Old 04-10-2011, 09:52 PM   #226
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
when is the turbo arriving?
Old 04-10-2011, 11:16 PM   #227
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
end of the month per full-race....
Bariga is offline   Reply With Quote
Old 04-11-2011, 01:19 AM   #228
alcoolaid
Member#: 134949
'07 SWP STi
Didn't they say beginning of Feb in Jan, then end of March in Feb, and now it's April and they say end of the month? Does anyone know what accurate lead times are nowadays....
Old 04-11-2011, 02:04 AM   #229
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Originally Posted by kellygnsd
I forgot, are you doing heads and cams in your build?
Heads already have Supertech STD size valves, dual 80lbs springs, radius valve job and blending of the seats. I have Bc 272s but may go with Kelford 264s. KB oil pan and Koyo rad is also on my list.
methaddict is offline   Reply With Quote
Old 04-12-2011, 01:27 AM   #230
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
pics of the engine\
Old 04-12-2011, 08:18 AM   #231
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
So fresh and so clean. May the force be with you, always.
maxpowr is offline   Reply With Quote
Old 04-26-2011, 04:00 AM   #232
reid-o
Member#: 103631
2004 STI
So we are shooting for May now?
Old 04-26-2011, 05:17 PM   #233
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Raffi told me they are on time for delivery, so i'm guessing 1-2 weeks.
But again BW wont release anything as far as Raffi tells me, maybe there is a bigger partner that BW work with that has some updates....
Old 04-27-2011, 12:54 AM   #234
reid-o
Member#: 103631
2004 STI
Well I hope you do well, bro. It's too bad that you changed cams and headwork. It would have been great to compare the 2 dynographs--old to new.
Old 04-28-2011, 12:40 AM   #235
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Everything is ready to go in, waiting on turbo
Here are Turbo coolant / oil drain hardware, this time I'm doing it the right way..
Old 04-28-2011, 11:32 AM   #236
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
You tapped the block for the oil return? I have been meaning to do that myself. AN coolant supply is the way to go!
aboothman is offline   Reply With Quote
Old 04-28-2011, 11:50 AM   #237
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Coolant and oil drain lines will have clamps! this hose seats nice and tight, but everything on the turbo will have AN fittings.
Old 04-28-2011, 12:56 PM   #238
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
u have concert lighting in your living room behind the couch? disco disco?
Old 04-28-2011, 01:34 PM   #239
Maxwell Power
Member#: 190729
is that a light or a speaker?
Maxwell Power is offline   Reply With Quote
Old 04-28-2011, 01:47 PM   #240
Phatron
Member#: 36033
CEO PhatBottiTuning
idk....but i definately see one of these on the counter in the garage
Old 04-28-2011, 01:54 PM   #241
Maxwell Power
Member#: 190729
I don't see it.
I see a Stella Artios beer bottle and an optima battery.
Old 04-28-2011, 02:07 PM   #242
Phatron
Member#: 36033
CEO PhatBottiTuning
lol....my eyes were playin tricks on me
Old 04-28-2011, 02:24 PM   #243
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
haha
Old 04-28-2011, 04:45 PM   #244
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Here are pics of Evac setup with Crawford can!
It takes very low pressure to open this valve i like that!
Not like Jegs pos.
Old 04-28-2011, 05:12 PM   #245
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Not like Jegs pos.
Where can one obtain such a valve?
AKSubieDubie is offline   Reply With Quote
Old 04-28-2011, 05:26 PM   #246
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 04-28-2011, 05:54 PM   #247
Phatron
Member#: 36033
CEO PhatBottiTuning
I really dont understand how the valve is supposed to help?
the theory behind exhaust scavenging the crankcase is that the exhaust will pull a vaccum on that line.....so if its pulling a vacuum, then why do you need the valve?
also...i believe an angled (~45*) entry into the flow is supposed to help....vice having it a 90
Old 04-28-2011, 07:49 PM   #248
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Because under all conditions you cannot guarantee the scavenging effect will be enough to draw a vacuum on the line and it beats pumping exhaust gas into your crankcase.
Old 04-28-2011, 08:03 PM   #249
CatfaceType-R
Member#: 81102
Originally Posted by Phatron View Post
+1
Old 04-29-2011, 01:03 AM   #250
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
That's exactly what Jegs unit does when you at full boost it creates back pressure when not it stays closed and also its prone to fail l95% "because you have rubber seal + exhaust temps = fail"
This unit makes allot more sense because it take less energy to open and has metal assembly which is more durable.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
