Old 07-18-2011, 10:55 AM   #26
markqt
Member#: 284893
2006 MY06 WRX
year: 2006
model: Impreza WRX
wheel model: Rota Gunmetal
wheel size/offset: 18x9 +35
tire brand/model: Kumho ku31
tire size: 235/40/18
suspension: xyz coilovers
alignment: -2.5f -2r
fender mods: rears and front rolled, tires rubbing crazy in back. Coilovers set on full stiff. Raising it tomorrow, don't know how much I want to raise. Like to keep it low. Any suggestions from looking at picture?
spacers: yes/no? size? no
markqt is offline   Reply With Quote
Old 07-18-2011, 03:38 PM   #27
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
05 Wrx AW 18x10 WFC#295
dont raise it if you want to stay low. i say lower the front alittle more and add more camber all around, also think about a mild pull as well. this is an easy setup to fit and be low you just have to work at it.
under0athh51189 is offline   Reply With Quote
Old 07-18-2011, 04:40 PM   #28
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
Originally Posted by DAlexsanderC View Post
Ok so i just got the car. I seen this thread http://forums.nasioc.com/forums/show....php?t=2138259 and i love that setup but id like a lil more tire for these damn potholes out here.
I wanna run the Miro stp-1's. 18x10 +25
I ordered BC BR coilovers already, im just trying to figure out what tire size i need and do i need spacers to clear the brembos? i would like to avoid pulling and rolling the fenders but if i have to i can get it rolled. I dont mind camber also as i will only have this setup just for the summer.
Help is much appreciated.
haha thats my car bro, thats great. i just want to throw it out there that these wheels only come in 5x100 and you sir need 5x114.3. also if you were to run these you would need 5mm spacers up front to clear your brembos. im not sure about the 11 Stis but i had to roll and pull my fenders. i also had to cut out my front fender liners, tuck my wiring harnesses and get in the front fender tubs with a blow torch and hammer to knock them back far enough to where i wouldnt rub. its a big pain to get 18x10s to fit on my body style but on yours im pretty sure just a all around roll and maybe slight pull with -3 camber all around would alow you to go pretty low. im running -3.5f and -4.5r camber with crazy stretched tires. maybe somebody with a 11 Sti can chime in here.
Old 07-18-2011, 08:22 PM   #29
DAlexsanderC
Member#: 287879
2011 Wrx Sti
Damn didnt know i had to do all that haha. I guess im **** out of luck if it only comes in 5x100. Thanks for the help
DAlexsanderC is offline   Reply With Quote
Old 07-18-2011, 11:40 PM   #30
markqt
Member#: 284893
2006 MY06 WRX
Yeah, I was thinking of just adjusting it similar to the front. Don't really want to add more camber, I don't want having quicker tire wear. Might just add a little negative camber on the rear, probably the same as front from -2 to -2.5.
Old 07-19-2011, 12:46 PM   #31
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
it would probably help. btw camber doesnt really kill tires its toe. ive been running -4.5 for at least 6months with no excessive tire wear. dont get me wrong it wears faster than no camber but from -2.0 to say -3.0 its not a big difference
Old 07-19-2011, 06:32 PM   #32
littlewhitewagon
Member#: 103068
11 STI sedan
That's too bad since I don't think they make 5x114.3.
littlewhitewagon is offline   Reply With Quote
Old 07-21-2011, 03:00 AM   #33
DAlexsanderC
Member#: 287879
2011 Wrx Sti
http://www.tsxclub.com/forums/tsx-cl...rice-drop.html
How about these wheels lol. I wanna know if they would clear the brembos on my 2011 sti. Any spacers needed? Fenders rolled?
And what tire size would look and go well for it.
5x114.3
2x 18x8 +37
2x 18x9 +37
Old 07-21-2011, 11:07 AM   #34
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
5x114.3
2x 18x8 +37
2x 18x9 +37
why do you keep looking at staggered wheels?
Old 07-21-2011, 11:08 AM   #35
littlewhitewagon
Member#: 103068
11 STI sedan
No way to answer you unless we know the disk type, but you really don't want those wheels. They are narrower than your stock wheels and staggered. You will need so much spacer to make them somewhat "fitted", about 25mm or so.
Old 07-21-2011, 12:09 PM   #36
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
year: 1999
model: Impreza 2.5rs
wheel model: Rota SVN-R
wheel size/offset: 18x10 +30
tire size: 225/40/18
suspension: Raceland coilovers
alignment: 0*f -.5*r
fender mods: 22b widebody
spacers: no
S53089 is offline   Reply With Quote
Old 07-21-2011, 12:10 PM   #37
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
0* f and -0.5* rear? really? that must feel awful.
other than that, looks good but you could run a LOT more tire of you dial in some camber.
Old 07-21-2011, 12:18 PM   #38
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
yea, when i have camber it looks sunk, so i am in the process of ordering 18x11 +13 as soon as i can get the money
Old 07-21-2011, 02:54 PM   #39
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
why not more tire? looks like you have more than enough room for 255s.
Old 07-21-2011, 04:12 PM   #40
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
because i dont track it, it just parks hard. and im ganna be switching to a wider rim soon, so im not that worried about it
Old 07-21-2011, 04:12 PM   #41
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
and that tire already rubs with how low i am
Old 07-21-2011, 05:36 PM   #42
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
May I ask why you're looking into an 11" wheel?
Byzantium is offline   Reply With Quote
Old 07-21-2011, 05:53 PM   #43
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
because as he stated he is a hard parker and wants to be herrafrush yo why does it matter to you so much what somebody does to there car?
i personally would try to fit 18x12s if you could just to say you did, but 18x11s with a low offset will look sick as hell with lots of camber. what wheels are you thinking of getting? cant wait to see it when you do it. im thinking of getting some 18x10.5s or maybe 11s just to see if i can get them to fit on stock body with just alittle pull and alot of camber
Old 07-21-2011, 05:57 PM   #44
Byzantium
Member#: 207826
85k 2002 WRX
Oh, sorry. I thought I quoted S53089, not under0ath51189.
Old 07-21-2011, 06:46 PM   #45
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
Oh, sorry. I thought I quoted S53089, not under0ath51189.http://forums.nasioc.com/forums/member.php?u=172942
Originally Posted by nhat
this is not the thread for opinions. there is no right and wrong. points will given accordingly. if any "correct fitment" crew members post here, you will receive points for each and every post.
enjoy your points.
edit: when i get to a laptop
Old 07-21-2011, 09:38 PM   #46
Byzantium
Member#: 207826
85k 2002 WRX
enjoy your points.
Points for what, asking a simple question? Get over it nhat.
Old 07-21-2011, 11:59 PM   #47
under0athh51189
Member#: 193959
2002 Wrx Wrb wagon
Old 07-22-2011, 04:18 AM   #48
sc00by4life
Member#: 97135
i'm pretty sure miro's in that size require at least a 10mm spacer to clear brembos......
Old 07-22-2011, 11:48 AM   #49
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
i stated in the very first post you aren't welcome here. you haven't posted anything constructive and your questions only serve one purpose. you have all the other threads to post your righteous opinion and hatred in, stay out of here. the others are doing a damn fine job of staying out, for some reason you can't.
your points are still coming.
Old 07-22-2011, 12:57 PM   #50
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
yes, 18x11 just for the looks, no real reason, but im alright with that uhm but being that i have 5x100 there is not a whole lot of choices for that size, but more than likely i will go with vs-xx but those are a large chunk of change.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
Message Board Statistics All times are GMT -4. The time now is 12:13 AM.
