Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 03-06-2011, 05:36 PM   #1
HARRIMONSTER
Member#: 240715
Question WRX RWD conversion
Does anyone now if you can make a WRX RWD by just taking the front axles out? or do you need to take apart the transmision?
HARRIMONSTER is offline   Reply With Quote
Old 03-06-2011, 05:48 PM   #2
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Yep you need to weld the center diff.
Punk In Drublic is offline   Reply With Quote
Old 03-06-2011, 05:50 PM   #3
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
The most you need to do is repalce the center diff with a RWD conversion spool. You can modify a stock center diff to make it RWD or purchase the conversion spool. If you removed the front axles the center diff would put most of the power where there is no load (the front axles). Not to mention that there would be nothing to hold the front wheel bearings together.
KONKILR is offline   Reply With Quote
Old 03-09-2011, 12:24 AM   #4
HARRIMONSTER
Member#: 240715
alright cool thanks!!!
Old 04-18-2011, 11:05 PM   #5
bill hincher
Member#: 280288
you can run a toyota transmission to the subaru engine in either 2wd or 4wd
bill hincher is offline   Reply With Quote
Old 04-19-2011, 01:21 PM   #6
KONKILR
Member#: 3190
2004 Impreza TS and
Care to elaborate? What is this out of? A truck? Are the input splines the same?
jake
Old 04-19-2011, 02:15 PM   #7
bill hincher
Member#: 280288
the two series of transmissions that are used are either the Toyota 'W' series trans ( from w 55 to 59 2wheel drive or 4 wheel drive)
OR the 'R' series Toyota transmission ( either the R 150 or the R 151 from the V-6 Toyota truck in either 4wheel drive OR 2wheel drive)
depending on how they are ordered is how they are machined
The R 154 was avoided because the trans is getting harder to find and more expensive, so these two common transmissions were chosen, the R 154 input shaft is 3/4 inch longer and can be used in the R design bellhousing if needed
these are designed to use all the stock Subaru components over with nothing more then adding a stock toyota clutch disc
Old 04-19-2011, 03:06 PM   #8
KONKILR
Member#: 3190
2004 Impreza TS and
So this is a bellhousing adapter you make?
jake
Old 04-19-2011, 03:10 PM   #9
bill hincher
Member#: 280288
yeah, a guy in Portland Oregon asked me about and we built a couple just to see how it all worked out
Old 04-20-2011, 12:17 PM   #10
bill hincher
Member#: 280288
Old 04-20-2011, 02:31 PM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
awesome!! I was just thinking about casting a bellhousing adapter in a similar manner for a mid-engine, subie powered project.
Very cool!!!
Old 04-20-2011, 03:39 PM   #12
bill hincher
Member#: 280288
Very cool!!!
take a look at the Formula Ford open wheel cars and see a very cool layout for the mid engine set up
i get my castings done at the proto type shop for the major car companies in Detriot ( or whats left of the big 3) I can help you with the castings and the hardening treatment on aything you want
Old 04-20-2011, 03:42 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
I'm familiar with Formula Fords as they use to always get pissed when we'd wipe them up at autox's with our Formula SAE car (as it should be).
I might have to shoot you an email for casting contacts
Old 04-20-2011, 11:59 PM   #14
bill hincher
Member#: 280288
Old 04-24-2011, 11:56 AM   #15
bill hincher
Member#: 280288
Old 04-24-2011, 01:11 PM   #16
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Woah, I think I saw the post on this at dirtyimpreza (or maybe it was another forum)... nice work!
Would this require a custom driveshaft?
What rear diff would you use? R200?
Does the shifter line up right?
Also, pardon my n00bness, you mentioned 4wd tranny. Would that even work with the subie? or would you use it in a 2wd configuration?
BeBop86 is offline   Reply With Quote
Old 04-24-2011, 01:36 PM   #17
bill hincher
Member#: 280288
yeah, it uses either the Toyota R 151 or R 150 4wd or the Toyota W 55 through 59 2wd or 4 wd
Old 04-26-2011, 12:05 AM   #18
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Every time I see those pictures I remember how badass that is. Very good work man.
~Josh~
ballitch is offline   Reply With Quote
Old 04-26-2011, 12:05 PM   #19
bill hincher
Member#: 280288
~Josh~
I was just show'en off Josh >;o)
Old 04-28-2011, 12:25 AM   #20
gf8ftw
Member#: 273917
1993 Swaped waggy
very cool. how much do these bell housings go for?
gf8ftw is offline   Reply With Quote
Old 04-28-2011, 01:36 AM   #21
bill hincher
Member#: 280288
I think I may have to register as a vendor so I dont violate and rules here before I sell any of these.
I have built many different designs for many custom bellhousings and I am under a lot of heat to build some more of these Subaru set up, so I will be building a batch in the next month
Just bump me in about a week
Old 05-06-2011, 04:16 PM   #22
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^^^^^^^^^^^bump^^^^^^^^^^^^^^^^
Paidfor is offline   Reply With Quote
Old 05-19-2011, 06:21 PM   #23
bill hincher
Member#: 280288
Its all good, I spent some time building a work holder for this type of work for sanding and welding
these are the 3 sizes, the one on the far right is the first pattern, it was built at 3% larger scale and roughed in the shape, the middle one is the first real casting and then adjustments were made to the weight and shape for casting drafts and expected shrinkage, then the final pattern is built on the left, it is the result of all the other work
This is the final pattern, its built with no primer or body filler , its all aluminum so adjustments can be done after testing the first castings in the brigeport
Old 08-25-2011, 10:22 PM   #24
racer555
Member#: 98895
2013 Frs
Raven black
Finally someone is makin a bellhousing to swap in my spare w58 trans? Say it isn't so? Wait lemme go look outside............. nope no cats & dogs rainin down........ Is this for real? How do I get one cause at this point I am desperate. Can't afford to keep fixin the stock'ish 5spd in the bugeye but I can get w58's super cheap all day long. So if this for real lemme know. I need to get my car back on the track, startin to get the shakes
racer555 is offline   Reply With Quote
Old 08-25-2011, 10:57 PM   #25
bill hincher
Member#: 280288
yes Eric, it is all true, I have 3 on hand, I am sorry I been hiding but I am stone cold focused on the C-4 Ford auto trans to a 6G72 Mitsubish V-6 housing I am building right now, so I have been away from the subaru site, please feel free to E mail me
[email protected]
FS: RWD conversion center diff for 5MT WRX Crazykev Drivetrain 23 05-04-2016 10:00 PM
WRX RWD conversion spool nismo502 Drivetrain 0 11-30-2007 07:58 AM
FS: RWD Conversion for WRX/2.5RS (bc, will ship) steve VIC Private Classifieds 32 10-23-2006 09:09 PM
FS: RWD conversion center diff for 5MT WRX Crazykev Private 'For Sale' Classifieds 45 07-19-2006 09:40 PM
FS: RWD conversion for WRX, done right! Crazykev Private 'For Sale' Classifieds 15 02-09-2006 11:05 PM
