Old 04-14-2011, 06:13 PM   #1
patricksmith04
Member#: 116816
Default 2011 WRX Blinker Issue: Fix
As many who have gotten the 2011 Subaru WRX, you've probably experienced the dreaded "fast blinker" on the front right headlamp. There has been a lot of speculation on what it could be, from: bad bulb, loose bulb, bad wiring harness, short wires, pinched wires, etc.
I've searched high and low on the Internet for a fix. Is it a major issue? No. Annoying for a new car? Yes. I could take it to a dealer since it's new and under warranty still. But when I asked my local dealer about it, they seemed clueless.
So before heading to another dealer further away, I thought I'd inspect it myself. I did have another member send me what they did, but when I tore out my air box, my car was nowhere close to what he described (which seems really, really odd).
Anyways, here is what I did. It's currently fixed, and has lasted all day. If it comes back, I'll go to a dealer. But it took me all of 10 minutes with limited tools and seems like it could help, which I've found, was pinched wires and tension.
Tools Needed: Flathead screw driver, socket wrench, long extension, 10mm socket
Step 1: Remove air box scoop. Really easy, just untwist the two plastic screws and pop them out. While you're at it, remove the wired connection from the air box and also untighten the hose clamp on the air hose.
Step 2: Using long extension, unscrew on of two bolts holding down the air box
(Here is a picture of what you need to unscrew)
Step 3: Pull off the rear of the air box and filter (Just use a strong pull, as it's a tight fit).
Step 4: Once all you have is the front of the air box, look inside, and again with the extension, take last nut off from the inside. Then pull out rest of the box.
Step 5:
This is what you should see after you detach the blinker bulb from the back of the headlight. I've made the wire read so you can see it clearer. My wire was obviously pinched and didn't have enough slack (where the wire goes through the metal opening)
Step 6:
Run hand with the wire and unclip/unhold (not really clipped, just holding) it from the plastic clips on the headlight.
Step 7:
You should have a lot more slack and see that where the wires were pinched, it's not so much anymore.
Step 8: Put back in air box and check blinker.
Conclusion, the correct fix would be to re-run the wire without it going through that opening, but it's impossible to pass the blinker bulb housing through the metal opening where the wire runs. I hope this quick fix lasts.
Good Luck!
patricksmith04 is offline   Reply With Quote
Old 04-14-2011, 06:18 PM   #2
O.C.D.
Member#: 19640
2005 RBP LGT 5T WAG
Cryotuned Stage 1
Sweet, pics always make it easier. I am sure when mine has this issue (which I bet it will) I will refer to your post.
Thanks!!!!
O.C.D. is offline   Reply With Quote
Old 04-14-2011, 08:35 PM   #3
mrkyle3
Member#: 272675
2011 WRX hatch
I have described how to fix it multiple times on here and this is EXACTLY how I fixed it. Great pictures! The way the wire was routed through those clips put too much tension in the wire so I just unhooked it from the clips and that loosened it right up.
I can vouch for it working, I fixed it about 600 miles ago and it's still working great
By the way, a suggestion when doing this is to put your hazards on. That way you can constantly see how your turn signal is working as you are working on it. When I loosened the slack it didn't fix it at first, I also had to physically push the wires back into the bulb harness and then the bulb lit right back up to normal brightness
Old 04-15-2011, 12:40 AM   #4
walkercart
Member#: 227991
2011 STI HB
this problem arose on my sti after 200miles. i was dumbfounded until i was able to get to a computer and do a search. Once i understood the culprit was a tight wire, it was an easy fix. Unlike most folks i did not move the entire airbox. All i did was loosen the front nut to the airbox. My hands were small enough to squeeze through to unplug the turn signal. I gave it a few tugs to get some slack. BOOM no more turn signal problems 1000miles later.
walkercart is offline   Reply With Quote
Old 04-15-2011, 01:00 AM   #5
2011WRXOBP
Member#: 268088
2011 WRX Sedan
Thumbs up
Good job bro, I didn't know it was such a common problem, but yeah I took mine to the dealer...took them over an hour, well done.
2011WRXOBP is offline   Reply With Quote
Old 04-15-2011, 01:02 AM   #6
snkp360
Member#: 276780
2011 WRX 4DR
Obsidian Black Pearl
I had the same thing roughly 1 week after buying my brand new 2011 WRX.
Just took my car into my local dealer to fix and it hasn't happened again. They told me it was a burned out bulb, but I am not sure how much I believe as I couldn't see any burned out....
I was more annoyed than anything else that my brand spanking new car was doing this, I could care less about a burned out bulb lol
snkp360 is offline   Reply With Quote
Old 04-15-2011, 08:25 AM   #7
mrkyle3
Member#: 272675
2011 WRX hatch
It probably wasn't a burned out bulb. They probably just figured they'd try replacing the bulb and in the process of replacing it they made a better connection to the bulb so it ended up working.
Unless they changed the wiring there is a possibility that it could come back but it's nothing to worry about because if it does now you know how to fix it
Old 04-15-2011, 10:20 AM   #8
patricksmith04
Member#: 116816
Thanks for your PM. It helped, but as I described, my wires weren't held by any metal clips, just plastic clips you could easily see.
Nonetheless, glad you could help me out! Thanks again.
Old 04-15-2011, 11:24 AM   #9
mrkyle3
Member#: 272675
2011 WRX hatch
I was wearing gloves so it could be I mistook the plastic clips as being metal (I did all of it based on feel), sorry if my mistake confused you but I'm glad to see you got it all worked out
Old 04-15-2011, 12:45 PM   #10
hieu1004
Member#: 240385
E92 BMW M3
Mine did this awhile back and this method worked for me too.
hieu1004 is offline   Reply With Quote
Old 04-26-2011, 06:38 PM   #11
toolie
Member#: 273955
2011 WRX Prem. Hatch
My WRX is two weeks old and I have the same issue with my front right blinker. I've taken off the air scoop and reached in based on your photos but the wire in question doesn't seem tight. The bulb is definitely dim though so something is up.
I don't have enough daylight to get into the filter today, but maybe this weekend. Or maybe I'll take it to the dealer and let them tear it all out. I'm paying for a warranty after all.
toolie is offline   Reply With Quote
Old 04-26-2011, 09:13 PM   #12
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Mines the front left blinker...I'll look at it tomorrow.
AndrewtechAutomotive is offline   Reply With Quote
Old 04-26-2011, 09:50 PM   #13
mrkyle3
Member#: 272675
2011 WRX hatch
Turn on your hazards and play around with the wire and watch for when the bulb lights back up to its normal brightness.
My turn signal issue came back the other day even after I fixed the wiring issue. It had been around 600 miles since I fixed it. I took the airbox out and pushed the wires back into the harness and haven't had it come back yet. It's a pretty annoying issue.
Old 04-26-2011, 09:53 PM   #14
Maudlin
Member#: 206124
2011 WRX 4-door
Satin Pearl White
Thank you for this.
Maudlin is offline   Reply With Quote
Old 04-27-2011, 10:26 AM   #15
SamuraiLincoln
Member#: 274670
2011 WRX Premium
Cool, good to know & thanks for taking the time to do this.
I had my driver side burnout at 600 miles & replaced both with some long life bulbs. I didn't notice that the wire was taught but I'll have to take it back apart and see if I have this issue.
Thanks again.
SamuraiLincoln is offline   Reply With Quote
Old 04-27-2011, 10:57 AM   #16
buki_JB
Member#: 274345
2011 STI 5dr
This just happened to my 2011 STI after 800 or so miles...I just brought it into the dealer, they re-routed the harness, and I had them hand wash it while they were at it.
Not sure why you guys are bothering to mess with it yourselves...why not just use the warranty? It's a brand new car.
buki_JB is offline   Reply With Quote
Old 04-27-2011, 11:27 AM   #17
toolie
Member#: 273955
Took the car to my dealer this morning. The tech popped everthing out and had it back in action in 15 minutes. He was aware of this issue on the Impreza and his opinion is that the culprit is more likely the socket than a tight wire. Like I said, my wire was not pinched when I was rooting around in there last night. He told me they would replace the socket if it happened again.
Old 04-27-2011, 11:49 AM   #18
mrkyle3
Member#: 272675
2011 WRX hatch
I brought it to the dealer and they had no idea how to fix it.
Old 04-27-2011, 11:53 AM   #19
buki_JB
Member#: 274345
2011 STI 5dr
That's simply unacceptable. I would have called SOA and told them to make sure that dealership gets their junk together.
My fear would be that if I routed the wire myself and it catches on something or causes a bigger issue, they could put the blame on me. I don't like taking those kinds of risks, especially when the dealership is 100% responsible for taking care of issues like this.
Old 04-27-2011, 12:09 PM   #20
toolie
Member#: 273955
I like to tinker. So there's that, but also it's just a stupid bulb. It shouldn't require burning office hours and gas with a trip to the dealer to get fixed, especially if it's going to happen every two weeks. It is quite a bit more difficult to get at the back of these headlights than any other car I've ever owned though. Now that I've watched them disassemble the airbox I should be able to bang it out quickly if I ever need to again.
mrkyle3, sorry to hear about your incompetent dealer. This shouldn't be over their heads in the slightest. It's just a light bulb. My guy pulled the bulb out of the socket and blew in it and put it back in. Problem solved (for now). The bulb didn't look terribly snug, at least not compared to bulbs I've replaced in the past in different cars. Again why I think it's a socket issue and not a wiring one. If I ever have to open it up again myself I'll look into a way to tighten up that connection between the bulb and socket.
Old 05-02-2011, 02:28 PM   #21
patricksmith04
Member#: 116816
Just to update, since my posting to fix this, I have NOT had the problem since.
THIS IS NOT A BULB ISSUE.
Old 05-23-2011, 03:54 PM   #22
nonoywrx
Member#: 274337
2011 WRX 5D Limited
It happen to me yesterday. After reading your posts, I tried just to push the harness and straighten the wires (it was bent, maybe pulling the harness) for now and it work. I don't know how long will it last though.
nonoywrx is offline   Reply With Quote
Old 05-23-2011, 04:10 PM   #23
litany
Member#: 272319
My right blinker went out too a few weeks ago. Took it to the dealer and they handled it under warranty. They said it was the bulb but they also said they were "looking to see if it [was] shorting" on anything. Who knows what really fixed it but I haven't had a problem since.
litany is offline   Reply With Quote
Old 05-25-2011, 04:00 AM   #24
nonoywrx
Member#: 274337
2011 WRX 5D Limited
Well it didn't last long enough. Called the dealer and dropping it off tomorrow.
Old 05-25-2011, 09:27 AM   #25
patricksmith04
Member#: 116816
I'm still blinker issue free after my fix in April.
Just picked up 2011 WRX..will dealer fix rattles? mesarec Newbies & FAQs 33 01-04-2012 01:14 AM
2011 WRX with upgraded suspension that I can check out? boudy New England Impreza Club Forum -- NESIC 11 04-22-2011 08:52 PM
2011 wrx exhaust question agarr19 Factory 2.5L Turbo Powertrain 0 04-14-2011 03:28 PM
FS : GA: **SOLD**2011 WRX OEM Wheels & Tires $900 shipped to the 48 Kontankerous Wheels/Tires 9 04-02-2011 12:37 PM
02 WRX 4EAT Issue: Car won't move in Drive or Reverse when cold. Loud humming too. YinUCSD Transmission (AT/MT) & Driveline 2 10-30-2007 10:02 PM
Message Board Statistics All times are GMT -4. The time now is 01:52 PM.
