Old 03-01-2011, 10:21 AM   #51
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Originally Posted by rasheedn View Post
any idea when this will be available ??
ecutek r always a few years late than their release date...
This past week EcuTek RaceRom was released to EcuTek Dealers.
I've been using it on a number of cars and have had great success with all the new features.
Visconti is offline   Reply With Quote
Old 04-21-2011, 02:15 AM   #52
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Been busy over here but finally have made some nice progress with Stock ECU Speed Density.
My biggest worry with SD was temperature change.
I always found that when I ran my AEM ECU the a/f's would move around.
Even with adjusting settings it just was never right.
Currently EcuTek's Speed Density's a/f's are very consistent on temp change.
Right now I'm maxing out DW1000 Top Feed Injectors w/ my DW300 Pump on 20Psi.
I had planned on putting Top Feed 1600's in over the weekend but had clearance issues. The injectors I'm running need adapters and they're not clearing my agency power fuel rails .
Any how here's a little video of me beating up my car over the weekend.
Old 04-21-2011, 09:04 PM   #53
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
I like that auto blip! hmmmm do i go back to ecuTek which i ditched a few years ago or not. So a/f seem to be good with SD so far... Damn i want autoblip ffs and sd
mpsti05 is offline   Reply With Quote
Old 04-21-2011, 09:57 PM   #54
AirManCam
Member#: 219513
2006 STI
AirManCam is offline   Reply With Quote
Old 04-22-2011, 01:35 AM   #55
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
^haha - that was a fun night
Old 04-22-2011, 08:12 AM   #56
AirManCam
Member#: 219513
2006 STI
Fun weekend for sure man. 14 cars, and we didn't even see a cop
Old 04-23-2011, 07:56 PM   #57
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
One of the local Subie guys came by to see what all this "RaceRom" stuff was about.
Here's the vid
Old 04-28-2011, 03:02 PM   #58
spoolordie
Member#: 184387
2002 vf48'd Bugeye
crappy silver metallic
that ending was awesome lol ^^^
spoolordie is offline   Reply With Quote
Old 04-28-2011, 04:00 PM   #59
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
"right in a school zone" lol
Old 04-28-2011, 04:26 PM   #60
Liberal STi
Member#: 242159
2006 STi
I was most supprised when the water bottle landed at my feet and it was in the backseat....well then.
Liberal STi is offline   Reply With Quote
Old 04-28-2011, 04:31 PM   #61
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ if you're getting compressor surge...could be from a too tight BOV spring. When you let off the gas from WOT and the BOV doesnt open soon enough the pressurized air starts trying to go back through the compressor the wrong way, which causes the comp surge.
but then contrary to that...stalling out is usually from too loose of a BOV spring.
Old 04-28-2011, 05:12 PM   #62
Liberal STi
Member#: 242159
2006 STi
I have a Tial 50mm with a 12lbs spring in it. I might switch out to 11lb (the one it comes with). Also the stalling was because of the location of the MAF. I don't think I will have that problem anymore with the SD. I will keep you guys updated on what happen's, untill then subscribe to "Fasterthanurwrx's" youtube acount and John and I will continue to document our shenanigan's...
Old 04-29-2011, 11:18 AM   #63
foolio
Member#: 9351
2006 trailblazer SS
black
Your welcome for the diff.. .lol You want aggressive you get aggressive. haha.. Rallispec blocks started out with Wiseco Pistons, then Dave used a few sets of Manley and those are ones thats burned oil because at the time Manley had no lock on the top oiling ring, however since have fixed that problem. I have used them a few times since without any issues. Then the cost of cosworth pistons came down and Dave has been using them ever since that Im aware of. Im not sure cuz Im not there anymore. But Id imagen its the same.
foolio is offline   Reply With Quote
Old 05-14-2011, 02:17 PM   #64
rasheedn
Member#: 123333
2009 STi
DMG
hey
u use a GM IAT sensor right?
any pics?
also which wires from the stock harness are for the temp.
rasheedn is offline   Reply With Quote
Old 05-14-2011, 06:44 PM   #65
04trailsti
Member#: 179170
Auto blip? As in a "rev match" feature?
04trailsti is offline   Reply With Quote
Old 05-14-2011, 06:47 PM   #66
AirManCam
Member#: 219513
2006 STI
Yes sir.
Old 05-14-2011, 06:49 PM   #67
04trailsti
Member#: 179170
Wow thas awesome. When the 370z came out with that, Ive been curiouse if it was possible to tune that feature into a drive by wire car ..... well theres my answer
Old 05-14-2011, 07:40 PM   #68
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
hey
any pics?
I dont know off the top of my head, but I'll take a look at my car tomorrow and let you know
Old 05-15-2011, 03:26 PM   #69
rasheedn
Member#: 123333
2009 STi
DMG
thanks
Old 12-04-2012, 07:38 AM   #70
ksalex
Member#: 107917
1995 STI Type-RA
white
I am trying to get information about RaceROM but cannot find some answers.
I think you must know by now
1) AutoBlip on downshift
1a) I assume AutoBlip does not work correctly if I want to switch from 5th to 3rd or 2nd?
1b) Does it work when ABS disabled?
1c) Does it work when ABS disabled and wheels locked because I am braking on snow or gravel? I assume it will go down to idle revs?
1d) Can I still control revs using gas pedal when AutoBlip enabled?
2) I assume it support maps for Dual AVCS?
3) As I understand it may work with MAF or without MAF (Speed Density mode). How it can be set to switch from MAF to SpeedDensity mode? Some limit be Revs? Boost?
Does SpeedDensity mode have any advantage on stock turbo?
4) I assume RaceROM can work without any additional sensors? However some sensors can be useful? Something like Intercooler temp sensor? Something else?
5) RaceROM work fine with stock knock sensor?
ksalex is offline   Reply With Quote
Old 12-04-2012, 09:15 AM   #71
CatfaceType-R
Member#: 81102
We need a thread title change, Visconti is no longer tuning at the shop. His contact info is www.vtune.us
Mike is tuning at the shop, very capable as well. The shop website is down, at least when I checked it. Edit: found one that did work, an email and contact page. http://www.theshopct.com/contact_us.html
