Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 06-15-2011, 02:37 PM   #1
AVANTI R5
Member#: 73805
Default Direct Injection Fouls Some Early Adopters
In their efforts to wring more power and efficiency from the internal combustion engine, automakers are increasingly turning to gasoline direct-injection technology – also known as GDI or DI. Originally developed to produce more economical and quieter combustion for diesel engines, DI is inherently more efficient and helps generate more power than port injection. And advances in engineering and engine management, fueled by fierce industry competition and consumer demand, are making DI technology more cost-effective than ever for manufacturers: gasoline DI engines are appearing in entry-level models from Ford Motor Co., General Motors Co.’s Chevrolet and Hyundai Motors. Currently, more than 60 2011 and 2012 models in the U.S. offer DI engines as standard equipment. But there has been a dark side to the technology: carbon build-up around intake valves that, over time, can degrade power and efficiency, eroding the bonus DI is supposed to provide. While there’s evidence that the most recent designs and technical enhancements have greatly reduced the issue, carbon buildup has been a distinct and well-documented issue in some DI engines from a variety of manufacturers over the last few years.
Known Problems
A U.S. patent application filed in 2002 by Volkswagen AG explains the DI-engine carbon-deposit dilemma this way: “Gasoline engines with direct injection of the fuel into the combustion chamber…suffer especially from the problem of the formation of carbon deposits…especially in the neck region of the intake valves.”
The document describes these deposits as a sticky coating of oil and fuel constituents that, once formed, serves as a base for further deposits, creating “a circular process, by which the coating thickness of the carbon deposits continuously increases.” Excessive carbon deposits “have extremely negative effects,” the patent application concludes, citing significant performance losses, sporadic ignition failures and, potentially, holes burned in the structure of the catalytic converter (should bits of carbon break from the valves and pass though the combustion chamber).
Ameer Haider, GM’s assistant chief engineer for V6 engines, certainly knows the problem, telling AutoObserver, “DI engines are prone to forming oily deposits on the intake valves, unlike in port fuel-injected engines, where a constant spray of fuel into the port allows any deposits to wash away. With DI engines, the fuel gets injected directly into the combustion chamber, so there isn't a chance for the deposits to wash away. Typically, deposits form when soot – which is an end-product of combustion – adheres to the valve stem.”
The main purpose of VW’s patent application was to propose a fix for DI engine carbon deposits: specifically, applying “a catalytic surface” to the engine valves that “counteracts the formation of carbon deposits.” But nearly 10 years later, there’s ample evidence that this and other potential solutions have failed.
Constantine Boyadjiev works as a risk management officer at a financial firm in New York and has been an auto enthusiast for most of his life. In 2008, he decided it was time to part with his beloved 2001 BMW M5, mainly due to escalating maintenance costs – but also because he discovered that a number of fellow owners were dealing with expensive-to-fix carbon build-up in their vehicles’ engine cylinder heads.
When Boyadjiev replaced his BMW with a barely-used 2008 Audi RS 4, he thought he had put all worry about carbon build-up behind him. But, as he said, “Little did I know that there was a much uglier carbon-build-up problem awaiting me.” Boyadjiev became involved with the online RS 4 owner community when he was searching for his car, in particular a group of veteran Audiworld.com members who later migrated to QuattroWorld.com. He kept active with the group as he took delivery of the car and enjoyed the first few months of ownership. Not long after, though, he was dismayed to see that “the message boards caught fire with plenty of formally documented cases” of carbon build-up with fellow RS 4 owners’ engines.
Boyadjiev admits to some initial “wishful thinking” that perhaps the problem might only affect earlier production models or that the forum members were merely trumpeting an isolated issue. But then, despite his own “religious” maintenance practices, including using only 93-octane premium fuel and avoiding short, in-town trips that failed to bring the engine up to proper operating temperatures, it soon was apparent his Audi’s 4.2-liter direct-injected V8 also was plagued by carbon buildup.
“The loss of performance became very noticeable over time,” he says. He decided to document it, taking the car to a local automotive performance specialist in nearby Stamford, Connecticut, to have its power measured by a dynamometer.
At its first measurement, Boyadjiev’s RS 4 had 15,000 miles and produced 324 all-wheel horsepower, measured at the wheels (AWHP). Roughly one year and 5,000 miles later, the same test showed 317 AWHP. After another year and 5,000 miles, power was down to 305 AWHP. Power from the 4.2-liter V8 had degraded by almost 5 percent in just 10,000 miles.
Considering the RS 4’s performance pedigree – and correspondingly large price tag (in excess of $70,000 MSRP) – this was an alarming trend, something Boyadjiev thought Audi would want to address head-on, especially since parent company VW had earlier documented these very issues in its DI engines. But Boyadjiev and his fellow RS 4 owners found Audi quick to dismiss the issue as a byproduct of poor-quality U.S. gasoline and American-style driving habits (i.e. the absence of high-speed runs on the Autobahn). Audi offered no assistance.
So Boyadjiev took an action to which many other RS 4 owners already had resigned themselves: he had an independent mechanic disassemble the engine and clean it – a $1,200 expense at the time. He returned to the dynamometer to see if the cleaning had made any difference. It had. Engine output soared by 41 AWHP and the car felt new again. For the moment, at least.
Boyadjiev said he is prepared to pay for such a maintenance cleaning every 10,000 miles. And while he is certainly not happy about that, he’s willing to endure the hassle and cost. “The car is so rewarding and a joy to drive,” he says. He is far less complimentary about Audi’s response to the issue.
Despite the evidence Boyadjiev and many of his fellow RS 4 forum members have presented, “the company continues to deny this is a very serious issue,” he said. “I have very little respect for a company that refuses to stand behind its name, especially when professing a motto of ‘Progress through Technology,’” he added. And experiences like Boyadjiev’s are not uncommon.
A Google search for “direct injection carbon build up” reveals a flood of owner complaints about the issue across vehicle brands and models, including particularly active threads for the VW GTI, the Lexus IS 250, and a variety of Audi models in addition to the RS 4.
All Engines Not Designed Equally
Many automakers’ gasoline DI engines do not appear to exhibit any carbon build-up issues at all, however. Digging into online threads about Cadillac’s 3.6-liter DI V6 in its popular CTS lineup does reveal some owner concerns about carbon build-up, but it’s difficult to find even a single report that any build-up has actually occurred – a record that is notable considering that Cadillac has sold more than 200,000 CTS models with DI V6s (Audi sold fewer than 2,000 RS 4s in the US during its two-year sales run).
Haider, GM’s V6 assistant chief engineer, explained how GM has designed its DI engines to combat carbon buildup: “We maintain great engine function and performance in our all our DI engines through an optimization strategy with our valve events,” he said. “Our intake-cam timing, injector targeting and timing of the injection events are optimized to avoid direct fuel contact on the intake valves. This strategy keeps smoke and soot formation to an absolute minimum, which in turn prevents excessive deposit formation.”
At the Detroit Auto Show in January, Ford was confident enough about its popular 3.5 liter EcoBoost direct-injection V6 to have technicians tear down an example engine that had accumulated the equivalent of 160,000 miles through an intentionally abusive regimen of log dragging, high-speed towing and desert racing. When they opened it up before a live audience, they found some light carbon deposits on the valves and pistons, but not enough to affect performance. In fact, the engine showed a loss of just one horsepower afterwards – roughly what Boyadjiev’s RS 4 engine lost every 500 miles.
Stephen Russ, technical leader for combustion for Ford’s 2-liter Duratec DI engine, said that similar to GM, engineers have determined the proper injection-timing calibration to help eliminate the carbon deposits. But Russ also said the technology of injection components – particularly the high-pressure solenoid injectors – has quickly matured, meaning excess valve deposits in most DI engines should become a thing of the past as these improved components are incorporated into production.
Tony Chick, principal engineer at European Performance Labs in Stratford, Connecticut, has made a career of repairing and rebuilding high-performance engines from Audi, Porsche AG and BMW, among others and his operation has garnered a reputation among car enthusiasts as a go-to place for cleaning DI engines that have become choked with carbon. Chick thinks the problem for most affected engines can be traced to the breathing system – specifically, the design of its crankcase ventilation and exhaust-gas recirculation components.
All modern gasoline engines return some crankcase and exhaust gases back through the intake manifold in order to help control emissions, but, according to Chick, some exhaust-gas recirculation designs are “dirtier" than others. Some, he said, are less-effective at preventing the passage of tiny bits of oil, carbon and other particulates that eventually get baked onto the intake ports and valves.
Chick reached his conclusion after inspecting dozens of different DI engines at his shop and finding some, like the V8 in Boyadjiev’s Audi RS 4, regularly choked with carbon while others, like the DI version of Porsche’s horizontally opposed 6-cylinder, remained much cleaner.
If he’s right, the rapid adoption of DI has actually illuminated an issue, not caused one. A “dirty” intake or exhaust-recirculation design can easily go undetected in a conventional port-injected engine due to the cleaning effect of gasoline passing over the intake valves. When the same engine designs are adapted to direct-injection fueling, however, that cleaning effect is suddenly lost – and the carbon layers can build.
There is no simple fix for engines that are prone to carbon build-up, Chick says. What’s needed is a complete redesign of the crankcase ventilation and exhaust-gas recirculation systems to prevent particulates from getting through. Fortunately, the manufacturers whose engines are frequently cited in carbon build-up reports – mainly VW, Audi and Lexus – appear to have taken this step with many of their latest models. For instance, Audi’s new 3-liter supercharged V6, used in the S4 and A6 models, has so far been free from carbon-related complaints – a far cry from the 3.2 liter V6, which has numerous threads dedicated to the condition.
If Ford and GM engineers and Chick are correct, the carbon-buildup problem now may be relegated to previous engine designs that were not well-adapted for DI. But that’s probably little consolation to some early adopters like Boyadjiev, who must add regular carbon cleaning services to their cars’ ongoing maintenance requirements – a cost that, for now at least, they are expected to absorb entirely on their own as they grapple with the “dirty” secret of this emerging technology.
http://www.autoobserver.com/2011/06/...-adopters.html
Old 06-15-2011, 03:43 PM   #2
wrxsubaru
Member#: 65133
Well written article. Its interesting to learn about advances in DI. I am glad Subaru held off long enough so they can just implement it with much R&D. Optimal valve/injector timing along with a well designed recirculation system is all that you need.
wrxsubaru is offline   Reply With Quote
Old 06-15-2011, 03:55 PM   #3
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Agreed. Nice to know that the deposits are not related to just DI, but to engine design and that hopefully it will be designed out in all future engines.
wobbletop is offline   Reply With Quote
Old 06-15-2011, 04:49 PM   #4
HipToBeSquare
Member#: 119958
1992 SVX LS-L
Toyota's D4-S also has the advantage of having port fuel injectors retained, in addition to the direct cylinder head injectors.
It keeps some of the solvent-cleaning properties.
But hopefully the DFI engine manufacturers get the EGR-PCV issues sorted, across the board.
HipToBeSquare is offline   Reply With Quote
Old 06-15-2011, 07:50 PM   #5
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
Where are all the AUDI RS4 guys that have had their motors torn down and re-built due to this very issue? Also has been a primary concern in the Porsche forums.
Old 06-15-2011, 08:09 PM   #6
shikataganai
Member#: 92634
'07 LC, '12 RAV4 EV
'13 LEAF, for now
Toyota has a solution: have both port injection and direct injection on the same engine. Their V8 as found in the Lexus LS has exactly this to net the best of both worlds, albeit at additional cost: more power, quieter idle, no carbon buildup.
shikataganai is online now   Reply With Quote
Old 06-15-2011, 09:53 PM   #7
skywaffles
Member#: 82470
cat snatch
First his M5 and now an RS4? I weep for this man, I really do.
skywaffles is offline   Reply With Quote
Old 06-15-2011, 10:05 PM   #8
subarujimbo
Member#: 140702
07 Wrx Wagon
Garnet Red Pearl
shikataganai,
Toyota does use both types of injectors in the IS350 and LS but the IS250 they do not. That engine is a carbon disaster. I've seen those engines have misfire codes with under 40000km because the carbon buildup was so excessive.
subarujimbo is offline   Reply With Quote
Old 06-15-2011, 10:07 PM   #9
Mechie3
Member#: 120152
I find it interesting that they say an entire redesign is necessary rather than the simple installation of a catch can. The direct injection on the FT86 is supposed to use Toyota's DS-4 injection system (port and direct).
Old 06-16-2011, 01:00 AM   #10
4wdwrx
Member#: 72042
2002 V7 WRX impreza
WRB "Blue Mammoth" Return
Where's all the guys worshipping DI now?
4wdwrx is offline   Reply With Quote
Old 06-16-2011, 04:38 AM   #11
AVANTI R5
Member#: 73805
right here my RS4 was living HELL, I tried to push it off on JC but he didn't bite.
Old 06-16-2011, 07:17 AM   #12
JuggernautTCW
Member#: 169223
not sure how old this article was supposed to be, but this was a well known issue even years ago... a beat to dead topic on audi forums.
the solution is to spend $200 to get the carbon deposit cleaned... end of story. EVERYONE who does that at every oil change was able to get their power to factory level.
JuggernautTCW is offline   Reply With Quote
Old 06-16-2011, 08:40 AM   #13
max_stirling
Member#: 44010
2004 Cayenne Turbo
Wow, simple solution, add $200 on top of an expensive German exotic oil change. What a deal.
max_stirling is offline   Reply With Quote
Old 06-16-2011, 09:08 AM   #14
lark6
Member#: 2715
70 911T
<-- raises hand just a little bit
I was hoping it'd give Subaru a way to increase fuel economy without having to slap a CVT behind every engine.
lark6 is offline   Reply With Quote
Old 06-16-2011, 09:56 AM   #15
AVANTI R5
Member#: 73805
Well in fairness, my troubles where exacerbated from the Dealer (Wyoming Valley Motors). Plus, I had one of the first ones and they had no experience with that model. But then again they screwed my STI up too, so maybe I need my head examined for not learning my lesson the first time.
Old 06-16-2011, 10:06 AM   #16
AVANTI R5
Member#: 73805
Default Xinde Technology's New Diesel Fuel Injection System
Breakthrough Domestically Produced Xinde Technology System Costs 50% to 75% Less Than Foreign Manufactured Systems and Exceeds Euro III Emission Standards;
New System Also Has Wide Applicability in Such High Demand Products as Agriculture, Construction, Mining Machinery, as Well as Trains, Trucks and Passenger Autos
WEIFANG, China, June 16, 2011 /PRNewswire-Asia/ -- Xinde Technology Company (OTCBB: WTFS), a widely respected China based designer and manufacturer of internal combustion engines and parts, primarily for the $100 billion diesel engine and parts market in China, said today that following successful tests and market studies, and the granting of technical patent certification and exclusive manufacturing and distribution rights for its breakthrough diesel engine FIRCRI common rail electrically-controlled fuel injection system, the Company is confident the new system -- jointly developed with engineers at Tianjin University -- will end the technical monopoly currently enjoyed in China by foreign manufacturers in this key product category.
Supply Letter of Intentwith Weichai Power
Mr. Dianjun Liu, President and Chief Executive Officer of the Company stated, "Our confidence in this very significant 'home grown' product is supported by the supply letter of intent we have concluded with Weichai Power Co., Ltd, one of the main diesel engine manufacturers in the PRC. They are prepared to purchase 200,000 sets of products yearly whenever our new diesel fuel injection system comes to market, which we currently estimate could be in approximately 18 to 24 months. At that time, we expect to be the sole domestic manufacturer of an electrically-controlled diesel fuel injection system that meets and exceeds the new emission standards that will become mandatory in China in 2015. Further, with significantly lower manufacturing costs than current foreign leaders in this market such as Bosch and Denso, we believe our new product will be quite competitive and are seeking additional supply LOA's with other domestic diesel engine manufacturers."
Euro IV and V Emission Standards Within Reach
The Company noted additionally it believes that with slight modifications, its new fuel injection system can be upgraded to meet the Euro IV/V emission standard, which is only slightly lower than the 35.5 mile per gallon standard to be adopted in the U.S. in 2016, and likely to become the standard in China in future years.
In summary, the Company believes the new Xinde fuel injection system:
- - provides for uniform fuel supply and optimal combustion, thereby reducing fuel/energy costs;
- - greatly reduces gas emissions;
- - competes on a technical and cost basis with foreign made systems currently monopolizing the diesel combustion market with domestic manufacturing costs that are expected to be at least 50% to 75% lower than production costs of competitors outside of China.
Mr. Liu concluded, "We see the new patented fuel injection system as a major addition to our already technically strong, widely recognized product line that will broaden our participation in several rapidly growing areas and open the door to new product applications and markets domestically as well as abroad."
About Xinde Technology Company
Based in China's Shandong Province in the city of Weifang, Xinde Technology Company, with fiscal 2010 revenues of $123 million, competes in three primary product segments, namely (1) fuel injection system products, (2) diesel engine products and (3) generator products. The Company has a broad range of products including non-vehicle diesel engines, diesel generators, injection pumps, injectors and three-coupling components, agricultural machinery and construction machinery which greatly reduces its comprehensive costs which, in turn, increases its competitiveness. The Company's focus is on the domestic market in China, where its customers include several of China's largest companies in the country's most rapidly growing industries. As a consequence, the Company's production volume has been growing approximately 30% annually.
need5
Old 06-16-2011, 10:36 AM   #17
sxotty
Member#: 95600
2003 WRX wagon
Why does it change anything? GM and Ford can do it. I am sure other companies will get it all sorted out eventually. Just b/c some manufacturers screw something up doesn't mean that it is impossible to do it right. And given examples of doing it right already exist it seems instead ire should be directed at the failure of companies to implement it instead of the concept in general.
sxotty is offline   Reply With Quote
Old 06-16-2011, 10:52 AM   #18
hippo
Member#: 52503
I agree -- if you read the article, it points out that Ford's design with DI looked, well, really good:
hippo is offline   Reply With Quote
Old 06-16-2011, 12:39 PM   #19
Lboogie
Member#: 171611
2014 FiST
Blk
Sucks for the early DI adopters, but it looks like the engineers are sorting things out in "generation two".
For the early adopters there are ways to mitigate the carbon buildup that don't run $1200.
http://forums.subdriven.com/showthre...p-and-the-TFSI
Lboogie is offline   Reply With Quote
Old 06-16-2011, 01:00 PM   #20
FLZ_Boy
Member#: 186303
2011 Legacy 2.5i 6MT
SPW
I'm curious if Hyundai's 2.4L DI engines suffer from carbon build up.
FLZ_Boy is offline   Reply With Quote
GM Powertrain Unveils 3.6-Liter VVT Engine With Direct Injection NYCshopper Non-Subaru News & Rumors 51 04-13-2008 01:07 PM
direct injection Beanboy News & Rumors 88 08-01-2007 10:02 PM
When is subaru going to add direct injection to its motors? jmott Texas Impreza Club Forum -- TXIC 11 06-14-2006 02:18 PM
Solstice GXP to have direct injection scott_gunn Non-Subaru News & Rumors 28 03-18-2006 12:03 AM
Direct injection for 2005 STi Stiger News & Rumors 9 07-21-2003 10:00 PM
