Old 08-20-2009, 01:31 PM   #1
litowrx
Member#: 132418
2004 EJ207
Default Purge Control solenoid valve hooked up correctly?
Hey guys, i notice a few months ago, that i had a couple of hoses unhooked around the PCSV (purge control solenoid valve)
I found a diagram, and i decided to hook them up the way the diagram tells...
Just want to make sure this is correct... these have been unhooked, god knows how long... i havent had any problem but i guess its better this way...
This is the diagram i found:
So i go ahead and zip tied that blue coupler , because everytime i move something it pops put...
Are the circled hoses suppose to be hooked up?
This is what it looks like finished... is this the correct way?
litowrx is offline   Reply With Quote
Old 08-20-2009, 03:06 PM   #2
litowrx
Member#: 132418
2004 EJ207
Anyone?
Old 08-21-2009, 02:44 PM   #3
litowrx
Member#: 132418
2004 EJ207
Help please...
Old 08-21-2009, 03:39 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
http://www.thesuicidaleggroll.com/sti/7-18-09/
pics of the purge system are at
0557
0570
0571
0572
hope they help
Old 08-21-2009, 04:07 PM   #5
burtonboy759
Member#: 178707
2002 BUGEYE HYBRID
MBP- NO ITS NOT BLUE
not to thread jack or anything, but after looking at this stock setup i've realized. What do people do with aftermarket fuel rails when venting the valve off the evaporation pipe?
Aftermarket fuel rails would delete that evaporation pipe (the bottom pipe on the stock fuel rails Part C in the diagram) and would keep the blue nipple exposed. The only reason i ask is because i have aftermarket fuel rails coming and have been wondering where to vent that off to. Do you just use an extended hose?
burtonboy759 is offline   Reply With Quote
Old 08-21-2009, 04:16 PM   #6
Mechie3
Member#: 120152
Take a line of fuel hose from the metal tube on the firewall, run it under the manifold and hook itup.
Old 08-22-2009, 01:40 PM   #7
litowrx
Member#: 132418
2004 EJ207
0557
0570
0571
0572
hope they help
Thanks dude! it seems i hooked them up correctly!
Old 08-22-2009, 09:09 PM   #8
fastfive09
Member#: 169597
2011 WRX Sedan
im having a problem with my PCV and I just want to confirm that the EJ205 in the 02 WRX has a different setup bc mine looks different.
fastfive09 is offline   Reply With Quote
Old 09-27-2009, 04:07 PM   #9
supa74
Member#: 154815
thanks for posting the pics up.
supa74 is offline   Reply With Quote
Old 01-02-2010, 08:24 PM   #10
olivertwisto
Member#: 224318
1998 WRX
snow white
thanks for the pics x2. I'm facing the same problem. Note to self...take pics before ripping things apart.
olivertwisto is offline   Reply With Quote
Old 10-01-2010, 01:13 AM   #11
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
If you did that, then you would have both positive and negative pressure in the fuel tank... theoretically as much as positive pressure as what the turbo puts out. Pretty sure you don't want that
I'm trying to figure out how to delete the system properly - ideally a valve that only works when under negative pressure to deal with the fuel evap issue; I need to remove the solenoid.
Geek Guy is offline   Reply With Quote
Old 05-13-2011, 04:30 PM   #12
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Here is another option, it is free and avoids the hassle of the hoses coming off in the future. This is how the JDM ver7/8 STi cars are setup. We have lots of customer cars running this configuration without any CELs or negative side affects.
IA Performance is offline   Reply With Quote
Old 05-13-2011, 09:56 PM   #13
onesixnin
Member#: 50992
02 Bugeye
Is there somewhere to find the purpose of this hose routing? Emissions? If IA says it can go away without harm...what is subaru's reasoning for having it?
onesixnin is offline   Reply With Quote
Old 07-14-2011, 12:58 AM   #14
Obey
Member#: 283482
02 WRX Impreza
Black and Rugged
Would this configuration work for an 02 wrx?
I found my PC solenoid hoses disconnected and one of the hoses looks like it was cut in half..i bought the wrx right when a used newer ej20 was added to it.. Thanks in advance.
Obey is offline   Reply With Quote
Old 07-14-2011, 02:29 PM   #15
IA Performance
Member#: 25194
Dark Gray
yes, it will work perfectly for 02-05 WRX cars.
Old 07-14-2011, 06:37 PM   #16
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
So just cap those off and eliminate the purge altogether?
Old 07-14-2011, 07:39 PM   #17
IA Performance
Member#: 25194
Dark Gray
Yes, solenoid will stay. Please refer to the diagram.
Stephen
Old 07-14-2011, 07:43 PM   #18
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Too complicated
Saving it for next time I break that stuff, though.
Old 08-10-2011, 10:54 AM   #19
KevSmu
Member#: 279340
I did me setup/delete as described in post#12 and I noticed I was hitting 25lbs of boost instead oif my standard 20lbs...
KevSmu is offline   Reply With Quote
Old 08-10-2011, 10:58 AM   #20
Member#: 51961
2005 STi
Sounds like your valve might have been leaking
Old 08-10-2011, 12:43 PM   #21
IA Performance
Member#: 25194
Dark Gray
I agree, sounds like a boost leak was fixed in the process. It would be interesting to see if your AFR changed as well. With most boost leaks you will see a leaner condition during full throttle after fixing it since the air is no long escaping.
Stephen
Old 08-10-2011, 01:00 PM   #22
WRX357
Member#: 224249
2002 Subiworx built/
Soulless tuned Bugeye
Stephen
Imma go try this right meow to see if it may help with my boost issue.
WRX357 is offline   Reply With Quote
Old 08-10-2011, 01:12 PM   #23
IA Performance
Member#: 25194
Dark Gray
meow what's so funny...
Old 08-10-2011, 03:20 PM   #24
KevSmu
Member#: 279340
I've only got an 18lb spring in the wastegate, how is it possible that I am able to hit 25lbs?
Old 08-10-2011, 03:38 PM   #25
IA Performance
Member#: 25194
Dark Gray
18 is the base pressure / minimum pressure the car will run. The solenoid hoses are completely separate from the boost system.
If the wastegate lower nipple is hooked directly to the intake manifold then, in theory, it should peak right around 18psi. If you have a boost controller of some sort then that will increase your base pressure. The plausible causes:
1) boost solenoid or hoses were disturbed while doing working on the other hoses
2) if your boost solenoid or boost gauge tie into the intake manifold's front nipple then the readings 'could' change now that the hoses have been switched around, leading into #3
3) If the boost was set at 20psi using a boost controller and now runs 25psi after amending the hoses then there was most likely a boost leak where the purge valve attaches to the intake manifold since there are no barbs at either of those nipples.
If you have not already done so, put a zip tie on every hose that connects to the intake manifold as well as one at the BPV, wastegate, and boost controller.
Stephen
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 09:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 06:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 08:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 05:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 05:36 AM
