#51 |
Member#: 241600
Vehicle:2004 WRX STi like a million whp |
yes, bake it, take the lens off, remove the chrome trim, paint, reassemble
#52 |
Member#: 262203
Vehicle:2009 Impreza 2.5i Silver |
has anyone done this to the 2008+ yet? and if so is there a write up somewhere? i really want to do this but im horrible at this stuff so i dont really want to try it without a write up so i dont mess it up
#53 |
Member#: 134764
RMIC
Vehicle:04 sti java black pearl |
I wanna do this to mine but have always worried about the Paint flaking or fading on the inside. Have you seen any problems like this happen?
#54 |
Member#: 276391
Vehicle:2004 WRX java black pearl |
i had mine done on the lexus for two years with no problems. just make sure that you scuff the housings up really good with some steel wool. i used krylon bar-b-q and stove paint for mine. im going to do the subies lights hopefully tomorrow
#55 | |
Member#: 191557
TXIC
Vehicle:2004 WRX Wagon WRB not so minty fresh |
ok spoon fed version: 1. remove lights 2. remove bulbs & screws holding (2) pieces of the light together. 3. pre-heat oven 150-200* & remove middle rack. 4. place prepped light in oven on cookie sheet, bake for 15-20 minutes 5. remove light from oven its hot. 6. carefully separate the (2) haves of the light. 7. remove ambers, scuff & paint the chrome facia 8. let dry at least 30-45 minutes. Better overnight. 9. reassemble the light. 10. bake again to set the adhesive. 11. reinstall. Rob |
#56 |
Member#: 265983
Vehicle:2002 WRX MBP |
What kind of paint are you using for this? I definitely want to do this but i want the paint to last, are you using primer or another type of adhesion promoting primer?
#57 |
Member#: 247911
BAIC
Vehicle:2005 obp WRX color: HUMMER H2 WHITE |
I use Rust Oleum semi-gloss black paint. Believe me, it will last
#58 |
Member#: 247911
BAIC
did taillights today.....
#59 |
Member#: 275399
Vehicle:2006 Impreza WRX STI Aspen White |
I've been following this for a bit, you do great work man.
After seeing the tails I've gotta ask, how much would you charge to do this for my hawkeye? Headlights and taillights I mean ![]() |
#60 |
Member#: 267839
Vehicle:2011 STI SWP |
i want to bake my head lights and remove the amber reflector and paint the chrome ring around the project black but how do you resealed so cleanly?
I have seen jobs where there is goop all over the place. |
#61 |
Member#: 212170
TXIC
Vehicle:2004 Jetta Silver |
just be careful and you wont get goop all over the place. you dont add more you just resoften the goo thats already there and reattach it.
#62 |
Member#: 212170
TXIC
Heres a link to pictures and a DIY for the 08+
http://forums.nasioc.com/forums/show....php?t=2046189 |
#63 | |
Member#: 204438
E. Canada
#64 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
#65 | |
Member#: 239452
Vehicle:2010 Impreza WRX 1991 Prelude Si 4WS |
#66 | |
Member#: 62408
South East
Idiot. Last edited by NitroTrike; 05-16-2011 at 12:39 PM. |
#67 | |
Member#: 204438
E. Canada
#68 |
Member#: 239452
Please don't listen to the above poster. 450 Fahrenheit on a front headlamp, made of polycarbonate (PC), will cause it to melt, even more so the taillamp, which are usually made of polymethyl methacrylate (PMMA). These plastics, which are not as impact resistant as PC, melt at 160 C but will probably begin to meltflow at the temperatures people use to melt the butyl rubber seal on headlamps. You can go through threads here and see idiots who've tried it and then have cried about ruining their tails.
The referenced guy with the taillamp modification either 1) used a low enough temperature or locally heated the butyl seal with a heatgun just enough to get it to be pliable, or 2) cut the seal with an exacto knife and some brute force. |
#69 | |
Member#: 247415
Vehicle:2013 BRZ Galaxy Blue Silica |
#70 |
Member#: 247911
BAIC
With tails you don't use the oven. Your best friend is a Dremel rotary tool to cut the lights open. After painting the housing and assembling everything you have to glue pieces together. I used JB Weld, worked great!
For headlights - 230-240 degrees for 15 minutes. Trust me, that's the best option, atleast for 02-07 WRX and STI headlights. |
#71 |
Member#: 111755
![]() homemade "illest" sticker is trying too hard. |
#72 |
Member#: 139955
Vehicle:# OneBoston |
You can't bake tail lamps apart..gotta cut them..
#73 |
Member#: 133267
Vehicle:2004 psm WRX mucho door dingo stg 2er |
Did my 04 wrx a few year back- didn't paint, just cleared them out. Still looks good.
Just have to be real careful with the gooey, hot, stringy, messy black sealant when pulling the front & rear parts of the light assembly apart. |
#74 |
Member#: 267343
Vehicle:2005 STI WRB |
OP, how much to do my Bug eye's headlights? pm me if you want
#75 |
Member#: 247911
BAIC
40 bucks will do
| Thread Tools | |
| Display Modes | |
| Clearing/baking headlights for others | sc00ter | Interior & Exterior Modification | 9 | 04-30-2008 12:19 AM |
| baking headlights (evo) question | PSMWRX03 | Interior & Exterior Modification | 6 | 03-06-2008 12:48 AM |
| baking headlights...HELP! | PSMWRX03 | Interior & Exterior Modification | 10 | 01-09-2008 09:09 PM |
| baked headlights and gasket came loose... | mindchatter | Interior & Exterior Modification | 1 | 04-20-2006 04:43 PM |
| Baking headlights | devil13 | Tri-State Area Forum | 8 | 08-16-2005 07:03 PM |
