Old 08-06-2011, 12:35 AM   #26
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
Originally Posted by chadws85 View Post
Why would companies sell BOV VTA? I posted to get opinions from experts, not dicks.
For people and cars that are blow through and run speed density. NOT draw through.
synolimit is offline   Reply With Quote
Old 08-06-2011, 12:45 AM   #27
chadws85
Member#: 284496
2011 Rex
Rally Blue
thank you
chadws85 is offline   Reply With Quote
Old 08-06-2011, 01:40 AM   #28
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by mick3ymik3
op seems like a showoff d-bag
Helpful.
Old 08-06-2011, 02:20 AM   #29
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Hook up a scanner and go to live data and do a on car live data test drive the car around with scanner hooked up and see what reading is abnormal such as air/fuel ratio maf readings egt to high etc and go from there then after you find and fix I would change the plugs and oil cuz all that unburned gas your were pumping into your combustion chamber had to of past your rings into your oil thus breaking it down somewhat
subaru_sti_steve is offline   Reply With Quote
Old 08-06-2011, 02:24 AM   #30
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^that, before you do anything, change plugs, oil, and get rid of bov and get a bpv.
Old 08-06-2011, 02:25 AM   #31
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
OP, you still haven't answered Xan's first question. Who tuned your car?
Gallo2011 is offline   Reply With Quote
Old 08-06-2011, 01:37 PM   #32
TeeJayHoward
Member#: 286449
Dark Grey Metallic
Let's see if I recall this correctly from my RX-7 days...
Black smoke - Rich, fuel
Grey smoke - Coolant, normally head gasket
Blue smoke - Oil, normally turbo.
Sounds to me like something went MAJORLY wrong during your show-off period. If you got all three smoke colors, I'd be very, very concerned. Start with a compression test. If needed, follow with a leak down test. Remove the turbo and inspect. Heck, I'd probably even use a borescope and do a visual on the engine internals.
I can imagine very few scenarios where you'd get three different smoke colors. Hrm... I'll make one up. Spark plug broke, sending the unburned air/fuel into the exhaust manifold along with the tip of the plug, which banged around in your (water-cooled?) turbo, unbalancing/damaging it enough to leak coolant and oil... But even with that, you'd only see the dark smoke, not three different variants.
TeeJayHoward is offline   Reply With Quote
Old 08-06-2011, 04:50 PM   #33
Shewillbemine
Member#: 84680
Cars are complicated machines that go far beyond yesteryear's mechanical adjustments.
Though a forum like this one can convince many rookies that bolting on parts and paying tuners (there's one on every street corner) is always a safe bet, it isn't. Then many of these guys with failed set-ups blame the car (not it's fault) or expect Subaru to back the mistakes the owner made (not Subaru's fault).
There are no Subaru ricer owners. There are no Subaru ricer owners. There are no Subaru ricer owners (repeat several times a day).
Shewillbemine is offline   Reply With Quote
Old 08-06-2011, 07:29 PM   #34
chadws85
Member#: 284496
2011 Rex
Rally Blue
Thanks for all the info, I had a 2004 wrx stage 2 and everything was fine using cobb. The car is at the tuner and wont be looked at till monday. They said its the BOV VTA causing the issue. I'll def get the oil changed and change the pluggs. The dealer looked at it before it was towed and said everything was ok and not damaged, so Idk what to expect, maybe the WORSE?
Old 08-06-2011, 08:15 PM   #35
Smokin' Joe
Member#: 219679
2011 Impreza WRX
prepare for the worst just so you don't get blindsided if a ringland or something common with these cars is blown. I've had a few issues with my '11 and then ultimately cylinder #1 was out-of-round (which eventually leads to the broken ringland issue) at 17,000 miles. Stage 2, AEM intake, Perrin recirc BPV, Process West TMIC, and a lightweight pulley. Paying the cost to be the boss right now and putting everything back to stock for break in... again. I hate to put in negative vibes or get you down about it, but some of these are lemons and some are animals that will last 200K. Just gotta make sure before going nuts with it I guess and there's really no way to tell. I hope it all works out for the best man.
Smokin' Joe is offline   Reply With Quote
Old 08-06-2011, 09:33 PM   #36
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
...PERRIN BOV VTA...
furiouswrx is offline   Reply With Quote
Old 08-06-2011, 11:48 PM   #37
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
^^^late to the party
Old 08-07-2011, 12:09 AM   #38
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
kinda went and jumped right into things huh? tuned? ....TWICE?! bov? down pipe... damn!!! now you have a brand new car with no warranty because they more then likely reported you to SOA :-D ... an a car that will not run. stock BPV is ALL YOU NEED. Read about it you will find out not only is it the best thing for your car it also shoots air back into your intake that you NEED so you do not run rich in-between shifts or revs... ask the tune shop whoever tuned your car for your map on a usb drive and let me see it .... surprised you didn't get a MBC instead of a bov
white guys wrx is offline   Reply With Quote
Old 08-07-2011, 09:10 AM   #39
chadws85
Member#: 284496
2011 Rex
Rally Blue
ok, I am going up tomorrow or maybe tonight to put my stock bov on and see if that fixes it. If not, I am going up tomorrow early and seeing what they say. I will get the map on a thumb drive. Thanks. No one gets that my dealer is ok with tunes, idc what people think but I got three cars from them and two others for my family members. All my tune ups and oil changes go through them. I am a neat freak and take care of my ****. Thanks for the info though. MBC?
Old 08-07-2011, 09:45 AM   #40
SpamBot
Member#: 287534
It's not a matter of your dealership being 'cool' with mods. If you've done major damage to the engine, and the dealership puts in for a big dollar warranty claim on a new car, you can bet SOA is going to want to see this thing. Don't even bother trying to bolt on all your stock stuff and flashing back to stock - Big Brother will know, trust me.
You play, you pay.
p.s.: if I were at a light and somebody wanted to hear my BOV, I would have just ripped a good fart. Same thing.
SpamBot is offline   Reply With Quote
Old 08-07-2011, 10:38 AM   #41
syndromeofthedown
Member#: 190627
chadws85. Do yourself a favor. Make the switch over to 3gwrx.com. The folks over there are enthusiasts of our generation of Subies. This site lacks in the honest advice department. Nasioc exisits for people who think they know what's going on to show off their so-called web penises. Welcome BTW.
syndromeofthedown is offline   Reply With Quote
Old 08-07-2011, 10:46 AM   #42
Jack
Add Lightness
Member#: 13699
#NOT my president
(From General)
So....uh....first thing, that you are doing in removing the BOV, is heading in the right direction. While you're at it, might as well put the stock intake back on. Then get it retuned.
Old 08-07-2011, 11:13 AM   #43
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Let us know how it goes Monday.
Phil_Dunphy is offline   Reply With Quote
Old 08-07-2011, 11:29 AM   #44
joebobanaught
Member#: 43566
2002 WRX Sedan
I spent a lot of money on two tunes, the first was perfect, then they told me to get a downpipe and BOV. I got the product and retuned it and everything was fine until three days after.
Honestly, I'd say find a new tuner after they diagnose what happened. I personally would never trust a tuner who told me to get a BOV with the types of mods you have.
Not to mention they tune your car, and THEN tell you to get more parts so you need a new tune? wtf is that? Now your motor is putting out smoke 3 days after you get parts they told you to get? Sounds like a shady shop to me.
joebobanaught is offline   Reply With Quote
Old 08-07-2011, 11:35 AM   #45
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Probably didn't happen right away, op probably went to them wanting more power, they said new dp and bpv, he looked and saw bov's and got one.
Old 08-07-2011, 11:49 AM   #46
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
You play, you pay.
2011WRXMT is offline   Reply With Quote
Old 08-07-2011, 01:08 PM   #47
WashmyScooby
Member#: 83820
Two pages of thread here and there are maybe a handful of helpful answers. The poor guy has a problem and he turns to the community for answers, not a bunch of B.S. Sheesh...
WashmyScooby is offline   Reply With Quote
Old 08-07-2011, 01:48 PM   #48
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Yeah...we've been a little hard on the beaver. I'm not surprised with the intro post, but still.
Keep us posted. I'm willing to bet you have a MUCH bigger issue than just the bov. Your internals are likely in bad shape given the smoke you're producing. Replacing the bov isn't going to fix that. I'd start saving for a major project.
Decipher is offline   Reply With Quote
Old 08-07-2011, 02:06 PM   #49
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
we're being hard on him because him putting a bov on probably had a lot to do with his problems. if he had done ANY research, he'd find that it's bad for his car. chances are, the tuner he went with had something to do with his problems as well. again, research may have saved him as well.
Old 08-07-2011, 02:17 PM   #50
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
It's also too bad he hasn't filled out any of his location info so that someone on here can point him to a proper tuner in his area.
everdying55 is offline   Reply With Quote
FS : Ga: 2011 Wrx Sedan Swp Kontankerous Private Vehicle 'For Sale' Classifieds 3 09-16-2011 01:26 PM
Used value of a 2011 WRX premium w/ accident chiefchankton General Community 6 08-05-2011 10:54 PM
Discovered some lovely rock chips on my 2011 WRX today. Help! xabre1200 Car Care & Detailing 44 06-17-2011 05:02 PM
Between a 2011 wrx and a 2011 5.0 mustang...need help deciding. 2.5 warranty issues? r00st Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 254 03-12-2011 01:11 PM
2011 WRX wheel help thebigevilfoot Tire & Wheel 1 11-12-2010 01:27 AM
