Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 12-23-2010, 10:25 AM   #201
Blackwagonman
Member#: 198088
Red
yup, if you match the design and specs ... xaviar appears to be another re-branded kamak turbo just like kinugawa.
Blackwagonman is offline   Reply With Quote
Old 06-03-2011, 06:56 PM   #202
thenic123
Member#: 259392
2007 WRX
WRC Blue
I sold my Kinugawa Turbo and bought a VF43.
thenic123 is offline   Reply With Quote
Old 06-04-2011, 11:10 AM   #203
teiva-boy
Member#: 22825
Any particular reason as to why?
teiva-boy is offline   Reply With Quote
Old 06-08-2011, 06:52 AM   #204
thenic123
Member#: 259392
2007 WRX
WRC Blue
Wanted a factory part.
Old 06-16-2011, 05:53 AM   #205
SCOOBMAN2011
Member#: 285788
I have used kamak rebiuld kits with no problems , also used a Kinugawa 18g which performed well.
SCOOBMAN2011 is offline   Reply With Quote
Old 06-17-2011, 02:29 AM   #206
Mr. Ed
Member#: 99211
2014 Legacy
money can't buy you love
Thought I would update ...my Turbo is still holding strong. Its been through hell and back...has now been on the car since October 2009. Will try and remember to post back next time she is on the dyno
Mr. Ed is offline   Reply With Quote
Old 07-12-2011, 05:39 PM   #207
slasherkill
Member#: 109186
dyno last week with td05-20g-8cm kamak turbo. at 1 bar with E85 producing 330 BHP. no problems so far, but its only been 1 week.
slasherkill is offline   Reply With Quote
Old 07-13-2011, 10:59 AM   #208
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
A recent Cobb customer in Austin made 350ish whp with a kinugawa (kamak) 18g on his 08 wrx. I dont remember if he was on E85 or gas. The turbos work. Even my old blouch 20g has kamak housings. Not sure about the internals, but it has held up well.
gabedude is offline   Reply With Quote
Old 07-13-2011, 11:05 AM   #209
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
I have a old DeadBolt TD06-20G. I want to rebuilt it before a slap it on for kicks. I plan to use a Kinugawa kit too rebuild it.
Ive used them in the past with good results.
rexworx is online now   Reply With Quote
Old 07-13-2011, 11:35 AM   #210
Mr. Ed
Member#: 99211
2014 Legacy
Very similar to my numbers at cobb plano...on a very conservative tune
Old 07-13-2011, 12:45 PM   #211
gabedude
Member#: 10108
07 STI
I would think a kamak td05 20g on e85 would be way above 330. I make more than that on gas with my 20g. On e85 I make over 400. But I have a ton of supporting mods.
Yeah, cobb trains their calibrators well. I still need to slap my car on Trey's dyno. I finally fixed all of my boost, vacuum, oil, and coolant leaks last night. I did a road dyno run on the way to work this morning. It read 368 whp and 408 wtq on gas. The tune is still rouugh though.
Old 07-14-2011, 12:50 AM   #212
Mr. Ed
Member#: 99211
2014 Legacy
I would think so to...i have the tdo5 18g kamak and hit 350/375ish on e85 @ only18psi .
Old 07-14-2011, 01:54 PM   #213
slasherkill
Member#: 109186
guys, thats only on 1 bar. and I have the 2.0 STi RA.
I have to change to newage coils before I up the boost, as my coils can't keep up.
what about posting some graphs with the td05-20g-8cm ??
Old 01-13-2012, 10:30 AM   #214
bisonjr
Member#: 102714
Anyone have any updates on the Kamak - Kinugawa turbos? Miles? Looking to maybe replace my fp18g with the same thing (only 8cm).
bisonjr is offline   Reply With Quote
Old 01-13-2012, 10:52 AM   #215
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You live 2 hours from Lebanon, PA, home of Blouch Turbo and they just came out with a ball bearing, billet wheel 18g. Think local bro...
Old 01-13-2012, 10:54 AM   #216
2gnt2wrx
Member#: 123625
2002 wrx
2015 wrx gbp
Think secret discounts bro?
2gnt2wrx is offline   Reply With Quote
Old 01-13-2012, 11:12 AM   #217
bisonjr
Member#: 102714
Thanks for the advice, that turbo is one of my options.
I was thinking more towards install and run some logs to verify everything is the same vs. an entire new tune.
Old 03-16-2013, 03:22 PM   #218
SubaruDood
Member#: 340058
Default Kamak and Kinugawa - Anyone?
I've been looking into the Kamak turbochargers recently. It seems they are still selling them as there is a group buy going on right now on the forum by http://www.steamspeed.com/. Anyone have any experience with the Kamak 20g on an STI recently? I know this forum is a bit dated, but I'd like to know what I can expect i power output as well as in durability. They have a no questions asked 1yr warranty, but I'm interested in knowing what experience people are having past that mark.
SubaruDood is offline   Reply With Quote
Old 03-17-2013, 06:45 AM   #219
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
I don't have much to add other than I bought a kamak p18 exhaust housing and it's almost identical to the factory turbo. It is evident that there is less attention to detail in the machining in some areas though.
It's hard to know what to make of it. If they can't pay attention to detail with something as simple as a cast exhaust housing, I'm not sure I would trust their complete turbos. then again the exhaust housing isn't necessarily a precision part in many ways, so it's possible that they just cut out "unnecessary" work.
YMMV
p951951951t is offline   Reply With Quote
Old 03-17-2013, 09:36 AM   #220
2011boostdwrx
Member#: 263470
360/380 mustang dyno KAmak 20GTX STS 8cm^2 IWG. Full stage-2, full build 6-spd swap 2011 WRX 23 psi. We are going to turn up the boost a bit, was thinking of going EWG soon, this is with Meth injection though. 1:1 HSF-3 Aquamist setup. FMIC full spool around 4100 rpm
Old 05-08-2013, 09:18 AM   #221
kmoleggygt
Member#: 284484
2005 20g lgt
I have been reading quite a bit on the Kinugawa turbos and think I will be going the 20g tdo6 with 8cm route. My question is will a billet wheel upgrade be worth the money. Have not seen any one that has menitioned if the upgrade is worth it??
kmoleggygt is offline   Reply With Quote
Old 05-21-2013, 08:41 PM   #222
Original-ATWRX
Member#: 357107
Hi everyone, I live in the UK and I've been researching these turbos quite a lot and ended up buying one thru' the steamspeed offer on here. I'm like the OP, I enjoy experimenting and not running with the crowd.
Just thought I'd let you know what I found about them.
KAMAK are the manufacturer of these turbos, the rest, kinugawa etc are brand names. KAMAK are also OEM turbo manufacturers for a few manufacturers, the main one being Hyundai.
How they appear to operate is that the KAMAK turbos are the best turbos that the company produce, uprated actuators, compressors, turbines etc, all the best and newest parts go into the KAMAK turbo.
Kinugawa etc are there old tech designs, meaning you can pick up their turbos at a slightly lower price, however, you can specify that they are built with the latest tech, so you can have the STS turbine, or the billet compressor if you wish. Personally, I think it's quite a good setup, if a little confusing...but I think that is because they don't seem to try and force their products like most, so aren't that well known.
The parts are manufactured in Japan, compressors, housings, rotating assemblies, turbines etc and then sent off to be assembled/balanced in Thaiwan before being shipped out.
I think for 750 ($1150) delivered within 4 days, they are a great deal, so long as they do as advertised. I'll keep you guys updated with progress once the snail is nailed to my car (Saturday) and mapped (Wednesday).
Anyway here's a couple of pictures for you.
And here is my car...stock until the weekend rolls around. 2005 widetrack STi.
Original-ATWRX is offline   Reply With Quote
Old 05-21-2013, 11:38 PM   #223
punker39
Member#: 221065
2004 wrx
blue
i used the rebuild kit for the td04 and have had no problems.
punker39 is offline   Reply With Quote
Old 05-22-2013, 03:43 PM   #224
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I got tuned with a KAMAK TD06SL2-20g a week ago on my 2011 WRX, and it made 370whp/381tq on a dynojet. Very happy with it so far, the billet compressor and sts turbine wheels are works of art.
ResidentR is offline   Reply With Quote
Old 05-22-2013, 04:28 PM   #225
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
What other mods do you have done? Stock block and internals? TMIC or FMIC? Thanks.
Nice numbers by the way.
SouthernWRX is offline   Reply With Quote
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
Kamak Turbos drmichael Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-22-2010 07:04 PM
BNIB Kamak 18G 8cm and DW 650 sidefeeds badhogan Engine/Power/Exhaust 15 10-01-2009 07:34 PM
KAMAK Turbos? 98jdmwrx Pre-2002 Factory Turbo Powertrain 11 06-21-2009 01:10 AM
Kamak Turbos? somaguchi Newbies & FAQs 11 06-11-2009 03:37 PM
