Old 04-29-2011, 09:53 AM   #1551
Zulu-
Member#: 232213
Don't want to go through the whole thread so, has anyone painted factory 08-10 WRX wheels?
Zulu- is offline   Reply With Quote
Old 05-01-2011, 04:43 PM   #1552
kakarotoni
Member#: 156240
02 WRX
06 Impreza
I got a quick question guys.
Does anyone suggest using Adhession Promoter or Primer before you start applying paint?
I've seen mixed methods of guys just using adhession promoter with no primer and vice versa.
kakarotoni is offline   Reply With Quote
Old 05-01-2011, 06:50 PM   #1553
Donzo
Member#: 95337
2012 Jeep Overland
I've always used primer. From my understanding, adhesion promoter is used when applying to plastics since they flex. I'm not a painter though so I could be wrong.
Donzo is offline   Reply With Quote
Old 05-09-2011, 07:56 PM   #1554
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
I just picked up my 2009 WRX two months ago and after reading through this thread decided I wanted to paint my rims. Here's what I used:
One 2.5 Ton Jack $55
Four 2 Ton Jack stands $55
Dupli-Color Primer Sealer (2 cans) $14
Dupli-Color High Performance Graphite (4 cans) $28
Dupli-Color High Performance Clear (2 cans) $14
400 grade Sand paper $10
Simple Green $6
3x5 Index Cards
Total Price = $173
1) Took all four wheels off
2) Washed with auto soap and water
3) Sprayed with Simple Green & scrubbed with a wheel brush & dish green pads
4) Washed with Soap and water again
5) Dried tires
6) 400 Grit Sandpaper rub down, probably spent 30 minutes per wheel
7) Washed with water
8) 400 Grit Sandpaper round 2, spent another 30 minutes per wheel, really got it scuffed up good.
9) Cleaned with rubbing alcohol
10) 2 Coats primer with 10 minutes in between coats, then 1 hour to dry
11) 4 Coats graphite, 10 minutes in between coats, 40 minutes to dry
12) 3 Coats clear, 15 minutes in between coats
Before Shot
All four tires cleaned, sanded & ready to paint
1st coat of Primer
1st coat of Graphite Paint
3rd coat of Graphite Paint
1st coat of clear, we over sprayed the first tire, let it sit in sun for 20 minutes, then did light coats on the rest.
All four tires freshly finished, ready to dry. I put back on my car 6 hours later.
After Shots
geezersmk is offline   Reply With Quote
Old 05-14-2011, 04:59 PM   #1555
swede978
Member#: 89233
99 RS Aspen White
2014 Outback SWP
Originally Posted by geezersmk View Post
After Shots
Nice job and write up, Thanks.
swede978 is offline   Reply With Quote
Old 05-15-2011, 02:29 PM   #1556
jah13ang
Member#: 252495
2008 WRX
Charcoal Grey
Nice!!! I have the same car, same color. Looking to paint my rims this summer. I was thinking the same color and im really glad you just posted this because it looks really great. Did you ever consider a bronze? not too bold, maybe the same color as the Rota Torques in bronze. I just don't want to go with the bronze and end up regretting it
jah13ang is offline   Reply With Quote
Old 05-15-2011, 05:17 PM   #1557
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
Hey no problem! Since these pictures I've debadged the back and will be painting the chrome piece to match next week. One thing at a time I guess.
I've seen this car with bronze rims and they look good, but it just wasn't the look I'm going for. Sometimes I think I should of gone darker with the wheels, but I really like how they turned out.
Old 05-17-2011, 06:58 PM   #1558
jah13ang
Member#: 252495
2008 WRX
Charcoal Grey
If you were to go darker would you have gotten a different paint? or just a couple more coats?
Old 05-17-2011, 08:40 PM   #1559
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
Yes, darker paint. Saw a silver metallic paint on this thread that looked really good. I'll try and find the picture.
Old 05-17-2011, 09:59 PM   #1560
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
Darker like this picture - I like the metallic paint.
Old 05-18-2011, 10:32 AM   #1561
ej20forester
Member#: 117185
2006 FXT MT
Rustoleum antique brass metallic with a flat clear coat.
On the Fozz
ej20forester is offline   Reply With Quote
Old 05-20-2011, 05:21 PM   #1562
DieselClown
Member#: 36135
2005 WRX
did it get darker the more coats you applied? I'm curious if I can just apply a few coats and then clearcoat for a lighter finish.
Simple Green $6
3x5 Index Cards
Total Price = $173
5) Dried tires
Before Shot
1st coat of Primer
After Shots
DieselClown is offline   Reply With Quote
Old 05-20-2011, 09:58 PM   #1563
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
It definitely didn't get darker the more coats just filled out the rim better.
Old 05-22-2011, 08:15 PM   #1564
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Painted with a base coat of PSM then I hit it with a red tint, and I don't have the paint code to it either.
breaksOFTEN is offline   Reply With Quote
Old 05-23-2011, 06:37 PM   #1565
chadr111
Member#: 37718
02 TS, (too Slow)
black
Looking good! I used the exact same color on my wrx stockers simply because it was the closest color match to brake dust. Still look decent after 2 1/2 years.
chadr111 is offline   Reply With Quote
Old 05-31-2011, 12:52 AM   #1566
WrxBogdan
Member#: 281716
2005 Impreza Wrx
Platinum Silver Metallic
Do you have a non photoshoped pic of your car? rims look great Btw!
WrxBogdan is offline   Reply With Quote
Old 06-01-2011, 04:36 AM   #1567
jah13ang
Member#: 252495
2008 WRX
Charcoal Grey
I agree, those look great. You happen to know the name/brand of the paint?
Old 06-01-2011, 10:44 AM   #1568
geezersmk
Member#: 282228
2009 WRX Sedan
Dark Grey
Nope no idea, only on my graphite paint color.
Old 06-01-2011, 03:23 PM   #1569
diirk
Member#: 204238
2013 BRZ Premium
Originally Posted by Donzo View Post
I need to respray them again. They're all chipped and curbed from taking a beating this winter. Also because I literally just sprayed them in a rush. No sanding, no primer... just sprayed them. I think this is the 4th paint job they've had.
Donzo,
What color is this? Looks like the perfect compromise between stock and black.
diirk is offline   Reply With Quote
Old 06-01-2011, 04:50 PM   #1570
Escapee
Member#: 73176
2006 wrx
Awesome. Love the color, it would look hot as hell on a white car.
Escapee is offline   Reply With Quote
Old 06-02-2011, 12:36 AM   #1571
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
What brand red paint did you use? This is what I'm trying to do.
CGMDan is offline   Reply With Quote
Old 06-02-2011, 02:12 PM   #1572
tmoney4894
Member#: 226047
That red looks hot
tmoney4894 is offline   Reply With Quote
Old 06-02-2011, 06:48 PM   #1573
Esupra773
Member#: 243448
04 WRX PSM
Neva Narc'd on Nobody
Just finished mine yesterday.
Used Valspar White Metal Primer, Rustoleum Graphite Wheel Paint, Rustoleum Clear Coat.
Esupra773 is offline   Reply With Quote
Old 06-02-2011, 11:41 PM   #1574
Donzo
Member#: 95337
2012 Jeep Overland
Originally Posted by diirk
Donzo,
I forgot but I got it at Walmart and it's a basic graphite. I think it's Rustoleum.
Old 06-03-2011, 07:41 AM   #1575
skinzzfan25
Member#: 230829
2010 WRX
Looks like a PPG paint or some body shop work, doubt it was rattle can.
skinzzfan25 is offline   Reply With Quote
re-painting already painted stock wheels subiedriver4444 Interior & Exterior Modification 14 12-04-2012 08:13 PM
WANTED: Pics of painted stock wheels on PSM Bugeye.. vipernj Member's Car Gallery 1 10-10-2005 07:40 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Any pictures of painted stock wheels (WRX)?? eightballrj Member's Car Gallery 31 11-15-2004 12:08 PM
Painted stock wheels WRBlueMeanie Interior & Exterior Modification 8 04-23-2003 02:35 PM
