Old 07-22-2011, 10:51 AM   #76
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
Bummer - I must have gotten a differently-made harness then. There is definitely not enough wire to get there.
rmj is offline   Reply With Quote
Old 07-23-2011, 07:45 PM   #77
ryyiann
Member#: 259241
2011 WRX Limited 5dr
i never understood this mod. Its pretty lame IMO.
ryyiann is offline   Reply With Quote
Old 07-24-2011, 03:10 AM   #78
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Pretty useful IMO if you ever need it.
xabre1200 is offline   Reply With Quote
Old 07-24-2011, 04:10 AM   #79
jdmct9mr
Member#: 289223
2015 STI
CBS
Looks good!
jdmct9mr is offline   Reply With Quote
Old 07-27-2011, 11:11 AM   #80
olazy
Member#: 263322
2011 WRX Limited
WRBP
black thingamabob (relay socket) similar to the one used on the subimods harness, cleans the install up a lot.
olazy is offline   Reply With Quote
Old 07-27-2011, 11:43 AM   #81
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
olazy, where did you pick that up at? I'm thinking soon I will want to rewire mine and I used liquid electrical tape to create a waterproof seal around the relay and the Subimods connector. Currently everything is hidden well, but I'd like to do a better job.
The Subimods wire harness was great, but it is disappointing that the relay won't reach the engine bay.
Old 07-27-2011, 12:01 PM   #82
olazy
Member#: 263322
2011 WRX Limited
WRBP
i bought it off amazon, 5 wire relay socket. i'm making my own harness, not sure how comfortable you are but you could try to solder a longer wire to reach further.
Old 08-02-2011, 12:41 PM   #83
olazy
Member#: 263322
2011 WRX Limited
WRBP
for those of you with the subimods wiring harness, do you only have 1 ring connector for ground, i'm trying to see if it's ok to combine the horn ground to the relay ground.
also where are you guys grounding? directly too the negative terminal on the battery or somewhere on the frame?
Old 08-02-2011, 12:50 PM   #84
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
There was only one ring connector for the ground with the kit.
I wired it to the negative terminal on the battery. I guess I just assumed it would be ok - hopefully no one tells me otherwise!
Old 08-02-2011, 12:59 PM   #85
JustinV
Member#: 239875
2010 STI
I want the sound of hella horns but I've always hated how they look behind the grill.
Can you just mount them in the stock horn locations?
JustinV is offline   Reply With Quote
Old 08-02-2011, 01:05 PM   #86
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
You'd see them in the stock horn locations. Im sure you could mount them in a hidden place though.
Old 08-02-2011, 02:35 PM   #87
olazy
Member#: 263322
2011 WRX Limited
WRBP
the factory horn is visible from the grille but yeah, you can mount them where ever you want as long as you can figure away to mount them. although the grille allows better projection because it's unblocked. i didn't really like the flashiness of the horns either, that's why i painted them black.
thanks rmj for the responsing to my questions.
Old 08-02-2011, 03:10 PM   #88
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Why on earth people install these things on their car, I'll never understand.
midwestmonster is offline   Reply With Quote
Old 08-02-2011, 03:22 PM   #89
kh15
Member#: 132400
those things have saved my @ s$ many a times over! Other drivers now a days are retarded and the louder my horns are the quicker, more effectively, I cant get their attention! Esp for those idiots who drive with their iPod earbuds in!
kh15 is offline   Reply With Quote
Old 08-02-2011, 03:26 PM   #90
olazy
Member#: 263322
2011 WRX Limited
WRBP
its a louder horn, whats to understand.
Old 08-02-2011, 04:00 PM   #91
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
How? Is the stock horn not loud enough? Just seems rediculous and a waste to me.
Old 08-02-2011, 05:21 PM   #92
mrkyle3
Member#: 272675
2004 Miata
I had people not responding to my stock horns about 40% of the time. Now they definitely hear it
Old 01-29-2012, 12:08 AM   #93
revin9k
Member#: 294105
cool!!
revin9k is offline   Reply With Quote
Old 11-11-2012, 09:32 PM   #94
ajmillan
Member#: 298536
2013 STI
Satin white
Er... are you sure about that?
I can attest to what he said that is how i installed mine, not only did i not have to remove the bumper i also didn't need the relay since the car already has one and a fuse so just hook up to factory horn wire.
ajmillan is offline   Reply With Quote
Old 11-12-2012, 06:00 AM   #95
GrumpyPitbull
Member#: 313311
You know, I used to feel the same way you do ... that is until I recently needed to hit my horn to warn someone who was changing lanes into me.
Long story short, the horn sucks and is way to quiet ... like it belongs in one of those European tiny cars.
This mod is now on my list for the near future.
Old 11-12-2012, 06:36 PM   #96
4-n-zics
Member#: 228961
2016 4Runner TRDP
For the life of me I cannot remove the nut on the back to remove the already attached brackets. Anyone else have trouble removing the nut? I have a bracket simliar to the subimods brackes (but much, much cheaper) to use.
4-n-zics is offline   Reply With Quote
Old 11-13-2012, 09:11 PM   #97
k2hat
Member#: 336647
2015 Legacy
Impact wrench?
k2hat is offline   Reply With Quote
Old 12-28-2012, 08:32 PM   #98
S1CkWrx
Member#: 325249
2012 wrx
dgm
^ it comes off very hard to do but it does.
S1CkWrx is offline   Reply With Quote
Old 12-28-2012, 09:27 PM   #99
thescreensavers
Member#: 333820
2013 WRX Limited
Yea was pretty hard for me the first time, doing it by hand was a no go. I use a bench vise and some WD40 which helped alot.
thescreensavers is offline   Reply With Quote
Old 01-05-2013, 10:43 PM   #100
intheflesh
Member#: 330159
'13 WRX Limited
1995 Ferrari F355
Stupid question... When push the lock button twice, normally the horn toots.
So when you 'double lock' the car, do the Hellas toot?
intheflesh is offline   Reply With Quote
Some a** smashed in the fender on my '11 WRX :( Vrenlos Tri-State Area Forum 6 01-14-2011 04:05 PM
Will installing Hella Supertones void any part of my warranty on my '11 WRX? xabre1200 Interior & Exterior Modification 10 12-20-2010 06:31 PM
Where do you mount Hella Supertones on an 07 WRX?? Zerro0713 Newbies & FAQs 13 01-04-2010 09:10 PM
17x8.5 +32 offset on my '05 wrx without rubbing? tbcboo Tire & Wheel 13 11-10-2009 12:37 PM
Hella Supertones on a 2008 WRX CALBANO1833 Interior & Exterior Modification 1 10-09-2009 08:04 PM
