#526 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Yes, I still have the silver one. I still wish I had the black one, but I don't care enough to try and sell it and buy a new one. My brother put the same valve (but in black) on his MS3, and I want to steal it but he says no, haha. I'd also like black couplers on the FMIC piping. Maybe some day I'll pony up the cash to do both (couplers and BPV). It's not going to change how the car runs, so I don't think it's really worth it right now.
The Forge BPV has a clear annodize on it, it's not just bare aluminum, so it shouldn't corrode. I am currently running with the yellow spring and no shims. With the TMIC I used a green spring I bought from Forge. It is even lighter than the yellow one. Springs/shims will have nothing to do with boost holding ability. They will simply control how quickly the valve vents off when you release the throttle. I used a light spring for quick response and reduced wear on the turbo. A stiffer spring will allow you to hold boost better during shifts, but could be harder on the turbo. Both the green and yellow seem to work OK for me. The blue tends to be a bit too stiff and I get some compressor surge.
#527 |
Member#: 267865
NWIC
Vehicle:2012 STI Hatch Satin White Pearl |
So you purchased the green spring and still decided to use the yellow instead, huh? This is great news. Thanks for taking the time to share your experience.
#528 |
Member#: 261612
I liked the green one better when I had a TMIC. Much better response than any of the other springs. But when I went to the FMIC it seemed like it was TOO touchy. It would vent even when I tried to lightly slow down and made the car pretty jerky. The yellow one seems to be better. I'm not exactly sure why it was different, or maybe it was all in my head.
#529 |
Member#: 280844
TXIC
Vehicle:2006 STi OBP |
Alright, I found one of the write ups, but all it is metal gutter bottom, and probably need some way of holding it to the bumper hole. The grillcraft one has mounting brackets around the edge, but the grill's also thick enough that the brackets were welded onto it.
Here are a few I found that might help give an idea how to do it, since it doesn't look like you'll be able to buy a grill that will work. http://forums.nasioc.com/forums/show...ight=diy+grill http://forums.nasioc.com/forums/show...ight=diy+grill |
#530 |
Member#: 280844
TXIC
Here are a few I found that might help give an idea how to do it, since it doesn't look like you'll be able to buy a grill that will work. http://forums.nasioc.com/forums/show...ight=diy+grill http://forums.nasioc.com/forums/show...ight=diy+grill And a little more than halfway down on this page, 2point0 is talking about how he did his lower grill. Last edited by gregroot198521; 06-24-2011 at 08:22 PM. |
#531 |
Member#: 261612
I put a bike rack on my WRX today. I went with the Yakima setup. More info can be found here (scroll up for the part numbers):
http://forums.nasioc.com/forums/show...8#post34472148 I will be adding a second bike mount very soon. Probably tomorrow. Here are some photos with a single bike mounted to the rack: ![]() ![]() ![]() ![]() ![]() |
#532 |
Member#: 197077
SWIC
Vehicle:1992 Dodge Ram W150 BAN CORINATOR |
Killer shots of an equally killer car sir, all around well played!
#533 |
Member#: 263322
NESIC
Vehicle:2011 WRX Limited WRBP |
d@mn, lovin the stance. any issues with clearance at that height? i want to go lower but boston roads are not friendly.
btw the scoopless hood is looking better and better. |
#534 | ||
Member#: 261612
I scrape my bumper every time I go in or out of my driveway, I nailed a dead goose with my undertray because I thought I could straddle it on the freeway, right now they're doing road work near my house and have small lumps of dirt across the road, any normal car would make it, but for me, I am now limited to one single point of access to my house, because I have no change of making it over the dirt piles, etc, etc. I think about raising it up every day. But when I walk out to my car, I can't do it, because it just looks so cool ![]() |
#535 |
Member#: 267865
NWIC
I love the juxtaposition of the look of performance with a wide, low stance and mean grill alongside the look of utility with a loaded bikerack on the roof.
Subaru: Performance plus utility. |
#536 |
Member#: 181047
Tri-State
Vehicle:2010 SWP WRX Agile Tuned 310/345 EWG |
How do you like having the spacers? Thinking about picking some up for myself, because like you i'm trying to get the best look out of my stock wheel setup. Also, what sizes do you recommend for a '10 f/r?
ps you have the cleanest '11 i've seen ![]() |
#537 | |
Member#: 261612
Thanks! I really don't know what size spacers would work best for the non-widebody. Probably 10mm or so? Just keep in mind you will either need extended lugs, or spacers that come with their own lugs, and you will likely have to trim the stock lugs to all the wheel to mount. |
#538 |
Member#: 254097
Vehicle:2010 WRX Hatch |
^ I used 10mm on the rear of my car to even it out with the front, and I have 2011 wheels and tires (which stick out about 7mm more than stock) on my 2010 non wide-body, and my wheels aren't as flush as xluben's. Feel free to PM me for info/pics of my set-up, I don't wanna crap up his thread with pics of my car
![]() Oh, and to xluben: raise your car up about 1/2" and you'll thank yourself every day! |
#539 |
Member#: 261612
^Thanks. I agree on the drop. Might have to do that one of these days.
#540 |
Member#: 125580
Tri-State
Vehicle:2011 WRX 5dr OBP |
Any plans to build the engine if/when it goes?
#541 |
Member#: 261612
Yeah, probably. Some tentative plans, but nothing really set in stone yet.
#542 |
Member#: 275605
NWIC
Vehicle:2011 WRX Hatch DGM |
Nice rack... have you thought about flipping the fairing to hide the big YAKIMA logo? I'm not a big fan of stickers and logos, so did that with mine. Of course, it's all just a matter of personal preference.
#543 |
Member#: 261612
Oh, good idea. Didn't think of that. I think the other side is a matte finish, right? I'm not sure if those little clips will survive being pulled out, though. They seemed like the one-time-use type of thing.
#544 |
Member#: 261612
I tried the "Brenizer Method" on a few images. If you're not familiar with it, you basically take a fast telephoto and shoot wide open on MF. Position yourself fairly close and take a bunch of shots to cover the area you want. Then stitch the images together in post processing. The end result is an "equivalent" image to one taken with a wider lens that is a very wide aperture (or conversely a camera with a much larger sensor). Often the resulting aperture is something that isn't physically available (especially if you start with a very fast lens to begin with). In essence, it gives you a nice blurry background with a wider frame of view than would normally be seen.
Here are my attempts. Info is below each image. ![]() Camera: Canon 5D Lens: Canon 70-200 f/2.8 IS Focal Length: 200mm f/2.8 Stitched Image Size: 57MP Equivalent Full Frame Lens: 95mm f/1.3 Equivalent 1.6x Crop Lens: 59mm f/0.85 ![]() Camera: Canon 5D Lens: Canon 70-200 f/2.8 IS Focal Length: 200mm f/2.8 Stitched Image Size: 71MP Equivalent Full Frame Lens: 85mm f/1.2 Equivalent 1.6x Crop Lens: 53mm f/0.8 ![]() Camera: Canon 5D Lens: Canon 70-200 f/2.8 IS Focal Length: 200mm f/2.8 Stitched Image Size: 102MP Equivalent Full Frame Lens: 70mm f/1.0 Equivalent 1.6x Crop Lens: 44mm f/0.7 The post processing work isn't perfect. When stitching together dozens of images the work goes very slowly. I may have been able to do better if I put more time into it, but I think they came out looking quite good. In the end I was hoping to get a faster "equivalent" aperture (most ended up being around 85mm f/1.2, which is a lens Canon actually does make), but you do see the desired affect is achieved. Ideally I would probably shoot the images with a 85mm f/1.2 or 135mm f/2.0, so that the resulting image would be a ridiculously low effective aperture, but I don't have either of those lenses. The last one really starts to get the unreal "3D" effect I was going for, but I still think I could have done better. They key is to overlap just enough, but not too much. I really took way too many shots and it made it much harder for Photoshop to stitch them together. Most of the photos seen here were a few dozens shots, but by the end file size, it appears I could have done most with just 6-12 well placed photos. One other cool thing about this, is that it would allow a user with a 1.6x crop body to shoot full frame type images ![]() |
#545 | |
Member#: 275605
NWIC
![]() Good point about the plastic thingies, not sure whether or not they'd hold up. One more tip that I just remembered - go find some locking nuts to replace the wing nuts that hold your fairing on. They're not theft-proof, but at least a little more difficult to remove than the wingnuts. A buddy of mine got his stolen a week after installing it. I found some stainless nylock nuts at Home Depot for mine. |
#546 | |
Member#: 261612
#547 |
Member#: 249401
Vehicle:2009 WRX - Hatch DMG |
#548 |
Member#: 252786
Vehicle:2009 WRX Black |
The Brenizer Method is super cool. Going to have to try it out with my XTI and 70-200 F4L.
Question for you. Are you using manual focus or AF lock when doing the Brenizer Method? Last edited by Rod Knock; 07-06-2011 at 08:53 AM. |
#549 |
Member#: 275642
South East
Vehicle:2011 WRX sedan WRB |
xluben loving the thread man, was curious as to how you mounted the AFR in the little cubby? On my old car I had on in the cluster and it was too "loud" with all the colors and constant changing at night it was wayyyy to distracting. Any advice would help if you don't mind me stealing your idea
#550 | ||
Member#: 261612
| Thread Tools | |
| Display Modes | |
| xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch | xluben | Car Part Reviews | 26 | 11-08-2012 06:55 PM |
| My first post and my first Subaru, a 2011 WRX 5 door in white. | Decade240 | Newbies & FAQs | 25 | 06-20-2012 01:48 PM |
| 2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? | BretCutler | Tire & Wheel | 4 | 01-14-2011 08:05 AM |
| 2011 WRX 5 Door | Ruz4life | General Community | 55 | 10-13-2010 11:37 PM |
| 2011 WRX 5 Door | Ruz4life | General Community | 10 | 10-04-2010 04:02 PM |
