Old 06-27-2011, 12:53 AM   #76
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Why 2 switches?
bdj238 is offline   Reply With Quote
Old 06-27-2011, 06:38 AM   #77
lykemeyet
Member#: 283890
2002 impreza
I wasnt sure what the green connectors and the blue plug do individual for other applications other than than using the ap. So just incase I need to u just one I still can. All I do is flip both switches and I'm in test mode. It's a lot easier
lykemeyet is offline   Reply With Quote
Old 06-27-2011, 03:26 PM   #78
tyscat
Member#: 196438
2006 STI
Crystal Gray Metallic
I have a similar setup w/ a switch:
Works pretty good.
tyscat is offline   Reply With Quote
Old 07-08-2011, 06:43 AM   #79
Johnnywalker
Member#: 267501
2011 WRX hatch
Dark grey metallic
I was wondering, you guys all seems to have a standard usb plug to connect your accessport to OBDII...
I only have that sort of 8-9 pins rectangular plug on mine, AP-SUB-003...I dont get it!
Johnnywalker is offline   Reply With Quote
Old 07-08-2011, 10:06 AM   #80
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
I have the same. The usb is for the computer. 8 pin plug is for OBD. You look normal to me.
Sheltonmega is offline   Reply With Quote
Old 07-08-2011, 11:29 AM   #81
Johnnywalker
Member#: 267501
2011 WRX hatch
Dark grey metallic
Humm yeah, but still dont get why all AP pictures posted in this thread are plugged with a standard USB cable?
Old 07-08-2011, 11:35 AM   #82
Sheriff_Austin
Member#: 287212
2011 WRX 5dr Stage 1
The version 2 and less used an adapter in the OBD port that the usb cable plugged into. You and I have the version 2b, which is a direct connect.
My guess is its cheaper to manufacture just the one cable than have an adapter in between.
Sheriff_Austin is offline   Reply With Quote
Old 07-08-2011, 11:38 AM   #83
tyscat
Member#: 196438
2006 STI
I don't know about the AP-SUB-003, but on the -002, it is a standard USB to 5-pin cable:
Amazon.com: Belkin F3U138-06 Pro Series USB 5-Pin Mini-B Cable (6-Feet): ElectronicsAmazon.com: Belkin F3U138-06 Pro Series USB 5-Pin Mini-B Cable (6-Feet): Electronics
When hooking your AP up to your computer, you plug the 5-pin into the AP and the USB end into the computer. When hooking the AP up to your car, you plug the 5-pin into the OBDII and the USB into the AP.
Like I said, I don't know what's up with the -003, but that is why you are seeing so many USB to 5-pin cables in this thread. That it how it is supposed to work.
Old 08-07-2011, 01:17 PM   #84
mudferret
Member#: 240688
06 WRX
I found myself using my AP more and more since the latest firmware update. Was picky about the type of mount, and location. Ultimately I wanted it within the gauge cluster area, but I settled upon this location once I found a mount that I actually liked. I didn't want to drill holes, use velcro, have the Canadarm on my windshield, mount something to my vents, etc... and wanted the AP easily visible to me while looking down at the gauges. It's also a versatile mount and came with various device adapters and can be swapped back/forth from dash to windshield. It stays stuck to the dash or glass very well, and since the arm is short it doesn't bounce around.
It's an IQ solutions ZR mount.
mudferret is offline   Reply With Quote
Old 08-07-2011, 07:23 PM   #85
Bloodbath
Member#: 281248
2011 STI sedan
Thanks for the ideas! Until now, when my AP is hooked up, it just sits in the cup holder
Bloodbath is offline   Reply With Quote
Old 09-11-2011, 01:07 AM   #86
young_skywalker
Member#: 290707
2008 WRX Hatch
I'm with you at this point, though I did get a OBDII 5' extension and route my cable through the console. The rubber tray just north of the shifter seemed to work well during during the test drive.
young_skywalker is offline   Reply With Quote
Old 04-09-2012, 05:06 PM   #87
Trustkevin13
Member#: 259184
2008 Subaru WRX
Originally Posted by olazy View Post
using
Looks great, more pics and links of products you use?
Doin for my 2008 WRX now too.
Trustkevin13 is offline   Reply With Quote
Old 04-09-2012, 05:07 PM   #88
Trustkevin13
Member#: 259184
2008 Subaru WRX
......pics of the wiring...........and a link to the thingy..... sorry, big noob, got my wrx a year ago and i'm still learning. still pretty fly for a 19yr old guy.
Old 04-09-2012, 05:22 PM   #89
promted
Member#: 282888
Rally Blue
I've wanted to post this for a while now because I think it's perfect! I had this little sample thing from some outdoor retail show and never used it but then when I got the access port I remembered it and sure enough it was a perfect fit! It's super easy to use, and does not change your access port in any way, in fact I just put a little twisty tie on my vent and hooked this thing up. Another thing that I love is I can detach it while leaving the twisty tie on. Hope this helps some of you guys...
http://www.ebay.com/itm/For-iPhone-4...ht_3742wt_1170
promted is offline   Reply With Quote
Old 04-12-2012, 01:54 PM   #90
olazy
Member#: 263322
2011 WRX Limited
WRBP
here's some more pics. the AP is now blocked by the boost gauge but i only use it for datalogging anyways. if i tilt it like pic#4 i can still see the high/low readings.
1
2
3
4
5
olazy is offline   Reply With Quote
Old 04-15-2012, 11:07 AM   #91
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Recently I taught myself to tune. I was absolutely appalled by the dyno tune I got. Knock counts everywhere, afr's off the chart. Good thing I rarely drive my sti otherwise I might be replacing the motor.
This is my new "accessport" mount.
Scrap aluminum+1 hour of my labor welding=free
2.5 turbo hyped is online now   Reply With Quote
Old 05-19-2012, 05:29 PM   #92
sc00ter
Member#: 117767
2015 WRX
CWP
I just got the Proto Tuning Tool Mount from RallySport Direct.
It fits the Accessport perfectly and provides a permanent mounting solution as well as a vent clip mount. The vent mount will work until I find the best place to use the permanent mount provided in the packaging.
sc00ter is offline   Reply With Quote
Old 01-10-2013, 01:19 AM   #93
949
Member#: 58906
i have this for sale. 20 bucks.
its plug and play.
no drilling or cutting. just mount it and place the ap on it. or even a cell phone.
here i put a cell phone holder on it.
the accessport can be installed instead.
949 is offline   Reply With Quote
Old 02-17-2013, 10:13 AM   #94
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
there is another thread on this, but this is a GoPro Hero2 windshield mount, i put one of the backings on my AP for use when data logging only. otherwise, NOT in use, on my kitchen counter.
ChesterWRX is offline   Reply With Quote
Old 02-21-2013, 02:35 PM   #95
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I like that! Nice work
Old 02-21-2013, 03:25 PM   #96
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
If you want one of these, here is the website. I bought this one from 949 and I like it a lot. Ill post pics later.
http://www.panaviseonline.com/Panavi...751-34-202.htm
Daddy_Digital is offline   Reply With Quote
Old 05-13-2013, 10:05 AM   #97
WilR
Member#: 343078
2013 WRX Hatchback
Finally got around to trying this out. Not sure if I like the hole but it will do until I can figure something out to fill it.
WilR is offline   Reply With Quote
Old 05-13-2013, 12:18 PM   #98
fushnica2
Member#: 248151
2013 STI
Ice Silver Metallic
Not the greatest picture, but this is using the Proto Tuning Tool holder from Rally Sport Direct.
It has a couple of different mounting methods, the one I'm using here "grasps" a vent fin. It holds it firmly, but it moves easily. It's decent, but not great. The other mounting method it comes with is a adhesive backed base with a ball on it that the tool connects to, so you can mount it anywhere.
I just had the cable wrapped with velcro and a couple small pieces of velcro on the dash below the steering wheel to keep the cable "tucked."
fushnica2 is offline   Reply With Quote
Old 05-13-2013, 12:58 PM   #99
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I take it that you will do a myk cluster pod? Cuz the location of that AP won't allow a pillar pod
Old 05-13-2013, 01:46 PM   #100
fushnica2
Member#: 248151
2013 STI
Ice Silver Metallic
I also now have an A-pillar cluster and although I don't normally keep my AP mounted anymore, I have placed it there for datalogging. It fits fine. It all looks a bit crowded, but I can throw it up there and snap a picture if you want to see how it looks.
Post your LOCATION please... Longitude Private 'For Sale' Classifieds 16 03-17-2006 03:39 PM
Picture Request. Your Ps2 mounting Location Crump Member's Car Gallery 19 04-13-2005 06:47 PM
Can you sellers please post your location in the subject line pha qed Private 'For Sale' Classifieds 14 06-02-2004 03:39 AM
New antenna location pic, post your pics too IA Performance Interior & Exterior Modification 0 08-22-2003 11:42 PM
