy 300):
Catless up-pipe, catless turbo-back exhaust, EVO316G, 650cc injectors, STi (or larger) TMIC, Walbro pump, ECU tune.
^ this im running this setup with a blouch evo III big 16g dw 780cc inj precision front mount, cobb intake, and tial 38mm ewg and made 330whp at 20psi. this will cost you quite a bit to get to this, a protune alone on a dyno run about $450. good luck
under0athh51189 is offline   Reply With Quote
Old 03-27-2011, 03:09 AM   #46
sc00by4life
Member#: 97135
VF39 is not a 300whp turbo on the 2.0, even on the most forgiving of dynos.
Old 03-27-2011, 09:58 AM   #47
gonzo1
Member#: 243589
2005 Impreza WRX
Nice....! This thread is still going. I've been researching, reading a bunch and getting headaches from reading so much. Lol. I thank and appreciate everyones opinion and Nasioc site for educating me. Well it's been 8 months since I started this thread. Since then I upgraded to this:
-Cobb Downpipe, Cobb Access port, K&N Cold Air intake, 3" Invidia exhaust system
-Walbro Fuel Pump
-Agency Front and Rear Sway Bar Links
-Perrin Front Sway Bar 22mm
-Perrin Rear Sway Bar Kit 25mm
-Perrin Rear SLS
-Perrin Oil Catch Can
-H Brace
-Front strut bar and Rear strut bar
*Just bought last week**Waiting to install*
-VF43 turbo, 07 Sti injectors, Large Sti TMIC, silicone turbo inlet
I have a friend that'll tune for less than $450. Think it'll turn out fine. 300whp or not, this is what'll I'll stay with. Next is up pipes, mounts, and somehow take weight off car. Ideas?? :-B
Old 03-27-2011, 10:07 AM   #48
SnowgodCCR
Member#: 256968
2008 STi
Red
-Walbro Fuel Pump
-Perrin Rear SLS
-H Brace
Be sure to report back with how laggy/not that vf43 is on the 2.0, I wasunder the impression that the 43 isn't recommended on the 2.0 because its too big for the smaller displacement.
Old 03-27-2011, 04:40 PM   #49
'02 Subaru Rex
Member#: 160725
2005 STi
WRB sittin on GOLD
I've heard the same…I probably would have looked for a twin scroll vf…
OP, whats your obsession with 300awhp…have you ever driven anything with that much power?
Trust me cobb stage two and suspension mods are plenty for both the street and the occasional track day.
'02 Subaru Rex is offline   Reply With Quote
Old 03-27-2011, 06:53 PM   #50
gc822
Member#: 81217
300hp. What does everyone think about the Cobb stage1? STI injectors ok for upgarade, plug and play? Walbro fuel pump? To get it tuned just any dyno shop will do? And what does flash ecu mean, tune? If not can we flash ecu ourselves? Thanx guys
You are already past Cobb Stage 1.
Cobb Stage 1= Completely stock WRX, Accessport stage 1 flash.
Cobb Stage 2= WRX with turbo-back exhaust, Accessport stage 2 flash.
With the mods you have right now(how your car is exactly this second) you would benefit most from a dyno tune.
Also, you don't need a BOV. The factory BPV is good and will hold boost until about 22psi.
EDIT
I saw the update that you already went stage 2 and beyond. Good luck w/ the car.
gc822 is offline   Reply With Quote
05 wrx 2.0 conv. to 06 wrx 2.5 Questions??? LT_DAN0690 Subaru Conversions 3 07-05-2009 01:19 PM
Fs: (Nc) Cobb Acessport V.2 for 02 - 05 wrx 2.0 (In Box) Kingdlee Engine/Power/Exhaust 10 04-27-2008 01:35 PM
V2 Accessport for 02-05 WRX 2.0 (2 weeks old) Drink Engine/Power/Exhaust 3 02-19-2007 01:39 PM
Advice on next mod??? Help from Local Seattle WRX 2.0 owners!! dhalley North West Impreza Club Forum -- NWIC 20 08-29-2006 11:49 AM
Is EM upgrade or utec need for Uppipe on 05 WRX 2.0 l Boosto Newbies & FAQs 2 08-02-2005 11:57 AM
