Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 04-08-2011, 02:03 AM   #26
Bo0stin5STI
Member#: 162174
05 CGM STi - SOLD
13 SWP STi - TITS
Bo0stin5STI is offline   Reply With Quote
Old 04-08-2011, 02:10 AM   #27
monsta121
Member#: 261534
Originally Posted by Bo0stin5STI View Post
The oven temperature is really low around 150*. They only stay in long enough for the adhesive to become soft. About 10 to 15 minutes. I always do mine in the center and put it right on the rack. Just do one at a time. Slowly. search around the DIY's and you should find something.
Awesome! Thanks for the DIY links. Fat Black Pig Sac put it on a plate and you said you put it right on the rack. Any difference or is that just a personal preference?
Originally Posted by Fat Black Pig Sac View Post
No it won't. Make sure you set your oven to "bake" (heat coming from lower part), not broil.
I usually bake for 15min at 230-240 degrees
Ohh I always wondered what the difference between bake and broil was lol. Thanks.
monsta121 is offline   Reply With Quote
Old 04-08-2011, 02:17 AM   #28
monsta121
Member#: 261534
Another question, when you put the light back in the oven to re-heat the sealant. Is it ok to have the painted reflector in there with it or will the new paint start to melt?
Old 04-08-2011, 03:14 AM   #29
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
if the paint is OK to touch, it's ok to put the lights back in the oven. It won't melt, I think it will even cure the paint. Just guessing. I never had problems with painting and then putting the whole light into the oven 40 min after the painting.
Of course it's better to wait overnight for paint to cure
Fat Black Pig Sac is online now   Reply With Quote
Old 04-08-2011, 03:23 AM   #30
monsta121
Member#: 261534
Okay cool, thanks. BTW you car looks superrr clean in white
Old 04-08-2011, 12:42 PM   #31
Suby WRX
Member#: 264417
The paint won't cure in 10min. If you want to cure it put it at about 200degrees for 30-40min opened up. this is not necessary though if your lights are sealed. And if you paint without scuffing or priming make sure you do very light coats or it will run super easy since the surface is almost like glass your painting.
Suby WRX is offline   Reply With Quote
Old 04-08-2011, 12:49 PM   #32
Bo0stin5STI
Member#: 162174
05 CGM STi - SOLD
13 SWP STi - TITS
My oven temperatures are really low compared to Fat Black Pig Sac's, that's why I put mine on the rack. If you think about it, anything you put in the oven (cookie sheet, plate, etc..) will heat up just the same. I've never had problems on the rack.
Old 04-08-2011, 12:54 PM   #33
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
I want to do this to my blobeye's, however I also want to install HID projectors and run HIDs. Any pointers?
Also what wheels are those on the OP. Look like Rota G-Force, I'm just curious because I'm getting Rota G-Force in gold in a few weeks and like how your wheels look.
subaru_steve is offline   Reply With Quote
Old 04-08-2011, 12:56 PM   #34
Suby WRX
Member#: 264417
Read through the DIY threads posted earlier and when your ready to buy talk to the guys at theretrofitsource.com. awesome customer service and good prices.
Old 04-08-2011, 01:01 PM   #35
dazedone
Member#: 173938
06 sti
matte black
Just for information, it works much better to separate the headlight housing with a heat gun. because heat can be added were needed to separate the sealant and one can heat only were the sealant is to avoid damage to any other part of the housing (especially the clear piece because when heated to much will turn a yellowish color.) then went resealing the heat gun works in the same way, just reverse of disassembly.
I disagree with not scuffing the surface. Any time paint is used the surface underneath should be rough to a degree. without it being scuffed the chances of the paint chipping and/or flaking is much grater. (abrasion is not necessary to create chipping or flaking because of the constant heating and cooling the headlight goes through.)
dazedone is offline   Reply With Quote
Old 04-08-2011, 01:07 PM   #36
Suby WRX
Member#: 264417
ive had mine opened twice now in the oven method and the housings are still as clear as the day i bought it. yes a heat gun works too but requires a person to heat, and a person to separate. the oven method i did by myself twice now. if your careful about not touching the light to anything its not supposed to touch you wont harm it. not saying you should bake your lights 50times, but a few times wont hurt them.
Old 04-08-2011, 01:08 PM   #37
mixed244
Member#: 275086
they look really nice
mixed244 is offline   Reply With Quote
Old 04-08-2011, 01:24 PM   #38
dazedone
Member#: 173938
06 sti
matte black
Iv Done it both ways by myself, more then once, and trust me a heat gun works much better and is much safer! also, think of all the contaminants in the oven from cooking food in there. just another way something could go wrong. that with a heat gun is a not an issue. There are many other reasons why a heat gun is better, but just trust me when I say USE A HEAT GUN.
Old 04-08-2011, 08:04 PM   #39
abehanna
Member#: 249152
2012 ForesterTouring
Super Silver
I ended up wet sanding with 600 and spraying adhesion promoter first then black trim paint... came out smooth as glass and no worries about flaking / cracking i figure i might as well do it the right way the first time around!
abehanna is offline   Reply With Quote
Old 04-09-2011, 03:11 AM   #40
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
Yes, those are Rota G-Force gold 18x8.5. If I was you, I'd get 18x9. They look way more aggressive than 8.5s!
Old 04-09-2011, 08:02 AM   #41
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
not to thread jack but...what wheels are these? I have a set sitting at my house from a customer but I can't find any details on them.
btw those headlights turned out amazing! Great job!
King of Poop is offline   Reply With Quote
Old 04-09-2011, 08:13 AM   #42
Murat
Member#: 251074
2004 WRX
WORK VS-XX ^
I might be wrong tho
Murat is offline   Reply With Quote
Old 04-09-2011, 08:31 AM   #43
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
^omg I hope not. These are curbed like a mother. ugh.
also I don't think mine have the rivets. It doesn't look like those do either.
Old 04-14-2011, 02:19 AM   #44
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
Murat - great job!
Those rims are WORK VS-XX
Very heavy 2 piece rims
Old 04-15-2011, 02:41 PM   #45
keegancdr
Member#: 226355
2002 Bugeye
wrb
did mine last night on my bugeye, first one went smooth, second one i threw in the oven, but when i took it out realized i forgot the two little screws, i got a video, of it, but ill post the whole thing when my full retro kit is built
keegancdr is offline   Reply With Quote
Old 04-24-2011, 04:26 AM   #46
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
... and one more set I've done just now
Old 04-24-2011, 10:56 AM   #47
b5rks
Member#: 280634
15 STi
ISM
Love the look of painted headlights!
b5rks is offline   Reply With Quote
Old 04-24-2011, 11:22 AM   #48
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
The other other white meat
Black bezels & cleared lenses, look brand new
Strobe Media is offline   Reply With Quote
Old 04-24-2011, 12:17 PM   #49
stillatoy
Member#: 276391
2004 WRX
java black pearl
stillatoy is offline   Reply With Quote
Old 04-24-2011, 11:23 PM   #50
Rapier46
Member#: 277987
So, you bake the light to get it apart? Then you paint it. Then attach it back together again?
Or if that's not correct...what is the process?
Rapier46 is offline   Reply With Quote
Baking headlights devil13 Tri-State Area Forum 10 10-13-2013 02:11 PM
Clearing/baking headlights for others sc00ter Interior & Exterior Modification 9 04-30-2008 12:19 AM
baking headlights (evo) question PSMWRX03 Interior & Exterior Modification 6 03-06-2008 12:48 AM
baking headlights...HELP! PSMWRX03 Interior & Exterior Modification 10 01-09-2008 09:09 PM
baked headlights and gasket came loose... mindchatter Interior & Exterior Modification 1 04-20-2006 04:43 PM
