Old 05-27-2011, 10:10 AM   #1
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Default AMS built and tuned 2.5l 2008 STI, 450+ whp on a 20g.. on a Mustang Dyno.. :O
Really really impressed with this car. Making 454whp on a 20g is pretty stout, but when you realize that this would be about 490whp on our Dynojet it becomes simply astonishing. And to top it off, it makes power faster than the stock turbo!
Car: 2008 STI
Tuner: Mitch @ AMS Performance
Dyno Info: Mustang MD-AWD-500
Transmission: Stock 6 speed
Gear: 4th
Peak HP at RPM: 454 SAE CF
Peak Torque at RPM: 391 SAE CF
Baseline hp/tq for a stock on same dyno: 211 whp
Target Boost: 26 psi
Target AFR: 11.4:1
Fuel: e85
Engine/Power Modifications:
Built Motor -
Kelford 264/260
GSC Beehive Valve Springs and Ti Retainers
ARP head studs
CP 9:1 Pistons
K1 H beams
K1 billet crank
Blouch 20g-XT 7cm^2
P&L EWG Up Pipe - 38mm TiAL v-band
Custom Supertrapp Muffler EWG dump tube for track dB limit
P&L Cat Back
Catless downpipe
Perrin Turbo Inlet
Process West TMIC
ID 1000cc
Other Modifications:
TGV delete
Air pump delete
Grimmspeed 3 port BCS
Cobb AP
Miscellaneous other suspension/etc. upgrades
AMS is offline   Reply With Quote
Old 05-27-2011, 10:19 AM   #2
Rizen
Member#: 157002
2011 STI
All these cars getting crazy #s on E85 makes me wish we had it in my area.
Rizen is offline   Reply With Quote
Old 05-27-2011, 10:22 AM   #3
xsnapshot
Member#: 170973
2004 WRX 4EAT
So this dyno had the stock turbo'd car peaking at 274 on E85? That is a low reading dyno for sure. Boost seems a little odd to, as it's not peaking until ~3500 RPM stock turbo. Is this the dyno loading the car differently?
It would seem to me, that if this power level is accurate, then perhaps the 7cm^2 turbine housing really isn't as restrictive as most nasioc members make it out to be? And yes I know it has an EWG and cams, but still, for a 7cm that's impressive! Good work AMS!
xsnapshot is offline   Reply With Quote
Old 05-27-2011, 10:31 AM   #4
AMS
Member#: 27854
STI, WRX, GTR, EVO,
The stock turbo plot has a stock motor, no EWG, etc. so keep that in mind. Also, the Mustang dyno reads about 300rpm slower than our Dynojet due to the difference in load.
-Ty
Old 05-27-2011, 10:39 AM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
[B,][/b]
I would said that is a weak VF48 on E85 not a low reading dyno, we know how much a VF48 on E85 makes on GST dyno and it makes more than that. EWG makes no difference on a VF turbo.
I am impress with this new 20g, is making 30-40 more than my OG green. Very impressive indeed.
Good job AMS
Old 05-27-2011, 10:45 AM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I love the flat torque curve!!
Old 05-27-2011, 11:13 AM   #7
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Thats a really nice power band. WHat did it do without SAE CF?
Old 05-27-2011, 11:14 AM   #8
CatfaceType-R
Member#: 81102
@homeade: yup, that must be a nice pulling car
Old 05-27-2011, 11:15 AM   #9
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
^that's what I'm talking about! Those cams are really doing their job, that torque curve is beautiful! Are you sure you didnt accidently post an Evo's chart?
Old 05-27-2011, 11:21 AM   #10
dmross
Member#: 2818
2000 2.5RS
That might be one of the nicest power bands I have ever seen posted on this board. I bet that car is a blast to drive, nice work!
dmross is offline   Reply With Quote
Old 05-27-2011, 11:22 AM   #11
Badler
Member#: 133597
Old 05-27-2011, 11:24 AM   #12
juanmedina
Member#: 133146
How much does it out down uncorrected? What are the IDC? U Should be out of injectors with the Id1000s at stock fuel pressure.
Old 05-27-2011, 02:17 PM   #13
bilt2run
Member#: 134211
^^^ yea..something aint right, I have id1000's with my base pressure set at 53psi and I'm at 100% duty cycle on e78 at about 6800rpm, 11.7af only making right around 340whp dyno dynamics..
Btw: tdo6sl-2 20g 8cm 23psi
bilt2run is offline   Reply With Quote
Old 05-27-2011, 05:52 PM   #14
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
Nice job guys! The car looks like it's a blast to drive
TERRY...
P&L Motorsports Inc. is offline   Reply With Quote
Old 05-27-2011, 05:58 PM   #15
AMS
Member#: 27854
STI, WRX, GTR, EVO,
The car is at about 90% IDC, but they have not become static. I doubt there is any more power this car could make on e85 with this fuel system set up.
Uncorrected for both plots:
Old 05-27-2011, 11:02 PM   #16
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Great job AMS! I talked with Mike after he left your place and he is one happy person for sure
Wish I could be Co-driving his car this weekend in Nebraska...damn on call hahaha
I guess next weekend will have to do
kayen is offline   Reply With Quote
Old 05-27-2011, 11:23 PM   #17
RCMASTI
Member#: 265967
2010 STI SE
On stock headers?!
RCMASTI is offline   Reply With Quote
Old 05-28-2011, 08:04 AM   #18
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Stock fuel rails too? What pump?
trex616 is offline   Reply With Quote
Old 05-29-2011, 11:23 AM   #19
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Originally Posted by RCMASTI View Post
On stock headers?!
I can answer those questions for you guys.
Yes and Yes, also it has a Walbro Pump the last time I knew.
Old 05-29-2011, 11:47 AM   #20
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Impressive. I've heard 1000s are generally the limit on a stock single Walboro, I wonder if 13's rails and an extra pump would yield any more power out of this already impressive setup. I guess if they're really only at 90% IDC on E85, its probably perfect the way it is.
Old 05-29-2011, 11:59 AM   #21
RCMASTI
Member#: 265967
2010 STI SE
That is awesome. I guess I over-modded and could have stayed tmic...
Great job.
Old 05-29-2011, 12:04 PM   #22
SVT_WRX
Member#: 164830
G61 III OVE 58e
With a filter value of 1....that's a pretty damn smooth curve.
11.4 on E85 seems to be my magic number too...
Nice work.
Oh, and update your first post to include your peak RPM's.
SVT_WRX is offline   Reply With Quote
Old 05-29-2011, 12:38 PM   #23
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Great job.
A lot of 30R guys stay TMIC and have killer street setups.
http://forums.nasioc.com/forums/show...light=30r+tmic
Old 05-29-2011, 02:17 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
Something is way off here. The vf48 should be making at least 320-330whp on e85 and there's no way you're pushing 450whp on ID1000's on E85 at stock pressure. Not to mention the walbro wouldn't keep up with that flow either. None of this adds up.
-- Ed
Old 05-29-2011, 03:02 PM   #25
SVT_WRX
Member#: 164830
G61 III OVE 58e
Uh oh...don't tell me we have another effed with Mustang dyno...
Lets see some road dyno logs and plots...
2005 STi - 426whp/425wtq Mustang Dyno EFI Logics Built and Tuned... MacSti Proven Power Bragging 13 09-26-2010 08:49 PM
Dyno Tune 2.5L VF-39 on E85 makes 336WHP 385 WTQ blackdub06 Proven Power Bragging 12 06-18-2010 11:46 AM
dyno tune 2.35L Ej22t sti heads gt35r 571 whp @ 25 psi Rod702 Proven Power Bragging 28 04-30-2010 09:58 AM
Dyno Tune: Motion Lab Tuning Makes 264whp On A '02 WRX TD04 + 2.5L w/STi Cams Motion Lab Tuning Proven Power Bragging 7 02-09-2010 06:17 PM
Privately owned, built, and tuned STI breaks 800+ whp liberty2000rs Proven Power Bragging 380 10-26-2009 08:19 AM
