Old 05-16-2011, 07:54 PM   #1
O.C.D.
Member#: 19640
2003 WRX Sedan
Default SMY and Defi Gauges install - great pics if you want them!
Like many, I have been oogling over the SMY Cluster for the 2008+ Imprezas. I decided to pull the trigger and buy the setup. The gauges were the killer as Defi is not cheap! But I decided I wanted the best so I ordered them.
I must note, the SMY cluster is a fantastic piece of work. The fitment was great and the finish was even better!
I chose the oil pressure gauge and the boost gauge. The flavor was Defi Red Racer Series.
Pre-install:
For the oil pressure unit you have to remove the alternator. To be honest it was cake in this car. When you remove the alternator you can see exactly where the stock unit sits and what you have to remove.
Based on XLuben's thread I grabbed a 24mm deep socket and removed the stock sensor and bung:
O.C.D. is offline   Reply With Quote
Old 05-16-2011, 07:58 PM   #2
O.C.D.
Member#: 19640
2003 WRX Sedan
I cleaned up the bung and wrapped it in teflon tape then installed:
here is the Defi sending unit with the 1/8th pt thread wrapped in teflon tape as well:
Here she is installed:
Here is the pigtail and the sensor installed. All that is left is the alternator and zip-ties:
Old 05-16-2011, 08:02 PM   #3
O.C.D.
Member#: 19640
2003 WRX Sedan
I then routed the lead and attached with zip-ties:
Next was the boost gauge. This was pretty easy but I am anal so I had to make sure it looked factory:
So I routed the unit up and decided I wanted a solid place for it to mount. I rotated a hose clamp and used a longer metric bolt setup. Because of this I have a solid mount and it look almost factory:
Old 05-16-2011, 08:04 PM   #4
O.C.D.
Member#: 19640
2003 WRX Sedan
Remove the driver's side wheel and have some fun. Getting the fender liner out was not the easiest but dooable. Just be careful with the trim work:
When removed, look up into the fender and you will see this:
On the top of this grommet there is an area that you can cut into and feed the cabling through.
naked dash:
Old 05-16-2011, 08:07 PM   #5
O.C.D.
Member#: 19640
2003 WRX Sedan
Feed the gauge wires through the grommet and then you are ready to wire the gauges.
I used the rubber bands provided from the SMY Cluster and then wrapped them with some electrical tape. This gives a very tight fit but has some give to move the gauges.
Here is the stock cluster with the SMY Cluster:
Notice the stock cluster and the two part construction:
Notice the SMY Cluster and the one piece construction:
Old 05-16-2011, 08:15 PM   #6
O.C.D.
Member#: 19640
2003 WRX Sedan
As I had the gauges in place I grouped the wires together:
I added the fuse-taps and the ground eyelet:
I then taped the clusters together to make it easier when installing:
Feed it all through the top of the steering column and then hit the fuses you need:
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
(thanks xluben)
Here is how it looks when fired up. Click the link:
http://smg.photobucket.com/albums/v316/bluej/WRX/?action=view&current=Defistartup.mp4
I must say that I have waited years for a setup like this. The SMY Cluster is phenomenal and the Defi gauges really make it all work.
I would not have used any other parts,........period.
Jon
Old 05-16-2011, 08:21 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Fantastic job.
Old 05-16-2011, 08:28 PM   #8
bigusnickus
Member#: 245851
2004 WRX Rally car
The username fits this thread haha. Amazing look and work man. I need to pull the trigger on this exact same setup.
bigusnickus is offline   Reply With Quote
Old 05-16-2011, 08:28 PM   #9
Entaille
Member#: 217875
2008 STi
great write up - thanks.
Entaille is offline   Reply With Quote
Old 05-16-2011, 08:31 PM   #10
O.C.D.
Member#: 19640
2003 WRX Sedan
Yup, OCD is really how I do things. I feel that if you do something, make sure it is 125%.
Thanks for the comments.
Old 05-16-2011, 09:25 PM   #11
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
Fantastic info! I just picked up my STI the other day and I am already lusting a clean, functional gauge setup, probably boost and EGT or oil pressure. This thread is going into my gauges folder. Nicely done.
Ziggyrama is offline   Reply With Quote
Old 05-16-2011, 09:30 PM   #12
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
I don't have a 2011 but I have been eyeing up the Defi Racer series and was curious how easily everything went together, looks easy enough!
Great write up and very clean!
subaru_steve is offline   Reply With Quote
Old 05-17-2011, 07:55 AM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks awesome. This should help a lot of people!
Old 05-17-2011, 09:36 AM   #14
O.C.D.
Member#: 19640
2003 WRX Sedan
I was daunted in the wiring which is odd. I never get daunted, lol. But this is a brand new car so I had to make sure it was clean and done right.
Simply wire the gauges together and hit the right fuses and it is really easy. I could do the whole thing over in a few hours now. Took me a lot longer the first time though.
Thanks for the props all.
Old 05-17-2011, 10:05 AM   #15
aleeann
Member#: 255913
2011 WRX Premium
Awesome work! I have the exact same setup, minus the very smart boost sender mounting solution. I decided to mount the sender on the fuse box with a small screw. I may try your solution as it shortens the hose length a bit.
Thanks for the pics and writeup.
A
aleeann is offline   Reply With Quote
Old 05-17-2011, 11:24 AM   #16
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Great job on the install!!! Lol I am anal about installing things right too so I appreciate the work you did!!!! Awesome, and it looks great!!!
Old 05-17-2011, 12:11 PM   #17
Suby WRX
Member#: 264417
Subscribed for when I do my boost! Great writeup thanks for the info.
Suby WRX is offline   Reply With Quote
Old 05-17-2011, 12:26 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
For reference, here is the exact same setup during the day:
The Defi gauges match the stock ones perfectly!
Old 05-17-2011, 02:01 PM   #19
CpnNeeda
Member#: 20060
02 WRX
Midnight Black Pearl
Default Wiring
Awesome install, but I'd like to see a pic of the fuse links and possibly a link from where you got them. Very interested in them.
CpnNeeda is offline   Reply With Quote
Old 05-17-2011, 04:10 PM   #20
Izero
Member#: 121332
2004 STi
Platinum Silver Metallic
I always thought you had to use Yellow Teflon tape for Oil Pressure Fittings? Anyways nice write-up def. like the look!
Izero is offline   Reply With Quote
Old 05-17-2011, 04:30 PM   #21
SamuraiLincoln
Member#: 274670
2016 S3
Glacier Metallic White
Very nice write up. I watched the video and was curious as to why the gauges flicker a bit on startup?? What wire is the illumination tapped into??
I can't wait to order mine and get them installed, love the way it looks.
SamuraiLincoln is offline   Reply With Quote
Old 05-17-2011, 04:39 PM   #22
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
This is how a write-up should be. Good job sir!
Bishop is offline   Reply With Quote
Old 05-17-2011, 10:10 PM   #23
bzbuzz
Member#: 116052
2011 STI ( Sold )
fantastic write-up !!!
bzbuzz is offline   Reply With Quote
Old 05-17-2011, 11:46 PM   #24
WrxBogdan
Member#: 281716
2015 Wrx Sti
Galaxy Blue Pearl
Amazing job!
WrxBogdan is offline   Reply With Quote
Old 05-18-2011, 12:56 AM   #25
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Brilliant. Of course, just today I finally installed my boost gauge. I wish I'd seen this thread first and run the line through the fender like you did. I'm tempted to move it now.
2point0 is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
