Closed Thread
Old 06-04-2011, 12:40 PM   #1976
jnathan68
Member#: 191580
***Wrong Thread....Moved****
jnathan68 is offline
Old 06-15-2011, 09:23 PM   #1977
arf80
Member#: 125580
2011 WRX 5dr
Is it reasonable to assume Rota DPT will also fit the Brembos since it's a knockoff of the CE28 and comes in nearly identical offsets?
Volk CE28N = 17x9_ET43__(14.8 lbs)...
Volk CE28N = 18x8.5_ET40 & ET44__(15.2 lbs)... (
arf80 is offline
Old 06-15-2011, 09:27 PM   #1978
BigRigger
Member#: 129969
2005 Sti
Silver/Black
2005 Sti...
Drag DR-34 Black w/machine lip 18X8.5 45mm offset with Bridgestone RE-11 235/40/18, no issues
BigRigger is offline
Old 06-15-2011, 10:25 PM   #1979
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
I know the 17x9 +42 DPT clears the Brembos just fine.
dbrier is offline
Old 06-16-2011, 12:27 AM   #1980
Shred-Hed
Member#: 272570
Sparco Drift fits. As well as everything else on this list:
http://www.tirerack.com/wheels/resul...&filterNew=All
Shred-Hed is offline
Old 06-16-2011, 07:06 AM   #1981
Scargod
Member#: 260314
2008 STI hatch
Default I had rear tire clearance issues w. 17x9 & 48 offset
No Brembo interference (I would surely think), but I believe you will have serious interference wit the lip in the back with only a 43~44mm offset. With my 17x9 & 48mm offset & Toyo 255x40 R888's I had to roll the rear a tiny bit. And, this was with over -2 camber.
Scargod is offline
Old 06-19-2011, 12:34 AM   #1982
dblo
Member#: 285868
hi, sorry for the n00b question, but i hope i'm posting in the right thread:
for a 2011 sti sedan, will either of the following wheel sizes fit?
17x7 +50mm
18x7.5 +42mm
ive got these on hand and hope to use a set as winter rims if possible...
dblo is offline
Old 06-19-2011, 02:39 AM   #1983
jamesw95
Member#: 270830
2008 STi
Brand and model of wheel and I am sure someone can help you.
jamesw95 is offline
Old 06-19-2011, 08:51 AM   #1984
dblo
Member#: 285868
the 18's are Work Euro Fedelta
the 17's are just stock rims from another car (is300) that have the same bolt pattern.
dblo is offline
Old 06-20-2011, 06:37 PM   #1985
nhat
Member#: 140163
03 STi
hellaflunctional
17x7 +50mm
18x7.5 +42mm
i highly doubt either will fit. if you're looking for inexpensive winter wheels, 05-07 sti wheels or rotas are your best bet.
nhat is offline
Old 06-20-2011, 06:40 PM   #1986
Scargod
Member#: 260314
2008 STI hatch
I think it's likely the 17x7's will work. Why aren't you just putting them on the car and seeing for yourself?
Scargod is offline
Old 06-20-2011, 08:38 PM   #1987
nhat
Member#: 140163
03 STi
hellaflunctional
likely? that's like saying '06-07 and '08-10 wrx wheels likely clear brembos...
nhat is offline
Old 06-20-2011, 09:50 PM   #1988
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
As its been said over and over, clearing Brembos is more about spoke design than width or offset.
dbrier is offline
Old 06-21-2011, 10:27 AM   #1989
Scargod
Member#: 260314
2008 STI hatch
I don't see why the OP is not trying these on the car... How hard is it to do that?
I got cheapo 17x8 wheels that cleared my Brembos just fine. I agree it is a spoke design issue. Also think a lot will fit.
Scargod is offline
Old 06-22-2011, 10:05 PM   #1990
stisland
Member#: 283414
2008 STi
Looking to get some rota grids 18 x 8.5. I know i need some spacers to clear the brembos in the front, and i'm gonna half to roll the back fenders. Just wondering what offset i should run on stock springs and if anyone knows if i will have to just roll the back fenders or pull them as well? thanks!
stisland is offline
Old 06-22-2011, 10:19 PM   #1991
nhat
Member#: 140163
03 STi
hellaflunctional
you don't know which offset to buy but you know you'll hafta run spacers?
nhat is offline
Old 06-22-2011, 10:53 PM   #1992
stisland
Member#: 283414
2008 STi
well i've read up on the grids some, and those are the things i've found out. some people say they have to roll and pull the back fenders, some say they don't have to at all. as far as the offset, i'm really not sure so i thought i'd ask here. kind of came out like quite a noob question my bad, just trying to get some feedback
stisland is offline
Old 06-22-2011, 10:56 PM   #1993
sc00by4life
Member#: 97135
not for the 18x8.5's....no fender mods required...as far as spacers, i believe those are only required for the 18x9.5 +38.
sc00by4life is offline
Old 06-22-2011, 11:33 PM   #1994
stisland
Member#: 283414
2008 STi
my fault, i've been wrong all along. i meant to put 9.5 not 8.5, i've found most people running between 41-45 camber. i'm not going to lower for a little while. want to know how much work really needs to be done for the least amount of rubbing as possible
stisland is offline
Old 06-23-2011, 05:49 AM   #1995
Scargod
Member#: 260314
2008 STI hatch
Default What year car?
stisland: First off, what car do you have?
Secondly, what offset are we talking about for the wheels? What tires and size?
All this is critical to giving you help. Otherwise you might as well not ask.
Spacers is not the first thing you should be thinking about.
There is no such thing as 41-45 camber. Mostly we are interested in increasing negative camber so numbers would be like -2 degrees of camber.
Scargod is offline
Old 06-23-2011, 10:43 AM   #1996
nhat
Member#: 140163
03 STi
hellaflunctional
first, we don't know what kind of sti you have.
second, don't bother if you're not gonna modify your suspension.
nhat is offline
Old 06-23-2011, 06:56 PM   #1997
stisland
Member#: 283414
2008 STi
08 sti, was planning on running on stock springs just because i'm already fairly low to the ground with the front lip. are you saying it would be absolutely necessary to get different springs as in coilovers? or would i be okay just getting some lowering springs?
stisland is offline
Old 06-23-2011, 07:14 PM   #1998
nhat
Member#: 140163
03 STi
hellaflunctional
if you're gonna run stock springs, you might as well not bother with wider and lower offset wheels. stiffer springs will help keep the fenders off the tires.
or you could be cheap and lazy by running stock springs and stretched tires with fender mods.
nhat is offline
Old 06-24-2011, 07:32 AM   #1999
dblo
Member#: 285868
thanks for the advice!
yeah i will try them on the car, when it is ready to come home with me, lol, thanks guys. most likely the center bore size is wrong though, since these are OE rims from a different manufacturer.
dblo is offline
Old 06-24-2011, 07:47 AM   #2000
dblo
Member#: 285868
so if they fit and clear the 06 sti brembos, can I be sure that they will clear the '11 sti brembos as well? i found (but havent bought) a set of 17x7 +42 rims that were used on an 06 sti
dblo is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
