Old 04-03-2011, 04:56 PM   #1
BLUE STINGER
Member#: 84206
Question Will a stock GR sti tmic fit a GD sti? Well, I'll let you guys decide.
Anyhow, I did this test cause I keep hearing people say it won't fit. So here we go...............
Stock GR sti tmic vs GD sti tmic comparison. The bigger unit is the GR core with no throttle body hose.
Now on to the test fit.
First you will need this 3rd bracket from a GR sti and bolt it on in place like it's shown in the bottom picture, if not you can always fabricate a bracket to extend it out to accommodate for the larger core.
A quick install tease to see if it fits.
AC lines clear. Check
Wastegate actuator and etc. clearance. Check
BLUE STINGER is offline   Reply With Quote
Old 04-03-2011, 04:57 PM   #2
BLUE STINGER
Member#: 84206
So will it fit? I'll let the pictures do the talking.
Ron
Old 04-03-2011, 04:59 PM   #3
BLUE STINGER
Member#: 84206
I posted this in other forums but maybe it will help someone here in Nasioc.
Ron
Old 04-03-2011, 05:13 PM   #4
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
P/N on the bracket for future parties to swap ICs would be great. I thought about this a while ago, and figured it would only take using the GR brackets.
OrbitalEllipses is online now   Reply With Quote
Old 04-03-2011, 05:30 PM   #5
BLUE STINGER
Member#: 84206
You would only need the 3rd bracket in the 4th picture, all other brackets are identical in previous years except for maybe the models that do not use these type of brackets. Now this install/experiment was only done with a GD DBW sti so I'm not sure how fitment is with DBC and etc. subarus. I would also like to add that a modified stock heat shield fits with no problem. Hood scoop splitter modification is also a must, if your going to use this bigger GR sti tmic you need to get the most of out of it, which is not hard to do.
Ron
Old 04-03-2011, 08:49 PM   #6
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Strong work! This ought to provide adequate cooling up to 20G or so. Appreciate your efforts.
Old 04-03-2011, 10:41 PM   #7
marc_b
Member#: 245118
06 wrx
wrb
nice job, fitment looks good
marc_b is offline   Reply With Quote
Old 04-04-2011, 02:52 AM   #8
BLUE STINGER3
Member#: 252764
Yes this will be more than adequate for a 20g and I've heard of some other tuners running this on a rotated 35r. I've tuned a few GR sti's and the tmic does a good job of cooling much better than I expected.
Thanks, fitment is just as good as stock and install was a breeze. Looks stealth too.
Thanks,
Ron
BLUE STINGER3 is offline   Reply With Quote
Old 04-04-2011, 09:22 AM   #9
WickedXj
Member#: 189391
2011 WK2
Looks great!
I have an opportunity to buy one for my 07 wrx, I was going to pass on it, but I think I will take it now after seeing your pictures.
I shouldn't have any issues on a wrx right?
WickedXj is offline   Reply With Quote
Old 04-04-2011, 11:51 AM   #10
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
With a WRX you may need the STI brackets. I don't recall, but there should be a thread in the 2L forum about fitting an STI intercooler to a WRX.
Old 04-04-2011, 02:26 PM   #11
pooster.online
Member#: 120461
2004 WRX STi JBP
Ron
what kind of modification to the splitter would you need to do?
pooster.online is offline   Reply With Quote
Old 04-04-2011, 03:04 PM   #12
my name is joe
Member#: 171412
how is this unit compared to process west?
my name is joe is offline   Reply With Quote
Old 04-04-2011, 03:32 PM   #13
BLUE STINGER3
Member#: 252764
Originally Posted by WickedXj View Post
Looks great!
Honestly you can make this tmic fit with slight modification. 07 wrx are DBW's so it should fit if not you will have to play with the y-pipe, elbow hose, and throttle body coupler. You can cut or extend the hoses I mentioned above and those play a major role on how you want your fitment to be.
Ron
Old 04-04-2011, 03:39 PM   #14
BLUE STINGER3
Member#: 252764
I have no idea but the process west coupled with its own splitter should be better but overall this tmic is a good option compared to the previous years. I've also owned a version 7 sti tmic and I've ran that with my old fp green setup in the past with no problem. Also it also depends on how much your willing to pay.
Ron
Old 04-04-2011, 03:58 PM   #15
BLUE STINGER3
Member#: 252764
As you can see from the picture it's noticeably bigger. You will have to cut the splitter to fit the larger tmic core. It's not that hard to do and I've done it in the past with other aftermarket tmics. Here is some good read http://forums.nasioc.com/forums/show...light=splitter and modification is something but not quite like this. Maybe when I have time, when my busy schedule permits, I can do my own DIY version of modifying the splitter.
Ron
Old 04-04-2011, 04:02 PM   #16
BLUE STINGER3
Member#: 252764
Not too sure on the brackets as I have some wrx and sti IC brackets at home but I think the changes is due to the intake manifold/throttle body design from previous years not so much on the brackets themselves. Then again maybe I'm wrong but I have quite a few brackets collecting dust in the garage.
Ron
Old 04-05-2011, 03:39 PM   #17
my name is joe
Member#: 171412
Ron
i was planning on running a v7 sti top with a 20g but if the new GR's are bigger i might have a take on one..
Old 04-06-2011, 07:02 PM   #18
BLUE STINGER3
Member#: 252764
Yes a bit bigger. And remember if you have a wrx get a sti splitter(modification also needed) or simply just modify your stock splitters.
Ron
Old 05-01-2011, 09:07 PM   #19
WickedXj
Member#: 189391
2011 WK2
Looks great!
Thanks for the thread Blue Stinger!
Old 05-02-2011, 12:27 AM   #20
BLUE STINGER3
Member#: 252764
^^^ Wow that looks awesome, it looks like it belongs in there! Glad to be of some help. I'm digging the blue hoses too.
Regards,
Ron
Old 10-17-2011, 11:12 PM   #21
freshADR
Member#: 141565
2007 UGM Impreza
SoCal Flat Four #28
bumping up an old thread but I would like to add a few things from my installation on an 07 WRX for future reference.
I ran into fitment issues with the stock GRB bracket so I trimmed it to make it literally an extended piece. As stated before, you can measure and fabricate a bracket at a local hardware store.
The stock y-pipe red hose is just as much of a PITA to get on as the 04-07 STi intercooler y-pipe red hose is (as they are the same size) so getting an extended y-pipe hose makes installation easier.
I was still able to reinstall the JDM STi FHI Titanium front strut bar without any fitment issues.
SPT or similar style turbo heat shields will not fit due to the extended bracket.
The Subtle Solutions GRB Intercooler splitter will fit under the 06/07 hood scoop without the intercooler splitter if you want to cheat. However, the GRB splitter sits a bit slanted due to the lower passenger bolt and removing the intercooler splitter does not allow the air to directly flow over the last 1/3 section of the intercooler so modifying the intercooler splitter is still needed for efficiency.
freshADR is offline   Reply With Quote
Old 10-26-2011, 08:47 AM   #22
05-rsx
Member#: 101188
MY07 WRX Wagon
Anyone tracked down the part number for the 3rd 'extra' bracket to fit these TMICs to GDs?
05-rsx is offline   Reply With Quote
Old 10-27-2011, 02:43 PM   #23
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Blatant Sales pitch
We have a brand new 2008+ tmic up for sale (still in the factory box). It is the same one as shown in this thread's images. $550 retail, blowing out for $421 + ship. We accidentally ordered this unit instead of an aftermarket unit and found out it can not be returned to our dealer since it was special order
Part # for TMIC: 21820AA380
Stephen
www.iaperformance.com
IA Performance is offline   Reply With Quote
Old 10-27-2011, 08:57 PM   #24
05-rsx
Member#: 101188
MY07 WRX Wagon
Also just feeding back to my question.
Thanks to the staff working at the local parts department at (who is also working his last day before retirement today!)
the part number for the bracket is 21885AA330, ~$47 from Subaru Australia.
Might do some US-investigation methinks.
Searchy keywords: GR TMIC brakcet 3rd stay intercooler inter cooler 08+ STi
Old 03-26-2012, 03:24 PM   #25
junk240sx
Member#: 53826
2005 WRX STi
Thanks for the bracket part number. Here is my before and after upgrading to the GR TMIC:
junk240sx is offline   Reply With Quote
Widest tire that will fit inside GD wheel well bayluck Tire & Wheel 11 03-23-2010 07:21 PM
will a stock 02 WRX Dowpipe fit my 04 STi ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-30-2009 07:03 AM
Will Sti tmic fit on WRX wrxbert Tri-State Area Forum 6 03-12-2007 06:53 PM
Will GC8 Cusco front camber plates fit a GD front strut? esper Brakes, Steering & Suspension 9 06-17-2005 02:20 AM
Will GC Tein RA Coil Over Fit 02+GD WRX? SpoonTypeR Brakes, Steering & Suspension 2 02-10-2004 02:26 AM
