Old 07-22-2010, 12:01 PM   #151
biodtl
Member#: 206570
I could use a bit more clarification for those of us who don't know any better. If I follow the method described in the P&L document, I see in the picture they have a single hose clamped off right above the PVC cap. Is that the ONLY hose i need to clamp off/plug along with leaving the oil cap off?
biodtl is offline   Reply With Quote
Old 07-25-2010, 11:45 AM   #152
biodtl
Member#: 206570
Anyone?
Old 08-03-2010, 08:51 PM   #153
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
bumped
FleaDog is offline   Reply With Quote
Old 08-03-2010, 09:10 PM   #154
jarrenishere
Member#: 250624
sweet that is using your head
jarrenishere is offline   Reply With Quote
Old 10-26-2010, 11:15 PM   #155
Hendo
Member#: 124804
2002 Impreza WRX Wag
i got creative with this, cuz i didn't want to leave the house:
i used :
an empty artichoke hearts can (happened to be the same OD as the ID on one of my inlet couplings
a valve stem from a flat tire on an old bicycle
general purpose caulk
drill a hole in the empty can thats about the size of the valve stem
caulk it in from both sides, making sure its airtight, let it cure overnight
voila
Hendo is offline   Reply With Quote
Old 05-26-2011, 12:58 PM   #156
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Bump because I haven't been able to find the right answer.
I was hoping you could help me figure out if pinching these 4 places is sufficient. I had seen talk of pinching a 5th location, but I can't find anything else that connects to the intake line
I found this image on a boost leak tester site. The only difference I can see is the top right line by the BPV. I don't know where that comes from, nor is it clear on my car which line it is. The arrow just left of the bright red rubber cap seems to split into 2 lines. I had assumed I would cap it closest to the intake tubing, but is there a reason I should pinch it after this junction (in between the round part and the intake manifold) ?
any/all help would be greatly appreciated
I assume the one I am missing is this:
but that line seems to have travelled a long way if its coming from the air intake to get there
IceWilly is online now   Reply With Quote
Old 06-30-2011, 11:01 PM   #157
soob noob
Member#: 220158
02 bugeye
medamullet tuned
bump.. im still a little confused as to what i need to block off.
so from the pics above do i need to disconnect those hoses and block both openings from disconnecting those hoses? does that make sense?
also im doing this on a wrx so is that different than doing it on the STi?
soob noob is offline   Reply With Quote
Old 07-12-2011, 01:53 PM   #158
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Bumping this for some clarification.
On the stock turbo inlet and after MAF pipe, I couldn't find a PVC cap at Home Depot that would fit tightly inside the after MAF piping. The PVC only comes in whole sizes. 2", 3" etc.
The 2" is too small and the 3" is too large.
Also, where can you get a shrader valve?
Brock31 is offline   Reply With Quote
Old 07-22-2011, 01:02 PM   #159
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Bumping again...
I have sourced the parts to fabricate a tester of sorts.
I just would like to clarify the hoses to be clamped off in the pictures above. Is it 4 hoses or 5 ?
Old 07-23-2011, 10:39 PM   #160
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Originally Posted by IceWilly View Post
Can someone identify the "valve" / connection that is identified with the upper-most red circle? Just above the intake manifold to the left of the throttle body.
That connection has a sensor on it that when I unclipped, found the section that is connected to a hose just basically hanging there. The connection was very loose.
I was able to plug the hole with my finger while pressurizing the system. Now I can hear air leaking from what seems to be underneath the upper coolant tank?
Any ideas?
Old 07-23-2011, 10:52 PM   #161
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Bump...
Old 07-24-2011, 08:21 AM   #162
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
....crickets....
Old 07-24-2011, 08:46 AM   #163
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I think the 05 Sti and WRX have an in-line sensor, white or grey in color on that hose. that is supposed to detect a leak and throw a code.
The Sti has dual hoses venting the breather cover for the PCV. There is a PCV cover under the overflow tank. One of the two hoses would be blocked if you did a good job blocking hose #3 to the bottom right.
I am new to Sti PCV routing, so I never traced the second set of PCV hoses. Trace it and block it.
Most likely even when you're done with blocking the hoses, you're not done yet. You will have to turn the crank manually slowly, as you feed air into the test rig, to find the valves closed position.
Depending on which turbo you have, it may let air go directly into the exhaust, from the compressor housing. It may not do that hot, but do that cold.
Old 07-24-2011, 10:09 AM   #164
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Tanks Vlad.
How do I turn the crank manually?
Old 07-24-2011, 11:36 AM   #165
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
...bump
Old 07-24-2011, 12:09 PM   #166
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
OK...so this leak under the upper coolant tank has been found. Air is leaking out from the base of the front pass. side injector. I have also found that turning the crank manually stops that leak , but also prevents me from building any pressure. I have plugged all hoses except for the smaller hose next to the BPV. I can hear air entering the engine I think, but I don't know where.
Old 07-24-2011, 04:07 PM   #167
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Well, you found a leak by the injector, right? that's good news, you're moving forward. Replace that o-ring.
Old 10-03-2011, 11:16 PM   #168
giroyac
Member#: 294761
thanks for the write up
will come in handy
giroyac is offline   Reply With Quote
Old 04-24-2012, 12:26 PM   #169
Blow0515
Member#: 296768
I know it is not as cool but can I put air in the system with a nice bike pump. All my tools were stolen and I am going to wait until Fathers day to get a new compressor to hopefully find one on sale.
Blow0515 is offline   Reply With Quote
Old 04-27-2012, 02:58 PM   #170
Blow0515
Member#: 296768
Found a leak fixed it now to see how things work out!
This just in - the War on Drugs is a complete failure FightingFalcon Political Playground 2753 01-09-2016 02:24 PM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
Swap complete, just lost the clutch! SJwrx Pre-2002 Factory Turbo Powertrain 9 05-08-2010 01:56 AM
The longest lasting DIY paint your wheels thread chimchimm5 Tire & Wheel 1 04-03-2010 01:26 PM
Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. Chandy69 Tri-State Area Forum 13 05-09-2005 05:58 PM
