#1 |
Member#: 278104
Vehicle:2004 Toyota Tacoma |
I have a 2004 toyota tacoma 4x4 and have been modding it over the past 2.5 years with all sorts of off road and truck things (lift, tires, etc) but i have had enough and have been having some problems with it so I will be switching over to an 06 or 07 WRX.
I have done some searching on this site and others for common things with the 06-07 WRX's and have looked at basic mods. This will be my daily driver and i need it to last atleast 4 years, so no racing or anything extreme and it NEEDS to be capable in snow. I was thinking for this list in this order for mild performance mods 1. Axle or Catback exhaust (Blitz) 2. Cobb AP Stage 1 Tune 3. AEM Intake 4. Stage 1+ Tune 5.Down Pipe 6. Stage 2+ Is that a correct order with the tunes and stuff? Am I missing something? Sorry for the newb thread but I'm hoping to learn as much on this forum as i did on my Tacoma one (just maybe spend less money b/c of it haha)
#2 |
Member#: 175401
Vehicle:2007 VF39'd OBP WRX 2008 Blue Kawi ZX-10R |
That is correct. You may want to make sure that the AEM intake uses stock diameter piping otherwise it won't be safe on that tune. It should say something along the lines of "no tuning required" in the description, or I'm sure others here on the forum can tell you. Besides that, you are on the correct path. Where are you located? You should find a local tuner in your area if at all possible. You could forego the AP altogether(saving you a couple hundred dollars in the process).
#3 |
Member#: 170415
Vehicle:2002 Hardware store bumper clips, that is all |
Just go stage2 with an opensource (custom dyno) tune from the start.
#4 | |
Add Lightness
Moderator Member#: 13699
Vehicle:2007 Lotus Elise (From General) |
Otherwise, you're redundantly spending your redunant money over and over again. Just do it once and do stage 2 at your tuner who can open source tune it right there and then. An AP is fine if you are going strictly the Cobb route (which means you're buying only Cobb stuff, which is pricey) but varying from there means there's no guarantee. You're on your own. |
#5 | |
Member#: 263954
Vehicle:2008 STi Aspen White / Gold BBS |
#6 |
Member#: 270426
Vehicle:2011 WRX Premium Satin Pearl White |
What problems have you been having with your tacoma?
#7 |
Member#: 278104
Vibrations all over the place. Engine and tranny are great and will prob live longer than me haha. Still a great truck, but i had the frame replacement done through Toyota and who knows what wasn't done correctly there (over a year ago). I don't really need a truck, just something that can make it through snow and even if i have to use higher grade gas, i will still save money
PS Thanks for all the advice |
#8 | |
Member#: 278104
I was under the impression that the Cobb AP already had the stage 1 and two maps built in, and you just picked which one? Or do you buy the AP with the stage 1 map on it and then have to buy further maps? Really stage 2 would be atleast 2 years into the future, I'm just looking to get the sound of a cat/axle back and the little extra oomph of the intake and a stage 1 tune in the next year |
#9 | |
Member#: 270426
#10 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Yes, but neither of them work with aftermarket intakes. You listed stage 1, then stage 1+, then stage 2+ in your post, the only one of those that you could use the OTS map for is the first one, both the stage 1+ and stage 2+ means a custom dyno tune by a professional (IE: several hundred dollars each). If you're going to get a custom tune, you might as well just go stage 2 and get a custom tune via open source immediately, instead of spending $600 on an AP, then $300 on a stage 1+ tune for the intake, then another $300 on a stage 2+ tune after the downpipe.
#11 | |
Member#: 278104
OOO ok that makes sense. Well does in intake really make that much of a difference on these cars? I mean i'm not looking for a street demon here, modding cars is just a hobby that i enjoy. Would it be better to get the catabck exhaust then the intake and get a protune, eventually going with the downpipe and another protune? Or it it be better to just get the catback exhaust, get the AP and go stage 1 on my own, then eventually get the downpipe and use the provided stage 2 map and just forget intake? My budget within the next year for this is really going to be around 1200 bucks so thats why I'm putting these in that order and can't just jump to stage 2. AndThanks for all the help guys, I'm learning haha |
#12 |
Member#: 51961
RMIC
Intakes don't really do much on these cars, not until you get into 300whp and higher.
It's not like an N/A car, where every psi you gain from the higher-flowing intake is an extra psi in the engine. The boost control system regulates the manifold pressure to stay relatively constant. All a more restrictive intake does is increase the pressure ratio for the turbo, which makes it generate more heat (most of which gets cooled back off in the intercooler). The end result is the charge air is just a couple of degrees warmer and the engine makes maybe 1 HP less (as opposed to an N/A car where the engine is now injesting air at 13 psi instead of 14 psi and you lose 7% of your power). |
#13 |
Member#: 278104
well i doubt i will ever have a WRX over 300whp, too much money haha. So it would be more economical to just get the cat/axle back and then get the AP or protune then finish off the turboback exhaust and either tune it with the AP again or get another protune. Pretty much same cost
#14 |
Member#: 51961
RMIC
Or get a downpipe and protune and go stage 2 immediately, then add a catback later on.
#15 |
Member#: 278104
Touche haha but i love the sound and would prefer to have that first. But i guess it does make more sense to just have the exhaust on then wait for the DP and get the protune for stage 2. Does the downpipe hook right up to the midpipe since it has the cat in it? I'm confused with all these pipes that aren't on my truck. Also what are the most reliable exhausts/downpipes? I like the sound of the Blitz and Invidia as well as the HKS. I'm just looking to get one that will bolt right on and isn't too pricey since its the first mod and i want it to last
#16 |
Member#: 236017
South East
Vehicle:2005 OBP WRX Sedan 2.35L w/ GTX3071 |
Honestly man, I would just by a WRX or STi, purchase a TBE, Intake, and 3-Port EBCS, then get a custom Stage 2 dyno tune. Its what youre plan is in the end, but youre going the long, expensive route to get there. Just do it all at once, you will be more than satisfied....for a little while.
#17 | |
Member#: 278104
All of this is much more complicated than my truck haha |
| Thread Tools | |
| Display Modes | |
| How does this sound re: selling my car...? :( | bumble_roo | Southern California Impreza Club Forum -- SCIC | 13 | 11-10-2008 09:41 PM |
| How does this sound? | CBoldman | Off-Topic | 5 | 09-16-2003 03:15 PM |
| Columbus Ohio..How does this sound? | 42202sub | Mid West Subaru Owners Club Forum -- MWSOC | 183 | 09-07-2002 06:33 PM |
| How does this sound? | Hondakilla | Brakes, Steering & Suspension | 3 | 05-20-2002 01:25 PM |
| How does this sound? | sub25rs | General Forum Archive | 5 | 03-14-2001 01:24 PM |
