Old 06-27-2011, 05:44 PM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
Default How do I decide which map to use.
Hi,
Just got my AP. I don't see straight answer in the menu on how to decide if my car is Low Wastegate or high wastegate.
Thanks a lot...
Sheltonmega is offline   Reply With Quote
Old 06-27-2011, 06:16 PM   #2
Yellow_Feva
Member#: 269659
04 Forester STI
if your car is over boosting use LWG if its under boosting use HWG.
Just use the normal waste gate map and run it a couple of days. Do some login and determine if it needs it.
Yellow_Feva is offline   Reply With Quote
Old 06-27-2011, 06:53 PM   #3
Sheltonmega
Member#: 265204
Should I try redline? Anything I need to pay attention?
Old 06-27-2011, 09:15 PM   #4
Screwbal
Member#: 196946
2007 Wrx limited WRB
07 FXT WRB,'15 model S
Once you get I'd say at least 50 miles on the tune others may say a full tank you need to go somewhere safe and do a pull from ~2k to redline (or close to) in usually 3rd gear while logging the whole run. First note make sure it is somewhere safe and within local limits as anything outside of that a judge won't care that some guy online said you should heh. Anyways a couple of those and you can look at the logs and see what you're hitting for peak boost and go from there.
In my STI I did my 3rd gear pull, hit 4th and tried to run it up pushing my local limits and threw a CEL and ended up going with LWG and still hit ~1lb over target boost on WOT.
Each car is different and many things come into play so start with the normal one and see what you get. You'll figure it out over time!
Screwbal is offline   Reply With Quote
Old 06-27-2011, 09:15 PM   #5
Screwbal
Member#: 196946
Side note... Fill out your use profile with what car you have - makes it easier for folks to answer you on things
Old 06-27-2011, 11:17 PM   #6
Sheltonmega
Member#: 265204
Got it. Thanks!
Which map to use? SiPex Engine Management & Tuning 6 01-20-2011 02:09 PM
So I have the mods, which map to use? NWSTi-wa Newbies & FAQs 13 05-27-2010 03:09 PM
So I have the mods, which map to use? NWSTi-wa Engine Management & Tuning 1 05-27-2010 01:22 AM
Which map to use? ender87i AccessPort 2 10-25-2006 09:03 AM
Dilemma in deciding which EM to use RC0310 Engine Management & Tuning 9 12-22-2005 02:53 PM
