Old 07-04-2011, 04:25 AM   #1
e85monster
Member#: 271529
Alright so I bought my car when I was a junior in High school. I had a choice between a 2004 WRX with 50k or a brand new 2007 2.5i. I bought the 2.5i only to regret not having boost. Its been a long time in the making but I finally finished my project build. I waited until I had all of the pictures to write up a build list. I hope this inspires other people that are in my situation. It just shows that this type of build is possible. My main motivation to build my car was people saying I couldnt do it. Ill show you pictures of the car when I first got it till now when its fully built. I hope you enjoy.
e85monster is offline   Reply With Quote
Old 07-04-2011, 04:39 AM   #2
GDB FAN
Member#: 105814
I see no pictures.
GDB FAN is offline   Reply With Quote
Old 07-04-2011, 04:49 AM   #3
jonnylin1
Member#: 232228
2008 SWP WRX -BYE <3
WHITE FTW - AW e92 335i
me eitherrrr
jonnylin1 is offline   Reply With Quote
Old 07-04-2011, 04:50 AM   #4
Entaille
Member#: 217875
2008 STi
im going to go ahead and guess that even if you did this in spite of people saying you 'couldn't', that you spent way more then you probably should have and could have saved a grip of money just selling and buying a wrx to build up : P
either way interested to see the build
Entaille is offline   Reply With Quote
Old 07-04-2011, 04:56 AM   #5
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
^+1 I see this about to happen.
future_subaru_owner is offline   Reply With Quote
Old 07-04-2011, 05:29 AM   #6
e85monster
Member#: 271529
This is the very first day I brought the car home from the dealership. Brand new 2007 2.5i outback sport.
After a couple years of owning the car I didnt do too much. I baked the head lights, put a lip on it, rear WRX wing and a $10 set of dyno ridges for the back
A good friend of mine and I were talking about doing a full build on my car but we werent sure exactly how we could do it. After talking to a couple of local tuners and thinking it out we started.
IMAG0028 by imprezagic, on Flickr
The stock block hanging from the chain.
IMAG0032 by imprezagic, on Flickr
After getting all the internals for the motor we were ready to build. The STI EJ257 crank with eagle H beam rods
IMAG0008 by imprezagic, on Flickr
empty EJ257 short block...not for long lol
IMAG0007 by imprezagic, on Flickr
After plasti gaging the the crank with the bearings and rods we started to put it together
IMAG0009 by imprezagic, on Flickr
sorry for the blurry picture. The crank and rods in one half of the block.
IMAG0010 by imprezagic, on Flickr
After installing the rods and crank it was time for the CP pistons. With this engine we did a 100mm over bore so the block came out to basically be a 2.6L
IMAG0013 by imprezagic, on Flickr
The CP pistons!!
IMAG0014 by imprezagic, on Flickr
Old 07-04-2011, 05:31 AM   #7
e85monster
Member#: 271529
After installing the CP pistons we torqued down the ARP head studs.
IMAG0019 by imprezagic, on Flickr
Getting the long block ready to go after installing the cometic head gaskets
IMAG0035 by imprezagic, on Flickr
Brand new wrapped GT spec UEL headers
IMAG0036 by imprezagic, on Flickr
After installing the oil pan we tapped into the top of it for the oil return.
IMAG0038 by imprezagic, on Flickr
APS SR56 chrome polished turbo getting ready to be put on the GT spec up pipe
IMAG0005 by imprezagic, on Flickr
Long block all put together with the GT spec headers, GT spec up pipe, APS SR56 turbo, Cosworth high pressure oil pump.
IMAG0037 by imprezagic, on Flickr
For the clutch we decided to go with the ACT street light fly wheel and the ACT 6 puck sprung clutch
IMAG0040 by imprezagic, on Flickr
After dropping the engine back into the car this is how it looked...basically it was a mess
IMAG0041 by imprezagic, on Flickr
After realizing the 2.5i has a much larger intake manifold and a different throttle body we had to clock the turbo in order for it to fit. The APS SR56 and the APS hard inlet pipe.
IMAG0044 by imprezagic, on Flickr
There were so many problems we ran into a long the way but theres always a way to get around them. The fuel system in the stock 2.5i N/A cars is internally regulated. The most amount of boost we could push through the car was around 8 until it hit fuel cut. The best way around this problem was to switch my fuel plate out with a WRX fuel plate that had the fuel return option. I went down to the local race shop and picked up an aeromotive fuel pressure regulator with all stainless steel lines. The gold fuel plate on the left is the WRX one that has the fuel return. The silver fuel plate is my stock one that we had to get rid of.
IMAG0012 by imprezagic, on Flickr
Old 07-04-2011, 05:33 AM   #8
e85monster
Member#: 271529
After swapping fuel plates we started to build all of the fuel lines.
On the far right you can see an AN fitting that goes into the aeromotive fuel pressure regulator. The stainless steel lines are going into the turbo XS fuel rails.
IMAG0016 by imprezagic, on Flickr
For the TIAL Q BOV we tapped into the intake manifold for vaccum.
IMAG0017 by imprezagic, on Flickr
Fabbing up the intercooler and piping to work with the clocked turbo.
IMAG0042 by imprezagic, on Flickr
After starting the engine up and pulling the car out of the garage this is how it sat.
IMAG0045 by imprezagic, on Flickr
I forgot to mention that I bought seibon carbon wide body sedan fenders and 18x9 rotas
IMAG0027 by imprezagic, on Flickr
wheel fitment is a little wide...getting carbon rear fender flares in a couple of weeks
IMAG0020 by imprezagic, on Flickr
Old 07-04-2011, 06:10 AM   #9
e85monster
Member#: 271529
I will take more pictures tomorrow when we finish the build. We did a full wire tuck so you can see the entire intake manifold. I will update everyone as I go. Next is a full STI drive train with a seibon carbon rear trunk and STI side skirts with carbon fiber Bride seats that I havent put in yet. Just remember. This car was a 2.5i. If you have any questions about how we did certain things just message me and ill be glad to help.
This is it for now...until tomorrow night lol
Old 07-04-2011, 06:20 AM   #10
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
wow, that's an impressive build. nice to see you stuck with it.
michael_cano is offline   Reply With Quote
Old 07-04-2011, 06:49 AM   #11
wcc5
Member#: 193064
really nice build! cant wait to see more pictures!!
wcc5 is offline   Reply With Quote
Old 07-04-2011, 07:20 AM   #12
mth4life
Member#: 228506
Looks real good so far, hope to see more pictures soon.
mth4life is offline   Reply With Quote
Old 07-04-2011, 07:23 AM   #13
subieguy87
Member#: 153412
1998 Impreza wrxRS
Just goes to show, u can take any subie, and still have it run boost
subieguy87 is offline   Reply With Quote
Old 07-04-2011, 09:11 AM   #14
dhahn1012
Member#: 255578
2005 outback xt
white
Congrats on the build! Everything looks awesome. Good for you. I love when people say things cant be done
dhahn1012 is offline   Reply With Quote
Old 07-04-2011, 09:26 AM   #15
aps_sti1
Member#: 208837
Good job bro, very nice build. U do better work than most race shops u guys need 2open a suby shop n make akilling. This community needs more ppl like u to instill some confidence into all these ppl who are told builds like this either can't or shouldn't b done. Great job bro!
aps_sti1 is offline   Reply With Quote
Old 07-04-2011, 09:52 AM   #16
sooch
Member#: 281760
1998 legacy 2.5gt
black
plans with the carbonfiber? you going to leave it as is or paint?
sooch is offline   Reply With Quote
Old 07-04-2011, 11:11 AM   #17
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
keep the 2.5i badge to trick people
Very nice build dude!
blakkboxer is offline   Reply With Quote
Old 07-04-2011, 11:46 AM   #18
Kovs04sti
Member#: 257085
07 Sti SWP
This is sick I wanna see your numbers when it's all done!
Kovs04sti is offline   Reply With Quote
Old 07-04-2011, 11:49 AM   #19
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
That's a good build so far. Keep it up.
wrXmon is offline   Reply With Quote
Old 07-04-2011, 01:09 PM   #20
SubieRSjustin
Member#: 262254
2000 00rs/99 legacy
silver/ tan
Beautiful build! Keep the updates coming!
SubieRSjustin is offline   Reply With Quote
Old 07-04-2011, 01:15 PM   #21
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
awesome build, looking forward to seeing the finished product!
rolzrex is offline   Reply With Quote
Old 07-04-2011, 02:22 PM   #22
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
subscribed! Nice job man
Matt515 is offline   Reply With Quote
Old 07-04-2011, 02:32 PM   #23
01rs25
Member#: 117555
07 LGT
Agile Protunned
What are you going to tune it with?
Why not swap the heads, the stock SOHC heads are going to be an extremely big limiting factor.
Good progress so far though
01rs25 is offline   Reply With Quote
Old 07-04-2011, 02:53 PM   #24
mac1124
Member#: 286146
2003 2.5 TS Wagon
Blue Ridge Pearl
I agree.
Also awesome build. Looking forward to completed pictures. Great job.
mac1124 is offline   Reply With Quote
Old 07-04-2011, 02:54 PM   #25
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Damn, man, did you graduate from high school and get a job growing money trees? That's a helluva build you've got going on!
Either you got one of the ultra-rare stroker EJ257 cranks, or you need to work on your math.
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 20 11-20-2015 09:27 AM
Will the STi Front and Rear Bumper will fit on the 2.5i? GD6Noob Interior & Exterior Modification 7 04-30-2012 08:33 PM
FS : OEM 06 WRX parts - LOTS AND LOTS of them ninefourteener RMIC Private Classifieds 15 09-17-2010 11:31 AM
Nice deal on track rubber, ebay...A032R's new, and lots of them... REX8 Motorsports 62 11-09-2008 11:58 AM
2 I-80 Sightings in Sac (One of them MUST be from the club!) Kostamojen Bay Area Impreza Club Forum -- BAIC 5 01-09-2002 10:14 PM
