Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 07-13-2011, 01:50 PM   #51
flycaster
Member#: 60142
Grey
It totally depends on the dealer, not SOA. There are plenty of dealers who've stepped up and replaced shortblocks in cars with DP's and tunes, and there are plenty who haven't, regardless of claim acceptance by SOA. Matt (owner) was crystal clear with me: "as long as there's no DP on the car, we will fix it, period." BTW, Matt drives a 450whp GT35R 2009 STi, so he knows a little about "mods." Lol
Again, the "counter" tells them nothing. If the factory tune resides in the ECU, they're going to have to come up with a different reason for denial, if that's where they're headed. The SOA/Dealer catch-all classic is "abuse."
Sorry for the threadjack.
flycaster is offline   Reply With Quote
Old 07-13-2011, 10:35 PM   #52
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
Thanks for acknowledging this. This thread has been dead since Feb--saving it for my stage 2 posts. All of a sudden it gets bumped lately with conversations that belong in another forum.
KWIL is offline   Reply With Quote
Old 07-13-2011, 10:55 PM   #53
flycaster
Member#: 60142
Grey
No problem, but this tangent needed to be addressed.
Tim sure is a nice guy, and Surgeline is a clean shop too, huh? FWIW, I'll be very interested to see what the addition of a high flow catted downpipe does once tuned. I have 2 of these 2011's, and I've heard different things - "on the '11, you don't need a DP...you DO need a DP, etc, etc." It'll be great to see them overlayed, at the same boost levels.
Old 07-13-2011, 11:03 PM   #54
OrbitalEllipses
Member#: 178811
2013 Why don't you
just GFY?
When the 11s came out I recall tuners saying the stock DP flowed fine, furthermore, they asserted that aftermarket DPs on the market at the time were causing boost creep.
Old 07-14-2011, 12:58 AM   #55
flycaster
Member#: 60142
Grey
Let's see what magic Tim Bailey does. That'll be proof enough for me.
Old 07-14-2011, 10:17 PM   #56
Joker_927
Member#: 267865
2005 Outback XT
I'm glad this thread was bumped even for thread jacking reasons. I go in for a protune (at surgeline) next week and it was very refreshing to see some sweet numbers put down by another 11.
Joker_927 is offline   Reply With Quote
Old 07-14-2011, 10:41 PM   #57
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
Awesome. Do throw up a thread when you're done so we can see how you do!
Old 07-15-2011, 09:48 AM   #58
flycaster
Member#: 60142
Grey
So when are the DP and new tune going to happen, KWIL? My hunch is you won't see much whp increase, but you should get another 25 ft/lbs or so, with even more increase from 2.5K to 3.5K, and not as much fall-off on top. You got a boatload of whp on that stock tune at only 16 psi, I'm impressed.
Old 07-15-2011, 09:27 PM   #59
Joker_927
Member#: 267865
2005 Outback XT
Thanks, will do. I hope I get numbers like yours. Looks like you got a peach (or whatever the opposite of a lemon is).
Old 07-16-2011, 12:24 AM   #60
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
I'm hoping to head over again in August. They had done one other 2011 at the time that had an exhaust--if you search Surgeline's online DB there should be a few more and you can see how much better they are doing over me. 25 ft/lbs is a good guess....I suspect I'll see something around there with simply more area under the curve than I have now.
I prioritized my audio install first so when I put an exhaust on I'll still be able to hear the radio. Also, a little bit more mileage base with no DP warranty worries was good, too.
Surgeline is top notch and since we live in the NW, IMO Tim Bailey is an obvious choice. I actually asked for a conservative, safe tune and still got decent numbers--I suspect you'll be equally happy, looking forward to seeing your results.
Old 07-16-2011, 02:13 AM   #61
flycaster
Member#: 60142
Grey
Originally Posted by KWIL View Post
...I suspect I'll see something around there with simply more area under the curve than I have now...
Driveabilty, I'm with you all the way. I'm looking forwrard to seeing your results!
Old 07-16-2011, 01:29 PM   #62
pet3r
Member#: 283134
2008 STi AW
550whp - 530wtq
Did everyone miss this post? I'm still baffled by the numbers posted below, something doesn't add up here.
Originally Posted by pet3r View Post
Not trying to stir a pot, but, did anyone else notice the weirdness in these two maps that the OP has shared?
If you look at the "Stage 1 - green" vs "Stage 2 - blue", they are identical. Something can't be right about these two. Both claim 18psi boost, Stage2 was an Invidia DP, but their curve and numbers are identical. So, something is lying about these numbers
Could be that the tuner is trying to post bigger specs for their tunes than are realistic maybe?
pet3r is offline   Reply With Quote
Old 07-16-2011, 02:29 PM   #63
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
I didn't get the 18psi map when I left the tuner. They achieved that on the car but it isn't safe enough to run all the time. If you read the thread thoroughly you'll see that's why I run the 16psi and can use the 17.5psi on cooler days with better gas. They achieved the 18psi during their runs and they show those limits on the maps they provide online, but know that 17.5psi is the best map I walked away with. (I do still run the 16 all the time) I also asked for a safe tune, they may provide the achievable 18psi to others who want the risk.
When they pro tune your car they push it to its thresholds to help them negate ultimately the safe tune point and understand your range.
Those tuner maps aren't lying they are showing the top range they acheived on the dyno.
What it does show is that I should be able to run the 18psi map all the time after my Stage 2 tune since it will be within a safer range.
Old 07-16-2011, 03:26 PM   #64
Airboy
Member#: 72829
2006 WRX
EFR6758
Just looks like the data from one car (from the same day) got submitted into the dyno database under the wrong name (another 2011 wrx). The process is manual so human error is the most likely cause.
Airboy is offline   Reply With Quote
Old 07-17-2011, 10:29 AM   #65
flycaster
Member#: 60142
Grey
KWIL, most of the guys I know with 2011 WRXs who've been tuned by Tim end up with a 16-17.5 psi DD map, even with a DP. I think the issue he's concerned about is the stock I/C - the stocker is a 2 piece clamshell, the end tanks are clip fastened, and the unit can blow apart really, really easy. Put a solid TMIC on it and you could push 19-20 psi with no problem whatsoever with the right tune and fuel.
You're right, however, about his methodology. Thye push to see how far the motor can go safely, then back it down and fine tune for the final map(s). The last tune I got on my '04 with meth got up to 421whp, and we ended up at 405 - the timng was backed off touch and the AFR was bumped a touch for safety, but the boost remained at 25 psi. Out on the road, I could feel no difference whatsoever.
Old 07-22-2011, 06:51 AM   #66
turboman38
Member#: 119306
2011 SWP WRX
Ok, I have read this entire thread.
Couple things I came up with and I have questions about. First is the warranty issue. There are two important statements about this and I know it depends on the dealer:
If you re-flash with a non-stock map and have a stock downpipe the dealer shouldn't deny the warranty.
There is no counter on the ECU that keeps track of how many times the ECU was flashed. You can re-flash back to stock and the and disconnect the battery and the dealer should never know that you ever flashed the ECU.
Are these two statements correct?
I have a 2005 LGT with an AVO TMIC on it. This should fit on my new 2011 WRX and solve the stock TMIC end tank issue ...Is that correct?
I have an SPT exhaust from the factory on my 2011 WRX.
If I put a high flow catted downpipe on it can I flash to a stage two map? In other words is this considered stage two for a WRX?
If I put an aftermarket downpipe on it then the dealer may void the warranty, Correct?
If I put the AVO TMIC on and a highflow down pipe, what kind of boost can I run safely and what kind of HP and torque numbers should I see with a pro tune? Most importantly will this void the warranty?
I know this is off subject but the dealer told me that the 2011 WRXs come with synthetic oil? Is this true? Do I need to continue to use synthetic?
Thanks and have a great day!
turboman38 is offline   Reply With Quote
Old 07-23-2011, 12:30 AM   #67
Joker_927
Member#: 267865
2005 Outback XT
This a terrible thread jack, turboman38. In the future it would behoove you to make your own thread asking your own questions.
1)If you re-flash with a non-stock map and have a stock downpipe the dealer shouldn't deny the warranty.
2)There is no counter on the ECU that keeps track of how many times the ECU was flashed. You can re-flash back to stock and the and disconnect the battery and the dealer should never know that you ever flashed the ECU.
3) I have a 2005 LGT with an AVO TMIC on it. This should fit on my new 2011 WRX and solve the stock TMIC end tank issue ...Is that correct?
4) If I put a high flow catted downpipe on it can I flash to a stage two map? In other words is this considered stage two for a WRX?
5)If I put an aftermarket downpipe on it then the dealer may void the warranty, Correct?
6)If I put the AVO TMIC on and a highflow down pipe, what kind of boost can I run safely and what kind of HP and torque numbers should I see with a pro tune? Most importantly will this void the warranty?
7)I know this is off subject but the dealer told me that the 2011 WRXs come with synthetic oil? Is this true? Do I need to continue to use synthetic?
1) Typically correct.
2) Correct.
3) According to this, yes. http://www.avoturboworld.com/avoshop...late-p-32.html
4) Yes. I have this setup using a Cobb OST map.
5) Depends. Do yourself a favor and read up on the Magnuson-Moss Warranty Act. They can only deny your warranty if that part caused a failure.
6) If it's not an OTS map then you must find a local tuner and ask them about numbers since they will be doing the tune. If you are adding those mods but still worrying about warranty you're doing it wrong.
7) Yes they come from factory with synthetic, the dealer will put synthetic in it, and you should keep synthetic in it.
Extra credit: Read more. All the above answers are on this forums. U just gotta search.
Old 07-25-2011, 09:29 AM   #68
Midevil
Member#: 175065
2011 SWP WRX
INTERNET TOUGH GUYS? LOL
KWIL, I noticed that you plan to get a cobb dp and spt exhaust. I would recomment you go wit ha 3" option, such as invidia catted dp and a 3inch exhaust. The Cobb DP tapers to 2.5" at the end and the SPT exhaust is an overpriced POS and its also 2.5".
And.. the dealer can tell that the ecu has been changed back to stock.
Midevil is offline   Reply With Quote
Old 07-25-2011, 11:36 PM   #69
KWIL
Member#: 40848
2011 Impreza WRX
5-Door, DGM
I'm pretty set on the SPT for how quiet it is. Thanks for the tip though, I'm willing to sacrifice some performance to maintain DD. I like the warranty perks of the SPT also.
2011 WRX - Stage 2 - COBB Downpipe and SPT Exhaust (VIDEO) xluben General Community 47 01-19-2011 01:32 AM
Stock 2011 WRX Dyno numbers MotorrBoatrr Proven Power Bragging 75 10-26-2010 06:59 PM
STOCK 2011 WRX/STi Coming in September! Evanston Subaru MWSOC Vendor Classifieds 12 09-01-2010 02:39 PM
Dyno Tune: 2.5l wrx+ ATP 3076r Stock location syagbraves7 Proven Power Bragging 9 03-25-2010 04:43 PM
Agile Dyno Day - MY 07 WRX Stage 2 96accord Proven Power Bragging 38 03-07-2008 05:27 PM
