Old 06-21-2011, 12:30 PM   #1
Franko
Member#: 193628
2010 STI
SSM
Default How to Unbrick an ECU. Like A Boss!
A laptop crash half way through a reflash of my buddies 04 sti rendered the ecu useless. This event drove me to figure out how to recover a bricked ecu.
The forums can be confusing to read and understand and pictures of the rig built/hooked up are scarce. On top of that, tactrix doesn't offer the ecu recovery service anymore so I had to get right into it.
First of all, you need to be able to soldier or have a friend who can and is willing to help you out to build this thing.
The parts you will need..
Buy this.. DLP-USB232M from mouser.com
Click Here
The DLP has most of the circut built for you already so you dont need all kinds of parts, only a few.
Here is the pdf of the thing you need to build
Here is the DLP schematic (last page). Compare these two and you see that you only need a L1 Ferrite.. AKA a coil of wire for noise removal and you need a .01uf capacitor (reads 103 on it). They connect to EHR-5 pin 1.
VCC is usb voltage.. The down arrow in the shbootmode pdf is ground. The DLP needs to be self powered so you must make a connection on the pins to make it do that. Page 6 of this pdf will tell you how to do that. This is also where the vcc voltage is found.
Reset# goes to vcc
CTS#, DSR# and DCD# go to ground.
After that.. Pick up
Bread board
555 timer (radio shack)
a 47.5k resistor
2 1k resistors
and a 100nf capactor (has 104 on it)
Build the timer circuit using the same source for vcc and ground as your main circuit and that should make the nessicary 150 hz signal for the 'watch dog' signal.
Attach your circuit to the board as shown here..
p405 (pink) is VCC
p407 (purple) is the 150 hz 555 timer signal
p409 (orange) is TX
p411 (yellow) is RX
p413 (black) is ground.. this also goes to one side of the capacitor as shown.
After a lot of cursing you should have the following.
The ecu also needs to be powered up via a car battery or power supply. I powered up a lot of pins and when properly powered the ecu should draw around 400 ma of current.
Thick wires are 12v (incl black wire) and thin wires are ground. Hook up to power like so.. (this was an 04 ecu so check your own wiring diagram to see which ones need to be powered up on yours)
Now.. Tactrix's website tells you to use their application to recover the ecu.. It would not work for me. Some ppl can get it to work but with this setup I had to go a slightly different route.
Trying ecu flash generated this message:
[22:16:12.954] Using interface USB <-> Serial
[22:16:14.839] sending bit rate sync bytes...
[22:16:14.839] received bit rate adjust response
sending boot command
[22:16:15.370] received bit rate adjust response
[22:16:15.900] received bit rate adjust response
[22:16:16.431] received bit rate adjust response
etc.... it didnt work..
So go here.
Renesas Flash developer toolkit
Sign up and download the fdt application.
Run developer toolkit basic and search for your renesas ecu in the list.. this one was the 7055. Its written on top of the biggest chip on the ecu.
After that you will be here..
To load your tune (.hex file) into the application you must change the .hex extension to .bin. Before clicking 'program flash' its just like flashing the ecu in the car you must time the click the button a split second after you apply power to the ecu. If you succeed you will be rewarded with the following:
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH7055F' on 'COM8'
Configuration
'BOOT Mode' connection - using emulated interface
Opening port 'COM8' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device 0xAA
Using micro-Kernel 'CProgram Files (x86)RenesasFDT4.07kernelsProtB7055Renesas1_0_00uG en7055r.cde'
Downloading and verifying micro kernel...
Device is erasing...
Erase Timeout value set to 21 seconds
Erase Successful
micro-Kernel download successful
Sending inquiry for getting line size
Buffer size has been set to default (128 bytes)
Sending selection of device command
Selection of Device - Device selected, code 0405
Sending selection of clock mode
Selection of Clock Mode - Clock selected, code 0
Changing baud rate to 38400 bps
Set baud rate value = 38400
Downloading main kernel 'CProgram Files (x86)RenesasFDT4.07kernelsProtB7055Renesas1_0_00Ge nm7055.cde'
Main kernel download complete...
Connection complete
Processing file CUsersFrankDesktop2004 STI LC+FFS cobb settings.bin
Loading image file 'CUsersFrankDesktop2004 STI LC+FFS cobb settings.bin'
Operation on User Flash
Downloaded the operation module
Writing image to device... [0x00000000 - 0x00000B7F]
Writing image to device... [0x00000F80 - 0x00001EFF]
Writing image to device... [0x00001F80 - 0x0005FE7F]
Writing image to device... [0x0005FE80 - 0x0007D97F]
Writing image to device... [0x0007E700 - 0x0007E77F]
Writing image to device... [0x0007FA80 - 0x0007FAFF]
Writing image to device... [0x0007FB80 - 0x0007FFFF]
Data programmed at the following positions
0x00000000 - 0x00000B7F Length 0x00000B80
0x00000F80 - 0x00001EFF Length 0x00000F80
0x00001F80 - 0x0005FE7F Length 0x0005DF00
0x0005FE80 - 0x0007D97F Length 0x0001DB00
0x0007E700 - 0x0007E77F Length 0x00000080
0x0007FA80 - 0x0007FAFF Length 0x00000080
0x0007FB80 - 0x0007FFFF Length 0x00000480
502.63 K programmed in 609 seconds
Image written to device
Disconnecting
Disconnected
Holy crap it worked! Remove the connections from the ecu and put it back in the car. Enjoy your non bricked ecu.
I'll add to this post if I left anything out.
If you need help building this rig or want me to try and unbrick your ecu for you just send me a pm and I will be happy to help you out!
Franko is offline   Reply With Quote
Old 06-21-2011, 12:47 PM   #2
biodude
Member#: 271720
that was my favorite part.
nice write up. hope I never need it
biodude is offline   Reply With Quote
Old 06-21-2011, 03:06 PM   #3
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Wow, that's awesome work Franko!!! This is going to save a lot of people who are component savvy some time and $$. Great work!
wgr73 is offline   Reply With Quote
Old 06-21-2011, 11:32 PM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Bravo.
Old 06-22-2011, 11:45 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
too bad it doesn't work with 16bit ECUs
Hyper is online now   Reply With Quote
Old 06-23-2011, 07:40 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
nice job!
going to have build one of those myself.
so i can unbrick ecu's
Old 06-23-2011, 12:31 PM   #7
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
holy crap
pet3r is offline   Reply With Quote
Old 06-23-2011, 08:50 PM   #8
Franko
Member#: 193628
2010 STI
SSM
Its depressing.. From what I can see the 16 bit ecus do not use the renesas chip. There is a way to do it, but i cant find much info on the subject.
Old 06-23-2011, 11:15 PM   #9
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Nice! Perhaps the contents of this thread should become a sticky?
jigga is offline   Reply With Quote
Old 06-24-2011, 01:48 AM   #10
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
This seems like an appropriate place to comment about the 16 bit ecu. I thought I bricked mine today as a loose USB port connection caused a flash to interrupt. Nothing would work and the car was stuck in test mode. For whatever reason, unhooking the negative battery cable for a few minutes and then trying it worked to flash it and get it running again.
340Duster is online now   Reply With Quote
Old 06-24-2011, 09:41 AM   #11
adrenalinejunkie
Member#: 204728
2004 STI
Wow Franko!! This is a great thread, and I wish more people would post like this. Thanks +1 for sticky. I think my newer ecu(replaced last year) just shat itself again.....
adrenalinejunkie is offline   Reply With Quote
Old 06-24-2011, 10:42 AM   #12
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Amazing. I have this thread saved incase I ever brick my unit.
indytruckboy is offline   Reply With Quote
Old 06-24-2011, 01:39 PM   #13
ogboot
Member#: 170906
psm
For the love of all, please figure out the 16bit ECU too
ogboot is offline   Reply With Quote
Old 06-24-2011, 06:32 PM   #14
subsagrin
Member#: 198721
2005 Outback XT
nice work congrats, have two bricked ecu, time to bring them back to live
Just like others notice, someone has to finish you work and find out how to do 16bit
subsagrin is offline   Reply With Quote
Old 06-24-2011, 06:35 PM   #15
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Very nice! Sticky!!!!
Bishop is offline   Reply With Quote
Old 07-05-2011, 08:18 AM   #16
2bfi
Member#: 265981
2011 STi Sedan
Wow, this is great! What's the specs of the ferrite bead? Where did you get it?
2bfi is offline   Reply With Quote
Old 07-05-2011, 08:28 AM   #17
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
holy crap... you are awesome!
Bad Noodle is online now   Reply With Quote
Old 07-05-2011, 12:42 PM   #18
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I did a big reasearch a while ago and found all the chip specs, and even software and hardware that can be used to unbrick it, but those things cost a fortune...
if you are interested, I can email you all my info gathered on the subject, it might just take a while to recollect it in my memory and put it down on keyboard
Old 07-11-2011, 12:12 PM   #19
AB-737
Member#: 236196
I'm trying to build this and I'm a bit confused... You state to pick up 3 resistors and 2 caps from Rat Shack... yet in your image of your circuit I see 3 caps and 2 resistors...
AB-737 is offline   Reply With Quote
Old 07-12-2011, 03:39 PM   #20
AB-737
Member#: 236196
FYI, Tactrix still offers ECU recovery Services. I just sent them my 07 Legacy ECU today.
Old 10-28-2011, 01:53 AM   #21
jareds
Member#: 249729
2005 ADM WRX
Im very keen on all of this info.! If you can find it?
thanks,
Jared
jareds is offline   Reply With Quote
Old 10-28-2011, 07:41 AM   #22
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
pm me on tuesday, I will have time to dig it up
Old 01-10-2012, 09:26 PM   #23
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I'm also building this circuit. As per the timer circuit in the diagram, there are 3 resistors used. 2 build a voltage divider that then feeds pin 7. The other is to attenuate the timer output on pin 3 before it goes to the ECU. What is a bit confusing to me is the rest of USB portion of the circuit. The EHR-5 header and part where the 10uF cap goes is confusing me.
Here is what I've built so far.
Timer circuit is working properly.
What I find particularly confusing is that in the schematic, they use the pinouts for the FTDI chip on the DLP-USB232M board, instead of the pinout for that board.
http://www.ftdichip.com/Support/Docu...FT232BL_BQ.pdf
However, after reading through the documentation from DLP Design, I think I have it working. I will be testing this tomorrow on an 04 STI ECU.
Noah is offline   Reply With Quote
Old 01-11-2012, 08:37 PM   #24
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
I think I finally got it to work. Was having issues with my Watchdog timer stability until I modified the circuit a little.
Code:
Flash Development Toolkit and flash programming components
are provided without support
OS: Windows Vista/Server 2008 [Non-Admin]
FCF Settings Applied: SH/7055F, (C:\Program Files (x86)\Renesas\FDT4.08\kernels\ProtB\7055\Renesas\1_0_00\)
FDT API initialised: version 4, 08, 00, 004
Connecting to device 'SH/7055F' on 'COM2'
Configuration:
Opening port 'COM2' ...
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Received immediate response from device: 0xAA
Using micro-Kernel : 'C:\Program Files (x86)\Renesas\FDT4.08\kernels\ProtB\7055\Renesas\1_0_00\uGen7055r.cde'
Erase Successful
Downloading main kernel 'C:\Program Files (x86)\Renesas\FDT4.08\kernels\ProtB\7055\Renesas\1_0_00\Genm7055.cde'
Connection complete
Erasing 16 blocks from device
Erasing... 'EB0'...
Erased block EB0 (0x00000000 - 0x00000FFF)
Erasing... 'EB1'...
Erased block EB1 (0x00001000 - 0x00001FFF)
Erasing... 'EB2'...
Erased block EB2 (0x00002000 - 0x00002FFF)
Erasing... 'EB3'...
Erased block EB3 (0x00003000 - 0x00003FFF)
Erasing... 'EB4'...
Erased block EB4 (0x00004000 - 0x00004FFF)
Erasing... 'EB5'...
Erased block EB5 (0x00005000 - 0x00005FFF)
Erasing... 'EB6'...
Erased block EB6 (0x00006000 - 0x00006FFF)
Erasing... 'EB7'...
Erased block EB7 (0x00007000 - 0x00007FFF)
Erasing... 'EB8'...
Erased block EB8 (0x00008000 - 0x0000FFFF)
Erasing... 'EB9'...
Erased block EB9 (0x00010000 - 0x0001FFFF)
Erasing... 'EB10'...
Erased block EB10 (0x00020000 - 0x0002FFFF)
Erasing... 'EB11'...
Erased block EB11 (0x00030000 - 0x0003FFFF)
Erasing... 'EB12'...
Erased block EB12 (0x00040000 - 0x0004FFFF)
Erasing... 'EB13'...
Erased block EB13 (0x00050000 - 0x0005FFFF)
Erasing... 'EB14'...
Erased block EB14 (0x00060000 - 0x0006FFFF)
Erasing... 'EB15'...
Erased block EB15 (0x00070000 - 0x0007FFFF)
Erase complete
Processing file :"C:\Users\Noah\Desktop\A2ZJ710J - MY04 STi Stock USDM Latest - .bin"
Loading image file : 'C:\Users\Noah\Desktop\A2ZJ710J - MY04 STi Stock USDM Latest - .bin'
Writing image to device... [0x00000F80 - 0x0007E67F]
Data programmed at the following positions:
 0x00000000 - 0x00000B7F      Length : 0x00000B80
 0x00000F80 - 0x0007E67F      Length : 0x0007D700
 0x0007FA80 - 0x0007FAFF      Length : 0x00000080
 0x0007FB80 - 0x0007FFFF      Length : 0x00000480
505.88 K programmed in 585 seconds
Disconnecting
Disconnected
Old 01-12-2012, 05:06 PM   #25
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Confirmed that it worked today. Can read and write via ECUFlash in car.
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How to Make an STI Look Like a Sleeper? FostersAFB General Community 88 10-20-2004 09:29 PM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
