Closed Thread
Old 04-25-2011, 02:24 AM   #51
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
yes, bake it, take the lens off, remove the chrome trim, paint, reassemble
Strobe Media is offline
Old 04-25-2011, 06:56 PM   #52
c0nn0rwils0n
Member#: 262203
2009 Impreza 2.5i
has anyone done this to the 2008+ yet? and if so is there a write up somewhere? i really want to do this but im horrible at this stuff so i dont really want to try it without a write up so i dont mess it up
c0nn0rwils0n is offline
Old 04-25-2011, 07:17 PM   #53
wantsti
Member#: 134764
04 sti
java black pearl
I wanna do this to mine but have always worried about the Paint flaking or fading on the inside. Have you seen any problems like this happen?
wantsti is offline
Old 04-30-2011, 12:55 PM   #54
stillatoy
Member#: 276391
2004 WRX
java black pearl
i had mine done on the lexus for two years with no problems. just make sure that you scuff the housings up really good with some steel wool. i used krylon bar-b-q and stove paint for mine. im going to do the subies lights hopefully tomorrow
stillatoy is offline
Old 04-30-2011, 01:56 PM   #55
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
Originally Posted by Rapier46 View Post
So, you bake the light to get it apart? Then you paint it. Then attach it back together again?
Or if that's not correct...what is the process?
Really? I mean seriously? The very first post on page 2 are links to the entire process on 2 different years of Impreza's. then just 1-2 posts above yours is a link to a lexus IS install.... REALLY?
ok spoon fed version:
1. remove lights
2. remove bulbs & screws holding (2) pieces of the light together.
3. pre-heat oven 150-200* & remove middle rack.
4. place prepped light in oven on cookie sheet, bake for 15-20 minutes
5. remove light from oven its hot.
6. carefully separate the (2) haves of the light.
7. remove ambers, scuff & paint the chrome facia
8. let dry at least 30-45 minutes. Better overnight.
9. reassemble the light.
10. bake again to set the adhesive.
11. reinstall.
Rob
TXwrxWagon is offline
Old 04-30-2011, 02:25 PM   #56
DNelson
Member#: 265983
MBP
What kind of paint are you using for this? I definitely want to do this but i want the paint to last, are you using primer or another type of adhesion promoting primer?
DNelson is offline
Old 05-05-2011, 02:56 AM   #57
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
I use Rust Oleum semi-gloss black paint. Believe me, it will last
Fat Black Pig Sac is offline
Old 05-16-2011, 02:47 AM   #58
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
did taillights today.....
Old 05-16-2011, 04:12 AM   #59
codywill
Member#: 275399
2006 Impreza WRX STI
I've been following this for a bit, you do great work man.
After seeing the tails I've gotta ask, how much would you charge to do this for my hawkeye?
Headlights and taillights I mean
codywill is offline
Old 05-16-2011, 10:51 AM   #60
f575gtc
Member#: 267839
2011 STI
i want to bake my head lights and remove the amber reflector and paint the chrome ring around the project black but how do you resealed so cleanly?
I have seen jobs where there is goop all over the place.
f575gtc is offline
Old 05-16-2011, 11:11 AM   #61
IrishMykl
Member#: 212170
2004 Jetta
just be careful and you wont get goop all over the place. you dont add more you just resoften the goo thats already there and reattach it.
IrishMykl is offline
Old 05-16-2011, 11:34 AM   #62
IrishMykl
Member#: 212170
2004 Jetta
Heres a link to pictures and a DIY for the 08+
http://forums.nasioc.com/forums/show....php?t=2046189
Old 05-16-2011, 11:54 AM   #63
doom16
Member#: 204438
How you split tAillight , do you cut this our baking
doom16 is offline
Old 05-16-2011, 12:14 PM   #64
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Preheat oven to 450. Wrap up in aluminum foil, and place on cookie sheet. Put in oven. Bake for 2-1/2 hours, or until you learn to form a sentence. Either one.
NitroTrike is offline
Old 05-16-2011, 12:25 PM   #65
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Take your own advice and learn not to be an asshat. He's French Canadian, you troll... look at his profile location. I would imagine it is quite likely he knows a lot more about his native language than you do his.
P.Rico is offline
Old 05-16-2011, 12:33 PM   #66
NitroTrike
Member#: 62408
I really don't care where he is, or what his native language is. His question didn't make sense in any language.
Idiot.
Old 05-16-2011, 02:23 PM   #67
doom16
Member#: 204438
2-1/2 houe is secure ... The tAillight do not melt with time
doom16 is offline
Old 05-16-2011, 03:37 PM   #68
P.Rico
Member#: 239452
2010 Impreza WRX
2005 Outback 2.5i
Please don't listen to the above poster. 450 Fahrenheit on a front headlamp, made of polycarbonate (PC), will cause it to melt, even more so the taillamp, which are usually made of polymethyl methacrylate (PMMA). These plastics, which are not as impact resistant as PC, melt at 160 C but will probably begin to meltflow at the temperatures people use to melt the butyl rubber seal on headlamps. You can go through threads here and see idiots who've tried it and then have cried about ruining their tails.
The referenced guy with the taillamp modification either 1) used a low enough temperature or locally heated the butyl seal with a heatgun just enough to get it to be pliable, or 2) cut the seal with an exacto knife and some brute force.
P.Rico is offline
Old 05-16-2011, 04:35 PM   #69
mistanoX
Member#: 247415
2013 BRZ
Galaxy Blue Silica
So Fat Black Pig Sac: How did you get your tails open? What temp did you use? or did you use some other method? I've been wanting to do this on my car, even more so than the headlights and I'd really like to know. Thanks
mistanoX is offline
Old 05-30-2011, 08:06 AM   #70
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
With tails you don't use the oven. Your best friend is a Dremel rotary tool to cut the lights open. After painting the housing and assembling everything you have to glue pieces together. I used JB Weld, worked great!
For headlights - 230-240 degrees for 15 minutes. Trust me, that's the best option, atleast for 02-07 WRX and STI headlights.
Old 05-30-2011, 08:40 AM   #71
trueno92
Member#: 111755
homemade "illest" sticker is trying too hard.
trueno92 is offline
Old 05-30-2011, 12:45 PM   #72
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You can't bake tail lamps apart..gotta cut them..
vision.dynamix is offline
Old 05-30-2011, 02:15 PM   #73
NcKidd
Member#: 133267
2004 psm WRX
Did my 04 wrx a few year back- didn't paint, just cleared them out. Still looks good.
Just have to be real careful with the gooey, hot, stringy, messy black sealant when pulling the front & rear parts of the light assembly apart.
NcKidd is offline
Old 05-31-2011, 11:39 PM   #74
gmhracer
Member#: 267343
2006 STI
OP, how much to do my Bug eye's headlights? pm me if you want
gmhracer is offline
Old 06-21-2011, 03:21 AM   #75
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
40 bucks will do
Closed Thread
Baking headlights devil13 Tri-State Area Forum 10 10-13-2013 02:11 PM
Clearing/baking headlights for others sc00ter Interior & Exterior Modification 9 04-30-2008 12:19 AM
baking headlights (evo) question PSMWRX03 Interior & Exterior Modification 6 03-06-2008 12:48 AM
baking headlights...HELP! PSMWRX03 Interior & Exterior Modification 10 01-09-2008 09:09 PM
baked headlights and gasket came loose... mindchatter Interior & Exterior Modification 1 04-20-2006 04:43 PM
