#1 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
I recently bought a 2000 2.5RS with a blown motor. My goal is to turn it into a reliable daily driver to replace my dutiful 1997 Impreza L 2.2 5MT, who while totaled, continues to run like a champ, but is getting a little long in the tooth.
My goals for this project: 1) Get her driving again much quicker than my last project (wagon of doom) 2) Reliable 3) Cheap Here is what she looks like at this point: ![]() ![]() ![]() Car details: -169,555 miles -2.5L SOHC MAP -5MT -$500 The good: -AGX adjustable struts with stock springs -Full poly bushing set -Brand new tires -New front bumper -New headlight -New passenger-side fender The bad: -Motor was starved of oil - rod knock - needs to be rebuilt -Windows are SLOW and tint is tearing off - need to be rebuilt/retinted -Leather wheel and shifter and gone - need replacement -Driver-side seat is torn up -Interior needs a deep clean -Exterior paint is SHOT -Sun roof is jammed -Needs a better/complete stereo I'm sure there will be more as I get into it.
#2 |
Member#: 276955
SWIC
Vehicle:2002 WRX 1st White and 2nd Blue |
Hey I got a lot of random parts and don't ever mind helping if u need another guy to wrench let me know
#3 |
Member#: 120273
SWIC
#4 |
Member#: 120273
SWIC
I got a spare NA 2.5 short block from a fellow member on here. I promised to trade him alcohol for it, but I never delivered the goods, so this motor was free. brocksdad is a sucker.
![]() Either way, this motor also had rod knock despite having brand new bearings and despite having only run for a minute or two. What was strange is that this motor was from a 1997 Outback, which should have made it a Phase 1 DOHC 2.5. However, upon teardown, I found that the case and the crank were definitely Phase II as the thrust bearing was on #5 instead of #3 like the Phase I blocks. To compound things, the pistons in this block were definitely the old Phase I square relief ones. My guess is that this car had a warranty replacement motor at some point and Subaru repaired it with the updated block design. Whatever the case may be (no pun intended) on the doaner motor, it looks like I can use the block and the crank for this build. This saves me the trouble of driving down to Tucson and pulling the motor from the RS only to drag it back up here for disassembly and rebuild. Here are some pictures of what I found. #4: ![]() ![]() #3: ![]() #2: ![]() #1: ![]() As you can see, the bearings are shot. It seems that the bearing in the rod end (not the cap) on each took the brunt of the damage. This makes sense. What would you guess caused this? Lack of assembly lube? Not priming the motor? Improper clearances? Improper torque on the cap bolts? |
#5 |
Member#: 120273
SWIC
These stuck out from the top of the block by about 0.5-1.0mm at TDC.
![]() ![]() The skirts seem very worn with even a bit of scoring. They are 99.0mm. ![]() ![]() The crank looks to be in good shape with some scoring. I'm pretty certain it can be polished up and used with the correct bearings. What do you think? I know the pictures are not the best. ![]() ![]() ![]() ![]() ![]() ![]() |
#6 |
Member#: 120273
SWIC
#7 |
Member#: 14732
SWIC
Vehicle:+ 08 SG6 & 12 DBA Built not bought #0002 |
should have been my RS
#8 |
Member#: 66959
SCIC
Vehicle:VF Engineer'd e46 M3 & vip'd 2GS GS300 |
This was one of those good deals I've seen for sale on this forum.
#9 |
Member#: 6886
Tri-State
Vehicle:MY01 EJ207 HTA35r nothing to see, i'm stock |
Scrapping old green? I hope blue will handle just as well... flat out.
#10 |
Member#: 176944
SWIC
Vehicle:06 STI Aspen White |
Wow we have similar stories as far as finding a cheap GC with a blown motor haha. Currently waiting for the heads to come back from the shop then its on to reassembly
good luck with this build man, and I'm always down to lend a hand if you need! |
#11 |
Member#: 276955
SWIC
In glendale phx area got a place that will do valve jobs for 120 starting and cheap cheap for seals and things that need to be replaced
#12 |
Member#: 120273
SWIC
Ok cool. I will be in contact with you about them. I want to freshen up the heads while I have them out. I was looking at a mild grind set of delta cams too. Do you have any experience with those?
#13 |
Member#: 214737
Ken I've got a hook up at a machine shop. I can get your heads done for pretty cheap.
#14 | |
Member#: 120273
SWIC
So I got a pretty reasonable explanation for why this motor got smoked on the forst 30 seconds of running:
#15 |
Member#: 107352
SWIC
Vehicle:Not Respectable |
#16 |
Member#: 120273
SWIC
I started the easiest part of the motor build today, buying the components. Here is the list so far:
This car has 169,555 miles so I'm doing some extra maintenance parts while I'm in there. 1) Subaru OEM Gasket Kit - 10105AA860 - Purchased 2) NPR Piston & Ring Kit - Link - Stock size - Purchased (took a risk on these... we'll see. 3) ACL Bearing Kit - Waiting on sizing until after crank polishing. - Pending 4) Timing Belt Kit - PCI Belt, GMB pulleys and tensioner. Link - Purchased 5) Water Pump Kit - GMB Pump. Link - Purchased 6) Clutch Kit - Exedy KSB04. - Purchased 7) Power Steering Pump Rebuild Kit - Purchased 8) Aluminum oil separator (to replace the crappy plastic one that leaks). - Purchased 9) 3-4" Outside Micrometers (and other sizes) - Purchased 10) 3.5-4" Inside, 3-point Micrometer (for bore size) - Pending 11) Assembly lube/sealant/fluids/filters - Pending 12) A second set of EJ25 SOHC heads - - Still looking EDIT: I've decided NOT to build a second block. The NPR pistons were a bust... too small. I'm going to rebuild the block that's in the car. Last edited by kpluiten; 07-18-2011 at 12:53 AM. |
#17 |
Member#: 120273
SWIC
Ok, a bit of an update. I towed the car up from Tucson a couple of weekends ago. Turns out Jeep Wranglers are NOT a good tow vehicle. It was a SLOW trip.
#18 |
Member#: 120273
SWIC
I had some friends over this weekend and we pulled the motor out of the car on Saturday. Today I tore the motor down to the short block.
I have not seen any of the internals yet, but there were signs of bearing damage in the oil. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#19 |
Member#: 120273
SWIC
There were leaks EVERYWHERE on the block, from the PS pump to the cam covers. No wonder it ran out of oil. The heads look to be in good shape though as do the cylinder walls. I think I'll be able to have the heads refreshed with new seals and all, and then just do a re-ring, hone, and new crank/bearings and be on my way. Nothing extreme planned.
#20 |
Member#: 149819
SWIC
Vehicle:64 mustang real cars are red |
Hey Ill give you some beer for the block you didnt use....
#21 | |
Member#: 197077
SWIC
Vehicle:1992 Dodge Ram W150 BAN CORINATOR |
#22 |
Member#: 44422
SWIC
Vehicle:2008 G8 GT Burnouts on Central! |
Nice Ken. Always loved the RS. Nice with a 2.0L turbo swap though. I tuned one with a 16g. Holy cow was it fast
#23 |
Member#: 113342
SWIC
Vehicle:You owe me a 10 second car. |
Ken, are you still keeping the green car and the wagon? Just curious.
Also, why are you putting so much work into a NA motor? I'm sure a turbo 2.0 could be found on the cheap. |
#24 | ||||
Member#: 120273
SWIC
I'm looking for a solid daily driver now, not something I want to modify. I have the wagon for that. I'd like to spend about $1500 total on this car ($500 for the car, $1000 on rebuild). Then I will drive her for the next couple of years like I did with the Green car. If the right donor car comes along however... ![]() |
#25 |
Member#: 283881
Vehicle:2004 WRX wagon 2.0 Silver |
[quote=kpluiten;34393980]I started the easiest part of the motor build today, buying the components. Here is the list so far:
This car has 169,555 miles so I'm doing some extra maintenance parts while I'm in there. 1) Subaru OEM Gasket Kit - 10105AA860 - Purchased 2) NPR Piston & Ring Kit - [URL="http://cgi.ebay.com/ebaymotors/Subaru-2-5L-EJ25- I am looking at 2.0 WRX pistons how did yours hold up? I want a stock rebuild. |
| Thread Tools | |
| Display Modes | |
| Can you put an STI crossmember on a 2000 2.5rs /w the stock RS stuff? | Cyclops | Transmission (AT/MT) & Driveline | 3 | 03-12-2009 07:55 PM |
| WTB: 2000 2.5RS Drivers Seat | crxtls2 | NESIC Private Classifieds | 4 | 06-17-2008 09:27 AM |
| socal: 2000 2.5RS Drivers seat | pwrup25RS | Interior/Dressup/Audio & Security | 0 | 06-14-2007 11:34 PM |
| 2000 2.5RS w/86k mi on the odometer P0325 on startup? | AcquaCow | Normally Aspirated Powertrain | 2 | 11-16-2005 11:16 PM |
| ('93-'01) Want some facts on the 2000 2.5RS, please help! | UB_imprezzed | Impreza Forum | 6 | 04-18-2002 07:51 PM |
