Old 07-23-2011, 05:05 PM   #26
TIGWERKS
Member#: 256615
My box of wiggins clamps came in yesterday spent the whole day up till 11pm finishing the turbo setup enough to mount turbos. Had to do a lot of unexpected work, but turbos mounted and cab was installed today. Will get some pics up shortly.
TIGWERKS is offline   Reply With Quote
Old 07-23-2011, 08:13 PM   #27
AREA1320
Member#: 112508
Box of wiggins??? Holy $$$$
AREA1320 is offline   Reply With Quote
Old 07-27-2011, 02:42 AM   #28
TIGWERKS
Member#: 256615
Here are 3 of 6 sets of wiggins clamps being used. 2 on the bw s200 and 1 on the bw s400. Need to finish the axle back section of the exhaust finish piping from big turbo to small turbo since its a compoind setup. And also all the intercooler piping, but theres still quite a bit left to do.
Old 07-29-2011, 12:31 PM   #29
GEE-OTTO
Member#: 201277
2009 Legacy GT
Do yall worry about the hotsides of each turbo?? They are close to plastic things and the intake manifold itself but since this is a diesel I imagine extra heat on the intake side isnt a terrible thing. Nice work those welds are WOW the manifolds are clean and the chassis work is nice im sure that is a expensive project
GEE-OTTO is offline   Reply With Quote
Old 07-29-2011, 09:15 PM   #30
TIGWERKS
Member#: 256615
i orderd ptp tubo blankets for the hotsides. the big one has it installed since we did that before the cab was put on because its now impossible to install it with the cab on. Havent installed the smaller turbos turbo blanket yet. The stock turbo sits where the big turbo sits normally.
Old 07-31-2011, 01:02 AM   #31
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Originally Posted by TIGWERKS View Post
Truck is getting put back together, motor is being put back together and should be back in the chassis monday/tuesday. Which means I need to hurry up and finish these manifolds this weekend/monday. These will be mounted up to a twin turbo setup. Engine is 6.0 diesel-
am i missing something here, but i see a full hydro steering but then also a draglink from a steering box.
and damn, your work is sick
PARANOID56 is offline   Reply With Quote
Old 07-31-2011, 01:49 AM   #32
TIGWERKS
Member#: 256615
ya dont ask about that, i have feelings its going to fail. Not sure if any of the pics I posted showed it but we also have huge 6 piston calipers in the rear as well. I dont think a line lock is gonna fix that issue even though they think it will. Theres some things I wish would of been done differently, some things i wanted to do early on Im doing now because stuff didnt work out correctly like I had projected. I think the truck overall came out nice, but it could of been nicer and things could of been more streamlined and a lot of money and work could have been saved if things were more thought out and not rushed. In fact things probably would have been faster if it wasnt rushed as we had to redo several things because they werent thought out through the end. oh well, what can ya do.
Old 07-31-2011, 12:08 PM   #33
PLATNIUM2GSTi
Member#: 2756
2000 2.5RS
Silverthorn Metallic
I hope that you put headstuds, oil cooler and egr delete kits on that motor!
Also the new fuel press reg kit from ford to bump up the fuel press. These are the big 4 problems on the 6.OH that I replace on a regular basis, apart from injectors.
PLATNIUM2GSTi is offline   Reply With Quote
Old 07-31-2011, 12:34 PM   #34
TIGWERKS
Member#: 256615
we manufacture all those parts in house, except headstuds which we order boxes of from arp. Complete fuel system has been upgraded, nothing is oem.
Old 08-01-2011, 11:32 AM   #35
joshuaj
Member#: 216249
2011 STI Sedan
Hydro assist, but using a double ended ram isn't normal. Typically you'll run single ended attached to a tie rod.
I run full hydro on my Rover..
joshuaj is offline   Reply With Quote
Old 08-01-2011, 11:33 AM   #36
mann88
Member#: 289402
2008 WRX
those headers are amazing, great fabrication and welds!
mann88 is offline   Reply With Quote
Old 08-01-2011, 04:24 PM   #37
PARANOID56
Member#: 22035
2003 Brocoma DCab
yea, it looks like its supposed to be setup for just assist, but then some dork put full hydro on the axle. full hydro on the rover eh? no street driving? i am looking at doing the assist on my fj40
Old 08-01-2011, 07:10 PM   #38
joshuaj
Member#: 216249
2011 STI Sedan
It's dual purpose, it has a high feed back orbital.
It's a series III 88", although it's a touch over 100" now
Old 08-23-2011, 09:02 PM   #39
TIGWERKS
Member#: 256615
Old 09-02-2011, 07:50 PM   #40
TIGWERKS
Member#: 256615
Old 09-04-2011, 09:29 AM   #41
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
that reminds me of the packaging in my old H6 project, except your welds are much better and have sweet wiggins clamps haha.
That looks sick, nice work.
Ben
PHATsuby is offline   Reply With Quote
Old 09-04-2011, 03:23 PM   #42
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Why two batteries?
BeBop86 is offline   Reply With Quote
Old 09-04-2011, 03:51 PM   #43
AREA1320
Member#: 112508
Originally Posted by BeBop86
Why two batteries?
It's a diesel. Most are 24v systems. Or need the extra power
Old 09-04-2011, 07:17 PM   #44
johnt2k7
Member#: 194151
2008 WRX
RED
it takes alot of CCA to crank over 18:1 6.0l v8
johnt2k7 is offline   Reply With Quote
Old 09-07-2011, 03:50 PM   #45
tigermack
Member#: 170870
My god, the weld job is... sexy.
tigermack is offline   Reply With Quote
Old 09-07-2011, 04:57 PM   #46
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
12 volt or it will explode!!! Most medium size trucks have a big ole sticker somewhere that says to only jump with 12 volts. Most have the 2 batteries wired in parallel thus keeping the voltage 12 volts but the ah capacity doubles.
jay25RS is offline   Reply With Quote
Old 09-08-2011, 12:45 AM   #47
AREA1320
Member#: 112508
Depends if it's an ambulance or not :P there are some 24v trucks out there. I'm not too versed on which are which
Old 09-09-2011, 04:11 PM   #48
TIGWERKS
Member#: 256615
Hoepfully truck will get its first start today, we shall see.
Old 09-23-2011, 03:57 AM   #49
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Wheel tire specs? I'm looking at getting a diesel soon.
Big-Sexy907 is offline   Reply With Quote
Old 09-23-2011, 09:33 AM   #50
GEE-OTTO
Member#: 201277
2009 Legacy GT
Man i wonder what 1/4 miles times this thing will put down it is so insane and the torque numbers are going to make me cream my pants im sure. NICE fab work man can't say that enough times
Non Car Non Subi Content.... jeremy25056 Member's Car Gallery 21 04-27-2010 03:35 AM
stuff for sale for any car subie or non subie scobaru Mid West Subaru Owners Club Forum -- MWSOC 18 01-22-2004 11:20 PM
16" front, 17" back, non Subie handling Q 25psi General Forum Archive 3 03-02-2001 11:14 AM
softball anyone? yeah.. non subie Subie Gal North West Impreza Club Forum -- NWIC 0 05-10-2000 11:12 AM
Subie Gal goes LIVE - non subie (oh my gosh) Subie Gal North West Impreza Club Forum -- NWIC 4 04-06-2000 09:38 PM
