South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-03-2011, 11:55 AM   #1
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Default 2000 2.5RS Project: Daily Driver on the Cheap
I recently bought a 2000 2.5RS with a blown motor. My goal is to turn it into a reliable daily driver to replace my dutiful 1997 Impreza L 2.2 5MT, who while totaled, continues to run like a champ, but is getting a little long in the tooth.
My goals for this project:
1) Get her driving again much quicker than my last project (wagon of doom)
2) Reliable
3) Cheap
Here is what she looks like at this point:
Car details:
-169,555 miles
-2.5L SOHC MAP
-5MT
-$500
The good:
-AGX adjustable struts with stock springs
-Full poly bushing set
-Brand new tires
-New front bumper
-New headlight
-New passenger-side fender
The bad:
-Motor was starved of oil - rod knock - needs to be rebuilt
-Windows are SLOW and tint is tearing off - need to be rebuilt/retinted
-Leather wheel and shifter and gone - need replacement
-Driver-side seat is torn up
-Interior needs a deep clean
-Exterior paint is SHOT
-Sun roof is jammed
-Needs a better/complete stereo
I'm sure there will be more as I get into it.
kpluiten is online now   Reply With Quote
Old 06-03-2011, 12:10 PM   #2
SUBAWRECK
Member#: 276955
1st White and 2nd Blue
Hey I got a lot of random parts and don't ever mind helping if u need another guy to wrench let me know
SUBAWRECK is offline   Reply With Quote
Old 06-03-2011, 12:17 PM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Right on. Thanks! I'll let you know as the need arises. Where are you located?
Old 06-03-2011, 12:50 PM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
I got a spare NA 2.5 short block from a fellow member on here. I promised to trade him alcohol for it, but I never delivered the goods, so this motor was free. brocksdad is a sucker.
Either way, this motor also had rod knock despite having brand new bearings and despite having only run for a minute or two. What was strange is that this motor was from a 1997 Outback, which should have made it a Phase 1 DOHC 2.5. However, upon teardown, I found that the case and the crank were definitely Phase II as the thrust bearing was on #5 instead of #3 like the Phase I blocks. To compound things, the pistons in this block were definitely the old Phase I square relief ones. My guess is that this car had a warranty replacement motor at some point and Subaru repaired it with the updated block design.
Whatever the case may be (no pun intended) on the doaner motor, it looks like I can use the block and the crank for this build. This saves me the trouble of driving down to Tucson and pulling the motor from the RS only to drag it back up here for disassembly and rebuild.
Here are some pictures of what I found.
#4:
#3:
#2:
#1:
As you can see, the bearings are shot. It seems that the bearing in the rod end (not the cap) on each took the brunt of the damage. This makes sense.
What would you guess caused this? Lack of assembly lube? Not priming the motor? Improper clearances? Improper torque on the cap bolts?
Old 06-03-2011, 12:52 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
These stuck out from the top of the block by about 0.5-1.0mm at TDC.
The skirts seem very worn with even a bit of scoring. They are 99.0mm.
The crank looks to be in good shape with some scoring. I'm pretty certain it can be polished up and used with the correct bearings. What do you think? I know the pictures are not the best.
Old 06-03-2011, 12:53 PM   #6
kpluiten
Member#: 120273
06 WRBWRXWGN
Old 06-03-2011, 01:13 PM   #7
Evil Imports
Member#: 14732
+ 08 SG6 & 13 B8
Built not bought #0002
should have been my RS
Evil Imports is offline   Reply With Quote
Old 06-03-2011, 01:38 PM   #8
bObby
Member#: 66959
VF Engineer'd e46
M3 & vip'd 2GS GS300
This was one of those good deals I've seen for sale on this forum.
bObby is offline   Reply With Quote
Old 06-03-2011, 02:32 PM   #9
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
Scrapping old green? I hope blue will handle just as well... flat out.
Old 06-03-2011, 02:57 PM   #10
chubbsub
Member#: 176944
06 STI
Wow we have similar stories as far as finding a cheap GC with a blown motor haha. Currently waiting for the heads to come back from the shop then its on to reassembly good luck with this build man, and I'm always down to lend a hand if you need!
chubbsub is offline   Reply With Quote
Old 06-03-2011, 02:58 PM   #11
SUBAWRECK
Member#: 276955
In glendale phx area got a place that will do valve jobs for 120 starting and cheap cheap for seals and things that need to be replaced
Old 06-03-2011, 04:19 PM   #12
kpluiten
Member#: 120273
06 WRBWRXWGN
Ok cool. I will be in contact with you about them. I want to freshen up the heads while I have them out. I was looking at a mild grind set of delta cams too. Do you have any experience with those?
Old 06-03-2011, 07:08 PM   #13
Momosaurus WRX
Member#: 214737
Ken I've got a hook up at a machine shop. I can get your heads done for pretty cheap.
Momosaurus WRX is offline   Reply With Quote
Old 06-03-2011, 07:58 PM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
So I got a pretty reasonable explanation for why this motor got smoked on the forst 30 seconds of running:
Originally Posted by Storm View Post
That wasn't rod knock that killed the bearings. Using phase I pistons in a phase II setup is what killed the bearings. Check the heads too for a little dose of hammering, courtesy of those pistons. I'm surprised the builder didn't feel the resistance when hand cranking it during the timing process.....
Source some std size 99+ EJ25 pistons (A's) with but don't buy any bearings until you know what you'll need. I've got a set of + .25mm main/rod bearings and a set of std size main bearings, should you need some quickly. I can't use them, or return them....
Jay
Old 06-03-2011, 10:26 PM   #15
brocksdad
Member#: 107352
Not Respectable
Dick...
brocksdad is offline   Reply With Quote
Old 06-18-2011, 12:47 AM   #16
kpluiten
Member#: 120273
06 WRBWRXWGN
I started the easiest part of the motor build today, buying the components. Here is the list so far:
This car has 169,555 miles so I'm doing some extra maintenance parts while I'm in there.
1) Subaru OEM Gasket Kit - 10105AA860 - Purchased
2) NPR Piston & Ring Kit - Link - Stock size - Purchased (took a risk on these... we'll see.
3) ACL Bearing Kit - Waiting on sizing until after crank polishing. - Pending
4) Timing Belt Kit - PCI Belt, GMB pulleys and tensioner. Link - Purchased
5) Water Pump Kit - GMB Pump. Link - Purchased
6) Clutch Kit - Exedy KSB04.
LinkLink
- Purchased
7) Power Steering Pump Rebuild Kit - Purchased
8) Aluminum oil separator (to replace the crappy plastic one that leaks). - Purchased
9) 3-4" Outside Micrometers (and other sizes) - Purchased
10) 3.5-4" Inside, 3-point Micrometer (for bore size) - Pending
11) Assembly lube/sealant/fluids/filters - Pending
12) A second set of EJ25 SOHC heads - - Still looking
EDIT: I've decided NOT to build a second block. The NPR pistons were a bust... too small. I'm going to rebuild the block that's in the car.
Old 07-18-2011, 12:43 AM   #17
kpluiten
Member#: 120273
06 WRBWRXWGN
Ok, a bit of an update. I towed the car up from Tucson a couple of weekends ago. Turns out Jeep Wranglers are NOT a good tow vehicle. It was a SLOW trip.
Old 07-18-2011, 12:47 AM   #18
kpluiten
Member#: 120273
06 WRBWRXWGN
I had some friends over this weekend and we pulled the motor out of the car on Saturday. Today I tore the motor down to the short block.
I have not seen any of the internals yet, but there were signs of bearing damage in the oil.
Old 07-18-2011, 12:51 AM   #19
kpluiten
Member#: 120273
06 WRBWRXWGN
There were leaks EVERYWHERE on the block, from the PS pump to the cam covers. No wonder it ran out of oil. The heads look to be in good shape though as do the cylinder walls. I think I'll be able to have the heads refreshed with new seals and all, and then just do a re-ring, hone, and new crank/bearings and be on my way. Nothing extreme planned.
Old 07-20-2011, 11:45 PM   #20
dreadedwaygone
Member#: 149819
64 mustang
real cars are red
Default old block
Hey Ill give you some beer for the block you didnt use....
dreadedwaygone is offline   Reply With Quote
Old 07-24-2011, 08:39 AM   #21
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Wait, what? You mean that minivan v6 doesn't pull like a Cummins? Weird...
madmax_087 is offline   Reply With Quote
Old 07-25-2011, 02:04 AM   #22
blkscooby
Member#: 44422
2008 G8 GT
Burnouts on Central!
Nice Ken. Always loved the RS. Nice with a 2.0L turbo swap though. I tuned one with a 16g. Holy cow was it fast
blkscooby is offline   Reply With Quote
Old 07-25-2011, 11:21 AM   #23
SaabaruMike
Member#: 113342
You owe me a 10
second car.
Ken, are you still keeping the green car and the wagon? Just curious.
Also, why are you putting so much work into a NA motor? I'm sure a turbo 2.0 could be found on the cheap.
SaabaruMike is offline   Reply With Quote
Old 07-25-2011, 11:54 AM   #24
kpluiten
Member#: 120273
06 WRBWRXWGN
I was thinking about making a coffee table with it. If not, I'll let you know!
I know right!? That motor sucks. I miss the old tank I6 4.0L. Best jeep motor ever.
I love the look of these cars too. These things swapped are nuts. I will keep my eyes open for a wrecked 02-07 wrx swap car in the future.
I'm giving the green car to a friend who needs a car to get on his feet. I'll keep ownership of it though.
I'm looking for a solid daily driver now, not something I want to modify. I have the wagon for that. I'd like to spend about $1500 total on this car ($500 for the car, $1000 on rebuild). Then I will drive her for the next couple of years like I did with the Green car.
If the right donor car comes along however...
Old 12-29-2012, 09:22 PM   #25
davisclan
Member#: 283881
2004 WRX wagon 2.0
[quote=kpluiten;34393980]I started the easiest part of the motor build today, buying the components. Here is the list so far:
2) NPR Piston & Ring Kit - [URL="http://cgi.ebay.com/ebaymotors/Subaru-2-5L-EJ25-
I am looking at 2.0 WRX pistons how did yours hold up? I want a stock rebuild.
davisclan is offline   Reply With Quote
Can you put an STI crossmember on a 2000 2.5rs /w the stock RS stuff? Cyclops Transmission (AT/MT) & Driveline 3 03-12-2009 07:55 PM
WTB: 2000 2.5RS Drivers Seat crxtls2 NESIC Private Classifieds 4 06-17-2008 09:27 AM
socal: 2000 2.5RS Drivers seat pwrup25RS Interior/Dressup/Audio & Security 0 06-14-2007 11:34 PM
2000 2.5RS w/86k mi on the odometer P0325 on startup? AcquaCow Normally Aspirated Powertrain 2 11-16-2005 11:16 PM
('93-'01) Want some facts on the 2000 2.5RS, please help! UB_imprezzed Impreza Forum 6 04-18-2002 07:51 PM
Message Board Statistics All times are GMT -4. The time now is 01:05 AM.
