Old 05-21-2011, 08:09 PM   #1
bdom
Member#: 283317
Default Deactivate Hill Start Assist on 2011 WRX
I took delivery this week on a 2011 WRX. It has daytime running lights. As I did with my '02 WRX wagon, I disconnected the wire to the hand brake switch and grounded it. This turns off the daytime lights all the time, not just when the handbrake is engaged. Apparently, this maneuver has also disabled the hill start assist as well. Which is just fine with me. I've looked around and have found no other work around, save having a STI where Subaru offers it with the car. Just tried it a couple of times, but it seems to work. Am interested to hear from others to see if this is real. Maybe I'm hallucinating. Downside is handbrake light is always on when car is running. Had the same thing on my other car.
bdom is offline   Reply With Quote
Old 05-21-2011, 08:23 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
since when did 02 imprezas have DRLs?
nhat is offline   Reply With Quote
Old 05-21-2011, 09:24 PM   #3
bdom
Member#: 283317
Thought it was an '02. could be wrong. Was a bug eye. bought it used and kept it till I got my '04 STI in the summer of '03.
Old 05-21-2011, 09:41 PM   #4
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
My 03 has DRLs...
03SubyWRX is online now   Reply With Quote
Old 05-21-2011, 10:14 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by 03SubyWRX
My 03 has DRLs...
interesting. i've got an 02 wagon and a bastardized 03 sedan, neither have DRLs.
Old 05-24-2011, 10:35 PM   #6
bdom
Member#: 283317
So, I've been driving around for several days now and the hill assist is truly disabled on my 2011 WRX. Have not found any other solution posted on the internet to turn off the hill assist on my car. The only cost is the dashboard brake light that stays on once you release the handbrake. Any testimonials out there?
Old 05-24-2011, 10:41 PM   #7
Baddmnkey
Member#: 211812
09 WRX
SSM, mostly stock!
Hmmm interesting, I cant stand the hill assist! Good find and thanks for posting.
Baddmnkey is offline   Reply With Quote
Old 05-24-2011, 10:49 PM   #8
bdom
Member#: 283317
It was just dumb luck. I was disabling my daytime running lights. But what good luck. I hate the hill hold too. And I just got the car last week.
Old 05-25-2011, 02:21 AM   #9
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
My 02 wagon definitely does. They're disabled...but that's another story.
OrbitalEllipses is offline   Reply With Quote
Old 05-25-2011, 02:23 AM   #10
nhat
Member#: 140163
03 STi
hellaflunctional
i guess the guys i bought the 02 wagon and 03 sedan disabled them
Old 05-25-2011, 02:33 AM   #11
teiva-boy
Member#: 22825
The hill assist can be tweaked in other subaru's.. It's just a cable adjustment. You can make it more sensitive or less. This is the case with my FXT.
Personally I love the feature in the hilly downtown seattle area and other places. I don't think I want a car now without it. It's something you can learn to work with and learn to love.
teiva-boy is offline   Reply With Quote
Old 05-25-2011, 09:17 AM   #12
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Unfortunately the newer hill holder is all electronic via the VDC. It can only be turned off in the STI.
The newer one is a little slower to release than the old hill holder, like it has to realize the car has started to move before it lets go where the old one was linked to the clutch pedal. I've totally gotten used to it. But you can't be the cool kid that advertises to the world you still drive a stick by rolling back a li'l before you take off. I can live with that.
Power6 is offline   Reply With Quote
Old 05-26-2011, 08:17 AM   #13
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I thought DRL's were more easily deactivated by simply unplugging the DRL control module? That's all I did in my '05 WRX. That would allow you to keep your hill-holder (if you so desire) and not have your e-brake light on all the time. Keep in mind that having the e-brake light on all the time means you don't know if/when it turns on for other brake system problems.
Scooby921 is offline   Reply With Quote
Old 05-26-2011, 08:56 AM   #14
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1 you can just unplug the module. This works too.
Nice find!!!
Old 05-26-2011, 11:09 AM   #15
issueslude99
Member#: 280335
Nooby question. Anyone know where the DRL control module is on the 2011.
issueslude99 is offline   Reply With Quote
Old 05-26-2011, 12:23 PM   #16
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
I don't see why they'd have moved it, it's behind the bumper cover (or in front of the fender liner) on the passenger side in my 2010. I unplugged it then just removed the module since there's no point having it just sit there. And I covered the loose plug with electrical tape and zip-tied it behind the horn.
2point0 is offline   Reply With Quote
Old 05-27-2011, 03:48 PM   #17
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Are you talking the DRL control module or just the DRL resistor? In my '05 WRX the actual control module was inside the cabin of the car in the front passenger foot well.
Old 05-27-2011, 03:59 PM   #18
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
...and now that I think about it, neither lighting nor transmission/driveline have anything to do with suspension, brakes, or steering. This thread will be moving to the trans/driveline forum.
Old 05-27-2011, 07:52 PM   #19
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
There is no control module in the newer cars. You have to disconnect the resistor, or I found you can snip a pin off a relay and take them out too.
Old 06-29-2011, 11:04 PM   #20
please
Member#: 204758
I figured out how to disable hill assist on 2011 wrx. well i used an idea from a member on iwsti when i used Google. The car has two clutch sensors, one for safety switch on clutch other for cruise control/hill assist. The top of the two sensors is for hill assist and cruise. If you can figure a way to keep pin pushed down all the time hill assist hill never activate. Now i used a closed nut and adjusted sensor up a little to make room for nut. You need a 10 and 1.25 metric nut. now i have limited stores around me so i had to use a 10 and 1.50 closed nut and put a very small hex screw inside to push pin down and screw on slightly enough to stay on..
negative side effect is if using cruise control and hit clutch your engine will rev up. well if your smart and hit the break or cancel on cruise control you will be fine.
please is offline   Reply With Quote
Old 07-19-2011, 10:00 PM   #21
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
"please"
What about putting your foot in the clutch and at the same time shifting into neutral? Will cruise control disengage?
Mike 01Hawk is offline   Reply With Quote
Old 07-28-2011, 12:50 AM   #22
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Just curious why you would want to disable drls?
midwestmonster is offline   Reply With Quote
Old 07-28-2011, 01:19 AM   #23
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Cause I occupy my ADD self sometimes at the light by rockin... lol
I also like to roll back a bit to give the A-hole that is crowding my bumper a bit of a fright.
Old 07-31-2011, 12:01 AM   #24
bdom
Member#: 283317
I like to choose when I use headlights. Same with windshield wipers, brakes, turn signals. I'm just old fashioned like that.
Last edited by bdom; 07-31-2011 at 12:06 AM. Reason: mistake in trying to quote prior post
Old 08-03-2011, 10:33 PM   #25
please
Member#: 204758
Originally Posted by Mike 01Hawk View Post
"please"
not sure off top my head, i can try it and let you know... if i remember
but if you hit cancel, cruise button or brakes the cruise control will disengage
VDC and Hill start assist warning lights on docsmitty Service & Maintenance 19 10-31-2011 02:20 PM
hill start assist? blackzilla69 Newbies & FAQs 19 02-07-2011 11:02 AM
" Hill Start assist " can it installed in Impreza Sedan 2009 M/T 1,5R !?!? # ahmad7610 Brakes, Steering & Suspension 17 04-21-2009 04:39 AM
Ford develops new hill start assist for manuals BlownGasket Non-Subaru News & Rumors 2 11-09-2007 04:48 AM
So about the 08 Impreza hill start assist... moestock Newbies & FAQs 22 10-12-2007 09:46 AM
