Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 05-05-2011, 12:11 PM   #1
maxpower_454
Member#: 88963
2005 WRX
Default Best Gas Mileage with 2.0T??
I know most people on here say that gas mileage is for hybrids and WRX owners shouldn't worry about it but I disagree so don't reply if that's all you're going to say. My WRX is my DD and I have a 46mi commute that is 95% highway so I'm starting to think about gas mileage with fuel getting so expensive. I'd hate to have to sell my car because of gas mileage...
So I'd like to know, who here is getting the best gas mileage? I'd like to keep it apples to apples so only drivers with a 2.0T powertrain should respond - meaning 02-05 US WRX powertrain. Please state:
Year
Average mpg
Any mods that would affect gas mileage
Percentage city/highway miles
I'll start.
2005
25-27mpg
Cobb Stage 2, Cobb catted DP, gutter UP, Borla hush catback, STi wheels
90% highway usually cruising around 70-75
What else can be done to increase gas mileage? Different tune? Intake? I haven't tried the 'economy' cobb tune yet.
maxpower_454 is offline   Reply With Quote
Old 05-05-2011, 12:15 PM   #2
SoGardSuby
Member#: 144104
2013 Ram Big Horn
cruise at 60-65 will probably help out some
SoGardSuby is offline   Reply With Quote
Old 05-05-2011, 12:20 PM   #3
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
problem: you bought an inefficient car for commuting
solution: sell your Subaru and buy a Mazda2
Spenk is offline   Reply With Quote
Old 05-05-2011, 12:49 PM   #4
bad grocerygetter
Member#: 279962
2003 wrx wagon
03 wagon
22-25mpg
Cobb stage 2 catless turboback, catless uppipe, lightweight konig wheels wrapped in toyo proxes 4s intake silencer delete.
prob 70% highway commute 30 miles one way. Usually 65-75 mph. Meh...don't really care about mpgs though. good luck with your findings though.
bad grocerygetter is offline   Reply With Quote
Old 05-05-2011, 01:07 PM   #5
kaetos03
Member#: 249928
Or a PRIUS....
Tip: Let your foot of the gas... or take a train/bus.
kaetos03 is offline   Reply With Quote
Old 05-05-2011, 01:12 PM   #6
kpotzmann
Member#: 215454
2005 9-2x Aero
Full under-body try would help, as would blocking off some or all of the grill. When you do this you need to watch the temps to make sure you dont go too far. I'm guessing that if you blocked off the Lower opening 100% you would be fine for Hwy driving.
You could prob Block the entire front in the winter and not see any issues. I'm guessing the full Under-body tray and grill block might get you 3-6mpg... I'm currently trying to come up with a removable block for the lower opening in my 05' 9-2x. In when just driving around, pull it for fun.
kpotzmann is offline   Reply With Quote
Old 05-05-2011, 01:38 PM   #7
JhnBrackett
Member#: 42460
20.5 mixed, 25 highway [avg 80 mph, 7000 ft elevation]
Stage 2.5 w/ 6 speed [K&N CAI, TBE, STI TMIC, Accessport w/ Stage 2 91 octane map]
BF Goodrich Super Sport G-Force A/S - 40 psi
JhnBrackett is offline   Reply With Quote
Old 05-05-2011, 02:25 PM   #8
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
Get a tune that is a little leaner than 14.7:1 which is stoichometric it will help with closed loop fuel economy.
subiewrx001 is offline   Reply With Quote
Old 05-05-2011, 03:56 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
~23-26 MPG depending on driving.
~24 without advanced fuel conservation driving(which is kind of annoying to do.
I've gotten 29-30 MPG on a trip, but that was FLAT and SLOW driving through Oregon, who has low speed limits and have some reputation for targeting CA plates for tickets, I basically drove 55-60 for 300+ miles of pretty flat land.
Commute is 22 miles. There is a large hill between my house and my work, about 1.2 is a significant uphill grade (followed by downhill).
Almost every bolt-on (Intake, silicone inlet, 18g, Process West TMIC, TGV delete, PnP exhaust manifold, uppipe, Invidia catted DP, Borla hush, fueling mods, self tuned via open source.
There are two problems with the WRX with respect to fuel economy... the aero is not so aerodynamic, and the engine is not the best design for fuel economy. The 2.5L is a much better design for fuel economy, which is how they can have 23% more displacement, but get about the same mileage as the EJ205. You're not going to do much better than what you have now. If you need significantly better, you need a different car.
I always wondered why they never released a 2.1L with the EJ205 block, a 2.5L crank and small port AVCS heads. Raise compression a bit and stick with the TD04 and I think it has potential for 30MPG in real world driving without being a total dog on performance.
Old 05-05-2011, 04:03 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If you care about this kind of thing, this will also skyrocket NOX emissions.
NOX emissions spike really high in the mid 15:1 range. This is why the lean burn engines that have made it to consumers run leaner than this. They avoid 15:1-16:1 because you cannot pass emissions in this range.
A little lean is not good. You need to go gung ho lean, and it's not easy to get our ECU to do that, as far as I know (but could just not know the right parameter to do it).
Old 05-05-2011, 07:34 PM   #11
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
^You do get the best economy around 15.5:1 though...
You also only revealed part of the picture. Which is the "worst" emission? Sure, NOx goes up (skyrocket is an overstatement), but CO and CO2 drop. Also, remember you thinking about ppm measurements. If these things were measured in an aggregate view, your total emissions would be less. You're using less fuel.
I've always gotten good economy with my 2.0L. I bet it would be better with a 79mm crank.
If you're not wanting to modify the motor or spend big money, I've seen the best economy with a properly tuned stg 2 setup on a 2.0L.
02 WRX
catless uppipe, downpipe, exhaust
26-29mpg, mostly highway, 90 mile commute
02 WRX
VF43, supporting mods, 820 cc/min modified stockers, E85
21-22mpg, mostly highway, 90 mile commute
02 WRX
Stock, 565 cc/min injectors
24-25mpg, mixed driving
One last note. Stay with stock 440's or 565's injectors if you care about fuel economy.
thefoos is offline   Reply With Quote
Old 05-05-2011, 07:54 PM   #12
subiewrx001
Member#: 193591
04 WRX VF34
^^both are very good points but I would flash your stage 2 map a few days before emissions then just flash the eco map after. Invest in a AFR gauge then you will know exactly whats going on.
Old 05-06-2011, 01:51 AM   #13
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
Version 8 EJ207
04 outback sport
Stock wheels
Stage 2 with walbro & 565cc
60% highway for 50mile round trip commute
70-85mph with daily wot 8,000rpm rips
17-20mpg
prokaw875 is offline   Reply With Quote
Old 05-06-2011, 07:35 AM   #14
450exc115
Member#: 193058
2002 WRX Wagon
Vf30
Pinks
Prodrive. Dp to Cobb. 3rd cat. Aps mid pipe and sti. Can
23-24 mix 80-20 hey/city
Cobb vf30 91 octane map
450exc115 is offline   Reply With Quote
Old 05-06-2011, 10:19 AM   #15
quazimoto
Member#: 70395
Best economy comes from a bigger turbo. As long as you drive it conservatively you will spend alot less time in boost using less gas due to the much higher boost thresh hold. I can drive around all day long and never leave vacuum and go into positive pressure.
26-28 city 32-34 hwy
16G-XT 650cc injectors,EL header,BPM TMIC,TGV deletes,TBE,Halman MBC,APS 65mm CAI,APS inlet
self tuned with Opensource. Target a 15:1 AFR closed loop
tires inflated to 35 psi all around
Old 05-06-2011, 11:22 AM   #16
ogboot
Member#: 170906
psm
02 WRX
Stage 2 Catless
K&N Typhoon, Turbo Inlet, SRS Turboback
avg 25mpg mixed, 28mpg on 90% highway trips
ogboot is offline   Reply With Quote
Old 05-06-2011, 12:07 PM   #17
maxpower_454
Member#: 88963
2005 WRX
Quazimoto and ogboot, what tunes do you guys have? Custom? dyno?
Old 05-06-2011, 01:49 PM   #18
quazimoto
Member#: 70395
Self tuned with Opensource on the road.
Old 05-06-2011, 04:32 PM   #19
bushman95
Member#: 248738
2004 wrx
red
I have a 2004 wrx with a catless up pipe and I get around 32-34mpg highway driving very conservatively, never run any boost. I drive a 300 mile commute every other weekend.
bushman95 is offline   Reply With Quote
Old 05-06-2011, 08:28 PM   #20
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
I have never gotten more than 25 mpg on a completely stock WRX. And that 25 mpg was on a 500 mile road trip. On MY WRX I get 18-19 mpg highway (or at least 80%) on average, but I'm heavily modified. Nobody who gets over 20 mpg should ever complain.
Byzantium is offline   Reply With Quote
Old 05-06-2011, 08:35 PM   #21
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
05 wrx
protuned by Turbo XS
vf34
iag 38mm ewg
gt spec EL header
565cc injectors
walbro 255 fp
full tbe
etc
I get about 22mpg around town and about 28-29mpg on the highway so I'm pretty happy.
shadowmd is offline   Reply With Quote
Old 05-06-2011, 09:06 PM   #22
nfm
Member#: 171697
05 WRX
0whp
To tweak the closed loop AFRs, does anything else has to be set besides "Closed Loop Base Fueling Target"? I currently have 14.87, but thinking of 15.01. Is 15.5 safe? I'm running around 40 degrees of timing in cruising ranges.
nfm is offline   Reply With Quote
Old 05-06-2011, 11:51 PM   #23
rydog
Member#: 70982
2004 WRX 5spd,
Cobb Stage 2,
23-25 in 50/50 mixed driving
The best I got was about 29, when it was stage 1, loaded to the max with my crap, during my move from DFW to STL back in Aug of 05.
Im getting pro tuned in a few weeks hoping to keep the same mpg's on E85 with a VF39.
2005 92x Aero 4eat.
Stock, and it guzzles gas. All city, about 18. Wife was getting about 21mpg on a 40 mile R/T, 99% highway, commute.
Cant figure it out.
rydog is offline   Reply With Quote
Old 05-07-2011, 02:20 AM   #24
monsta121
Member#: 261534
Originally Posted by rydog View Post
2004 WRX 5spd,
Cobb Stage 2,
2005 92x Aero 4eat.
Cant figure it out.
Doesnt E85 drastically decrease fuel economy? I know it decreases it but by how much I have no idea. On another thread someone was saying that at current gas prices its still not worth switching to e85 because of the drastic decrease in fuel econ. Can anyone confirm?
monsta121 is offline   Reply With Quote
Old 05-07-2011, 12:00 PM   #25
ogboot
Member#: 170906
psm
Self tuned, road. Nearest AWD dyno is hours away.
Gas mileage with an XPT stage 2 flash Ultimateone Commercial ECU Reflashes 9 10-04-2008 07:22 PM
Gas mileage with Cobb stage 2.5 WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-29-2004 02:54 AM
Better gas mileage with Unichip stage 2? TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-03-2002 10:06 AM
Beteer, best Gas Mileage How to improve? emprezadent General Forum Archive 6 02-22-2001 07:36 PM
Gas mileage with supercharger!! 305 miles to a tank of gas. ARG General Forum Archive 15 06-22-2000 01:39 AM
