Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 02-21-2011, 06:58 PM   #26
sorrowfulkiller
Member#: 170439
I <3 Lamp
I'm also super interested in these.
sorrowfulkiller is offline   Reply With Quote
Old 02-22-2011, 10:23 PM   #27
splicer4u2
Member#: 133254
2002 hta68 hybrid
I am interested as well. Im running around with an open diff from a 99 impreza in the rear on my 6 speed wrx swap. Im in need or traction!!!
splicer4u2 is offline   Reply With Quote
Old 02-28-2011, 07:29 AM   #28
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
I like this.
srREXed is offline   Reply With Quote
Old 03-19-2011, 09:10 PM   #29
haggardfab
Member#: 240637
02 wrx
aspen white
I finally got aRound to installing these in my wrx and the spline on the axle is not even close to the splines on the hybrid races....? Do i need a certain year wrx axle or something?
haggardfab is offline   Reply With Quote
Old 03-19-2011, 10:19 PM   #30
mowgli29
Member#: 203438
Is the spline count different or axle diameter different or....? Got pics?
Mine just slid right on. :gotme:
mowgli29 is offline   Reply With Quote
Old 03-19-2011, 11:45 PM   #31
haggardfab
Member#: 240637
02 wrx
aspen white
Hey dont fit on my 02 axles and i just had a friend bring iver his 06 axles and they dont fit his either, his measures .895 OD at the splines, mine measures .905 and the id on the new race is .975.... What year axle are you running?
Old 03-20-2011, 03:20 PM   #32
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
You guys saying you bought it and it wont fit?
hybrid gti 2 is online now   Reply With Quote
Old 03-20-2011, 10:28 PM   #33
haggardfab
Member#: 240637
02 wrx
aspen white
im not trying to start a battle, but i spent a good amount of money for these and they do not fit on my axles.. the od on my axle is .070 smaller then the splines on the race
Old 03-21-2011, 11:48 PM   #34
haggardfab
Member#: 240637
02 wrx
aspen white
got it straightened out.. for some reason my rear axles were different but i grabbed an 03 axle and they worked.. fyi these only work on 02-04 axles
Old 03-23-2011, 01:35 AM   #35
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Good to hear.
I used axles from the 90's in my race conversion, and had to remove a bit of material in order to get the new inner race on far enough to get the snap ring on. 10 mins w/ a dremel.
Thank you Dave for saving us 100s of dollars!
biggreen96 is offline   Reply With Quote
Old 03-25-2011, 12:41 AM   #36
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
How much are these for a pair? I've got a setup with 2004 wrx rear axles.
Old 03-25-2011, 01:09 AM   #37
biggreen96
Member#: 12535
Pm Op, Ok?
Old 03-31-2011, 04:02 PM   #38
smith_wrx
Member#: 237438
Got my set today can't wait to do the swap thanks again Dave!!
smith_wrx is offline   Reply With Quote
Old 04-01-2011, 02:24 AM   #39
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Why don't you guys just post a price? Sounds shady...
Old 04-01-2011, 02:30 AM   #40
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
As a non-vendor you can't advertise for stuff like these...
minifreak is offline   Reply With Quote
Old 04-01-2011, 03:22 PM   #41
mowgli29
Member#: 203438
Word.
Plus, I figured I'd respect the OP's right to change his price, if ever anything changes.
BTW, almost 16k miles on mine so far!
Old 04-04-2011, 12:33 PM   #42
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
wow great hybrid fix, great price and savings....
blue_wrx_chic03 is offline   Reply With Quote
Old 04-04-2011, 01:14 PM   #43
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
It is not advertising if the OP does not put the price, or make actual advertisements
Old 04-04-2011, 01:55 PM   #44
bisonjr
Member#: 102714
Already been covered but I had to see for myself. I figured I had 50/50 chance from the beginning, lol.
07 WRX Wagon, they don't fit. Diameter is good, spline count, no go. My 07 has a higher spline count.
Is there any reason why I cannot swap 02-04 Wagon axles into 07 hubs?
bisonjr is offline   Reply With Quote
Old 04-06-2011, 06:52 AM   #45
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
This would be a nice alternative to sourcing Spec B axles. If this was available a earlier I wouldn't have to buy a set of STi hubs just to run R180.
I have to wonder how the strength compares though. I really have no idea, so I gotta ask...
Does anyone know if the outboard CV joints on the Spec B axles are the same as STI CVs, or WRX CVs, or are they unique? And of course what I'm really wondering is, how do they all stack up in terms of strength?
Or what about the axle shafts themselves? How do Spec B shafts compare to WRX or STI shafts?
I have a couple of R160 axles that I'm tempted to upgrade this way so I can use them as spares for my 6MT setup. But on the other hand I'm also wondering how much strength I'd be giving up (if any?), as compared to the Spec B axles I'm running now, or STI axles with the outboard ends swapped out to mate to my 5x100 hubs (the opposite of this thread, basically).
If anyone knows what's up, I'd love to hear about it.
Old 04-06-2011, 03:38 PM   #46
biggreen96
Member#: 12535
I'll be racing mine at the Olympus rally in a month so... If you can wait that long you should get a pretty definitive answer
But really these are just as strong as a normal r160 wrx spec axle with 6 balls in the outboard joint. I seem to remember reading the specB had a 6 ball outer too. You should pull yours out and get a true count.
Old 04-06-2011, 03:50 PM   #47
scoobie_snacks
Member#: 212744
2005 Ver8 EJ207 VF37
6 speed
Originally Posted by mowgli29 View Post
Maybe I'm taking your statement the wrong way, but it seems rather arrogant and bit ignorant. Take a second and think about it...
Personally, I wanted a halfway decent LSD in the rear, but I didn't want to have to run Brembos.
Yes, I realize a person could use the FHI rear 2 pots and group n "gravel rotors," but either way, that's added expense. Stock brake pads and rotors are WAY cheaper than Brembo stuff. In addition, you (generally) can't run smaller than a 17" wheel with Brembos, which = FAIL for those who rally. I know I have no desire to shell out the cash for 17" snow tires, either; my 16" blizzaks have plenty of life left.
Brembos also add weight, which is stupid if a person doesn't need/want the braking capabilities of the Brembos.
Lastly, I'm not concerned about the axles breaking. I don't drive hard enough to break them, at least not any time soon.
It's my DD; I want to keep maintenance costs low, keep it reliable, but have some fun with it too. Its all about compromises, and for some people, hybrid axles fit the bill.
Cool solution! could of used that last year but I'm pretty sure brembo's are lighter than 02-05 wrx calipers.
scoobie_snacks is offline   Reply With Quote
Old 04-21-2011, 10:19 AM   #48
Roel03
Member#: 127450
2007 WRX
Satin White
Which year of wrx axles did everyone use that worked. Which didnt work? I have an 07 wrx and need to know if I have to purchase other wrx axles or if mine will work.
Roel03 is offline   Reply With Quote
Old 04-28-2011, 04:59 PM   #49
mowgli29
Member#: 203438
Haha, thanks. And yeah, calipers might be... Rotors, fcuk no. The rotors are where Brembos gain weight compared to WRX brakes. Not to mention, its rotational weight, aka: more drivetrain loss. In my case, that weight is unjustified.
Old 04-29-2011, 10:18 PM   #50
grkimpreza
Member#: 281448
just wondering how much for those hybrid races
grkimpreza is offline   Reply With Quote
Hybrid axles Jpizzzle Transmission (AT/MT) & Driveline 7 02-22-2010 01:55 PM
"The Missing Link" Discovered in Germany? Jard Off-Topic 55 05-21-2009 04:21 AM
How did I miss "The Wire" for so long? Rice & Gravy Off-Topic 19 01-05-2007 06:56 PM
WTB:SOCAL: Hybrid Axles xplane Private 'Wanted' Classifieds 0 05-23-2006 12:25 PM
Do you miss "the monkey?" obyone General Community 6 11-15-2002 06:01 PM
