#1 |
Member#: 14727
Vehicle:2002 impreza RS |
I have noticed an oil stain on the left side of the transmission case, around where the shifter linkage enters... Does anyone else have this?
#2 |
Member#: 163619
I have this issue too, I'm doing a clutch kit install and there's a bit of fluid leaking.
#3 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
I've actually seen this in almost every 5MT I've worked on. It's pretty common, but varies in severity.
It's a pain in the butt to fix though. You need to completely remove the linkage and the attachment point on the gear selector shaft. Then you need to pull the driveshaft, pull the crossmember, lean the box back and remove the tailstock portion with the center diff. once removed, the seal can be removed and replaced fairly easily. |
#4 |
Member#: 61484
Vehicle:2004 wrx sedan wrb |
would you happen to have the service manual on that? i have this issue too
#5 |
Member#: 71092
MWSOC
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Count me in as well. Pretty significant amount of oil sloshes out of there and has since about 20k miles.
#6 |
Member#: 50699
TXIC
Vehicle:2004 WRX Platinum Silver |
basically same procedure to remove the center diff. Its a tedious process, but very doable with simple hand tools
#7 |
Member#: 61484
thanks
#8 |
Member#: 115297
SWIC
Vehicle:2002 ej207 vf34 WRB |
Can someone point me in the right direction on the FSM for this?
I've got the tranny out and I need to what's involved in getting the new seal in there. It looks like you've got to undo the "tail cap" and take off the linkage pieces, but I can't figure out how to remove the linkage piece. thanks. |
#9 |
Member#: 50699
TXIC
can you post a pic of where you are on the replacement. Will help a bunch
#10 |
Member#: 115297
SWIC
[IMG]
Uploaded with ImageShack.us[/IMG]This is where I'm at. Do I have to take the "tail-cap" off the center diff? I punched out the roll pin that holds the linkage in, but can't get anything else to budge. How do I get that last piece of linkage off? |
#11 |
Member#: 115297
SWIC
Can you see that almost silver colored piece that goes vertically through the linkage?
That's the piece I can't get to move. Does it punch through like the roll-pin? |
#12 |
Member#: 120273
SWIC
Dude, give me a call. I'll PM you my number.
It is actually one roll pin inside another. You need to punch out the inside roll pin and then the outer. They can be it there very tight at time. A proper sized punch helps a lot. |
#13 |
Member#: 248067
#14 |
Member#: 231774
Check the shifter linkage seal it is a small on and can leak like the fifth gear seal.
#15 |
Member#: 20794
Vehicle:2002 WRX Sedan WR Blue Perl |
It appears that I have this leak as well. Have a bit of a cash flow crunch right now though - how important is it to get this quickly fixed (versus waiting a while), as long as I make sure the transmission fluid stays at an appropriate level?
#16 |
Member#: 178707
NESIC
Vehicle:2002 BUGEYE HYBRID MBP- NO ITS NOT BLUE |
I have the same leak on mine right now too. Not looking forward to fixing this but its a must, just keeping an eye on my fluid level for now. Been driving for about 4k miles now on new fluid and doesnt seem to be a huge problem... yet. How much u think a shop would charge for this fix, it seems awfully labor intensive.
#17 |
Member#: 76817
NESIC
Vehicle:2005 WRX Black |
Can we get a part number on this ASAP? I searched all over. I am replacing transfer case bearings this weekend and need to replace this as well.
#18 |
Member#: 176725
Vehicle:2003 WRX White |
did anyone ever get a part number for the gasket?
#19 |
Member#: 118086
MWSOC
Vehicle:2003 WRX WRB |
| Thread Tools | |
| Display Modes | |
| FS: (NY) oem tranny mount and shifter linkage | mikecsti | Drivetrain | 5 | 05-18-2010 11:35 AM |
| Tranny leaking at axle | recruitX | Transmission (AT/MT) & Driveline | 8 | 09-17-2007 11:35 AM |
| Q: Is there a seal where the shifter linkage enters the tranny case? | mpaone | Transmission (AT/MT) & Driveline | 2 | 01-15-2007 07:45 PM |
| Shifter linkage tranny leak | ryguy | Transmission (AT/MT) & Driveline | 4 | 07-19-2006 09:17 AM |
| RS shifter linkage on a FWD tranny? | ^jynx^ | Transmission (AT/MT) & Driveline | 2 | 09-14-2003 07:05 AM |
