Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 05-14-2011, 10:37 AM   #26
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Can't wait! Its going to be Epic
See you guys out there
wrxsubiemod is offline   Reply With Quote
Old 05-23-2011, 06:12 PM   #27
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Had a great Saturday morning-
JC went out in the first session and put down a 1:23.141, which set a new mod class track record over the Cobb GTR. I have some in-car that I'll edit and upload tonight.
Parked the car the rest of the day and went out Sunday morning to try for a high 1:22 when something went pop coming out of turn 1.
Today we found this:
So it was nice of the motor to hold up for most of 4 races:
Superlap battle in November where we set the track record there for Mod
Speedventures time attack in march where we tested the new front end aero
Modified Mag shootout in April- results will be in the August issue
and then this first Global Time Attack, where it lasted just long enough.
So we're not really surprised with the boost we're giving this thing. It's really tempting to go sleeves, wills rings, and oversize studs...
AQ Motorsports is offline   Reply With Quote
Old 05-24-2011, 01:22 AM   #28
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Old 05-24-2011, 06:38 PM   #29
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Sucks that it split. I do however wonder if more people will believe me now when I say sleeves are still going to split even with the 'closed deck' outback block...no replacement for getting sleeves.
So does this mean you guys have data now?
sounds like you guys have the right idea with rings and sleeves to keep the foundation of the motor strong. Don't forget pinning the mains too.
CONGRATS on the time!!!
Old 05-24-2011, 06:55 PM   #30
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
its outfront.....they had to change it from outback.
Phatron is online now   Reply With Quote
Old 05-24-2011, 07:27 PM   #31
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
yeah... about that data,
when Shawn was downloading the logs from Saturday morning the process froze and we got nothing. Then the dash and on switch weren't working right either so the master got cycled and everything seemed well. It makes me wonder if some sort of a glitch in the ecu, tune, or wiring had something to do with the failure but on the otherhand it's really not unexpected.
So sorry guys, data analysis is something I really wanted to spend more time doing this season and so far we haven't.
Oh and also the crank broke and some rods are bent.
We're getting WELL into 6th after an 8000rpm upshift. Should be somewhere north of 170 on the front straight.
Old 05-24-2011, 08:17 PM   #32
Homemade WRX
Member#: 33782
96 bastard child
weren't you guys on a BC billet?...that marks yet another snapped BC crank if so.
Old 05-24-2011, 10:10 PM   #33
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Wow guys that sucks. But great times as always.
Old 05-25-2011, 03:18 PM   #34
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
I'm really not all that surprised. This was a motor we threw together in a two week rush before superlap, and the crank got re-used after this happened last november:
the crank was actually bent after that one and we had it straightened, magnafluxed, and put it back in.
Other than the crack the shortblock that just came out is in good shape. We will probably have it sleeved now and get some oversize headstuds. What I think must have happened is the cracked cylinder let water in the chamber, and that bent the rods and broke the crank.
Old 05-25-2011, 05:01 PM   #35
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
Were those 100mm pistons?
Crystal_Imprezav is offline   Reply With Quote
Old 05-25-2011, 05:30 PM   #36
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
yes. We cracked a stock 99.5mm sleeve awhile back on much less power and I'm still unconvinced that going to 100mm = instant broken case. Really it was just that we were making so much power and boost on a mostly stock block.
Let me add up the number of laps this thing did:
~10 laps at SLB set to 32psi
~8 lap test day at speedventures with 25psi
38 psi tune for the GTX35R
two dyno pulls and two drag passes at modified shootout at 38psi
3 auto-x laps at modified shootout @30psi
5 hot laps at modified shootout @35psi
3 hot laps at GTA @35 psi
so about 30 laps total and only about 20 at over 30psi.
The previous motor, which was nearly identical, lasted a lot longer but never ran an event over 650whp.
Old 05-25-2011, 06:26 PM   #37
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Congrats on the new record! That's awesome and great driving!
Really sucks it let go on you though. I've heard that the bigger studs distort the block and guys up here are now using L19's instead, have you any thoughts to this?
I plan on running 30+psi and wonder if my studs (Stock diameter ARP's) will be the week link on my sleeved block?
Good luck with the new motor...
Old 05-25-2011, 06:44 PM   #38
GrimmSpeed
Member#: 136396
2012 wrx
white
Congrats on the great start to the season, it's nice to see you guys doing so well! we hope the rest of the year stays on pace!
Mike
Old 05-25-2011, 07:11 PM   #39
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
We're using the Cosworth L19 studs and stock headgaskets and I can't recall the last time we've lost a headgasket.
Ideally I would like to go all out on a build, but I can't help but wonder if we would just be breaking more expensive engines.
Here's some wrc eye candy in the meantime:
and motoiq has some good pictures of the car in their write up of the GTA event:
http://www.motoiq.com/magazine_artic...s-at-wsir.aspx
although JC decided to list the car as the OMG racing STi...
it also put us up to 9th overall fastest time attack car at WSIR:
http://hellafunctional.com/?p=490
I think as is (was) the car is good for a high 1:22 and a set of C91s should put it well into the 1:20s. LIC put on some slicks for the NASA TT session and picked up over 2s, winning TTR with a 1:23.136
Old 03-18-2012, 01:02 PM   #40
Utahmortgagepro
Member#: 134953
2004 STI
Updates! We need updates! JC Your car is absolutely amazing. I would love to be able to contact and ask questions!!
Utahmortgagepro is offline   Reply With Quote
Old 07-19-2012, 03:39 PM   #41
carlitos_s203
Member#: 233254
Chapter/Region: PRSIC
2005 Impreza WRX STI
WR blue
my favorite time attack sti ever!!!!!
carlitos_s203 is offline   Reply With Quote
Old 11-06-2012, 02:56 PM   #42
toffee
Member#: 245783
+1
Really like the look of this beat, been reading your build thread. front aero and wheel arch set-up looks cool.
toffee is offline   Reply With Quote
Old 11-06-2012, 03:14 PM   #43
logic246
Member#: 225907
That crank has to be used with the WRC rods , older block and WRC pistons.
logic246 is offline   Reply With Quote
A video I did for the TopSpeed GC8 time attack car. DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 20 09-05-2008 03:51 PM
P&L Motorsports Prepped, Takata Time Attack Car. 1st in class on debut showing! P&L Motorsports Inc. Proven Power Bragging 22 07-30-2008 06:50 PM
GST Motorsports Time Attack car goes 10.76. GST Motorsports Proven Power Bragging 25 05-30-2008 09:52 PM
We took the Time Attack car to the drag strip. GST Motorsports Proven Power Bragging 55 05-03-2008 08:51 AM
Message Board Statistics All times are GMT -4. The time now is 01:55 AM.
