Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 02-22-2011, 08:54 AM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default GTWorx Bilstein Dampers for '08+STI-Installed and a review on new system
Myles at RCE says we should be seeing a February delivery for the GTWorx Bilsteins
Review on IWSTI here: http://www.iwsti.com/forums/gr-suspe...ml#post3294244
This customer's '11 is a testbed for the new system.
I recently bought my first Subaru. The 2011 STi sedan. What an amazing car. ive never owned an AWD sports car and to describe it is quite difficult for me, none the less it is an amazing experience, and the handling is incredible. My past cars have always been steadily modded over time and my STi was no different. I went with Stage 1 and added exhaust, intake etc. Since I had never felt a car like my STi, and after reading all the things the company did for the 11 MY in regards to suspension, I just assumed it could not get any better. I joined IWSTI in hopes of reading more about my car, and learning good vs bad mods and the like. I ended up running into Myles at Race Comp Engineering, and talking back and forth about a lot of the STi in the present and the past as he has been in the subaru community for quite some time. As it turns out GTWorx and Bilstein needed a donor sedan to test their new prototype suspension in San Diego. I only lived an hour and a half or so from there and willingly offered up my car. They sent me sway bars from RCE which were quite easy to install, and shortly there after i dropped my new STi off at Bilstein. This was the longest week of my life. Upon returning to Bilstein to pick up my car with new lowering springs and shocks, I couldnt believe the difference behind the wheel. This car went from what i thought was “the best” to a full bred race car. The dampening force these shocks have were incredible to me. There is a huge hump in the main road in my town which used to cause my STi to get a few inches of air if i hit it going 50 or so, with these shocks, the car sticks to the road like glue. The car never loses contact with the road no matter what situation i put it in. I was fairly worried on the ride home assuming these shocks would be rough and wouldnt be “comfy” anymore. Although it is obviously stiffer, it does not shake or bounce while driving on the freeway. The car sits about 10mm lower and it looks more aggressive in my opinion, but not giving it that “hella flush” slammed look. Turn in and cornering are night and day, I used to feel understeer while cornering in this car at high speeds, but now i feel confident in almost any corner at any speed. This car had a very far limit before, but now it feels almost limitless. The rear suspension is ride height adjustable as well so depending on trunk load or equipment i can adjust the cars ride height. The car sits perfectly level at the “middle” setting on the rear struts.. To anyone who is looking for an aftermarket shock strut combo, this is hands down the best buy. Very simple and understated, until you get into a corner.....then all hell breaks loose. I can not stress enough how much more confident and solid the car feels in the corners. No matter what you throw at the STi with the Bilstein/GTworx kit, it will deliver.
For many years, the Impreza market has never had direct access to affordable Bilstein shocks due to the influence of a large UK based rally company.
BUT as many of you know, GTWORX has developed an option with Bilstein for the GH chassis Subaru Impreza WRX that comes as a kit with RCE Yellow springs that were designed in conjunction with the dampers. Excellent handling and ride quality from a serious shock and spring system upgrade. The pics below are the kit on a 2011 WRX with the rear circlip in the standard middle setting:
And as many of you have figured out, we're doing it now for the GR chassis STI as well.
These are indeed currently being developed and fine tuned for the GR STI chassis. They will be available for a SPRING release.
And since they're are many out there with RCE Black and Yellow springs already out there we wanted to officially let the cat out of the bag. They will be available as a package with RCE springs OR you can use them with your existing RCE Blacks and Yellows.
These GTWORX Bilstein dampers feature inverted front monotube struts, rear monotube shocks, GTWORX and Bilstein developed SPORT valving matched to RCE Yellows with plenty of gas pressure and low-speed damping for excellent handling, with digressive high speed valving to maintain comfort for a daily driver. The rear shocks feature an adjustable cir-clip for +/-5mm and +/-10mm of ride height change.
The objective is NOT to offer a TIME ATTACK shock, nor do we expect you to have to cut open your oem shocks, getting messy oil everywhere etc and use inserts inside your stock housings. We want to make a simple set it and forget SPORT SHOCK with matching springs. To be clear this is NOT a coilover, but a OEM fitment strut/shock set up with fixed perches just like stock. These are designed for sedan and hatchback using RCE Black or Yellow springs.
Comfortable, but with German sports type handling prowess. With THAT said...these will be excellent on the track!
We look forward to your feedback and interest. We are very excited about being able to offer this system specially tuned for the GR Impreza STI platform!
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 02-22-2011, 08:55 AM   #2
Member#: 173316
'13 BRZ
Here's what Myles from RCE had say about the upcoming launch of the GTWorx Bilsteins for the '08+ STI
All parts are in the country and being assembled @ Bilstein USA. With a little bit of luck early next month I will be in Socal doing the ride work. We are doing 2010 LGT at the same time. 2 very different cars but I am looking forward to it in a major way.
Soon I will be able to announce a confirmed price but I see no reason why it wont be like the WRX pricing.
We WILL do a intro buy special for the first 50 sets so anyone who knows they are in should email us and or pm us and we will send you a pre-order form. Once those first 50 are commited then its regular pricing.
GTWORX
M.
We will be taking pre-orders for these so we can be part of the first 50 set intro buy special, save a lot of $$$$.
Email me if your interested and I will send you a pre-order form to fill out.
jason@dalesmotorsport.com
__________________
[/CENTER]
Old 02-22-2011, 03:27 PM   #3
Member#: 173316
'13 BRZ
Here is what Myles had to say about pricing:
If I get the same pricing at last time....we will do a preorder of 1199.00US shocks and springs.
$899US intro on shocks and $299US intro on springs. PLUS SHIPPING.
Sounds pretty good.
__________________
[/CENTER]
Old 02-25-2011, 05:33 PM   #4
Member#: 173316
'13 BRZ
There will be only 50 sets of GTWorx Bilsteins(STI) offered at intro pricing. We will also offer a discount on a set of RCE springs when packaged along with the Bilsteins.
I will not charge anything until we get the final pricing quote and once everyone has been contacted and agreed to the order. I just need some sort of commitment before I go ahead and order 20-30 sets of these. This will help keep the intro buy organized on our end. When we get confirmed pricing and everyone has been notified I will need a deposit to get the ball rolling.
If you would like to guarantee a set at this price point please fill out this sheet(attached file) and email it back to us. If you have anymore questions please email.
jason@dalemotorsport.com
__________________
[/CENTER]
Old 03-07-2011, 09:46 AM   #5
SWP impreza GH
Member#: 257488
2011 Wrx Sedan
Sparkling Silver
Interested in pricing.
SWP impreza GH is offline
Old 03-07-2011, 09:32 PM   #6
Member#: 173316
'13 BRZ
Nothing set in stone yet but close to pricing 3 post up.
__________________
[/CENTER]
Old 03-11-2011, 09:17 PM   #7
RafCarre12
Member#: 274425
white
Definitely interested in what you guys come up with.
I've had cup kits in other cars I've owned and an option like this sounds really attractive.
RafCarre12 is offline
Old 03-27-2011, 11:06 PM   #8
emjayem
Member#: 225167
2009 wrx sdn dgm e85
332whp 370wtq
soooo... these are or are not available for 09 wrx.? I keep seeing that people have them, or some variation of them on their 08+wrx. cant seem to find a place to buy them tho...
emjayem is offline
Old 03-27-2011, 11:24 PM   #9
Studebaker83
Member Sales Rating: (20)
Member#: 169443
2008 WRX with VF-52
I believe you can still order them from Dale's
Here is an old thread
http://forums.nasioc.com/forums/show...light=racecomp
Studebaker83 is offline
Old 04-14-2011, 09:41 PM   #10
Member#: 173316
'13 BRZ
PMs replied
__________________
[/CENTER]
Old 04-15-2011, 03:37 PM   #11
Member#: 173316
'13 BRZ
No Tein coilovers for sale.
Thanks Onur
__________________
[/CENTER]
Old 04-15-2011, 06:02 PM   #12
Drakar
Member Sales Rating: (115)
Member#: 68402
2000 Impreza 2.5 RS
Silver with holes
you wanna let me test fit WRX bilsteins with my forester swift springs?
or is there plans to make a bilstein for the forester, would be wicked to have it ride and handle uber smooth and nice.
Drakar is offline
Old 04-20-2011, 06:48 PM   #13
iSTI
Member#: 241769
do you guys have this for 2010 sti =(?
iSTI is offline
Old 06-14-2011, 10:06 PM   #14
Member#: 173316
'13 BRZ
Bump for review on the GTWorx Bilstein and spring combo
__________________
[/CENTER]
Old 06-15-2011, 12:29 AM   #15
mctee
Member Sales Rating: (13)
Member#: 242446
2010 STI
SWP - Gone!
Hey Dale's:
Does this mean that GTWORX / RCE are close to ready to commercialize these things? We spoke earlier today - did you get an update on these since then?
If I was GTWORX I'd be in a little more of a hurry if Feal is ready to ship in 2 or 3 weeks!
Two great looking options now - Feal and Bilstein! Which ones?! Plus both should be approx 1/2 the price of decent quality coilovers.
I like the look of what Feal is doing and I really like the totally adjustable damping options and the full rebuild'ability. Gives the option of running their stock tarmac setting for baseline and then requesting adjustments based upon your own opinions or needs.
Plus Feal's rears are adjustable in ride height like a coilover and they have the added volume of the piggyback resevoir.
So really comes down to the bright yellow paint w/ the blue decal vs. custom low volume producer who actually rally's/drift's/etc., right?
mctee is offline
Old 06-15-2011, 01:01 AM   #16
Member#: 173316
'13 BRZ
I still feel the GTworx option is still going to be awhile. RCE has no real ETA so who knows when?
__________________
[/CENTER]
Old 01-25-2012, 03:32 PM   #17
Member#: 173316
'13 BRZ
I just talked to Myles at Racecomp and it looks like a February delivery on the Bilsteins.
If anyone is interested in getting on the intro buy please email jason@dalesmotorsport.com
Bilsteins frt/rr-$999US(shipping extra)
add springs:
RCE Regular Guy or Yellow spring-$319set
__________________
[/CENTER]
Closed Thread
GAUGING INTEREST-Bilstein Dampers for '08+STI dalesalignment&brake Vancouver Impreza Club Forum -- VIC 12 02-22-2011 12:28 PM
Look for '08+ STi for FMIC test fit. RacerX Engineering-BRMQ Southern California Impreza Club Forum -- SCIC 6 08-08-2010 10:47 AM
FOUND: RCE, TiC, or Bilstein Coilovers for 07 STI SubieEngineer Private 'Wanted' Classifieds 6 01-06-2010 07:41 PM
Looking for '08 STi Parts-Prefer to buy used locally SixD7 SWIC Private Classifieds 3 11-04-2009 05:03 PM
WTB: Bilstein PSS9 for 04 STI pictureboy Private 'Wanted' Classifieds 1 02-26-2008 04:11 PM
