Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 06-02-2011, 09:26 PM   #1
STight
Member#: 71506
2004 STi
Default 2006 Tribeca replacing the drivers side low beam again
I am sick of this crap.
I have had to replace the low beam headlight for the 3rd time since my wife has had the car(78,000 miles), driver side only.
I am not buying the bs about how subaru says that the low beams are driving lights and on all the time so it should be expected. I have had my STi for 7 years and 178,000 miles and replaced 2 low beam headlights. They are always on...
I am surprised noone else is as pissed as I am about this problem and not posting.
Just checking to see if there is any new info as to this problem. Something tells me this is alot more common than my search shows..
Just have to vent on this...
Last edited by STight; 06-02-2011 at 09:37 PM. Reason: forgot to give milage for the B9
STight is offline   Reply With Quote
Old 06-02-2011, 09:42 PM   #2
HB_Dad
Member#: 45190
2014 Impreza Sport L
I believe there is a real defect either in the design of said headlight or in the manufacturing process and SOA is just trying to ignore it. I have replaced the driver's side headlight 4 times now and the passenger side once and my 2006 Tribeca now has 112,000 miles on it. I totally agree there is a real issue here. In fact, if you read some of the threads regarding replacing the headlights on the Tribeca, you will notice a lot of comments about the driver side light going out much more in particular. You might want to have the dealer replace it so the bulb is at least under warranty for a year...
HB_Dad is offline   Reply With Quote
Old 06-02-2011, 09:58 PM   #3
STight
Member#: 71506
2004 STi
Its worth a try...I will post my results for sure if this keeps going on...
Thx, lol....laughing only bc I really hate taken it in to a dealership for something like this etc...
Old 06-05-2011, 01:38 AM   #4
kuoh
Member#: 127558
I must've gotten lucky, because my 06 has 126k and I've only had to replace one headlight and one taillight bulb so far. Ofcourse my GPS no longer locks on to any satellites anymore, so I guess it's not all good luck. I'd trade replacing a headlight every year for a working GPS.
KuoH
kuoh is offline   Reply With Quote
Old 06-28-2011, 03:22 AM   #5
Humphrey
Member#: 281570
2006 legacy
Hi I bought my 06 Tribeca 3 years ago and had the same problem. I managed to fix it by moving the e brake sensor from behind the pedal. I just loosened and twisted the bolt and now its fixed. The only thing is the emergency brake light stays on but saves me money and time. Hope it's helpful info.
Humphrey is offline   Reply With Quote
Old 07-13-2011, 12:11 AM   #6
HB_Dad
Member#: 45190
How does that fix a bulb burning out prematurely exactly? I'm confused...
Old 07-13-2011, 01:49 AM   #7
kuoh
Member#: 127558
It turns off the DRL, extending the bulb time if you're the type that does a lot of daytime driving. I just use the single click e-brake method and ignore the brake warning lamp. If you figure the runtime including DRL hours, the bulbs probably last as long as any others. My passenger side low beam is still the original, but I do notice that it is dimmer than the driver side, which I replaced last year.
KuoH
Old 08-07-2011, 10:02 PM   #8
HB_Dad
Member#: 45190
KuoH
All of my past SUbaru's had DRL's and NONE of them ever had a headlight go out at all. My Tribeca is a different story...
Old 08-08-2011, 11:48 AM   #9
kuoh
Member#: 127558
Different car, different bulbs, different wiring, different driving pattern, take your pick. You can choose to take it up with SOA, file a lawsuit, fix it yourself or use the e-brake. All I can say is that at 130k miles, I'm getting what I consider normal or even longer than expected bulb life, by not using the DRL. With so many new cars equipped with DRLs on the road now, I can't count the number of one eyed monsters I see on the road everyday and it doesn't surprise me one bit.
KuoH
wtb 2006 - 2007 impreza driver side headlight idrivetsi Private 'Wanted' Classifieds 8 03-25-2010 10:42 AM
WTB: 2006 WRX TR front drivers side coor card djerickd Private 'Wanted' Classifieds 2 09-30-2009 04:42 PM
Help replacing CSR 5.75 low beams on GC8 Morettes Rallly2000 Electrical & Lighting 0 08-20-2007 01:51 PM
Drivers side High Beam out TheMadScientist Electrical & Lighting 6 01-27-2007 03:55 PM
cleared my headlights and now drivers side low beam doesn't work EntrustXXX Electrical & Lighting 5 05-12-2005 02:46 PM
