#1 |
Member#: 257551
South East
Vehicle:2011 WRX Satin White Pearl |
I call this Part I, because i will eventually get down to the entire car as I slowly progress to other areas during the installs of aftermarket bliss.
I started off with the rear shelf because that and the front door panels are the most annoying thus far in the rattle dept. Plus I removed the rear shelf plastics so I could get closer to the rear window to install my tint (although it didn't provide me with much extra room]. Step I: Disassemble the rear c-pillar trim. The piece closest to the rear window comes out first. The top most corner is held on by a plastic push rivet. Be careful as you pull the front trailing edge, it does just snap in 3/4 of the way into the rear triangle surround plastic, but you have a metal push clip that you will need a flat head to depress the tab to release (unless you have REALLY small hands). ![]() ![]() Step II: Pop off the bolt cover on the rear triangle glass surround. Using a 10mm socket remove the 3 bolts securing the rest of the c-pillar in place. Gently pull to release the one plastic pin, slide the surround down the seat belt to where it sits safely on the back of the lower rear seatback. ![]() ![]() Step III: Remove the rear brake light assembly (if you have it). Held on underneath the shelf with two 10mm bolts and a plastic clip toward the rear of the assembly (front of the car). Unhook the wiring harness and remove light. There are 2 plastic pins holding the rear shelf plastic in at the front left and right corners you need to remove (rear seat back of course has to be down to see and get to these). Gently/firmly pull out and up on the front lip of the plastic shelf to release. Underneath (from inside the trunk)you will notice 3 accessible WHITE pins. Using a pair of needle nose, gently pinch and push up. There are a total of 5 pins, you can only get to 3 of them. Gently pull up on the front of the shelf plastic to release the 2 front white pins and you should now be able to maneuver the plastic out off the shelf exposing the wiring for the airbags, brake light, defroster, and keyless module. **I'll grab some pics of this, I forgot***
#2 |
Member#: 257551
South East
Step IV:
There are 6 points of contact that I found that cause the rattle. 1-4 are the rear edge of the plastic shelf, it has 4 fins that are covered in an adhesive foam. You can see that it's worn through from rubbing the metal shelf underneath. i pointed out the spots on the metal shelf where you can see the rubbing from the plastic fins on the bottom of the plastic cover. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 5 is the trailing edge of the plastic shelf where it touches the glass. ![]() 6 is the keyless module; it's a small metal clip suspending the module slightly above the metal shelf, the thin metal support flexes quite a bit allowing the module to vibrate against the metal. Remove this with a 10mm socket. ![]() |
#3 |
Member#: 257551
South East
Step V:
Cut pieces of vibration dampening material, be it foam tape or butyl mat. ![]() Place (4) 1.5"x.75" pieces where the 4 fins rub against the shelf. ![]() ![]() ![]() Take a roll of .25 foam weatherstrip and adhere it to the trailing edge of the plastic shelf covering (topside where it meets the window). ![]() Cut another 1.5"x3" piece of butyl mat or foam tape and adhere it where the keyless module ![]() Step VI: Install everything in reverse order of removing it. Step VII: Drive around and ask yourself, "Why the hell didn't I do this before". |
#4 |
Member#: 260624
TXIC
very nice. . . . i always figured it was the plastic covers over the hooks for a car seat because i after i used them they grew alot louder.
i really need to stop being lazy and fix this rattle, im just going to sound dampen the whole area ![]() |
#5 |
Member#: 260578
MWSOC
Vehicle:2011 WRX Premium WRB |
Very nice write up. Finally someone brave to tackle this problem. I'm definitely doing this as soon as it warns up outside. Thanks a lot.
#6 |
Member#: 260658
South East
Vehicle:2011 STi 4-Door WRB |
Any chance you could update this thread when you do more rattle tracking down in other places? I had this same issue in my sedan and this thread was very useful.
#7 |
Member#: 214020
W. Canada
Vehicle:2011 WRX SWP |
Just a heads up, I took my car to the dealership and they did all this for me for free under warranty, even the rear shelf. For the doors they knew were the rattles were and for the rear deck I showed them where I thought the rattles were coming from. Been a month now and still no rattles
#8 |
Member#: 270392
MAIC
Vehicle:2011 WRX Limited WR Blue |
Nice write-up, thanks man!
#9 |
Member#: 243663
SCIC
Vehicle:2011 WRX Sedan Black |
I took my car to the dealer today to ask them about fixing my rattles after mentioning this thread, they said they couldn't recreate it after going out on a 5-min drive with it. They said they don't want to tear it apart for nothing.
I heard the rattling on the back shelf pretty much as soon as I was exiting the place and my drive home. ![]() |
#10 | |
Member#: 274785
Tri-State
Vehicle:2011 WRX sedan silver |
#11 |
Member#: 260658
South East
Over the weekend I did this but when I took off my shelf I didn't have as much wear as you do (there was some wear). I did the foam on the contact points to play it safe but also put the soft side of velcro on all plastic pieces (C pillar components) where plastic-on-plastic contact would occur. If you do it right, you can't see the velcro once the pieces are installed.
These two things combined eliminated all squeaks / rattles from the rear of my sedan. |
#12 | |
Member#: 151781
MWSOC
Vehicle:2011 STI Sedan DGM |
#13 |
Member#: 260658
South East
I don't remember that from doing it; to further make you disappointed, the rattle came back in mine. I'm guessing the velcro fuzz got compressed over time and lost its padding ability. I ordered some single-side foam tape from McMaster-Carr and if it doesn't rain will replace the velcro this weekend (and take off the plastic shelf cover again to measure for more padding).
#14 |
Member#: 238447
Vehicle:2008 Impreza 2.5i Spark Silver Metallic |
Sorry to bring up an old(er) thread, but this might be helpful.
I followed this procedure on my 2.5i (thanks for the tutorial by the way)! Although I noticed similar wear as you on the metal portion of the rear shelf, adding the butyl mat and weather stripping didn't seem to fix the rattling I was experiencing. It turns out that the rattling was coming from the airbag brackets vibrating against the shell of the car. You can sorta see these brackets in the second picture of Step II in the OP. I could duplicate the noise by bumping the plastic piece surrounding the triangular window. Gently pushing on the airbag cylinder would make an audible clicking noise, so I figure a higher frequency vibration would sound more like a rattle. At any rate, if you stick some butyl mat between the brackets and the shell of the car, the rattling disappears! (I tried tightening the bolts at first, but they were already fully tightened). ![]() |
#15 |
Member#: 141952
MWSOC
Vehicle:03 emo 8/2011 wrx |
anyone else getting a noise at the b pillar? i think its where the shoulder harness attaches.
#16 |
Member#: 274785
Tri-State
#17 |
Member#: 212992
South East
Vehicle:2011 STI Sedan SWP |
awesome! any updates?
#18 |
Member#: 260638
Vehicle:2011 WRX Sedan Spark Silver Metallic |
i was waiting for this thread to show up. that back deck is the loudest rattle.
happens when engine is struggling due to too low RPM. |
#19 |
Member#: 294504
Finally got around to doing this fix today. Worked great. Thanks again for the write up.
#20 |
Member#: 271121
NESIC
Vehicle:2011 WRX Limited 4dr SSM |
need to do this!
#21 |
Member#: 80062
Tri-State
Vehicle:06 STi |
Nice!
#22 |
Member#: 295670
i have the same issue on my 2010 hatch but seems the rattle comes from the headboard at the back. cant really find where the rattle is coming from.
#23 |
Member#: 163879
NESIC
Vehicle:2005 Sti blue |
and i thought i was the only, great write up, gonna try it on my day off...temp fix i did that actually took most of the rattling out when im on the highway was .... stick pieces of folded cardboard around the plastic edges!..LOL...cured most of it, but i want to do it the correct way!
#24 |
Member#: 271121
NESIC
I'm going to try this tomorrow but I'm going to Dynamat the whole rear shelf.
#25 |
Member#: 75071
Tri-State
Vehicle:'11 WRX Ltd Nav 4dr Lightning Red |
So I have a weird tapping sound from the rear deck area (I think on the driver side). If I put the passenger-side rear seat down flat, the noise goes away. As soon as I snap it back in place the noise returns while driving.
I tried stuffing stuff behind the rear seat where it touches the deck, but no use. Any ideas? |
| Thread Tools | |
| Display Modes | |
| 2011 Impreza/WRX/STI Spoilers Buy/Sell/Trade | NotSoStock11 | Private 'Wanted' Classifieds | 27 | 02-10-2013 05:13 PM |
| 2011 Subaru WRX STI Sedan vs. 2007 STI | AVANTI R5 | News & Rumors | 42 | 01-18-2011 10:47 PM |
| The wing returns! Subaru teases 2011 Impreza WRX STI sedan | wrxposer | Vancouver Impreza Club Forum -- VIC | 103 | 04-25-2010 11:46 PM |
| 2011 Subaru Impreza WRX STI Sedan | Ryan314 | News & Rumors | 30 | 09-09-2009 03:29 PM |
| FS: NorCal JDM WRX/STI sedan rear windshield with rear wiper | Seranin | Exterior/Styling | 8 | 12-06-2006 12:31 AM |
