Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 05-18-2011, 07:18 PM   #101
synapseengineering
Vendor Sales Rating: (0)
Member#: 111393
Originally Posted by Vlad View Post
I have the new style and the flange is a Subaru flange, not this weld-on universal flange.
I also have the discharge flange for Subaru. Do the o-rings from the two interchange?
I looked at your kits, in the spare parts section of your site. Correct me if I'm wrong, but all kits come with a pair of connectors, not with two connectors of two types.
Just so we're on the same page, this is the picture that describes all of the components that you should have received.
E-mail a picture of all the components you've gotten at [email protected]. Tell us where did you buy the kit and where are you located. We'll make sure the dealer or someone sends you the missing components. Cheers.
synapseengineering is offline   Reply With Quote
Old 05-18-2011, 09:01 PM   #102
Vlad
Member Sales Rating: (40)
Member#: 46135
02 WRX
Sti V9 Spec C
As you can see, I have one of the straight connectors and one of the ninety degree connectors
Old 05-18-2011, 09:08 PM   #103
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
But this turns out to not even be the biggest probelm. As you can see, I went to test-fit this and it does not fit.
There are two problems:
1. It hits the intake manifold runner and it prevents me from bringing in the driver's side of the intercooler another 1/2"
2. If I try to fudge the position by tilting the valve more towards the driver's side, at a sharper angle, it hits the throttle position sensor.
Right now, I am looking for photos you may have posted of successful installations, to see how you did it.
Which reminds me why I recirculated the full-size Synapse towards the driver's fender.
In the photo below, I have to bring the intercooler in kinda half towards the hole on the bracket, there's another hole there.
Old 05-19-2011, 04:07 PM   #104
RallyBlue
Member Sales Rating: (9)
Member#: 69323
2004 WRX
82 BRAT
Interesting you are having fitment issues.
In this thread: http://forums.nasioc.com/forums/show....php?t=2058269
The DV was fitted on a USDM cable TB with stock TMIC and a USDM STI with stock TMIC
Still not much wiggle room in either case, but I doubt your IC is the problem.
RallyBlue is offline   Reply With Quote
Old 05-19-2011, 06:07 PM   #105
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Well, to be perfectly clear about what I have, I do have a JDM Version 9 Spec C engine, combined with a USDM Sti current generation intercooler.
The current generation intercooler is the biggest Subaru has fitted on any car.
This may still be relevant to the growing community of JDM EJ207 American Owners, as well as to the people that have chosen to upgrade their OEM intercooler to the biggest possible OEM intercooler, the 08+ Sti.
Also, David from Synapse is helping me already with my missing parts, so things are starting to look better.
With this said, I think I may be able to fix this by grinding the ribs on the OEM BPV Elbow at the bottom of the valve, I think it's wedging there and I only need 1/4" or less.
Old 05-19-2011, 11:04 PM   #106
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I finished grinding the ribs and the valve is in....
Old 06-23-2011, 11:01 AM   #107
Sti43
Member Sales Rating: (2)
Member#: 173635
2008 STI
sliver
Is There Any Sound Difference With Installing The New Dv???
Sti43 is offline   Reply With Quote
Old 06-23-2011, 11:06 AM   #108
Sti43
Member#: 173635
2008 STI
sliver
YEH i didnt get all that either i got my from no limit motor sports
Old 06-23-2011, 01:54 PM   #109
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
The new DV valve is a bit louder than the full size Synchronic I had before. I definitely feel it responds faster.
Sometimes, at low to medium loads, it surprises me with a kind of whistle.
I like it.
I reccomend using the OEM gasket to the intercooler seating area.
Old 06-24-2011, 07:47 AM   #110
Sti43
Member#: 173635
2008 STI
sliver
i dont get anything like that sounds lower to non from the stock bypass valve
Old 10-03-2012, 01:59 PM   #111
Subian
Member Sales Rating: (15)
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I hate bumping an old thread, but where do you run the line for Port C if you have a EWG/MBC?
Subian is offline   Reply With Quote
Old 10-03-2012, 03:17 PM   #112
NITROS
Member Sales Rating: (27)
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
What version did you get? the C port should always be run. It needs to be a dedicated line off the turbo. If you have the latest version of the sb001 the C port should already be built in, no additional lines to run.
Look at the answer linked below to the question: "What is a Port C delete and what is the service procedure?"
http://www.synapseengineering.com/su...cid=1&answer=1
NITROS is offline   Reply With Quote
Old 10-03-2012, 04:26 PM   #113
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I know they say to run it to a dedicated boost source on either the compressor nipple or charge piping. What about the lines that the MBC needs to hook up to? How would that work?
Old 10-03-2012, 06:04 PM   #114
NITROS
Member#: 41561
04 GT3076 2.1
In theory that could work if it is the line pre-input of the MBC. However, I think this might not be as stable as a dedicated boost source. You could just put a T in the vac line for the fuel pressure regulator that comes off the intake on the passenger side. I would say both should be used as last resorts.
Old 10-04-2012, 10:09 AM   #115
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Which version do you have? If you have the old school one, where do you have the line for port c hooked up?
Old 10-09-2012, 09:03 AM   #116
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Update: After several e-mails to Synapse, I supposedly have the port c line routed "correctly" as it's t'd off from the vacuum line going from the compressor to the mbc.
Old 10-09-2012, 05:36 PM   #117
NITROS
Member#: 41561
04 GT3076 2.1
Sorry, I didn't check this thread in a while. I'm glad you have it figured out.
On my sb001, I have a internal c-port per their latest design. I linked the image from synapse's website below.
Old 12-17-2015, 12:36 AM   #118
joek92
Member Sales Rating: (5)
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Here comes a great wall of text
Ok I'm going to buy an adjustable bov/bpv and do a thorough seat of the pants review - drive the Dragon & some back roads, maybe some gravel donuts etc.
Currently when I take off in 1st, lift, then back on throttle there is a noticeable delay then BAM its boosting to redline. Also the evo3 16g not good transient response (between shifts) compared to the vf39. With that in mind we will see if these bpv/bov really do 'shut faster' and 'boost quicker' like salesmen say they do.
This article got my interest
http://www.speedhunters.com/2015/11/...t-bov-install/
"the thing that surprised me the most was the perceptible difference in boost response during fast gear changes.."
Which one should i get nasioc? I think it will be synapse
http://www.motoiq.com/MagazineArticl...ter-Valve.aspx
Boooooooooooooooooooooooooost!!!
No more lag (well, much less). I was really not prepared for such a big difference. I have the Synapse DV thanks to Arista performance - great guys and subie owners.
To put this review in perspective you need to know some details:
1. 07 STI with evo3 16g 10cm hotside. The more lag you have now, the bigger improvement you will see (that's just a theory) I felt this turbo had much more lag than the vf39. To think I was actually considering a ball bearing chra and 8 cm hotisde haha not anymore.
2. I subconsciously analyze the car to find things I don't like and then obsess over them, lag being a major one.
3. Roads are curvy around here - feathering throttle mid-turn. I hardly ever go wot
4. Experience: 04 STI vf39 with ebay bov (not sure psi or injectors) That was an animal! Tail happy and wicked fast spool. 07 STI with APS 50/50 dual vent off an Evolution - seemed to make it bog between shifts no matter how i adjusted it (never oiled it, probably should have). OEM dv - delay between foot and turbo. Transient response was disappointing but I thought it was the turbo size and i would have to live with it. False.
Now go do some research on the synapse dv because it's all true. Can't compare to other aftermarket dv because I haven't had experience with them. What i can say is that when I put my foot down a bit, instantly there is boost pressure building. With the OEM dv there would always be some delay while it tried to decide whether it wanted to boost or not :/ Transient response is responsive! It doesn't irritate! I will have to find something else to nit pick... oh yea understeer.
I have only driven a few miles so far but couldn't wait to share. It gave me a rush. Now I am actually excited to hit the Dragon. It hasn't been much fun because lag+tight corners = no sweet spot.
Setup - push configuration (piston facing intercooler) only using 'B' vacuum port. Capped off 'A' port.
The clamps were kind of a pain but very high quality all around.
Noise - can't hear anything over the EWG chuff chuff. Apparently it's pretty quiet. You can make it full atmospheric dump which would be louder but bog between shifts (from what I've learned about mass air).
I'll post again after more thorough testing.
On the 12 psi map it doesn't feel any different. But on 18 psi it is wild! Feels like my old 04 that I get so nostalgic about. Got on it a bit tonight and there is a big butt dyno improvement. I'm very happy. Put your foot down and it's like you can feel boost coming through the gas pedal. Between shifts it's right there. You know, that would be a good thing to data log - boost pressure, rpm, and throttle position through all gears, oem dv vs. synapse dv.
Ever since my 04 sti blew I have compared this car and found it lacking. I was looking at getting a VF39 like it had, 04-05 trans for shorter 2-3-4 gears, or a 8cm hotside, all in the name of spool. And this diverter valve has successfully solved the problem.
At idle you can hear it snap shut the moment you rev.
It's funny because while doing an etune with a great tuner he didn't have a good suggestion on how to get faster spool. I suffered with lag for almost 2 years when it could have been dealt with in a few minutes.
Thank you Synapse Engineering for fixing my car. I like it now.
joek92 is offline   Reply With Quote
Synchronic BOV w/ Greddy Adapter - $175 Shipped CO WRX Engine/Power/Exhaust 23 08-14-2008 11:36 AM
Synchronic BOV STIFLYBY_RANGER Newbies & FAQs 18 03-11-2008 08:59 PM
Synapse Synchronic BOV 05 WHT STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-24-2008 09:45 PM
synapse synchronic bov wade869 General Community 0 10-30-2007 04:56 PM
Synapse Synchronic BOV... InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-16-2007 12:52 AM
