Old 07-08-2011, 07:12 PM   #1
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Default TopSpeed Motorsports | DOM 1.5 TESTING COMPLETE!!!
Today we finished the testing on our 2011 STI with the Blouch Dom 1.5 Turbo. We have done countless Blouch 20g XT builds here at TopSpeed, but no one had ventured out to try the ball bearing Dom 1.5. We were honestly floored with the results!
What we look for in a stock location turbo is something that we can keep drive pressures down on, still spools quickly. A lot of the bigger stock location turbos do not appeal to use because of the high drive pressures and laggy nature. We feel that you have to give up so much power curve most of the time that its better to stay with either the smaller stock location, or just bite the bullet and go rotated.
This turbo however surprised us! We are very happy with the curve, power, spool and top end performance. This test was done using an 8cm hotside, however we will be swapping to the 10cm to see how much power band we give up. I would recommend this turbo to anyone looking for great power, and a huge broad power band!
TopSpeed Motorsports 2011 STI Project Car:
Numbers
Dyno: Dyno Jet
Tuner: Douglas Wilks
Wheel HP: 377.61
Wheel TQ: 415.01
Ambient Temp: 85.47 F (23% Humidity)
Elevation: 1000ft (EST.)
Boost: 21PSI Peak
Fuel: 93oct Pump Gas
Car Info
Year: 2011
Engine Management: Cobb AP
Turbo: Blouch Dom 1.5
Intercooler: Stock
Meth Kit: None
Injectors: Injected Dynamics 1000cc
Intake/Inlet: Stock Air Box/Perrin Inlet
Headers: Invidia Race Headers
Uppipe: Invidia
Downpipe: Invidia
CBE: Invidia
TopSpeed Tuner Review
http://www.iwsti.com/forums/review-s...eed-ga-61.html
Future plans:
- testing 10cm Hotside
Thanks for looking, feel free to ask any questions.
~Cicio
GRAPH OVERLAID WITH THE STOCK TURBO PLOT
**EDIT
Here is an overlay of the Dom1.5 8cm & a 20gXT 10cm
This will be a better compairison once we do the 10cm testing on the Dom1.5, but this will give you guys an idea.
As you can see the 10cm barely outflows the 8cm up top with the 1.5, while the 8cm 1.5 kills it until 6k RPM
More to come guys.
~Cicio
TopSpeed is offline   Reply With Quote
Old 07-08-2011, 07:25 PM   #2
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Wow. I assume that is "stock stage 2" tuned, right? Looks like you give up very little on the bottom end for some very healthy gains. Good stuff....
thefoos is offline   Reply With Quote
Old 07-08-2011, 07:47 PM   #3
bilt2run
Member#: 134211
boost or better yet boost plot, octane..
bilt2run is offline   Reply With Quote
Old 07-08-2011, 09:26 PM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Nice! Boost, afr, and maybe timing plot?
rexworx is offline   Reply With Quote
Old 07-09-2011, 12:12 AM   #5
TopSpeed
Member#: 78884
Go faster
at TopSpeed
I updated the first post with boost and fuel...21PSI peak on 93oct pump gas...sorry I had to rush to get the thread done earlier and forgot.
I will post a boost graph tomorrow from the logs for you guys when I get to the shop.
Turbo is SICK on the street! Spool is so close to stock, yet there is SO much more power up top.
~Cicio
Old 07-09-2011, 09:02 AM   #6
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
Great Numbers! Just curious why the stock air box on the stage 2 and dom 1.5 testing? Seen some good info on updading the stock box so far.
Android287 is offline   Reply With Quote
Old 07-09-2011, 09:45 AM   #7
KA-T_240
Member#: 188402
05 STI
Looks like some awesome results. Which I find to be expected with Topspeed. I have a friend with a 20gXT tuned by topspeed, still running the stock airbox and making over 400whp on E85.
KA-T_240 is offline   Reply With Quote
Old 07-09-2011, 12:15 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
Looks impressive. Were these pulls done in the same gear as the stock turbo baseline? How does this compare to the 20g XT?
-- Ed
Old 07-09-2011, 12:16 PM   #9
TiredGXP
Member#: 245040
2010 Legacy GT
That looks like one fun daily driver powerband
TiredGXP is offline   Reply With Quote
Old 07-09-2011, 12:56 PM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Very nice.
Old 07-09-2011, 01:02 PM   #11
TopSpeed
Member#: 78884
Go faster
at TopSpeed
We find the stock box to be more consistant than a CAI when under 400 whp. You may be able to put on an aftermarket intake on the dyno and see a few more HP, but then go sit in some traffic when its 90 degrees out and see what happens. The stock box is not a restriction point under 400whp so we leave it be.
Thanks man..who is your friend?
-- Ed
Good question Ed, we ensured that they were done in the same gear as it will change the spool with the extra load in 4th vs. third. I have tones of 20g XT graphs, but honestly 90% of them are on E85, so its not a fair comparison. I'm going to dig through my records and try to find one for you guys today.
Thanks, the thing is a blast on the street...you honestly can barely tell it from stock spool....its sick.
Originally Posted by juanmedina View Post
Very nice.
Thanks Juan
Old 07-09-2011, 02:24 PM   #12
STIdad
Member#: 195929
what size inlet 2.5" or 3"
STIdad is offline   Reply With Quote
Old 07-09-2011, 03:08 PM   #13
jamesw95
Member#: 270830
2008 STi
I'd been looking at an AMS 750R set up on pump gas to get around those numbers and now your telling me I can do it with a bolt on turbo and injectors. I have on 08sti with Invidia Race header and TBE. Sounds great but almost too good to be true!
jamesw95 is offline   Reply With Quote
Old 07-09-2011, 10:24 PM   #14
wrx904
Member#: 97365
2015 Mustang PP SC
I am really wanting the turbo.
wrx904 is offline   Reply With Quote
Old 07-09-2011, 11:02 PM   #15
spintheground
Member#: 239638
2007 WRX TR UGM
What are stock numbers on this dyno? I can't see the graph as my ISP blocks the image hosting server you use.
spintheground is offline   Reply With Quote
Old 07-10-2011, 11:43 AM   #16
b00st3d
Member#: 9891
2015 RC-F
Ultra White
stock #s appear to be 304hp/379tq
that is a very high reading dyno!
b00st3d is offline   Reply With Quote
Old 07-10-2011, 12:23 PM   #17
TiredGXP
Member#: 245040
2010 Legacy GT
Depends on whether the baseline run included the inlet, headers, UP and TBE. the OP doesn't specify conditions for the baseline other than "stock turbo".
Clarification would be nice.
Old 07-10-2011, 12:28 PM   #18
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Were the ID1000's maxed out? How well would they do with E85 on this setup?
LIQUIDSK8S is offline   Reply With Quote
Old 07-10-2011, 12:45 PM   #19
STI08awd
Member#: 256411
08 STi
Those aren't stock numbers those are stage 2 numbers
STI08awd is offline   Reply With Quote
Old 07-10-2011, 08:16 PM   #20
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Peak tq @ 3750!? This is a real kick in the balls to my 20GXTR plan . Im going to attribute it to dual AVCS and pretend I didnt see this thread.
trex616 is offline   Reply With Quote
Old 07-11-2011, 08:57 AM   #21
TopSpeed
Member#: 78884
Go faster
at TopSpeed
2.5 inch inlet
If you are going to go AMS I would suggest the Garrett based kits VS the precision.
But yes...this turbo would make 400whp with a TMIC/FMIC I am quite confident.
So sorry about that...I should have made it more clear.
The "baseline" was the car fully tuned with all of the same mods except the turbo. It has an equal length Invidia race header which is why the torque numbers are amazing on stock turbo.
See above..fully protuned full bolt ons, not stock baseline.
Sorry...clarification above.
No they weren't even close to being maxed out....and this setup would EAT UP some E85.
You are correct.
Don't ignore the truth
The 20g is a great turbo though.
~Cicio
Old 07-11-2011, 12:12 PM   #22
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Thanks for the response, I assume by "EAT UP" you mean they would love it, which is great news for me
Old 07-11-2011, 12:17 PM   #23
TopSpeed
Member#: 78884
Go faster
at TopSpeed
LOVE LOVE LOVE
LOVE LOVE
LOVE
LOVE LOVE LOVE LOVE
NAM NAM
EAT UP!!!
LOL
~Cicio
Old 07-11-2011, 02:28 PM   #24
rexblake
Member#: 178426
2010 S4
Gray
Very nice.
Old 07-11-2011, 03:42 PM   #25
Troa
Member#: 183147
'98 OBS
Awesome!!! I looked for days for a dyno graph on this turbo before I bought it to no avail. I'm running it on my freshly forged motor w/ headwork but am still breaking her in. I was expecting closer to 350whp so these numbers are quite a surprise! If you wanna check in on my build in a few weeks you can watch my journal here - http://www.3gwrx.com/forum/index.php...;topicseen#new and I'll be posting dyno numbers as soon as she's broken in and tuned. My mods are quite a bit more extensive though so I think ill be putting down a bit more power. I'm excited to see the differences between te 8cm and 10cm! Subscribed!
Troa is offline   Reply With Quote
TopSpeed Motorsports - **2011 STI** Invidia Race Header Tested!! TopSpeed NASIOC Project Cars 79 02-22-2016 07:37 PM
TopSpeed Motorsports AMS GT30R\GT35R Turbo Kits (A TopSpeed Exsclusive) TopSpeed Vendor 'Group Buy' Classifieds 55 04-11-2011 03:38 PM
Dyno Tune Epic Motorsports Dom 2.5 XTR Makes 355 whp 372 trq 2006 STI 03WRXWagon Proven Power Bragging 7 03-09-2011 09:00 PM
