#51 | |
Member#: 164830
SCIC
Vehicle:2002 WRX G61 III OVE 58e |
I tried un-installing re-installing...same thing. I'll see if I can find the reg key and delete it in hopes of fixing it... EDIT: Nevermind...I wasn't clicking on the profile to select it. It works, however, I'm getting the following error: "E115: Failed updating column definitions There is no row at position 0"
#52 |
Member#: 256281
Vehicle:2007 Shelby GT 500 Grey |
UPDATE
============== I found the issue causing the problems with some peoples installs. If you had 1.0.7 installed and NEVER uninstalled it. PLEASE go uninstall it in control panel / Programs and Features. The installer that VD was using was install shield and that (piece of junk) has some residual registry entries and files that if you dont uninstall it wont let the new version run. So if you are getting any issues with the new version not being able to run. I have replicated the issue several times by installing 1.0.7 then 1.0.8 and installing 1.1.0 on top of them. You HAVE to uninstall the old version first. |
#53 |
Member#: 156326
South East
Vehicle:2011 RA 03 bugiftw for the track |
My boost plots are not showing up with romraider logs. I've never had this issue with the older versions. I've copied and pasted the column header just as before but nothing shows up under the boost plot. Evoscan works fine.
#54 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
I had the same problem. I don't think that "Custom Column Names in Logs" thing is working. I had to change the name of the column in the actual logs to get it to plot. You'll have to open the columnnames.xml file and find the acceptable headers for boost in the RomRaider section.
#55 |
Member#: 256281
Im looking into this.
#56 |
Member#: 279166
Vehicle:08 Umm subaru Dark Grey |
I keep getting E106: index was outside the bounds of the array. Any clues to what this means?
#57 |
Member#: 256281
Those error codes tell me what section of code the error was generated from but I really need the log to debug the issue. If I get the log I could probably track it down in a few minutes and push an update out to fix it if its something simple which Im sure it is. It may be something else other than a bug in the code too.
#58 |
Member#: 279166
Sent.
#59 |
Member#: 256281
SB5551: Just to recap what we talked via email about so everyone else knows. The E106 error was more than likely due to the fact that you had to rename your TPS column in your log file.
The real problem here is that no TPS data was recorded and an expected TPS value was recorded instead of an actual. The real problem was that there was no recognized TPS column and that forced ya to rename another column. Hence causing the error. |
#60 |
Member#: 164830
SCIC
You still looking into why AFRs and boost aren't being displayed?
#61 |
Member#: 176029
Can this support Innovate logs from logworks?
I have an aftermarket ecu that is not on your list, do you just need a log from my ECU for you to add it? I would donate if this was added! |
#62 |
Member#: 256281
SVT_WRX: Did you send me an example log (bradbarnhill at hotmail com) of one that wasnt showing AFR and boost? Its probably just an unknown column name. With the updater that is built in now I can fix it and push an update out and you wont even know it till you try to graph that log again
So send me a log and Ill be glad to.PETEDOTUK: Email me a CSV(comma seperated values) or TXT version of the logs from your ECU and the ECU name. Then we can go from there. I can ask questions if the column names don't make sense but they usually do. My email address is: bradbarnhill at hotmail com Sorry about it taking me so long to reply ... I have been in training all day ... Ill be in training all week so please be patient as I will not be able to check the forums between 8-5. ![]() |
#63 |
Member#: 5591
Vehicle:2002 WRX EJ257 Gt35r |
Installed the latest update today 1.1.0 and get an error e101 when opening my AEM logs. If I go back to the older version it works fine. Just wanted to give you a heads up.
#64 |
Member#: 256281
swoop ... I need a little info like a log to be able to debug the situation. Send me one that used to work and doesnt not. Send it to bradbarnhill at hotmail com
#65 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
Are you going to leave the software requiring some sort of TPS or make it optional or remove it?
#66 |
Member#: 256281
Well it is confirmed ... there is a HUGE bug in the custom column name logic. It just doesnt work. I broke it in 1.1.0
Im working on a fix for it and will more than likely release an update in the next couple of days to fix it. Your application will download the update automatically so just start it and see if it says there is an update to check for it. Thanks to everyone for bringing it to my attention. Im gonna try to hammer out a fix tonight sometime, but no promises. |
#67 |
Member#: 256281
I have released a patch (1.1.1) that should fix the custom column name problem. Just start Virtual Dyno with an internet connection and it will go grab the update. Let me how it goes.
#68 | |
Member#: 164830
SCIC
E112: Failed during update An Exception occurred during a WebClient request |
#69 |
Member#: 164830
SCIC
I got it to work. I just uninstalled 1.1.0 and downloaded 1.1.1. However, I checked my program files folder and the Pnuema Productions folder was still there, even after the uninstall. I deleted that folder, then installed the new release. So far so good.
#70 |
Member#: 256281
the folder stays around because I dont delete your profiles. There was another user that complained of the same E112 error today. That is the inability to contact the server to get the update. Im wondering if the webserver was down today at some point. I just installed 1.1.0 and it updated just fine so I think thats all that was. Just a hiccup. Its expected with it running on my home server. I had to move it to a server in house due to a problem at the place that was hosting it.
#71 |
Member#: 38222
Vehicle:'10 &'12 Foresters another Miata convert |
Gah! I did the uninstall thing and then installed 1.1.0 to no avail. Sad Vista op.
#72 |
Member#: 256281
What were you trying to do? Was there something you were fixing?
#73 |
Member#: 38222
Before I read your notes, I did a straight up 1.1.1 install. When that didn't work, I gave uninstall a shot, and now when I run the 1.1.1 installer, it places about five files in the folder but no executables.
#74 |
Member#: 256281
remove that whole installation directory ... then try. Are you sure you are an admin on this machine?
#75 |
Member#: 38222
To the best of my knowledge... I've installed things that've required admin rights before.
I busted out CCleaner and everything. Think I should reinstall 1.0.7 and then uninstall? I need my Virtual Dyno!! ![]() |
| Thread Tools | |
| Display Modes | |
| Log analyzer - check it out | jmc9809 | Engine Management & Tuning | 42 | 11-04-2007 09:00 AM |
| New Log-Analyzer program comming soon! | NavyBlueSubaru | Engine Management & Tuning | 69 | 03-24-2007 03:17 PM |
| U-LAME -- UTEC Log Analyzer and Map Editor | WolfDrive | Engine Management & Tuning | 14 | 12-05-2005 11:01 PM |
| UTECA (new log analyzer software)... need beta testers | WolfDrive | Engine Management & Tuning | 10 | 05-31-2005 02:42 PM |
