Notices
Closed Thread
Old 06-24-2011, 10:04 AM   #2001
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by dblo View Post
so if they fit and clear the 06 sti brembos, can I be sure that they will clear the '11 sti brembos as well? i found (but havent bought) a set of 17x7 +42 rims that were used on an 06 sti
yes. there's always the option of 05-07 sti wheels.
nhat is offline
Old 06-26-2011, 12:31 AM   #2002
dblo
Member#: 285868
thanks, i certainly wouldn't mind finding a set of those for cheap
dblo is offline
Old 07-03-2011, 12:21 AM   #2003
dblo
Member#: 285868
5zigen FN01R 17x8 +25mm, would these fit on 08+ STi?
dblo is offline
Old 07-03-2011, 12:05 PM   #2004
nhat
Member#: 140163
03 STi
hellaflunctional
yes but it's nowhere near an ideal offset. you're looking at a lot of mods to fit those without rubbing.
nhat is offline
Old 07-03-2011, 02:24 PM   #2005
Scargod
Member#: 260314
2008 STI hatch
Default Need to study-up
Use these:
http://www.1010tires.com/wheeloffsetcalculator.asp
http://www.rimsntires.com/specs.jsp
http://www.rx7.org/Robinette/tire_diameter.htm
Try and avoid spacers.
When you get to a realistic offset (like 40-55), you may find someone who has used the specific rim you are interested in and they may know if it will clear the calipers. Don't hesitate to call the wheel seller or manufacturer and ask if they will clear the Brembos. Some have drawings you can print out and cut out that will show you clearly, in a visual manner, how the wheel will fit.
Scargod is offline
Old 07-03-2011, 05:24 PM   #2006
dblo
Member#: 285868
Originally Posted by Scargod View Post
Use these:
thanks! these are very good reference materials
dblo is offline
Old 07-03-2011, 10:01 PM   #2007
nhat
Member#: 140163
03 STi
hellaflunctional
www.miata.net/garage/tirecalc.html is another good resource
nhat is offline
Old 07-04-2011, 01:38 AM   #2008
littlewhitewagon
Member#: 103068
11 STI sedan
A 17x8+25 would fit very easily, just not the right fit and you are going down from what is stock.
Short answer is don't do it.
littlewhitewagon is offline
Old 07-09-2011, 11:09 AM   #2009
nhat
Member#: 140163
03 STi
hellaflunctional
closing it so i can attempt to edit the first post with as many of the new wheels as possible and ask for different information.
nhat is offline
Closed Thread
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 09:19 PM
When the hell is prodrive going to make wheels that fit the 05 STI PARAMEDIC Tire & Wheel 2 01-09-2005 01:20 PM
Wheels that fit the 05 STI nhluhr Tire & Wheel 21 06-25-2004 01:46 PM
Need 17x7.5 wheels that fit the STi boxerT Private 'Wanted' Classifieds 5 02-17-2004 03:11 PM
Unknown wheels that fit the STi Neil Wallerstein Tire & Wheel 6 11-04-2003 12:51 PM
