Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 04-29-2011, 08:19 AM   #1
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
Default 2011 WRX Bi-Xenon Retrofit
When I was looking for the car, I couldn't find a silver Limited 5 door anywhere so I ended up with a Premium without the HID's. I had retrofitted another car in the past with TSX projectors so I went ahead and planned on retrofitting this car as soon as I got it.
Luckily, The Retrofit Source makes a complete plug and play HID retrofit specifically for the WRX. The kit included.
  • Morimoto Bi-Xenon Mini Projectors
  • Morimoto 4300k Capsules
  • OEM Subaru Ballasts
  • Wiring Harness (including relays to turn on bi-xenon hi-beams)
  • Mounting brackets
You can find it here.
WRX Retrofit Kit
The car apart to remove the headlights
The projectors installed and on. I also decided to remove the orange reflector in the housing and install some silver bulbs that burn orange.
Blue flicker at the cutoff
Aligning the lamps
Bi-xenon hi-beams (regular hi-beams stay on as well)
Overall I am incredibly happy with the system especially given the ease of install once you get the headlights open given the included brackets. There was zero fabrication, just bolt up and go.
rsutton1223 is offline   Reply With Quote
Old 04-29-2011, 10:08 AM   #2
Ric WRX
Member#: 187009
2008 WRX Sedan Prem
VF52, CAMTuned, Stage 2
I have the same setup w/phillips bulbs, I like it very much. Good price too (group buy).
Ric WRX is offline   Reply With Quote
Old 05-05-2011, 01:40 AM   #3
B-rentt
Member#: 280736
2011 WRX Premium
Red
In the little research I have done others have changed their headlight housings to STI housings. You are saying that you got great results without doing this thought, right?
B-rentt is offline   Reply With Quote
Old 05-05-2011, 01:46 AM   #4
pezcore
Member#: 178045
06 WRX
CGM
Looks great! Once you go HID you can never go back. My retrofit came from TRS as well, great company
pezcore is offline   Reply With Quote
Old 05-05-2011, 10:19 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Thank you for not putting in a cheap HID kit!
Edit: at this point, halogen high beams become somewhat useless, no?
Bluefoton is offline   Reply With Quote
Old 05-05-2011, 10:56 AM   #6
besthaticouldo
Member#: 279660
this is exactly what i want to do...
glad to hear you like it.
besthaticouldo is offline   Reply With Quote
Old 05-05-2011, 12:31 PM   #7
pyrocyborg
Member#: 278723
2011 2.5i 5 doors
Obsidian Black Pearl
Wow! Looks real good! Too bad I'll have to wait for my lease to be completed so I can install those.
pyrocyborg is offline   Reply With Quote
Old 05-05-2011, 02:48 PM   #8
royalnewjersey
Member#: 250954
2013 WRX Hatch
Wow, that's awesome. I'm assuming this will work for the 2.5i as well since it has the same headlight. Totally doing this.
royalnewjersey is offline   Reply With Quote
Old 05-06-2011, 06:52 PM   #9
musclemilk
Member#: 273152
You can buy a used pair if headlamps and place those on when you return the car.
musclemilk is offline   Reply With Quote
Old 05-06-2011, 07:00 PM   #10
musclemilk
Member#: 273152
Rsutton-
Great work...!!!!
Old 05-06-2011, 11:35 PM   #11
ptsmalls
Member#: 31960
2012 R
What chrome covered bulbs did you go with?
ptsmalls is offline   Reply With Quote
Old 05-10-2011, 06:14 AM   #12
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
Pretty much. You tap into the high beams for the bi-xenon wiring...so you might as well leave them hooked up anyway.
Old 05-10-2011, 06:14 AM   #13
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I picked these up...
http://www.stealthauto.com/stealth-bulbs.aspx
If you do some searching around online...you can find a coupon code to bring the price down some.
Old 05-10-2011, 06:17 AM   #14
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
The main reason people are switching to STI housings is to get the HID projector. I took apart the WRX headlight and replaced the stock halogen projector with a HID projector.
You can do it either way. Putting an eBay HID kit in your halogen projectors is what you want to stay away from. Putting those in halogen reflector housings is even worse...
Old 05-10-2011, 07:03 AM   #15
chen5108
Member#: 138187
2008 2.5i 5-Door
Nice work, I like how it all came out. Are those chrome bulbs as bright as the stock ambers?
I myself did the retro fit with an extra setof headlight housings (i'll have an extra set now). Just gotta wait till I get off work then put them in and get them aligned. Been looking forward to this all week.
chen5108 is offline   Reply With Quote
Old 05-10-2011, 07:11 AM   #16
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
They seem to be.
A LED setup on that corner would be the ideal situation, but I didn't want to go to the trouble of installing relays to get them to work correctly. This was an easy solution that looks good enough.
Old 05-10-2011, 12:04 PM   #17
chen5108
Member#: 138187
2008 2.5i 5-Door
I looked into the LED setup and felt the same way.
How did you tap into the high beam wires? Did you have to strip away some of the insulation or did the provided taps cut right in the wire?
Old 05-10-2011, 02:07 PM   #18
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
They provided the taps. Basic wiring stuff you can get from any hardware store though. --> http://news.thomasnet.com/fullstory/...ripping-451197
Old 05-14-2011, 02:11 AM   #19
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
Originally Posted by rsutton1223 View Post
They seem to be.
FYI, you don't have to install relays to put in LEDs. Some people opt to replace their stock blinker relay with an electronic blinker relay (takes 5 minutes), or do what I'm doing which is install two 3 ohm 50 watt resistors in line with the rear turn signals (one for each side). Takes all of 10 minutes to install the resistors as they use vampire clips. Superlumination.com has them. The resistors are more reliable than the electronic relay. But either route is a fast install. Way less complex than this HID install.
BTW, HID install looks awesome. Thanks for posting this thread. I'm totally going to do this once I get $330.
Jonnyfilmboy is offline   Reply With Quote
Old 07-04-2011, 08:39 PM   #20
Krayzie
Member#: 285678
2011 WRX Premium
Lightning Red
Op I have a question, Im guessing you could be my only help, TRS really hasnt helped me much. On the wiring, where does this part go connected to, there is only one on the main harness.
Also, Im having a hard time understanding where the projector wires connect for the hi beams;and on the same pic, What connects to what was connected to the halogen lowbeam?.
This is my first retrofit BTW
Any help will be greatly appreciated!!
Krayzie is offline   Reply With Quote
Old 07-05-2011, 02:57 AM   #21
Krayzie
Member#: 285678
2011 WRX Premium
Lightning Red
bump.
Old 07-05-2011, 11:53 AM   #22
Ric WRX
Member#: 187009
2008 WRX Sedan Prem
Krayzie, go on hidplanet.com and there instructions for the wiring.
Old 07-06-2011, 03:00 AM   #23
Krayzie
Member#: 285678
2011 WRX Premium
Lightning Red
Thanks I got it. I got the 6000k. Heres a quick pic, ill try and get more tomorrow.
Old 07-06-2011, 03:19 AM   #24
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
It looks like the rotational alignment is off on one of your projectors.
Old 07-06-2011, 03:24 AM   #25
Krayzie
Member#: 285678
2011 WRX Premium
Lightning Red
Yeah I know. Ill fix it one day.
Latest project : FX-R Bi-Xenon retrofit into 04-05 wrx s13 duey Electrical & Lighting 19 04-16-2011 03:58 PM
Very Serious Feeler: Bugeye Bi-Xenon Retrofits Turbo_Twinky NWIC Private Classifieds 13 07-23-2009 12:23 AM
FS: ON EBAY: Complete bi-xenon retrofit for any car. Hella, Phillips, D2S zuczek Private 'For Sale' Classifieds 0 05-28-2006 02:17 PM
FS: Bi-xenon retrofit - Hella, Phillips, D2S zuczek Private 'For Sale' Classifieds 2 04-18-2006 08:41 PM
FS: Bi-xenon retrofit setup zuczek Vancouver Impreza Club Forum -- VIC 3 04-17-2006 11:52 PM
