Old 01-12-2011, 04:58 PM   #26
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Originally Posted by Jovver View Post
I bought and installed hellas on my '06 STi just before Christmas. I too bought a wiring harness and because of the short leads from the relay, mounted it in the same location that you did using double sided tape. Everything was great until it snowed and the roads were salted. FOR ALL OF THOSE WHO REGULARLY DRIVE WITH HELLAS IN SNOWY, ROAD SALTED AREAS, THIS SETUP WILL NOT FLY. It took less than 2 weeks for my relay to thoroughly corrode (connection prongs and internals) and the relay failed. I bought a new relay and a buddy of mine helped me take out the harness, cut it apart, and rewire a new one so that the relay is mounted in the engine bay behind the fuse box. Luckily the harness was not a complete waste of money because most of the wiring was salvageable. Hopefully the new relay will not corrode in that location. Just a heads up for all those installing hellas in snowy areas. Btw, your car looks great and enjoy the horns!
Can you take a picture of where you mounted it? I am thinking about moving my relay to reduce the wear and tear on it.
xabre1200 is offline   Reply With Quote
Old 01-12-2011, 08:24 PM   #27
Ginsubie
Member#: 267554
2011 WRX 4-Door
This is why I first bubble-wrapped the relay/harness assembly before installing it (not that I have to worry about too much weather here in SoCal).
Ginsubie is offline   Reply With Quote
Old 01-13-2011, 07:42 PM   #28
Jovver
Member#: 107076
'06 WRX STi (WRB)
'06 Outback 2.5 (WGO/MGM)
Pics as requested!
There are two threaded holes on the sheet metal which is the strut tower that were plugged up with plastic inserts. I removed the bottom insert and used that threaded hole to mount the relay. You can easily see the power and ground leads to the battery. (much closer and efficient now)
Close up of the relay:
And the routing of the horn signal wire and power to the horns through the engine bay and through the spacing between the headlight and grill area:
Final product (pic taken at an earlier date with lack of salt):
I simply grounded the 2 with an wire ring terminal to a ground point behind the hella mounting bracket. End thread hijack.
Jovver is offline   Reply With Quote
Old 01-13-2011, 08:22 PM   #29
Nismonic
Member#: 162500
2011 LR WRX
^^^^ I can draw up a schematic for the wire harness that Jovver and I made if anyone wants to relocate their relay to that spot in the engine bay.
Nismonic is offline   Reply With Quote
Old 01-13-2011, 09:03 PM   #30
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Hmm that is a good idea. I'm going to have to remove my horns soon because I'm having trouble w/ my power window going up and down so I'll have to remove my horns before taking it into the dealer. Good chance to clean up my wiring and relocate the relay.
Old 01-13-2011, 11:17 PM   #31
Nismonic
Member#: 162500
2011 LR WRX
Ok so here is a real quick diagram I drew up... Please excuse my drawing skills, I'm and engineer, not an artist. EDIT: I redrew the diagram to make it neater. Also, USE THIS DIAGRAM AT YOUR OWN RISK... I'M NOT RESPOSIBLE FOR ANY DAMAGE TO YOUR CAR/WARRANTY/ HOUSE/PETS/EAR DRUMS ETC.
Note - In Jovver's install we did not put a fuse in the power wire... we really should have. The Subimods harness doesn't have one ether . Please include one in your install. All my connections were soldered and covered in heat shrink. Good crimp connections would probably be fine too.
I took a look at my 2011 and you won't be able to mount the relay in the same spot as Jovver since our fuse box is pushed right up against the shock tower. There are a few open tapped holes near the battery in the engine bay that might work for a relay though.
This one is tucked under the fuel lines and is pretty hard to access but there are 2 open holes here and someone with small enough hands might be able to hide the horn relay back there. That would probably be my last choice for a relay location.
There are 2 holes on the frame rail in front of the battery that work great and keep overall harness length down.
and a close up
I could see putting a relay here if it doesn't see much exposure to the elements. My car has 50 miles on it so I can't tell yet if this area will get dirty through driving.
Finally, the easiest thing would be to double stick tape it to the outside of the battery box... Tons of room and easy access.
Old 01-14-2011, 04:29 AM   #32
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
WOW thanks for that drawing. Great work!!!
Old 01-14-2011, 04:02 PM   #33
Ginsubie
Member#: 267554
2011 WRX 4-Door
For those who are looking for options where to put the relay using the original harness, this is where I put mine:
I used the thin metal brackets that came with the Supertones to bolt the relay onto the center chassis pillar along with the bracket that holds the horns. It obviously doesn't protect the relay from the elements as well as putting it far inside the engine bay, but if you live in an area that doesn't have too much weather (like me in SoCal), it'll serve.
Old 01-14-2011, 04:06 PM   #34
island boyeee
Member#: 171758
2006 WRX Ltd Stg m@!
Blk&Grn / 08 Daytona 675
Originally Posted by amp0412 View Post
Lol at buying a harness because the stock voltage to the horns is 12v's so there is no need to install the relay. Just ground the horns and extend the stock horn wire to the hellas.
you obviously do not understand the point of the relay. please don't speak about electronics again until you have AT LEAST a basic understanding.
island boyeee is offline   Reply With Quote
Old 01-14-2011, 04:12 PM   #35
Nsj77h
Member#: 65856
2000 S4 Black
1992 Miata Red
Looks great!
Nsj77h is offline   Reply With Quote
Old 01-14-2011, 11:02 PM   #36
06 Hawkeye STi
Member#: 270154
2006 Impreza WRX STi
Looks really good man, can't wait to get mine!!
06 Hawkeye STi is offline   Reply With Quote
Old 01-25-2011, 12:59 PM   #37
STIgurl73
Member#: 266506
2011 STi
PBP - Plasma Blue Pearl
I'm guessing this is the same thing just in a package deal? Am I correct?
http://www.subimods.com/product_info...{36}335{38}334
STIgurl73 is offline   Reply With Quote
Old 01-25-2011, 03:58 PM   #38
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
http://www.subimods.com/product_info.php?products_id=1773{8}345{37}339{36} 335{38}334
correct. thats what i bought.
Old 01-25-2011, 06:39 PM   #39
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
you loose almost 2 volts by the time it gets to the horns, so yea, it will be louder with a relay setup.
PARANOID56 is offline   Reply With Quote
Old 02-21-2011, 10:05 PM   #40
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
Originally Posted by my name is chump View Post
bought mine new for 43 shipped... theres a thread on how to get it for cheap somewhere.
and at people who paid for the harness.
Sorry you're too poor to afford this. Must suck.
JimmyOOOOO is offline   Reply With Quote
Old 04-09-2011, 09:31 PM   #41
Omutax
Member#: 243663
2011 WRX Sedan
I wanted to bring this thread up again as I tried to install my supertones without removing the bumper like OP did.
Maybe my arms are too thick or hands too fat, but I found it 100x more difficult to try this method versus taking off the bumper. Even wioth the Subimods bracket and harness, I found it impossible to fit it on without taking out the OEM meep-meep horn which itself was impossible for me to take off without removing the bumper first.
I personally suggest everyone save themselves the trouble of using OP's method and instead just use the iwsti how-to-guide on removing the bumper and do the supertone install with the open space. Also it allowed me to much more safely ziptie the harnesses where I can see clearly where it won't freely dangle and come loose in the elements. Removing and reinstalling the bumper was quite easy, much easier than trying to do everything through the lower air-dam.
Omutax is offline   Reply With Quote
Old 04-09-2011, 09:56 PM   #42
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah it's a little tricky to do. I just didn't want to take my entire bumper off. Can you link us to the bumper removal guide?
Old 04-09-2011, 10:05 PM   #43
Omutax
Member#: 243663
2011 WRX Sedan
I know what you mean man, I REALLY didn't want to take it off. That's why after searching I found your thread and thought it'd be a piece of cake.
Unfortunately for me, and I speak for myself only, it was just way too difficult with it on.
I used this guide:
http://www.iwsti.com/forums/how-inst...r-removal.html
- and looked at it on my smartphone as I was taking off the pieces. Thankfully everything was snap off and snap on, and was much more intimidating sounding and looking than it really was.
What'd I'd be curious to know is how you managed to take off the OEM horn? That Submiods bracket did not fit under the latch where the bolt goes in without taking that little bastard off.
Old 04-09-2011, 10:14 PM   #44
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Oh cool awesome. That will come in hand. Yeah I had to take off the oem horn before I could put on the bracket. That was a little challenging.
Old 04-09-2011, 10:35 PM   #45
ammodawg79
Member#: 267366
2012 Sportage SX
Black Cherry
Can't say I understand all the fuss regarding these horns. Do you guys all really use your horns that much?
ammodawg79 is offline   Reply With Quote
Old 04-10-2011, 05:22 AM   #46
Omutax
Member#: 243663
2011 WRX Sedan
A day of driving in Southern California? Yeah it's quite necessary. Not to spite the other driver, but to honestly prevent a catastrophe that will protect both me and the other driver as well as saving both of our wallets.
SoCal is filled with very absent minded drivers, just from the sheer number of drivers that are here. You're just statistically bound to come across a moron one way or another.
To be fair, I can't say I'm 100% innocent from making mistakes either. A preemptive warning honk to me has humbly saved me from being in a minor accident here and there as well.
Old 04-20-2011, 01:36 PM   #47
JimmyOOOOO
Member#: 12647
2011 STi
After driving with these for a while, I wish they had a version with a lower pitch
Old 04-20-2011, 01:47 PM   #48
kenmaru
Member#: 209682
2009 WRX STi
thanks for the diagram pics !!
kenmaru is offline   Reply With Quote
Old 05-22-2011, 04:22 PM   #49
lovin' it
Member#: 236710
2010 WRX Five Door
WRB!
Thanks for posting this!
lovin' it is offline   Reply With Quote
Old 05-28-2011, 01:10 PM   #50
Akamu142
Member#: 267808
Just put mine on this morning. I fabricated a bracket similar to the subimods to keep the even spacing and used the harness. I wish they had built the harness closer to the battery connection as I don't like having the relay so open to the elements. I did wrap the relay in a plastic bag and seal it up in hopes water will not get to it. I also recommend some electrical grease on all connections. Also went with the bumper removal from Iwsti and recommend it. Easy and loads of access. I did notice on my 2011 there is not a baffle on the CAI like there was on the IWSti bumper removal guide. It took me a bit longer than planned but happy with the result. Great help from the online posts. Thanks.
Akamu142 is offline   Reply With Quote
Some a** smashed in the fender on my '11 WRX :( Vrenlos Tri-State Area Forum 6 01-14-2011 04:05 PM
Will installing Hella Supertones void any part of my warranty on my '11 WRX? xabre1200 Interior & Exterior Modification 10 12-20-2010 06:31 PM
Where do you mount Hella Supertones on an 07 WRX?? Zerro0713 Newbies & FAQs 13 01-04-2010 09:10 PM
17x8.5 +32 offset on my '05 wrx without rubbing? tbcboo Tire & Wheel 13 11-10-2009 12:37 PM
Hella Supertones on a 2008 WRX CALBANO1833 Interior & Exterior Modification 1 10-09-2009 08:04 PM
