Old 04-01-2011, 03:01 PM   #26
Ken Cravillion
Member#: 123985
2002 GMC Yukon
'10 Forester XT DGM
Originally Posted by 04furesterXT View Post
Pretty sure he was talking about strut clearance in the front at stock offset. There's a ton of room in the rear.
Looking and feeling up my car at the front there's more room than in the back. According to the tire calc the diameter is about .4 inches less and a touch wider. I'll report back when I get this done.
Ken Cravillion is offline   Reply With Quote
Old 04-03-2011, 02:07 PM   #27
Noisyninja
Member#: 157624
2011 WRX Hatch
World Rally Blue
Now if only I could find something 18x9 between +40 and +48 in 5x100 that wasn't a Rota or $700 a wheel for a multi-piece in custom offsets and pcd. There doesn't seem to be many options for those who want to balance looks, performance, and practicality.
Still, thanks for the write-up and the info.
Noisyninja is offline   Reply With Quote
Old 04-03-2011, 05:22 PM   #28
ImprezivHokie
Member#: 256578
SSM - Agile Protuned
hoping for a +38ish 18x9.5 and a 265 on my 2011 sedan. Definitely not looking to pull and was hoping not to roll. Thanks for the write-up, I'll probably have questions as I get closer. Do your mentions of tire/wheel sizes requiring/not requiring rolling take into account stock or alternate camber settings?
ImprezivHokie is offline   Reply With Quote
Old 04-03-2011, 07:25 PM   #29
Mach V Dan
Member#: 12029
Stock camber settings.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 04-05-2011, 11:43 AM   #30
GUIL-BOT
Member#: 270940
2011 WRX Sedan
Great Information!
GUIL-BOT is offline   Reply With Quote
Old 04-07-2011, 08:48 PM   #31
Mach V Dan
Member#: 12029
Originally Posted by ksj1831 View Post
I am not shooting for the fullest wheel well out there and would really prefer the weight savings of the 17 over the extra inch of wheel diameter when going to 18s, so I am going to be considering 17x8 PF-01s*.
While we're on the subject, stay tuned in the next couple of months for a new 17x9 light weight wheel from us...
--Dan
Mach V
FastWRX.com
Old 04-07-2011, 09:42 PM   #32
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
17x9? and lightweight? cool..... not many out there in 5x100 pattern. if it's reasonably priced, might be interested.
Robin2 is offline   Reply With Quote
Old 04-08-2011, 01:50 PM   #33
bkruelle
Member#: 279027
Just in time to buy some wheels and tires!
Really do appreciate those on here that actually share their knowledge and expertise!
+1
bkruelle is offline   Reply With Quote
Old 04-08-2011, 02:12 PM   #34
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
--Dan
Mach V
FastWRX.com
Quoted for truth, Dan, put me on the list for these!
Old 04-08-2011, 04:02 PM   #35
Vossatron
Member#: 276634
2011 4dr WRX
SSM Whale Tail
sticky this thread
Vossatron is offline   Reply With Quote
Old 04-09-2011, 11:36 AM   #36
Cake
Member#: 262086
I've got a 2011 WRX sedan. Wanting to fit some wider 18's without performing any fender rolling.
Has anyone test fitted either of the following wheel and tire combinations on a 2011 WRX sedan?
Wheel: 18x8.5 +44mm
Tyre: 245/40/18
or
Wheel: 18x9.0 +43mm
Tyre: 245/40/18
Cake is offline   Reply With Quote
Old 04-09-2011, 12:29 PM   #37
sc00by4life
Member#: 97135
either one of those will be fine, though I might suggest a 245/35 or 255/35 instead.
Old 04-10-2011, 07:38 PM   #38
Mach V Dan
Member#: 12029
Originally Posted by sc00by4life View Post
...I might suggest a 245/35 or 255/35 instead.
Why the 245/35R18? The 245/40R18 is only 1.5% bigger than the stock WRX's 235/45R17, and we know it fits under the bodywork because that's the OEM STI tire. The 245/35R18 is 2.3% smaller than stock. That's beyond the usual 2% rule of thumb for tire size variance. The 255/35R18 is 1.2% smaller than stock, so it's a good match...
--Dan
Mach V
FastWRX.com
Old 04-19-2011, 06:13 PM   #39
SHIFTER55
Member#: 269010
sold
Default Width Size And Offset For 2011 Sti
Iam interested in the Enkei nto3 in 18 inch. What the preffered offset & wheel size? Dont want to roll fenders or wheels sticking out beyond fenders. Car will be lowered in future 15mm.
SHIFTER55 is offline   Reply With Quote
Old 04-19-2011, 11:05 PM   #40
jskrap
Member#: 253243
2011 Impreza WRX
I am getting some Enkei RPF1's 17x8 +45 offset for my 2011 WRX. Just using them with the stock tires. Do I need any other parts besides lugs to install these? I'm a total wheel noob, sorry.
jskrap is offline   Reply With Quote
Old 04-19-2011, 11:23 PM   #41
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
18x8.5 or 9 5x100 offset 38-45. Lower offset sticks out more.
smeerone is offline   Reply With Quote
Old 04-19-2011, 11:31 PM   #42
sc00by4life
Member#: 97135
--Dan
Mach V
FastWRX.com
5 speed gearing benefits from having a slightly shorter tire IMO, gives the car a more responsive feeling.
Old 04-20-2011, 09:26 AM   #43
MotorrBoatrr
Member#: 255312
2005 STi
World Rally Blue
I have a quick question for you Dan.
I have a 2011 Base WRX not lowered(yet)
I am looking at a wheel that is available in a 18x10 with a +16 to a +42, or a 19x9.5 with a +4 to a +42 offset.
I would like to say with a 18 just becasue tires are cheaper but will go with the 19 if thats the only one that will fit OK. I will roll the fenders if i need to.
MotorrBoatrr is offline   Reply With Quote
Old 04-20-2011, 09:47 AM   #44
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Depends on the tire motorrboat. Are you planning to run a tire that fits the rim, or are you going to put a small rubber band on it to ruin the handling and make you run -5 degrees of camber when you lower it.
Old 04-20-2011, 09:53 AM   #45
MotorrBoatrr
Member#: 255312
2005 STi
World Rally Blue
going to run a 265-275 tire. No i wont pull the camber way in just to make it fit.
There are other wheels i like that are a little narrower, just if im going to spend the $$$ i want to try and get my first choice in wheels.
Old 04-20-2011, 10:05 AM   #46
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Good to know. 265 is a lot of tire. should grip forever. But you will lose some steering feel.
Old 04-20-2011, 10:13 AM   #47
MotorrBoatrr
Member#: 255312
2005 STi
World Rally Blue
Shouldnt be to bad. I like a lot of tire. My old Trans Am had 275's up front and 315's in the rear.
Old 04-20-2011, 10:50 AM   #48
Mach V Dan
Member#: 12029
I see no question here...
If you are asking what size and offset to choose, either 18" or 19" can work. As I have mentioned previously in this thread, I would stay with a +40 or greater offset. +42 should work great on the 9.5" wide wheel. On the 10" I'd probably do +40 -- we have not tried fitting a 10" wheel yet, so watch your inboard clearance.
If you go with a 19" wheel you'll need a thinner profile tire -- so a 265/30R19 instead of a 265/35R18.
--Dan
Mach V
FastWRX.com
Old 04-20-2011, 12:26 PM   #49
jskrap
Member#: 253243
2011 Impreza WRX
Anyone know? Rings, spacers, anything like that? Or just a straight swap with the stock wheels?
Old 04-20-2011, 03:28 PM   #50
DrDanimalSize
Member#: 254097
2010 2014 Impreza
^ centering rings, tuner lug nuts. should bolt right on, no problemo
DrDanimalSize is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
