Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 06-01-2011, 06:56 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default .049" wall 2.5" SS bends for IC piping - where to buy?
Does anyone have a source for these? I ordered some from siliconeintakes.com but they just informed me that they're out...
Bad Noodle is offline   Reply With Quote
Old 06-01-2011, 07:11 PM   #2
AREA1320
Member#: 112508
pretty thin...why not just use 16g? easier to find
AREA1320 is offline   Reply With Quote
Old 06-01-2011, 08:42 PM   #3
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
The pipes I have are that thin. I have a couple 16g pieces and there's also a very noticeable weight difference. I'd like to keep it all the same.
Old 06-01-2011, 09:22 PM   #4
TIGWERKS
Member#: 256615
spd exhaust stocks a ton of different radius/OD/wallthickness combinations will have everything you might need and more......... .049" isnt really that thin, just need to learn some finesse there buddy (area1320)
Also if you go to woolf aircrafts webpage, go to there surplus bend section and you'll find VERY cheap bends there in very thin thicknesses. Ive got some thin .030" tubing from there before as well used some large 4" tube on a 4" bend radius before. Very nice guys there and very helpful. Plus they carry the exotic stuff which I like.
TIGWERKS is offline   Reply With Quote
Old 06-01-2011, 09:55 PM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ F-yeah thanks buddy
Old 06-01-2011, 10:12 PM   #6
AREA1320
Member#: 112508
Oh hush Kelly :P
Forgot it was ic piping lol. Im so used to using aluminum for ic piping
Old 06-01-2011, 10:44 PM   #7
TIGWERKS
Member#: 256615
lol....damn east coasters
Old 06-01-2011, 10:53 PM   #8
TIGWERKS
Member#: 256615
Your welcome!
Old 06-02-2011, 12:23 AM   #9
TIGWERKS
Member#: 256615
Did you ever get that rotated setup figured out and finished?
Old 06-02-2011, 07:58 AM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Still working on it :/ Slowest project ever. Constantly running into problems. First it was the precision drain valve adapter wouldn't fit to any NPT to hose fittings, then had to figure out what to do about the cooling lines, removing the coolant reservoir, now it's the IC pipes, and still don't know what I'm going to do about the BOV as Forge wouldn't sell me the 1" female NPT to hose barb fitting they use so I can get rid of the sti flange. Some parts had a little wait like the 3" metalic cat I'm going to be putting into the system, the GT spec header I have uses a 2.25" id uppipe while the VBand rings are for 2.5" OD pipes... and I could keep going. Seems that getting the right pieces and fittings is like 80% of the work.
SS brake line copper washers - where to buy mmiller2002 Brakes, Steering & Suspension 4 03-08-2010 03:07 PM
Red vinyl for taillights - where to buy? elwray Private 'Wanted' Classifieds 21 03-14-2009 08:24 AM
stock radio harness for 05 cd changer - where to buy? Sausage Car Audio, Video & Security 5 05-06-2006 03:35 PM
DIY IC Spray - Where to Order Nozzles? IndyRacer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2005 09:54 PM
Raceline Wheels - Where To Buy, How To Paint? dch Brakes, Steering & Suspension 9 08-13-2001 04:54 PM
